Не работает JMicron CardReade
SmolFox
09 апр 2020, 23:31
После установки LM 19.3 на ноутбук Lenovo 3000 G430 запустилось все, кроме кардридера. Все что находил в интернете по этому вопросу не помогает или для очень старых версий ядра.
Host: Lenovo-G430 Kernel: 5.3.0-46-generic x86_64 bits: 64 compiler: gcc
v: 7.5.0 Desktop: Cinnamon 4.4.8 Distro: Linux Mint 19.3 Tricia
base: Ubuntu 18.04 bionic
Type: Laptop System: LENOVO product: 3000 G430 v: N/A serial: <filter>
Mobo: LENOVO model: JIWA1 v: REFERENCE serial: <filter> BIOS: LENOVO
v: 0CCN52WW(V1.18) date: 03/26/2009
ID-1: BAT1 charge: 50.2 Wh condition: 57.7/57.7 Wh (100%)
model: LG PABAS024 status: Charging
Topology: Dual Core model: Intel Core2 Duo T5800 bits: 64 type: MCP
arch: Core Merom rev: D L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 ssse3 bogomips: 7979
Speed: 1403 MHz min/max: 800/2000 MHz Core speeds (MHz): 1: 1294 2: 1223
Device-1: NVIDIA G98M [GeForce 9300M GS] vendor: Lenovo driver: nvidia
v: 340.107 bus ID: 01:00.0
Display: x11 server: X.Org 1.20.5 driver: nvidia
unloaded: fbdev,modesetting,nouveau,vesa resolution: 1280x800~60Hz
OpenGL: renderer: GeForce 9300M GS/PCIe/SSE2 v: 3.3.0 NVIDIA 340.107
Device-1: Intel 82801I HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 00:1b.0
Sound Server: ALSA v: k5.3.0-46-generic
Device-1: Broadcom and subsidiaries BCM4312 802.11b/g LP-PHY driver: wl
v: kernel port: 2000 bus ID: 04:00.0
IF: wlp4s0 state: up mac: <filter>
Device-2: Broadcom and subsidiaries NetLink BCM5906M Fast Ethernet PCI
Express
vendor: Lenovo IdeaPad S10e driver: tg3 v: 3.137 port: 2000
bus ID: 07:00.0
IF: enp7s0 state: down mac: <filter>
Local Storage: total: 465.76 GiB used: 11.34 GiB (2.4%)
ID-1: /dev/sda vendor: Seagate model: ST9500325AS size: 465.76 GiB
temp: 43 C
ID-1: / size: 50.00 GiB used: 8.40 GiB (16.8%) fs: btrfs dev: /dev/sda3
ID-2: /boot size: 239.9 MiB used: 74.4 MiB (31.0%) fs: ext4 dev: /dev/sda1
ID-3: /home size: 409.31 GiB used: 2.86 GiB (0.7%) fs: xfs dev: /dev/sda4
ID-4: swap-1 size: 6.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda2
System Temperatures: cpu: 57.0 C mobo: N/A gpu: nvidia temp: 73 C
Processes: 231 Uptime: 33m Memory: 2.92 GiB used: 1.36 GiB (46.7%)
inxi: 3.0.32
a00:00.0 Host bridge: Intel Corporation Mobile 4 Series Chipset Memory Controller Hub (rev 07)
00:01.0 PCI bridge: Intel Corporation Mobile 4 Series Chipset PCI Express Graphics Port (rev 07)
00:1a.0 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #4 (rev 03)
00:1a.1 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #5 (rev 03)
00:1a.2 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #6 (rev 03)
00:1a.7 USB controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #2 (rev 03)
00:1b.0 Audio device: Intel Corporation 82801I (ICH9 Family) HD Audio Controller (rev 03)
00:1c.0 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 1 (rev 03)
00:1c.1 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 2 (rev 03)
00:1c.2 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 3 (rev 03)
00:1c.3 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 4 (rev 03)
00:1c.5 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 6 (rev 03)
00:1d.0 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #1 (rev 03)
00:1d.1 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #2 (rev 03)
00:1d.2 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #3 (rev 03)
00:1d.7 USB controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #1 (rev 03)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev 93)
00:1f.0 ISA bridge: Intel Corporation ICH9M LPC Interface Controller (rev 03)
00:1f.2 SATA controller: Intel Corporation 82801IBM/IEM (ICH9M/ICH9M-E) 4 port SATA Controller [AHCI mode] (rev 03)
00:1f.3 SMBus: Intel Corporation 82801I (ICH9 Family) SMBus Controller (rev 03)
01:00.0 VGA compatible controller: NVIDIA Corporation G98M [GeForce 9300M GS] (rev a1)
02:00.0 System peripheral: JMicron Technology Corp. SD/MMC Host Controller
02:00.2 SD Host controller: JMicron Technology Corp. Standard SD Host Controller
02:00.3 System peripheral: JMicron Technology Corp. MS Host Controller
04:00.0 Network controller: Broadcom Inc. and subsidiaries BCM4312 802.11b/g LP-PHY (rev 01)
07:00.0 Ethernet controller: Broadcom Inc. and subsidiaries NetLink BCM5906M Fast Ethernet PCI Express (rev 02)
Module Size Used by
xfs 1273856 1
joydev 28672 0
snd_hda_codec_conexant 28672 1
snd_hda_codec_generic 81920 1 snd_hda_codec_conexant
ledtrig_audio 16384 2 snd_hda_codec_generic,snd_hda_codec_conexant
snd_hda_codec_hdmi 57344 1
snd_hda_intel 53248 3
snd_intel_nhlt 20480 1 snd_hda_intel
snd_hda_codec 131072 4 snd_hda_codec_generic,snd_hda_codec_conexant,snd_hda_codec_hdmi,snd_hda_intel
snd_hda_core 90112 5 snd_hda_codec_generic,snd_hda_codec_conexant,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec
snd_hwdep 20480 1 snd_hda_codec
coretemp 20480 0
mmc_block 49152 0
wl 6451200 0
nvidia_uvm 36864 0
snd_pcm 102400 4 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_core
snd_seq_midi 20480 0
snd_seq_midi_event 16384 1 snd_seq_midi
snd_rawmidi 36864 1 snd_seq_midi
lpc_ich 24576 0
sdhci_pci 45056 0
cqhci 28672 1 sdhci_pci
snd_seq 69632 2 snd_seq_midi,snd_seq_midi_event
jmb38x_ms 24576 0
psmouse 151552 0
sdhci 57344 1 sdhci_pci
memstick 20480 1 jmb38x_ms
snd_seq_device 16384 3 snd_seq,snd_seq_midi,snd_rawmidi
ideapad_laptop 20480 0
snd_timer 36864 2 snd_seq,snd_pcm
cfg80211 704512 1 wl
nvidia 10584064 43 nvidia_uvm
snd 86016 17 snd_hda_codec_generic,snd_seq,snd_hda_codec_conexant,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_timer,snd_pcm,snd_rawmidi
sparse_keymap 16384 1 ideapad_laptop
soundcore 16384 1 snd
wmi 32768 1 ideapad_laptop
drm 491520 3 nvidia
sch_fq_codel 20480 3
parport_pc 40960 0
ppdev 24576 0
lp 20480 0
parport 53248 3 parport_pc,lp,ppdev
ip_tables 32768 0
x_tables 40960 1 ip_tables
autofs4 45056 2
btrfs 1232896 1
libcrc32c 16384 2 btrfs,xfs
xor 24576 1 btrfs
zstd_compress 163840 1 btrfs
raid6_pq 114688 1 btrfs
dm_mirror 24576 0
dm_region_hash 20480 1 dm_mirror
dm_log 20480 2 dm_region_hash,dm_mirror
input_leds 16384 0
serio_raw 20480 0
ahci 40960 4
libahci 32768 1 ahci
tg3 167936 0
video 49152 1 ideapad_laptop
mac_hid 16384 0
[ 149.349637] mmc0: new SDHC card at address 0002
[ 149.351178] mmcblk0: mmc0:0002 SD16G 14.9 GiB
[ 149.729788] print_req_error: 102 callbacks suppressed
[ 149.729791] blk_update_request: I/O error, dev mmcblk0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 149.731062] blk_update_request: I/O error, dev mmcblk0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 149.732324] blk_update_request: I/O error, dev mmcblk0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 149.733582] blk_update_request: I/O error, dev mmcblk0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 149.734857] blk_update_request: I/O error, dev mmcblk0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 149.736113] blk_update_request: I/O error, dev mmcblk0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 149.737371] blk_update_request: I/O error, dev mmcblk0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 149.738630] blk_update_request: I/O error, dev mmcblk0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 149.738635] buffer_io_error: 3 callbacks suppressed
[ 149.738636] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[ 149.743003] blk_update_request: I/O error, dev mmcblk0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 149.744258] blk_update_request: I/O error, dev mmcblk0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 149.751762] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[ 149.764818] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[ 149.764832] ldm_validate_partition_table(): Disk read failed.
