Компьютер не подключается к интернету по Ethernet соединению.
SergeiR
10 май 2020, 12:54
LM 19.1 x64 xfce
System: Host: sergei-Precision-M4800 Kernel: 4.15.0-96-generic x86_64 bits: 64 compiler: gcc v: 7.5.0 Desktop: Xfce 4.12.3
Machine: Type: Laptop System: Dell product: Precision M4800 v: 00 serial: <filter>
Mobo: Dell model: 0V5GVY v: A00 serial: <filter> BIOS: Dell v: A21 date: 12/15/2017
Battery: ID-1: BAT0 charge: 99.9 Wh condition: 72.2/99.9 Wh (72%) model: Sanyo DELL T4DTX59 status: Full
CPU: Topology: Quad Core model: Intel Core i7-4810MQ bits: 64 type: MT MCP arch: Haswell rev: 3 L2 cache: 6144 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 44698
Speed: 1944 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 2758 2: 2481 3: 2660 4: 2784 5: 2717 6: 2788 7: 3036
8: 2694
Graphics: Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Dell driver: i915 v: kernel bus ID: 00:02.0
Device-2: NVIDIA GK106GLM [Quadro K2100M] vendor: Dell driver: nouveau v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.19.6 driver: modesetting,nouveau unloaded: fbdev,vesa
resolution: 1920x1080~60Hz, 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel Haswell Mobile v: 4.5 Mesa 19.2.8 direct render: Yes
Audio: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Dell driver: snd_hda_intel v: kernel
bus ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Dell driver: snd_hda_intel v: kernel
bus ID: 00:1b.0
Device-3: NVIDIA GK106 HDMI Audio vendor: Dell driver: snd_hda_intel v: kernel bus ID: 01:00.1
Sound Server: ALSA v: k4.15.0-96-generic
Network: Device-1: Intel Ethernet I217-LM vendor: Dell driver: e1000e v: 3.2.6-k port: f080 bus ID: 00:19.0
IF: eno1 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel port: e000 bus ID: 03:00.0
Drives: Local Storage: total: 1.37 TiB used: 82.31 GiB (5.9%)
ID-1: /dev/sda vendor: Samsung model: SSD SM871 2.5 7mm 256GB size: 238.47 GiB
ID-2: /dev/sdb vendor: HGST (Hitachi) model: HTS541010B7E610 size: 931.51 GiB
ID-3: /dev/sdc vendor: Samsung model: SSD 860 EVO mSATA 250GB size: 232.89 GiB
Partition: ID-1: / size: 47.81 GiB used: 18.68 GiB (39.1%) fs: ext4 dev: /dev/sdc2
ID-2: /home size: 178.92 GiB used: 63.63 GiB (35.6%) fs: ext4 dev: /dev/sdc3
ID-3: swap-1 size: 1.27 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sdc1
Sensors: System Temperatures: cpu: 57.0 C mobo: 57.0 C sodimm: 47.0 C gpu: nouveau temp: 51 C
Fan Speeds (RPM): cpu: 2112
Info: Processes: 274 Uptime: 2d 14m Memory: 15.57 GiB used: 3.02 GiB (19.4%) Init: systemd runlevel: 5 Compilers:
gcc: 7.5.0 Shell: bash v: 4.4.20 inxi: 3.0.27
Имеется роутер который раздает интернет по DHCP, другие компьютеры, тв бокс, игровая приставка при подключении по кабелю получают локальный IP адрес и подключаются к интернету.
На текущем компьютере установлено две ОС LM 19.1 и Windows 10. Из под Windows 10 подключаясь по кабелю получаю локальный IP адрес и подключаются к интернету, из под LM 19.1 не подключаюсь, IP адрес не получаю. Поэтому я исключаю кабель, роутер, штекер.
Вывод ifconfig, wifi отключен.
~$ ifconfig -a
eno1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::9496:591a:380d:76ba prefixlen 64 scopeid 0x20<link>
ether f8:ca:b8:25:7a:bf txqueuelen 1000 (Ethernet)
RX packets 1740 bytes 193417 (193.4 KB)
RX errors 0 dropped 12 overruns 0 frame 0
TX packets 2615 bytes 498675 (498.6 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 20 memory 0xf7800000-f7820000
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 29654 bytes 2269691 (2.2 MB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 29654 bytes 2269691 (2.2 MB)
wlp3s0: flags=4098<BROADCAST,MULTICAST> mtu 1500
ether 7c:5c:f8:3c:e1:69 txqueuelen 1000 (Ethernet)
RX packets 73836 bytes 81267787 (81.2 MB)
TX packets 30083 bytes 6663166 (6.6 MB)
По wifi все работает хорошо.
