добрый день
Есть планшет lenovo на нем linuxMint 19.3 - Xface
System: Host: aleksa-Lenovo-MIIX-320-10ICR Kernel: 5.3.0-40-generic x86_64 bits: 64 compiler: gcc v: 7.4.0
Desktop: Xfce 4.14.1 Distro: Linux Mint 19.3 Tricia base: Ubuntu 18.04 bionic
Machine: Type: Detachable System: LENOVO product: 80XF v: Lenovo MIIX 320-10ICR serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J91185WIN serial: <filter> UEFI: LENOVO v: 5HCN39WW date: 05/11/2018
Battery: ID-1: BAPM charge: 31.0 Wh condition: 33.3/33.3 Wh (100%) model: Bitland AXP288 status: Charging
CPU: Topology: Quad Core model: Intel Atom x5-Z8350 bits: 64 type: MCP arch: Airmont rev: 4 L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 11520
Speed: 531 MHz min/max: 480/1920 MHz Core speeds (MHz): 1: 627 2: 520 3: 480 4: 480
Graphics: Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI Configuration Registers
vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0
Display: x11 server: X.Org 1.20.5 driver: modesetting unloaded: fbdev,vesa resolution: 1200x1920~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics (CHV)
v: 4.6 Mesa 20.1.0-devel (git-0103f02 2020-03-07 bionic-oibaf-ppa) direct render: Yes
Audio: Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Imaging Unit vendor: Lenovo
driver: intel_atomisp2_pm v: kernel bus ID: 00:03.0
Sound Server: ALSA v: k5.3.0-40-generic
Network: Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel port: 1000 bus ID: 01:00.0
Drives: Local Storage: total: 29.12 GiB used: 7.07 GiB (24.3%)
ID-1: /dev/mmcblk0 model: DF4032 size: 29.12 GiB
Partition: ID-1: / size: 27.08 GiB used: 7.06 GiB (26.1%) fs: ext4 dev: /dev/dm-0
ID-2: swap-1 size: 976.0 MiB used: 3.0 MiB (0.3%) fs: swap dev: /dev/dm-1
Sensors: System Temperatures: cpu: 44.0 C mobo: N/A
Info: Processes: 205 Uptime: 19m Memory: 1.81 GiB used: 547.9 MiB (29.6%) Init: systemd runlevel: 5 Compilers: gcc: 7.4.0
Shell: bash v: 4.4.20 inxi: 3.0.32
нету звука - как исправить
нет звука
нет звука
cat /proc/asound/modules
cat /proc/asound/cards
0 snd_hdmi_lpe_audio
1 snd_soc_sst_cht_bsw_rt5645
0 [Audio ]: HdmiLpeAudio - Intel HDMI/DP LPE Audio
1 [chtrt5645 ]: chtrt5645 - chtrt5645
LENOVO-80XF-LenovoMIIX320_10ICR-LNVNB161216
нет звука
У меня была проблема с отсутствием звука когда система "путалась" между 2 источниками.
Попробуйте выполнить в терминале
Цифры 0 и 1 указывают какой источник использовать для вывода звука.
Перезагрузитесь и проверьте звук. Если не помогло, попробуйте с цифрой 1.
Если совсем плохо - удалить созданный файл .asoundrc и придётся предпринимать другие действия.
alsactl init
, после этого создайте в своём домашнем каталоге скрытый файл .asoundrc такого содержания:pcm.!default {
type hw
card 0
ctl.!default {
type hw
card 0
type hw
card 0
ctl.!default {
type hw
card 0
нет звука
Добрый день. Спасибо за помощь. Какаимито своими действиями, вчера, удалось включить звук. Сегодня переустановил и снова звука нет, не получается повторить. команда dmesg выводит несколько красных строчек. Может в этом дело. Ваш способ обязательно попробую. О результатах напишу.
нет звука
добрый день. Ваше решение подошло, система выбирала неверный источник. Единственное я создал файл /etc/asound.conf. ~/.asoundrc - неполучилось. Спасибо за помощь.
Сейчас этот форум просматривают: BLEXBot [Bot] и 3 гостя
