Зависает программа установки пакетов
bitluice
30 апр 2020, 20:56
Добрый день всем!
Linux Mint 19.3 x32 xfce
System: Host: bitljuice-1015CX Kernel: 5.3.0-51-generic i686 bits: 32 compiler: gcc v: 7.5.0 Desktop: Xfce 4.14.1
Machine: Type: Laptop System: ASUSTeK product: 1015CX v: x.x serial: <filter>
Mobo: ASUSTeK model: 1015CX v: x.xx serial: <filter> BIOS: American Megatrends v: 1015CX.0601 date: 03/08/2012
Battery: ID-1: BAT0 charge: 34.5 Wh condition: 34.5/47.5 Wh (73%) model: ASUS 1015CX status: Unknown
CPU: Topology: Dual Core model: Intel Atom N2600 bits: 32 type: MT MCP arch: Saltwell rev: 1 L2 cache: 512 KiB
flags: nx pae sse sse2 sse3 ssse3 bogomips: 12771
Speed: 1197 MHz min/max: 600/1600 MHz Core speeds (MHz): 1: 1197 2: 1197 3: 1596 4: 1596
Graphics: Device-1: Intel Atom Processor D2xxx/N2xxx Integrated Graphics vendor: ASUSTeK driver: gma500 v: N/A
bus ID: 00:02.0
Display: x11 server: X.Org 1.20.5 driver: modesetting unloaded: fbdev,vesa resolution: 1024x600~60Hz
OpenGL: renderer: llvmpipe (LLVM 9.0 128 bits) v: 3.3 Mesa 19.2.8 direct render: Yes
Audio: Device-1: Intel NM10/ICH7 Family High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 00:1b.0
Sound Server: ALSA v: k5.3.0-51-generic
Network: Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter vendor: AzureWave AW-NE785 / AW-NE785H 802.11bgn
driver: ath9k v: kernel port: 0800 bus ID: 02:00.0
Device-2: Qualcomm Atheros AR8152 v2.0 Fast Ethernet vendor: ASUSTeK driver: atl1c v: 1.0.1.1-NAPI port: e000
bus ID: 03:00.0
Drives: Local Storage: total: 298.09 GiB used: 29.73 GiB (10.0%)
ID-1: /dev/sda vendor: Western Digital model: WD3200BPVT-80JJ5T0 size: 298.09 GiB
Partition: ID-1: / size: 292.41 GiB used: 14.73 GiB (5.0%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 2.00 GiB used: 275.9 MiB (13.5%) fs: swap dev: /dev/dm-0
Sensors: System Temperatures: cpu: 67.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Info: Processes: 194 Uptime: 1h 06m Memory: 916.0 MiB used: 552.0 MiB (60.3%) Init: systemd runlevel: 5 Compilers:
gcc: 7.5.0 Shell: bash v: 4.4.20 inxi: 3.0.32
Пытался установить с официальных сайтов программы AnyDesk и Zoom, оба раза выбирал спецификации файлов под свою систему. Пакеты скачивались, но после запуска и попытки установки возникала ошибка. В результате пакет не устанавливался, а программа установки пакетов переставала реагировать на закрытие и пропадала только после перезагрузки системы.
Опыт использования Линукс небольшой, раньше год сидел под Убунту, без углубления, спустя большой промежуток времени поставил Минт.
Собственно, вопрос, в чём проблема и что делать?
Whowka
Благодарил (а): 777 раз
30 апр 2020, 23:17
bitluice писал(а):
30 апр 2020, 20:56
На счёт Zoom ничего не могу сказать, не пробовал, а AnyDesk юзаю из оф. реп (полёт нормальный)
01 май 2020, 06:44
bitluice писал(а):
30 апр 2020, 20:56
Выскажу предположение. Бук старый , но всё таки поддерживает 64 бита. Многие приложения уже не поддерживают 32. Покажи название пакета zoom .
bitluice
01 май 2020, 11:19
Whowka писал(а):
30 апр 2020, 23:17
bitluice писал(а):
30 апр 2020, 20:56
Добрый день! Спасибо за комментарий! По Anydesk немного смутили отзывы, поэтому пошел на официальный сайт.
bitluice
01 май 2020, 11:27
01 май 2020, 06:44
bitluice писал(а):
30 апр 2020, 20:56
Приложу скрин с названиями пакетов Zoom и AnyDesk (заодно). Оба на 32-бит.