В настройках Ethernet соединения установлено Автоматический (DHCP)
Хотелось бы все таки настроить соединение )
10 май 2020, 13:20
SergeiR, За последние дни похожая тема , не совсем правда. на буке после выхода из сна не поднимается проводной сетевой интерфейс
Общее наверно только не очень стандартное сетевое железо. Добавте инфы по сети. Например lshw -c net , ip a и lspci -knn | grep "Eth\|Net" -A2
И желательно скрины НМ на проводном соединении.
SergeiR
12 май 2020, 18:32
10 май 2020, 13:20
В той теме больше про приоритеты, я специально отключаю wifi что бы был активен только ethernet.
~$ sudo lshw -c net
*-network
description: Ethernet interface
product: Ethernet Connection I217-LM
vendor: Intel Corporation
physical id: 19
bus info: pci@0000:00:19.0
logical name: eno1
version: 04
serial: f8:ca:b8:25:7a:bf
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=3.2.6-k duplex=full firmware=0.13-3 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:29 memory:f7800000-f781ffff memory:f783d000-f783dfff ioport:f080(size=32)
*-network DISABLED
description: Wireless interface
product: Wireless 7260
physical id: 0
bus info: pci@0000:03:00.0
logical name: wlp3s0
version: bb
serial: 7c:5c:f8:3c:e1:69
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=iwlwifi driverversion=4.15.0-96-generic firmware=17.948900127.0 latency=0 link=no multicast=yes wireless=IEEE 802.11
resources: irq:34 memory:f7700000-f7701fff
~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether f8:ca:b8:25:7a:bf brd ff:ff:ff:ff:ff:ff
inet6 fe80::9496:591a:380d:76ba/64 scope link noprefixroute
3: wlp3s0: <BROADCAST,MULTICAST> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether 7c:5c:f8:3c:e1:69 brd ff:ff:ff:ff:ff:ff
~$ lspci -knn | grep "Eth\|Net" -A2
00:19.0 Ethernet controller [0200]: Intel Corporation Ethernet Connection I217-LM [8086:153a] (rev 04)
Subsystem: Dell Ethernet Connection I217-LM [1028:05cc]
Kernel driver in use: e1000e
Kernel modules: e1000e
03:00.0 Network controller [0280]: Intel Corporation Wireless 7260 [8086:08b1] (rev bb)
Subsystem: Intel Corporation Dual Band Wireless-AC 7260 [8086:4470]
Kernel driver in use: iwlwifi
скрины НМ - Netwirk Manager?
12 май 2020, 18:43
SergeiR писал(а):
12 май 2020, 18:32
судя по этому , соединение вроде есть.
Наверно не поможет , но замени мак адрес на имя интерфейса (2 скрин)
SergeiR
12 май 2020, 19:59
Так? Не не помогает
Меня вот смущает эта строка в ifconfig
и то, что eno1 по inet6 получает адрес, а по inet нет.
12 май 2020, 20:03
SergeiR, а ты не пробовал то решение из ссылки , что я давал?
SergeiR
12 май 2020, 21:07
symon2014,
Там вообще много решений, и вроде все я попробовал:
Приоритеты,
Создал такой файл у меня его не было http://compizomania.blogspot.com/2018/0 ... nt-19.html
Вроде поменял NM на systemd-networkd, но это не точно ) https://linuxmint.com.ru/viewtopic.php?t=226
13 май 2020, 06:45
SergeiR писал(а):
12 май 2020, 21:07
Я имел ввиду это . на буке после выхода из сна не поднимается проводной сетевой интерфейс
SergeiR
13 май 2020, 18:50
13 май 2020, 06:45
SergeiR писал(а):
12 май 2020, 21:07
Я про неё и писал, в ней и ссылки на остальные советы. Или какой конкретно вы имеете в виду?
13 май 2020, 18:56
SergeiR, Я имел ввиду именно этот пост с добавлением параметров в груб.
SergeiR
13 май 2020, 20:55
13 май 2020, 18:56
Не помогло.
велес
14 май 2020, 07:59
SergeiR » Вчера, 20:55
попробуй эти команды sudo nmcli networking off , sudo nmcli networking on
14 май 2020, 08:02
велес писал(а):
14 май 2020, 07:59
Зачем?
велес
14 май 2020, 08:39
мне помогает,на ноуте,когда на уже загруженном подключаешь кабель
SergeiR
29 июн 2020, 11:56
велес писал(а):
14 май 2020, 07:59
Мне не помогло.
ilikethat
Решено: 10
Благодарил (а): 129 раз
29 июн 2020, 12:38
Похоже на Вашу проблему:
https://forums.linuxmint.com/viewtopic.php?t=302529
решение
1. Restart your router (if that doesn't work)
2. Delete your ethernet in network connections, unplug the ethernet cable, reboot and replug the cable.
SergeiR
19 июл 2020, 10:19
ilikethat писал(а):
29 июн 2020, 12:38
решение
Если бы было так просто я бы не создавал тут тему )
broken
Благодарил (а): 21 раз
19 июл 2020, 11:27
Не знаю правда на сколько это важно...
Вернуться в «Работа с сетью»
