Моргает экран при включение и при выходи из затухания
L1bre
11 мар 2020, 10:31
Моргает экран при включение и при выходи из затухания.
на 18 manjaro такого не было. это появилось на 19.01 после полной установки
System:    Host: ,,,,,,,,, Kernel: 5.4.23-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.1 Desktop: KDE Plasma 5.17.5
           Distro: Manjaro Linux
Machine:   Type: Laptop System: Acer product: Aspire A315-41 v: V1.11 serial: <filter>
           Mobo: RR model: Metapod_RR v: V1.11 serial: <filter> UEFI: Insyde v: 1.11 date: 10/30/2018
Battery:   ID-1: BAT1 charge: 26.7 Wh condition: 26.7/37.0 Wh (72%) model: PANASONIC 0x41,0x50,0x31,0x36,0x4D,0x35,0x0086
           status: Full
CPU:       Topology: Quad Core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen
           L2 cache: 2048 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 31952
           Speed: 2368 MHz min/max: 1600/2000 MHz Core speeds (MHz): 1: 2368 2: 1717 3: 1780 4: 2461 5: 1485 6: 1439 7: 1660
           8: 1453
Graphics:  Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series] vendor: Acer Incorporated ALI
           driver: amdgpu v: kernel bus ID: 03:00.0
           Display: x11 server: X.Org 1.20.7 driver: amdgpu FAILED: ati unloaded: modesetting resolution: 1920x1080~60Hz
           OpenGL: renderer: AMD RAVEN (DRM 3.35.0 5.4.23-1-MANJARO LLVM 9.0.1) v: 4.5 Mesa 19.3.4 direct render: Yes
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Acer Incorporated ALI
           driver: snd_hda_intel v: kernel bus ID: 03:00.1
           Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Acer Incorporated ALI driver: snd_hda_intel
           v: kernel bus ID: 03:00.6
           Sound Server: ALSA v: k5.4.23-1-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI driver: r8168
           v: 8.048.00-NAPI port: 2000 bus ID: 01:00.1
           IF: enp1s0f1 state: down mac: <filter>
           Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Lite-On driver: ath10k_pci v: kernel
           port: 2000 bus ID: 02:00.0
Drives:    Local Storage: total: 577.56 GiB used: 249.47 GiB (43.2%)
           ID-1: /dev/sda vendor: Seagate model: ST500LM012 HN-M500MBB size: 465.76 GiB
           ID-2: /dev/sdb vendor: Western Digital model: WDS120G2G0B-00EPW0 size: 111.80 GiB
Partition: ID-1: / size: 109.25 GiB used: 25.86 GiB (23.7%) fs: ext4 dev: /dev/sdb2
Sensors:   System Temperatures: cpu: 52.0 C mobo: N/A gpu: amdgpu temp: 52 C
Info:      Processes: 221 Uptime: 52m Memory: 6.76 GiB used: 1.37 GiB (20.3%) Init: systemd Compilers: gcc: 9.2.1 Shell: bash
           v: 5.0.16 inxi: 3.0.37
до этого стояла manjaro 18 на ядре 4.19 все работало. ну кроме pacman он начал марасить. приходилась все обновлять только через терминал.
из за этого решил перейти на новый релиз .19.01.
как с этим бороться :)?
Благодарил (а): 1737 раз
11 мар 2020, 10:34
L1bre писал(а):
11 мар 2020, 10:31
наверное идтить на сайт манжары ;)
11 мар 2020, 11:38
11 мар 2020, 10:34
Там пошлют куда дальше. :-D
11 мар 2020, 13:54
L1bre писал(а):
11 мар 2020, 10:31
Остаться на этом ядре. И следить за новостями, может это уже исправили
