Снес прогой Bleachbit не пойму что, теперь не монтируется диск
alx777
17 апр 2020, 12:40
Перешел на Линукс Минт х64 19.3 Tricia недавно еще и недели нет сидел на винде с 95 .
Host: 543656ncvmng Kernel: 5.0.0-32-generic x86_64 bits: 64 compiler: gcc
v: 7.4.0 Desktop: Cinnamon 4.4.5 Distro: Linux Mint 19.3 Tricia
base: Ubuntu 18.04 bionic
Type: Desktop Mobo: Gigabyte model: GA-78LMT-USB3 6.0 v: SEx
serial: <filter> BIOS: Award v: F2 date: 11/25/2014
Topology: 8-Core model: AMD FX-8300 bits: 64 type: MCP arch: Bulldozer
L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 53034
Speed: 1406 MHz min/max: 1400/3300 MHz Core speeds (MHz): 1: 1405 2: 1405
3: 1405 4: 1405 5: 1406 6: 1408 7: 1406 8: 1405
Device-1: NVIDIA GK104 [GeForce GTX 760] vendor: ASUSTeK driver: nvidia
v: 435.21 bus ID: 01:00.0
Display: x11 server: X.Org 1.20.4 driver: nvidia
unloaded: fbdev,modesetting,nouveau,vesa resolution: 1280x720~60Hz
OpenGL: renderer: GeForce GTX 760/PCIe/SSE2 v: 4.6.0 NVIDIA 435.21
Device-1: AMD SBx00 Azalia vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 00:14.2
Device-2: NVIDIA GK104 HDMI Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 01:00.1
vendor: Gigabyte driver: r8169 v: kernel port: ce00 bus ID: 03:00.0
Device-2: Ralink RT5372 Wireless Adapter type: USB driver: rt2800usb
bus ID: 1-1:2
IF: wlxc83a35c72a0c state: up mac: <filter>
Local Storage: total: 1.01 TiB used: 433.34 GiB (41.7%)
ID-1: /dev/sda vendor: Western Digital model: WD1600BEVT-22A23T0
ID-2: /dev/sdb vendor: SanDisk model: SDSSDA120G size: 111.79 GiB
ID-3: /dev/sdc vendor: Hitachi model: HDT721032SLA360 size: 298.09 GiB
ID-4: /dev/sdd vendor: Western Digital model: WD5000AADS-00S9B0
ID-5: /dev/sde type: USB vendor: Generic model: Flash Disk size: 14.65 GiB
ID-1: / size: 292.31 GiB used: 153.88 GiB (52.6%) fs: ext4 dev: /dev/sdc2
ID-2: /tmp size: 92.8 MiB used: 63.0 MiB (67.9%) fs: ext4 dev: /dev/sdc1
System Temperatures: cpu: 23.9 C mobo: N/A gpu: nvidia temp: 39 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 33%
Processes: 292 Uptime: 3h 32m Memory: 7.77 GiB used: 2.31 GiB (29.8%)
inxi: 3.0.32
https://linux-hardware.org/?probe=05bb2604e3
Что произошло
Собственно все встало все работало
Примонтировал диск винды с архивом,и вот тут похоже допустил какую то ошибку в точке монтирования. Которая вылезла чуть позже.
Дальше все было норм ставил кучу прог тестил и т.д.
Тут линукс написал заканчивается место на системном диске.
Что делает пользователь винды?
Правильно запускает утилиту Bleachbit с рутом,нажимает кнопку,игнорируя какие то лютые угрозы в виде - хер ведь потом загрузишься...
Что собственно и произошло не загрузился даже с флешки
Поставил линукс еще раз
А тот диск,который нужен, в непонятном положении не монтируется и не размонтируется одновременно и вообще пишет,что занят иди мол на хер.
С бубном пляшу уже третий день перебрал все возможные варианты.
Понимаю. что как вариант - каким то образом перезаписался путь с dev/sda/ на dev/sdc. Но не могу ничего сделать
Поставил виртуальную машину,думал из под 7 ки увижу -нет.
Пытался загрузится с флешки с виндой-нет
Хз в чем проблема.
До этого все норм было
Физически отключал диск с сектором загрузки,в надежде что новый где нить винда сделает- нет,не доходит до загрузки .
Варианты перебирал в биосе EFI , без EFI, авто-нет
Пытался размонтировать смонтировать с рут правами терминала -нет
Так бы и похер на этот диск форматнуть можно было,но данных на 300 гиг. ((((
Сами мы не местные короче,поможите чем можите. Вельми панеже. :dash:
17 апр 2020, 12:45
alx777, возникает вопрос: А какой диск не монтируется? А то у тебя их у дурака фантиков :-D
17 апр 2020, 14:13
Если данные ценные - не ковырять самостоятельно, а бежать в сервис. Причем чем меньше оно ковырялось до того - тем больший шанс отделаться малой кровью. Любое неправильное действие может усугубить ситуацию, уменьшив шанс на спасение данных. Я так понял - что проблема с диском где файловая система NTFS, а в этом случае тут линукс уже как-бы и не при деле будет. Другие инструменты требуются.