[ 149.777902] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[ 149.790946] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[ 149.803995] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[ 149.817050] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[ 149.817072] Dev mmcblk0: unable to read RDB block 0
[ 149.830208] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[ 149.843277] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[ 149.855980] Buffer I/O error on dev mmcblk0, logical block 3, async page read
[ 149.882487] mmcblk0: unable to read partition table
В 7 кардридер и карточка работают нормально
Направте в нужном направлении или помогите с проблемой .
Последний раз редактировалось пользователем 1 SmolFox; всего редактировалось раз: 9
09 апр 2020, 23:38
SmolFox, красное поле вверху страницы... давай сразу ссылку на hw-probe ...
потому как судя по всему всё там работает, кроме таймингов... в какой файловой системе карточка кстати?
SmolFox
09 апр 2020, 23:50
HW-Probe
Probe URL: https://linux-hardware.org/?probe=983e0ec783
Карточка в FAT32
SmolFox
09 апр 2020, 23:52
WWolf, Обновил шапку и добавил hw-probe
10 апр 2020, 00:11
SmolFox, попробуй ядро 4.15 поставить и с ним загрузиться... заработает?
SmolFox
10 апр 2020, 00:27
WWolf, Загрузился с 4.15.0-96... те же ошибки в dmesg с невозможностью прочесть карту. То есть от версии ядра особо ничего не поменялось. Меня лично смущает два устройства sd-host
10 апр 2020, 00:55
SmolFox, просто составное устройство как и многие другие...
ну я б ещё попробовал ядра из нормальной ветки 4.19, 5.4, 5.6...
о, попробуй загрузить live cd 18.3 и посмотреть там работает или нет
10 апр 2020, 01:43
На англоязычных ресурсах советуют попробовать догрузить модули:
sudo modprobe tifm_sd
sudo modprobe mmc_block
Это из консоли просто команды. Перегружать систему не надо (наоборот - оно будет загружено только до перезагрузки). Если поможет - то сразу. И если поможет - тогда можно эти модули в /etc/modules вписать на постоянной основе.
(Второй из модулей у вас загружен, если верить lsmod'у, а вот первый - похоже что нет).
SmolFox
10 апр 2020, 10:35
slant, к сожалению это тоже пробовал - не помогло.
SmolFox
10 апр 2020, 10:38
WWolf, перепробовал все основные версии ядер - проблема везде одинакова, включая и live cd
10 апр 2020, 11:35
SmolFox, значит "генетическая непереносимость"
10 апр 2020, 13:39
Ну, тогда видимо, решения нету. Кардридеры этого производителя, кстати, в списке проблемных. И видимо не даром. Можно правда попробовать где-нить раздобыть дешевую SD карточку которую не жалко, и поиграться с форматированием ее из под линукса - возможно и заработает. Но скорее всего нет.
