Не работает блютуз на линуксе на виндовсе всё работает
Dardwolf
04 апр 2020, 14:51
нв виндовс 8.1 и на виндовс 10 про и домашняя блутуз работает но на линукс минт 19,3 в системе видно но устройства к блютузу не подключаются помогите.
System:    Host: dardwolf-SVF1521D1RW Kernel: 5.3.0-45-generic x86_64 bits: 64 compiler: gcc v: 7.5.0 Desktop: Cinnamon 4.4.8
Machine:   Type: Laptop System: Sony product: SVF1521D1RW v: C10JSVL8 serial: <filter>
           Mobo: Sony model: VAIO serial: <filter> UEFI: Insyde v: R0250DA date: 07/19/2016
CPU:       Topology: Dual Core model: Intel Pentium 2117U bits: 64 type: MCP arch: Ivy Bridge rev: 9 L2 cache: 2048 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 7183
           Speed: 1315 MHz min/max: 800/1800 MHz Core speeds (MHz): 1: 1191 2: 1189
Graphics:  Device-1: Intel 3rd Gen Core processor Graphics vendor: Sony driver: i915 v: kernel bus ID: 00:02.0
           Device-2: NVIDIA GK208M [GeForce GT 740M] vendor: Sony driver: nvidia v: 390.116 bus ID: 01:00.0
           Display: x11 server: X.Org 1.20.5 driver: modesetting,nvidia unloaded: fbdev,nouveau,vesa resolution: 1366x768~60Hz
           OpenGL: renderer: GeForce GT 740M/PCIe/SSE2 v: 4.6.0 NVIDIA 390.116 direct render: Yes
Audio:     Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Sony driver: snd_hda_intel v: kernel
           bus ID: 00:1b.0
           Sound Server: ALSA v: k5.3.0-45-generic
Network:   Device-1: Broadcom and subsidiaries BCM43142 802.11b/g/n vendor: Foxconn driver: wl v: kernel port: 3000
           bus ID: 07:00.0
           IF: wlp7s0 state: up mac: <filter>
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Sony driver: r8169 v: kernel port: 2000
           bus ID: 0e:00.0
           IF: enp14s0 state: down mac: <filter>
Drives:    Local Storage: total: 465.76 GiB used: 11.87 GiB (2.5%)
           ID-1: /dev/sda vendor: Toshiba model: MQ01ABF050 size: 465.76 GiB
Partition: ID-1: / size: 456.01 GiB used: 11.80 GiB (2.6%) fs: ext4 dev: /dev/dm-0
           ID-2: swap-1 size: 980.0 MiB used: 67.2 MiB (6.9%) fs: swap dev: /dev/dm-1
Sensors:   System Temperatures: cpu: 59.0 C mobo: N/A gpu: nvidia temp: 53 C
Info:      Processes: 225 Uptime: 8h 39m Memory: 3.72 GiB used: 1.74 GiB (46.6%) Init: systemd runlevel: 5 Compilers:
           gcc: 7.5.0 Shell: bash v: 4.4.20 inxi: 3.0.32
что надо сделать что-бы заработал блютуз.
04 апр 2020, 15:34
Dardwolf
04 апр 2020, 19:08
прошол по твоей сыллке там асё на англиском я немног понимаю но в линуксе я полный профан
04 апр 2020, 19:15
Dardwolf, ну хоть начни сначала. Например с этого ,, покажи вывод sudo service bluetooth status , у меня вот что получается например.
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2020-04-04 17:22:28 MSK; 2h 11min ago
Docs: man:bluetoothd(8)
Main PID: 777 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 4503)
CGroup: /system.slice/bluetooth.service
└─777 /usr/lib/bluetooth/bluetoothd
апр 04 17:22:25 mtuser systemd[1]: Starting Bluetooth service...
апр 04 17:22:26 mtuser bluetoothd[777]: Bluetooth daemon 5.48
апр 04 17:22:28 mtuser bluetoothd[777]: Starting SDP server
апр 04 17:22:28 mtuser systemd[1]: Started Bluetooth service.
апр 04 17:22:29 mtuser bluetoothd[777]: Bluetooth management interface 1.14 initialized
апр 04 17:22:52 mtuser bluetoothd[777]: Endpoint registered: sender=:1.40 path=/MediaEndpoint/A2DPSource
апр 04 17:22:52 mtuser bluetoothd[777]: Endpoint registered: sender=:1.40 path=/MediaEndpoint/A2DPSink
Dardwolf
05 апр 2020, 08:48
Active: active (running) since Sun 2020-04-05 08:45:20 +05; 2h 23min ago
Main PID: 801 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 4489)
└─801 /usr/lib/bluetooth/bluetoothd
апр 05 08:45:18 dardwolf-SVF1521D1RW systemd[1]: Starting Bluetooth service...