alx777 писал(а):
17 апр 2020, 12:40
Надеюсь, этого опыта вам хватит чтобы понять - линукс не винда, делать что-то наугад если оно запрашивает root здесь нельзя, как и игнорировать предупреждения. За вас система думать не будет. Максимум - предупредит о возможных последствиях один раз.
alx777
17 апр 2020, 14:57
Забыл уточнить главное,речь идет о hitachi-hdt721032sla360 [55D] »
по железу видит все гут,а то что не видит э\в конце списка тот с ноута .
alx777
17 апр 2020, 15:01
вариантов нести то нет. Куда? и хз сколько вся эта херь продлится. До июля уже точно позоже,а если до осени до и все тогда.Кого еайдешь то.
alx777
17 апр 2020, 15:02
17 апр 2020, 12:45
alx777
17 апр 2020, 15:04
[quote=
[/quote]
17 апр 2020, 15:27
alx777, вот вообще не понятно что там стало с твоим диском. Инфу не хочется на нем угробить.
alx777 писал(а):
17 апр 2020, 14:57
hitachi
У тебя на нем два раздела. А инфы на нем на 150 гигов. Примонтирован к корень. Нифига не понятно.
У тебя на каком винте установлен линукс и что было на винте, который сейчасне можешь примонтировать.
17 апр 2020, 15:29
alx777 писал(а):
17 апр 2020, 15:04
Ну а если вы данные своими руками угробите - вам легче станет? Снимите диск, и положите в шкаф до появления возможности. Есть не просит, в отключенном состоянии - ничего с ним уже не произойдет худшего.
Без знаний и опыта что-то исправить в такой ситуации - шанс во много раз меньше чем еще больше навредить.
По интернету вам помочь - все равно что врачу-хирургу по телефону учить операцию делать того, кто последний раз биологию в школе видел. Задача той же сложности. Допустимо, когда пациент прямо сейчас окончательно помрет, а рядом никого больше нету и быть не может - т.е. по любому каюк, а так хоть минимальный шанс. У вас не тот случай. Наверное.
alx777
17 апр 2020, 16:04
17 апр 2020, 15:27
alx777 писал(а):
17 апр 2020, 14:57
hitachi
лиункс там стоял старый в одном разделе во втором данные с винды - фотки
сейчас гружусь и все практически поставил на другие диски
скорей всего на wdc-wd5000aads-00s9b0 [BB6] »,, медиа и прочая темпа
загрузку и системный с хомумом пытался поставить на ссд sandisk-sdssda120g [6AC] »,
вроде норм,а там хз как оно вышло.
не утверждаю точно после многодневной битвы все менялось много раз. Но судя по логике иманно так.
Rousk
Благодарил (а): 15 раз
17 апр 2020, 16:30
Загрузись посмотри с liveCD
Вывод с lsblk посмотри
Последний раз редактировалось пользователем 1 Rousk; всего редактировалось раз: 17
alx777
17 апр 2020, 16:36
17 апр 2020, 15:29
alx777 писал(а):
17 апр 2020, 15:04
Спасибо за ваше мнение.
В свете текущей ситуации и иммунитета ослабленного еждневной ,многолетней и упорной борьбой с зеленым змием,как то глупо чего то ждать в принципе . )))
Недаром же Ф. М. Достоевский устами героя одного из своих романов утверждал, что наше авось ­– дело великое.)))
alx777
17 апр 2020, 16:36
Rousk писал(а):
17 апр 2020, 16:30
liveCD с линуксом или с виндой?
Rousk
17 апр 2020, 16:39
alx777 писал(а):
17 апр 2020, 16:36
linux
alx777
17 апр 2020, 16:43
сборку любую? или есть нюансы?
Как загрузочный пилить я понял.
А вот со сборками по аналогии с виндой думаю может быть все не просто или под линуксом все равно?
Rousk
17 апр 2020, 16:46
alx777 писал(а):
17 апр 2020, 16:43
у тебя флешки установочной с mint не осталось что ли , затер ?
alx777
17 апр 2020, 17:37
Не затер.
Таки пытался и с нее .
Безопасный вообще не понял что почем.
Но там то что делать ?
как аварийный запустить ?
И надо ли?
не хуякнет ли новую загрузку обратившись к старой?
Устанавливал то с одного дистрибута.
На что жать ? :write:
17 апр 2020, 17:50
alx777 писал(а):
17 апр 2020, 17:37
На что жать ?
Первым делом не жать мне на мозг. Сдаётся мне , мил человек , что ты от скуки здесь потроллить решил.
Не стоит.
Или решаем проблему (если она есть) или вместе с
alx777 писал(а):
17 апр 2020, 15:02
отправляемся на
alx777 писал(а):
17 апр 2020, 12:40
винду с 95
 ! Сообщение из: symon2014
Шутить лень.
alx777
17 апр 2020, 21:09
Ясно все.
Спасибо всем кто откликнулся.
А супермодеру,кто он хозяин или кто он там успехов в пешем путешкствии. Карма она такая. На винду 95 посылать.
Без попытки даже обрисовать алгоритм. Отличная помощь да.
Не хами модерам. Они бывают злые. Если с 95 на винде , то должен понять был , что когда просят указать диск , не имеют ввиду модель и производителя , и SSD не обязательно переделывать в 55D.
