Не работает nvidia x server settings
Naqmon
06 мар 2020, 14:21
<r>1. Версия ОС: Linux mint 19.3 x64 Cinnamon<br/>
Установил систему, после сразу поставил рекомендованный драйвер, но почему-то nvidia x server settings отказывается нормально работать.
<SPOIL><s>
</s>System:<br/>
Host: naqmon-TM1701 Kernel: 5.3.0-40-generic x86_64 bits: 64 compiler: gcc <br/>
v: 7.4.0 Desktop: Cinnamon 4.4.8 Distro: Linux Mint 19.3 Tricia <br/>
base: Ubuntu 18.04 bionic <br/>
Machine:<br/>
Type: Laptop System: Timi product: TM1701 v: N/A serial: <filter> <br/>
Mobo: Timi model: TM1701 v: MP serial: <filter> UEFI: INSYDE <br/>
v: XMAKB5R0P0C07 date: 02/22/2019 <br/>
Battery:<br/>
ID-1: BAT0 charge: 28.1 Wh condition: 55.2/60.0 Wh (92%) <br/>
model: SUNWODA R15B01W status: Charging <br/>
CPU:<br/>
Topology: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP <br/>
arch: Kaby Lake rev: A L2 cache: 6144 KiB <br/>
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28800 <br/>
Speed: 800 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 800 2: 800 <br/>
3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 <br/>
Graphics:<br/>
Device-1: Intel UHD Graphics 620 vendor: Xiaomi driver: i915 v: kernel <br/>
bus ID: 00:02.0 <br/>
Device-2: NVIDIA vendor: Xiaomi driver: N/A bus ID: 01:00.0 <br/>
Display: x11 server: X.Org 1.20.5 driver: modesetting unloaded: fbdev,vesa <br/>
resolution: 1920x1080~60Hz <br/>
OpenGL: renderer: Mesa DRI Intel UHD Graphics 620 (Kabylake GT2) <br/>
v: 4.5 Mesa 19.2.8 direct render: Yes <br/>
Audio:<br/>
Device-1: Intel Sunrise Point-LP HD Audio vendor: Xiaomi <br/>
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 <br/>
Sound Server: ALSA v: k5.3.0-40-generic <br/>
Network:<br/>
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: 3000 <br/>
bus ID: 02:00.0 <br/>
IF: wlp2s0 state: up mac: <filter> <br/>
Drives:<br/>
Local Storage: total: 238.47 GiB used: 19.33 GiB (8.1%) <br/>
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB256HAHQ-00000 <br/>
size: 238.47 GiB <br/>
Partition:<br/>
ID-1: / size: 233.24 GiB used: 19.28 GiB (8.3%) fs: ext4 <br/>
dev: /dev/nvme0n1p2 <br/>
Sensors:<br/>
System Temperatures: cpu: 51.0 C mobo: N/A <br/>
Fan Speeds (RPM): N/A <br/>
Info:<br/>
Processes: 230 Uptime: 3h 00m Memory: 7.66 GiB used: 2.36 GiB (30.8%) <br/>
Init: systemd runlevel: 5 Compilers: gcc: 7.4.0 Shell: bash v: 4.4.20 <br/>
inxi: 3.0.32
<e>
</e></SPOIL></r>
06 мар 2020, 14:29
Naqmon
06 мар 2020, 14:38
После всего стало только хуже
06 мар 2020, 14:40
Naqmon писал(а):
06 мар 2020, 14:38
Очень содержательный ответ. Тогда и совет будет похожий. http://button.dekel.ru/
Naqmon
06 мар 2020, 14:49
А что вам нужно отправить. Просто я неопытный в таких делах
06 мар 2020, 14:52
Naqmon писал(а):
06 мар 2020, 14:49
Не свои впечатления. А то что делал , какие команды вводил , какие результаты получал. И всё это подтверждать текстами от системы и скринами.
Naqmon
06 мар 2020, 15:02
Делал всё строго по инструкции, которую вы мне предоставили
1)Добавил репозиторий
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt update
naqmon@naqmon-TM1701:~$ sudo add-apt-repository ppa:graphics-drivers/ppa
[sudo] password for naqmon:
You are about to add the following PPA:
Fresh drivers from upstream, currently shipping Nvidia.
## Current Status
Current long-lived branch release: `nvidia-430` (430.40)
Dropped support for Fermi series (https://nvidia.custhelp.com/app/answers ... /a_id/4656)
Old long-lived branch release: `nvidia-390` (390.129)
For GF1xx GPUs use `nvidia-390` (390.129)
For G8x, G9x and GT2xx GPUs use `nvidia-340` (340.107)
For NV4x and G7x GPUs use `nvidia-304` (304.137) End-Of-Life!
Support timeframes for Unix legacy GPU releases:
https://nvidia.custhelp.com/app/answers ... /a_id/3142
## What we're working on right now:
- Normal driver updates
- Help Wanted: Mesa Updates for Intel/AMD users, ping us if you want to help do this work, we're shorthanded.
## WARNINGS:
This PPA is currently in testing, you should be experienced with packaging before you dive in here:
Volunteers welcome!
