LM 19.3 MATE X64 когда звоню другу через WIRE у друга мой экран показываеть крива
Мади Бекназаров
18 мар 2020, 14:27
  Host: minecraft-PC Kernel: 5.0.0-32-generic x86_64 bits: 64 compiler: gcc
  v: 7.4.0 Desktop: MATE 1.22.2 Distro: Linux Mint 19.3 Tricia
  base: Ubuntu 18.04 bionic
  Type: Laptop System: ASUSTeK product: X540SA v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: X540SA v: 1.0 serial: <filter>
  UEFI [Legacy]: American Megatrends v: X540SA.302 date: 07/29/2016
  ID-1: BAT0 charge: 27.7 Wh condition: 28.7/33.2 Wh (86%)
  model: ASUSTeK X550A26 status: Discharging
  Topology: Dual Core model: Intel Celeron N3050 bits: 64 type: MCP
  arch: Airmont rev: 3 L2 cache: 1024 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 6400
  Speed: 588 MHz min/max: 480/2160 MHz Core speeds (MHz): 1: 520 2: 480
  Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
  Integrated Graphics
  vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0
  Display: x11 server: X.Org 1.20.4 driver: modesetting unloaded: fbdev,vesa
  resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa DRI Intel HD Graphics 400 (Braswell)
  v: 4.5 Mesa 19.0.8 direct render: Yes
  Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
  High Definition Audio
  vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: ASUSTeK
  driver: r8169 v: kernel port: e000 bus ID: 02:00.0
  Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Lite-On
  driver: rtl8723be v: kernel port: d000 bus ID: 03:00.0
  Local Storage: total: 465.76 GiB used: 10.37 GiB (2.2%)
  ID-1: /dev/sda vendor: Toshiba model: MQ01ABF050 size: 465.76 GiB
  ID-1: / size: 215.17 GiB used: 8.21 GiB (3.8%) fs: ext4 dev: /dev/sda5
  System Temperatures: cpu: 6280.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 3400
  Processes: 175 Uptime: 1h 13m Memory: 1.85 GiB used: 889.9 MiB (47.0%)
  inxi: 3.0.32
18 мар 2020, 14:32
 ! Сообщение из: symon2014
Мади Бекназаров, может тебя наказать за размножение тем?
18 мар 2020, 14:33
Обнови систему сначала.
Мади Бекназаров
18 мар 2020, 14:35
обновиль. переустоновль проблема осталос
18 мар 2020, 14:36
Мади Бекназаров писал(а):
18 мар 2020, 14:35
обновиль.
не верю , покажи inxi -Fxz ещё раз и в тегах [ code][ /code].
Мади Бекназаров
18 мар 2020, 15:21
  ID-1: BAT0 charge: 15.8 Wh condition: 28.7/33.2 Wh (86%)
  Speed: 646 MHz min/max: 480/2160 MHz Core speeds (MHz): 1: 553 2: 1844
  Integrated Graphics
  v: 4.5 Mesa 19.2.8 direct render: Yes
  Local Storage: total: 465.76 GiB used: 11.51 GiB (2.5%)
  temp: 41 C
  ID-1: / size: 215.17 GiB used: 9.35 GiB (4.3%) fs: ext4 dev: /dev/sda5
  Processes: 192 Uptime: 2h 28m Memory: 1.85 GiB used: 971.9 MiB (51.4%)
  inxi: 3.0.32
обновил
оформляй тему правильно , с тегами.
18 мар 2020, 15:29
18 мар 2020, 15:21
Ядро мне не нравится.
Выполни apt update и apt upgrade . Всё , что выдаст терминал , вставь сюда под спойлер. И по теме , как тебя видит твой знакомый , это его головная боль , а не твоя.
Мади Бекназаров
18 мар 2020, 15:36
  Host: minecraft-PC Kernel: 5.3.0-42-generic x86_64 bits: 64 compiler: gcc
  ID-1: BAT0 charge: 17.8 Wh condition: 28.7/33.2 Wh (86%)
  model: ASUSTeK X550A26 status: Charging
  Speed: 537 MHz min/max: 480/2160 MHz Core speeds (MHz): 1: 480 2: 718
  Integrated Graphics
  Display: x11 server: X.Org 1.20.5 driver: modesetting unloaded: fbdev,vesa
  Sound Server: ALSA v: k5.3.0-42-generic
  Local Storage: total: 465.76 GiB used: 9.08 GiB (1.9%)
  ID-1: / size: 215.17 GiB used: 9.08 GiB (4.2%) fs: ext4 dev: /dev/sda5
  Processes: 165 Uptime: 11m Memory: 1.84 GiB used: 1.00 GiB (54.3%)
  inxi: 3.0.32
Не будешь оформлять тему , накажу. Я не редактором у тебя на полставки.
Мади Бекназаров
18 мар 2020, 15:37
'если у меня есть такая проблема у других тоже будет. нужно как то попытаться исправить
18 мар 2020, 15:42
18 мар 2020, 15:37
Я повторю , это не твоя проблема. Ты себя в камере нормально видишь? Как в скайпе , линукс вообще нипричём , мессенджер кроссплатформенный и экспериментальный.
Вернуться в «Mate»