апр 05 08:45:19 dardwolf-SVF1521D1RW bluetoothd[801]: Bluetooth daemon 5.48
апр 05 08:45:20 dardwolf-SVF1521D1RW systemd[1]: Started Bluetooth service.
апр 05 08:45:20 dardwolf-SVF1521D1RW bluetoothd[801]: Starting SDP server
апр 05 08:45:21 dardwolf-SVF1521D1RW bluetoothd[801]: Bluetooth management inter
апр 05 11:06:50 dardwolf-SVF1521D1RW bluetoothd[801]: Endpoint registered: sende
lines 1-17/17 (END)
вот что выдало
что к чему не могу сообразить
05 апр 2020, 08:54
Dardwolf писал(а):
05 апр 2020, 08:48
Блютуз у тебя работает и включен. Набери и выполни команду blueberry
Dardwolf
05 апр 2020, 09:08
04 апр 2020, 19:15
Status: "Running"
Status: "Running"
lines 1-17/17 (END)
вот что вышло
05 апр 2020, 09:11
Dardwolf, ты что , заикаешься , повторяешь сообщения ?
Dardwolf
05 апр 2020, 09:38
05 апр 2020, 08:54
Dardwolf писал(а):
05 апр 2020, 08:48
команду выполнил но устройства не видит
не телефон не блютуз гарнитуру не другие устройства
Dardwolf
05 апр 2020, 09:42
Dardwolf писал(а):
05 апр 2020, 09:38
05 апр 2020, 08:54
Dardwolf писал(а):
05 апр 2020, 08:48
нет не заикаюсь просто клава продублировала блютуз не может обнаружить устройства хотя пишит поиск устройств
05 апр 2020, 09:45
Dardwolf писал(а):
05 апр 2020, 09:38
Когда вы уже отучитесь гнать отсебятину. Покажи ответ терминала. И перестань дублировать сообщения , у меня нет склероза.
05 апр 2020, 09:53
Dardwolf
05 апр 2020, 10:16
05 апр 2020, 09:45
Dardwolf писал(а):
05 апр 2020, 09:38
Active: active (running) since Sun 2020-04-05 08:45:20 +05; 3h 49min ago
Status: "Running"
lines 1-17/17 (END)
повторил команду
и кто говорит что у тебя склезоз если блютуз работает а сигнал с других устройств не видет это как
Dardwolf
05 апр 2020, 10:19
...skipping...
Status: "Running"
05 апр 2020, 10:31
Dardwolf, блин , я говорил , запустить команду blueberry и показать вывод , а не повторять 5 раз одно и то же.
 ! Сообщение из: symon2014
В следующий раз сочту за троллинг.
Dardwolf
05 апр 2020, 11:12
я ввёл команду запустилась программа блютуза и пишит поиск устройств
Dardwolf
05 апр 2020, 11:21
05 апр 2020, 09:45
Dardwolf писал(а):
05 апр 2020, 09:38
вот тебе ответ терминала
ERROR:lib/bluez/adapter.c:165:adapter_get_dbus_object_path: assertion failed: (ADAPTER_IS(self))
timeout: отслеживаемая команда завершилась созданием дампа
(blueberry.py:2363): com.linuxmint.blueberry-WARNING **: 13:38:21.042: Could not retrieve the BT adapter name with 'bt-adapter -i': Command '['timeout', '2s', 'bt-adapter', '-i']' died with <Signals.SIGABRT: 6>.
05 апр 2020, 12:43
Dardwolf, Сделай скрин по типу этого.
и вывод bt-adapter -i
Dardwolf
05 апр 2020, 14:03
05 апр 2020, 12:43
bt-adapter -i
[hci0]
Address: 34:23:87:78:11:82
Alias: dardwolf-SVF1521D1RW [rw]
Class: 0x1c010c
Discoverable: 1 [rw]
DiscoverableTimeout: 0 [rw]
Discovering: 0
Pairable: 1 [rw]
PairableTimeout: 0 [rw]
Powered: 1 [rw]
UUIDs: [HeadsetAudioGateway, 00001801-0000-1000-8000-00805f9b34fb, AVRemoteControl, OBEXFileTransfer, 00001800-0000-1000-8000-00805f9b34fb, OBEXObjectPush, PnPInformation, AVRemoteControlTarget, IrMCSync, AudioSource, AudioSink, 00005005-0000-1000-8000-0002ee000001, 00001133-0000-1000-8000-00805f9b34fb, PhoneBookAccess, 00001132-0000-1000-8000-00805f9b34fb, Headset]
скриншот позже сделаю пока адаптор откликнется
05 апр 2020, 14:08
Dardwolf, перестань плодить дубли сообщений , или выпишу горчичник.
Внизу на панели справа у тебя запущеный блютуз , открой окно и покажи его скрин.