### How you can help:
## Install PTS and benchmark your gear:
sudo apt-get install phoronix-test-suite
Run the benchmark:
phoronix-test-suite default-benchmark openarena xonotic tesseract gputest unigine-valley
and then say yes when it asks you to submit your results to openbechmarking.org. Then grab a cup of coffee, it takes a bit for the benchmarks to run. Depending on the version of Ubuntu you're using it might preferable for you to grabs PTS from upstream directly: http://www.phoronix-test-suite.com/?k=downloads
## Share your results with the community:
Post a link to your results (or any other feedback to): https://launchpad.net/~graphics-drivers-testers
Remember to rerun and resubmit the benchmarks after driver upgrades, this will allow us to gather a bunch of data on performance that we can share with everybody.
If you run into old documentation referring to other PPAs, you can help us by consolidating references to this PPA.
If someone wants to go ahead and start prototyping on `software-properties-gtk` on what the GUI should look like, please start hacking!
## Help us Help You!
We use the donation funds to get the developers hardware to test and upload these drivers, please consider donating to the "community" slider on the donation page if you're loving this PPA:
http://www.ubuntu.com/download/desktop/contribute
More info: https://launchpad.net/~graphics-drivers ... ubuntu/ppa
Press Enter to continue or Ctrl+C to cancel
Executing: /tmp/apt-key-gpghome.NRZl3x0pb3/gpg.1.sh --keyserver hkps://keyserver.ubuntu.com:443 --recv-keys 2388FF3BE10A76F638F80723FCAE110B1118213C
gpg: key FCAE110B1118213C: 12 signatures not checked due to missing keys
gpg: key FCAE110B1118213C: public key "Launchpad PPA for Graphics Drivers Team" imported
gpg: Total number processed: 1
gpg: imported: 1
naqmon@naqmon-TM1701:~$ sudo apt update
Hit:1 http://mirror.yandex.ru/ubuntu bionic InRelease
Hit:2 http://mirror.yandex.ru/ubuntu bionic-updates InRelease
Get:3 http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu bionic InRelease [21,3 kB]
Hit:4 http://mirror.yandex.ru/ubuntu bionic-backports InRelease
Hit:5 http://security.ubuntu.com/ubuntu bionic-security InRelease
Hit:6 http://archive.canonical.com/ubuntu bionic InRelease
Get:7 http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu bionic/main amd64 Packages [26,3 kB]
Get:8 http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu bionic/main i386 Packages [17,7 kB]
Hit:9 http://repo.steampowered.com/steam precise InRelease
Get:10 http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu bionic/main Translation-en [7 156 B]
Ign:11 http://mirror.truenetwork.ru/linuxmint-packages tricia InRelease
Hit:12 http://mirror.truenetwork.ru/linuxmint-packages tricia Release
Fetched 72,4 kB in 5s (14,1 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
All packages are up to date.
2)Обновил ядро до последней версии
3)Посмотрел на сайте актуальный драйвер, выбрал его в диспетчере драйверов, перезагрузился
Сейчас стоит свободный драйвер
06 мар 2020, 15:36
Naqmon писал(а):
06 мар 2020, 14:21
первая карта с драйвером.
Naqmon писал(а):
06 мар 2020, 14:21
вторая карта без драйвера. Показывай выводы после манипуляций.
inxi -G и lspci -knn | egrep 'VGA|3D' -A2
Naqmon
06 мар 2020, 16:15
Вот
spoil=]
naqmon@naqmon-TM1701:~$ inxi -G
Device-1: Intel UHD Graphics 620 driver: i915 v: kernel
Device-2: NVIDIA driver: N/A
v: 4.5 Mesa 19.2.8
naqmon@naqmon-TM1701:~$ lspci -knn | egrep 'VGA|3D' -A2
00:02.0 VGA compatible controller [0300]: Intel Corporation UHD Graphics 620 [8086:5917] (rev 07)
Subsystem: Xiaomi UHD Graphics 620 [1d72:1701]
Kernel driver in use: i915
01:00.0 3D controller [0302]: NVIDIA Corporation Device [10de:1d52] (rev a1)
Subsystem: Xiaomi Device [1d72:1701]
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
[/spoil]
Благодарил (а): 794 раза
06 мар 2020, 16:57
Naqmon, это ядро говнистое. Попробуй поставить ядро 5.4 или 5.5. Для этого можно воспользоваться UKUU. Только сначала удали дрова невидии, а перед этим переключись на свободный(в менеджере драйверов)
Удалить можно такой командой
sudo apt purge nvidia*
И уже после того как загрузишься с новым ядром пробуй ставить драйвер.
Naqmon
06 мар 2020, 17:38
вроде пишет, что всё успешно, но я не могу загрузиться с этих версий
06 мар 2020, 18:05
Naqmon, по умолчанию грузиться самое свежее ядро.
Можно настроить меню груб чтоб выбирать какое ядро грузить. Для этого
sudo xed /etc/default/grub
Найти строки
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=0
Привести к виду
#GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=3
Сохранить, закрыть.
Обновить груб
sudo update-grub
Перезагрузиться и выбрать ядро, с которым хочешь загрузиться
Naqmon
06 мар 2020, 18:57
Благодарю, теперь я полностью потерял доступ к системе
no boot device
06 мар 2020, 19:01
Naqmon писал(а):
06 мар 2020, 18:57
no boot device
Проверяй в биосе видел жесткий диск. Случайно никакой флешки не воткнуто?
Вернуться в «Видеокарты»
