Зомби процесс get_apt_cache.p /.py
desades
15 мар 2020, 00:19
Здравствуйте.
1. Выпуск Linux Mint 19.3 Tricia 64-разрядный
2. MATE
3. inxi -Fxz
Host: desades-P35-S3G Kernel: 4.15.0-88-generic x86_64 bits: 64
compiler: gcc v: 7.4.0 Desktop: MATE 1.22.2 Distro: Linux Mint 19.3 Tricia
base: Ubuntu 18.04 bionic
Type: Desktop Mobo: Gigabyte model: P35-S3G v: x.x serial: <filter>
BIOS: Award v: F5 date: 06/19/2009
Topology: Quad Core model: Intel Xeon E5450 bits: 64 type: MCP
arch: Penryn rev: A L2 cache: 6144 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx bogomips: 23998
Speed: 2000 MHz min/max: 2000/3000 MHz Core speeds (MHz): 1: 2000 2: 2000
3: 2000 4: 2000
Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: CardExpert driver: nvidia
v: 430.50 bus ID: 01:00.0
Display: x11 server: X.Org 1.19.6 driver: nvidia
resolution: 1680x1050~60Hz
OpenGL: renderer: GeForce GTX 960/PCIe/SSE2 v: 4.6.0 NVIDIA 430.50
Device-1: Intel 82801I HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 00:1b.0
Device-2: NVIDIA vendor: CardExpert driver: snd_hda_intel v: kernel
bus ID: 01:00.1
Device-3: Pixart Imaging type: USB driver: snd-usb-audio,uvcvideo
bus ID: 1-4.1:4
Sound Server: ALSA v: k4.15.0-88-generic
vendor: Gigabyte driver: r8169 v: 2.3LK-NAPI port: d000 bus ID: 04:00.0
Local Storage: total: 1.02 TiB used: 59.89 GiB (5.7%)
ID-1: /dev/sda vendor: Seagate model: ST31000528AS size: 931.51 GiB
ID-2: /dev/sdb model: IR-SSDPR-S25A-120 size: 111.79 GiB
ID-1: / size: 46.68 GiB used: 16.22 GiB (34.7%) fs: ext4 dev: /dev/sdb1
ID-2: /home size: 62.60 GiB used: 43.67 GiB (69.8%) fs: ext4
dev: /dev/sdb5
System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia temp: 30 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Processes: 207 Uptime: 49m Memory: 7.79 GiB used: 2.21 GiB (28.4%)
inxi: 3.0.32
4. Столкнулся с такой ситуацией, что при загрузке системы появляется процесс зомби. http://prntscr.com/rgfbhq, http://prntscr.com/rgfbq4. Пытался убить процесс, через kill, killall, sigkill. Результата нет. Пытался убить родительский процесс - система выводит меня на процесс mintmenu. Он перезагружается и вновь появляется зомби. При перезагрузке плагинов процесс исчезает и появляется вновь спустя секунд 10.
Что было сделано - откат системы с помощью Timeshift. Откат ядра системы. Результата нет.
Данная проблема систему не грузит, каких либо провисаний в работа не наблюдал. Есть замечание на момент копирования файлов на флешку (при копировании медиа-файла с Linux Mint на флешку копируется только 20% содержимого, хотя после копирования я запускаю файл на флешке и всё нормально, достаточно загрузится под Windows и половина файла пропала).
Хочу разобраться в данном вопросе. Знания про данную ОС поверхностные. Если есть идеи или был уже опыт с подобным вопросом - подскажите пожалуйста решение.
Решение symon2014 » 16 мар 2020, 09:25
desades, https://forums.linuxmint.com/viewtopic.php?t=291787
15 мар 2020, 00:32
desades писал(а):
15 мар 2020, 00:19
Флешка случайно не выдергивается без отмонтирования? Похоже на то, что данные не успевают быть записаны на флешку полностью и еще находятся в дисковом кеше, когда флешка уже выдергивается. Попробуйте перед тем как флешку выдернуть, дать в консоли команду sync и дождитесь ее окончания. Команда принудительно сбрасывает на диски все содержимое кешей в активном режиме.
desades
15 мар 2020, 01:17
Дожидаюсь уведомление о том, что файлы скопированы, затем нажимаю отмонтировать и затем уже извлекаю флешку. Был момент, когда Caja уведомила что всё скопировано, но при отсоединении флешки появилось окно - идёт работа с флешкой. Хотя нигде не показано что файлы ещё передаются.
desades
15 мар 2020, 19:58
Нашел в чём трудность - mintMenu Advanced Menu. Как только я убираю меню с панели - нет зомби процессов. Осталось разобраться что делать с mintMenu и как его восстановить/пофиксить.
16 мар 2020, 09:25
desades
16 мар 2020, 16:09
16 мар 2020, 09:25
Благодарю за ответ, применил изменения, ребут, зомби процессов нет.
