Проблема с дрвайверами Nvidia
oopsie_doopsie
02 май 2020, 19:42
1. Версия ОС: LM xfce x64
2. Железо:
Host: zed-X550CC Kernel: 5.3.0-51-generic x86_64 bits: 64 compiler: gcc
v: 7.5.0 Desktop: Xfce 4.14.1 Distro: Linux Mint 19.3 Tricia
base: Ubuntu 18.04 bionic
Type: Laptop System: ASUSTeK product: X550CC v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X550CC v: 1.0 serial: <filter>
UEFI: American Megatrends v: X550CC.212 date: 05/29/2013
Topology: Dual Core model: Intel Pentium 2117U bits: 64 type: MCP
arch: Ivy Bridge rev: 9 L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 7183
Speed: 798 MHz min/max: 800/1800 MHz Core speeds (MHz): 1: 798 2: 798
Device-1: Intel 3rd Gen Core processor Graphics vendor: ASUSTeK
Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT
620M/625M/630M/720M]
vendor: ASUSTeK driver: nouveau v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.20.5 driver: modesetting unloaded: fbdev,vesa
resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel Ivybridge Mobile v: 4.2 Mesa 19.2.8
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK
Sound Server: ALSA v: k5.3.0-51-generic
Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter
vendor: AzureWave driver: ath9k v: kernel port: e000 bus ID: 03:00.0
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus ID: 04:00.2
IF: enp4s0f2 state: down mac: <filter>
Device-3: IMC Networks Atheros AR3012 Bluetooth 4.0 Adapter type: USB
driver: btusb bus ID: 1-1.1:5
Local Storage: total: 465.76 GiB used: 9.05 GiB (1.9%)
ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS545050B7E660
ID-1: / size: 456.96 GiB used: 9.04 GiB (2.0%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 47.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2600
Processes: 178 Uptime: 1h 13m Memory: 3.73 GiB used: 1.39 GiB (37.4%)
inxi: 3.0.32
3. Суть проблемы: При выборе драйверов от NVIDIA в Менеджере Драйверов и последующем перезапуске системы наблюдается просто чёрный экран. Даже логотипа LM нету. Как быть?
oopsie_doopsie
02 май 2020, 20:06
symon2014, дык когда его вибираю и перезапускаю систему, у меня и возникает описанная проблема
02 май 2020, 20:07
oopsie_doopsie
03 май 2020, 10:31
symon2014, ну сделал всё как сказано во второй ссылке, установил драйвера. перезапустил систему - чёрный экран.
06 май 2020, 18:43
oopsie_doopsie писал(а):
03 май 2020, 10:31
а после добавления репозитария не появились что ли другие версии дров nvidia?
на всех чёрный экран что ли ловишь?
Ctyx
Благодарил (а): 64 раза
06 май 2020, 18:51
03 май 2020, 10:31
также имею старенький ноут асус с дискретной nvidia. Танцы с бубном по установке драйвера ни к чему не привели, пока не попробовал установить ubuntu-20.04. На этапе установки выбрал установку проприетарного ПО и вуаля - установилось!
ilikethat
Решено: 10
Благодарил (а): 129 раз
06 май 2020, 19:08
Почему-то мне кажется, что проблемы не с самим драйвером nVidia, а тем что видеокарт 2 и система не может определится какую использовать. Встройку или дискретку.
Но тут моих познаний не хватает....
oopsie_doopsie
06 май 2020, 19:22
WWolf, других версий дров не появилось
06 май 2020, 19:47
Ctyx писал(а):
06 май 2020, 18:51
а чего при первом разе то не поставил? :)
oopsie_doopsie, видимо эта галка и есть твоя проблема...
Ctyx
06 май 2020, 19:50
06 май 2020, 19:47
дык только на бубунте корректно встало... на минте - чёрный экран во всей красе, на манжаре кстати также - не заработало.
Теперь жду выхода минта на базе убунту 20.4 - софтваре в ней какой-то ущербный и снап пакеты... то ещё "наслаждение" :-D
oopsie_doopsie
06 май 2020, 19:59
WWolf, при установке LM я вообще-то выбрал установку проприетарного софта
06 май 2020, 20:01
Ctyx писал(а):
06 май 2020, 18:51
Ctyx писал(а):
06 май 2020, 19:50
Дык ещё не лето.
06 май 2020, 20:09
oopsie_doopsie, ну тогда странно... у меня похожее железо и проблем не испытываю...
вот только ксорг у тебя 1.20.5, у меня 1.19.6 хотя я вроде все самые последние ставил из экспериментальных репозитариев... откуда у тебя он?
06 май 2020, 21:11
WWolf,
из реп оибафа
06 май 2020, 21:13
rogoznik, да в чате уже вспомнил что это я патченный ставил и не откатился...
Вернуться в «Xfce»