01 май 2020, 12:43
bitluice писал(а):
30 апр 2020, 20:56
В некоторых случаях для установки стороннего ПО требуется установка дополнительных пакетов. Никаких уведомлений об этом при установке ваших программ не высвечивалось?
01 май 2020, 12:59
madesta, да на первом же скрине... Но зачем читать? Надо ставить
01 май 2020, 13:04
WWolf, ну как бы оно автоматически доставляет зависимости
01 май 2020, 13:14
А вот на вывод sudo dpkg -i zoom_i386.deb не мешало бы взглянуть.
01 май 2020, 13:26
rogoznik, не факт... Ту же 1с пока не поставишь все зависимости не поставить основной пакет
01 май 2020, 13:28
01 май 2020, 13:26
Факт , Gdebi так и делает.
01 май 2020, 13:30
symon2014, если зависимости так же в дебах, а их нет то как он разрулить должен? Так что не факт, зависит от пакета
01 май 2020, 13:33
WWolf, на скрине по русски написано , требует 2 пакета , нажмёшь на кнопку , увидишь какие. Значит нашлись.
01 май 2020, 13:34
WWolf, если зависимости не специфичные, которые нужно так же отдельно выкачивать, то GDebi нормально их устанавливает из реп. У меня AnyDesk так и установлен. Никакие дополнительные пакеты я не выкачивал
01 май 2020, 13:49
symon2014, эта надпись говорит лишь о не разрешённой зависимости и не факт что из реп она может разрешиться
А тут ещё и х86, так что не всё так линейно может быть ;-)
01 май 2020, 13:51
01 май 2020, 13:49
эта надпись говорит
Я говорю о надписи выше , в основном окне.
bitluice
01 май 2020, 14:21
madesta писал(а):
01 май 2020, 12:43
01 май 2020, 12:59
01 май 2020, 13:33
01 май 2020, 13:51
Всем привет! Спасибо за комментарии!
Из-за неопытности я решил, что предупреждающая надпись относится к устанавливаемым программам, а не к самой программе установки.
Посмотрел какие программы требует установить программа Gdebi (скриншот в приложении):
libgtkglext1
libpango1.0-0
libpangox-1.0-0
Я так понял эти пакеты надо доустановить через менеджер пакетов Synaptic?
Осуществил поиск по первому пакету "libgtkglext1"
Кроме самого пакета поиск выдал так же пакеты с приставками "-dev" и "-doc", их так же необходимо установить?
Ну, и видимо доустановить оставшиеся пакеты таким же образом?
01 май 2020, 13:14
Выдало ошибку (видимо я что-то не так делаю?)
bitljuice@bitljuice-1015CX:~$ sudo dpkg -i zoom_i386.deb
[sudo] пароль для bitljuice:
dpkg: ошибка: dpkg frontend заблокирована другим процессом
bitljuice@bitljuice-1015CX:~$ sudo dpkg -i /home/bitljuice/Загрузки/zoom_i386.deb
bitljuice@bitljuice-1015CX:~$ ^C
synaptic
gdebi
01 май 2020, 14:45
bitluice писал(а):
01 май 2020, 14:21
Одновременно открыт синаптик , закрой его и запусти команду. Весь вывод сюда.
warning
Решено: 7
Благодарил (а): 161 раз
01 май 2020, 16:07
Я стесняюсь спросить, а вы уверены, что вам нужен zoom на этой машине ? Судя по объему памяти и другим важным параметрам, zoom просто будет душить систему при работе...
У меня стояла до этого планка на 2Г памяти. При работающем zoom память уходила в swap. Начинались фризы..
hw-probe: тыц!
01 май 2020, 16:19
warning писал(а):
01 май 2020, 16:07
Это было бы названием следующей темы. :hoho:
Вернуться в «Xfce»
