Тормозит Панель задачь
Sander
Благодарил (а): 25 раз
06 апр 2020, 09:37
Linux Mint 19.3 Cinnamon 64
Host: sm Kernel: 5.3.0-45-generic x86_64 bits: 64 compiler: gcc v: 7.5.0
Desktop: Cinnamon 4.4.8 Distro: Linux Mint 19.3 Tricia
base: Ubuntu 18.04 bionic
Type: Desktop Mobo: ASUSTeK model: M4A87TD/USB3 v: Rev 1.xx
serial: <filter> BIOS: American Megatrends v: 2001 date: 03/08/2011
Topology: Quad Core model: AMD Phenom II X4 850 bits: 64 type: MCP
arch: K10 rev: 3 L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 26488
Speed: 2000 MHz min/max: 800/3300 MHz Core speeds (MHz): 1: 2000 2: 800
3: 2000 4: 800
Device-1: NVIDIA GF108 [GeForce GT 440] vendor: ASUSTeK driver: nouveau
v: kernel bus ID: 05:00.0
Display: x11 server: X.Org 1.20.5 driver: modesetting unloaded: fbdev,vesa
resolution: 1680x1050~60Hz
OpenGL: renderer: NVC1 v: 4.3 Mesa 19.2.8 direct render: Yes
Device-1: AMD SBx00 Azalia driver: snd_hda_intel v: kernel bus ID: 00:14.2
Device-2: NVIDIA GF108 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 05:00.1
Device-3: Nam Tai E&E Products or OmniVision Sony Playstation Eye
type: USB driver: ov534,snd-usb-audio bus ID: 1-3:2
Sound Server: ALSA v: k5.3.0-45-generic
vendor: ASUSTeK P8P67 and other motherboards driver: r8169 v: kernel
port: b800 bus ID: 01:00.0
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: VIA VT6105/VT6106S [Rhine-III]
vendor: D-Link System DFE-520TX Fast PCI driver: via-rhine v: N/A
port: c800 bus ID: 02:07.0
IF: enp2s7 state: down mac: <filter>
Local Storage: total: 1.02 TiB used: 313.94 GiB (30.1%)
ID-1: /dev/sda vendor: Western Digital model: WD10EARX-00N0YB0
ID-2: /dev/sdb vendor: Seagate model: ST3120813AS size: 111.79 GiB
ID-1: / size: 29.40 GiB used: 13.43 GiB (45.7%) fs: ext4 dev: /dev/sda1
ID-2: /home size: 196.74 GiB used: 112.45 GiB (57.2%) fs: ext4
dev: /dev/sda3
System Temperatures: cpu: 22.1 C mobo: N/A gpu: nouveau temp: 43 C
Processes: 243 Uptime: 1d 11h 53m Memory: 7.77 GiB used: 3.06 GiB (39.3%)
inxi: 3.0.32
Переустановил систему- была Linux Mint 18.3 Cinnamon 64. Корень отформатировал, home подцепил от прежней системы. Всё более менее хорошо (частенько вылетает cinnamon, но сейчас не об этом). Панель задач настроена на умное скрытие (автоматическое работает аналогично). Так вот скрытие и появление панели происходит не плавно, а так, как будто она цепляется за что то, я бы сказал "со скрипом". Как серпом по... Это так неприятно, что только из-за этого хочется снести систему. Если в настройках убрать задержку скрытия/появления, то ничего не меняется. Причём если поставить панель с любого бока или вверху, то панель начинает работать нормально. Но мне бы хотелось, что бы панель была внизу.
Подскажите пожалуйста как быть?
Решение rogoznik » 06 апр 2020, 13:51
Sander писал(а):
06 апр 2020, 13:30
Как сбросить?
ПКМ на панели, устранить неполадки, сбросить все настройки
06 апр 2020, 09:44
06 апр 2020, 10:35
Sander, возможно стоит сбросить все настройки панели и настроить заново, т.к. корица сильно обновилась по сравнению с 18.3.
Sander
06 апр 2020, 13:30
06 апр 2020, 10:35
Как сбросить?
06 апр 2020, 13:51
Sander писал(а):
06 апр 2020, 13:30
Как сбросить?
Sander
06 апр 2020, 14:35
rogoznik, Спасибо! Заработало как надо!
06 апр 2020, 14:39
:close:
