Большая нагрузка только на одно ядро и тормоза
Frozenpath
02 мар 2020, 20:51
Host: wolf-E5-575G Kernel: 4.15.0-88-generic x86_64 bits: 64 compiler: gcc
v: 7.4.0 Desktop: Cinnamon 4.4.8 Distro: Linux Mint 19.3 Tricia
base: Ubuntu 18.04 bionic
Type: Laptop System: Acer product: Aspire E5-575G v: V1.20
serial: <filter>
Mobo: Acer model: Ironman_SK v: V1.20 serial: <filter> UEFI: Insyde
v: 1.20 date: 12/13/2016
ID-1: BAT1 charge: 30.5 Wh condition: 30.5/41.4 Wh (74%)
model: PANASONIC AS16A5K status: Full
Topology: Dual Core model: Intel Core i7-7500U bits: 64 type: MT MCP
arch: Kaby Lake rev: 9 L2 cache: 4096 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 23232
Speed: 3500 MHz min/max: 400/3500 MHz Core speeds (MHz): 1: 3500 2: 3500
3: 3500 4: 3500
Device-1: Intel HD Graphics 620 vendor: Acer Incorporated ALI driver: i915
v: kernel bus ID: 00:02.0
Device-2: NVIDIA vendor: Acer Incorporated ALI driver: nvidia v: 390.116
bus ID: 01:00.0
Display: x11 server: X.Org 1.19.6 driver: modesetting,nvidia
unloaded: fbdev,nouveau,vesa resolution: 1366x768~60Hz
OpenGL: renderer: GeForce 940MX/PCIe/SSE2 v: 4.6.0 NVIDIA 390.116
Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
Device-2: NVIDIA vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus ID: 01:00.1
Sound Server: ALSA v: k4.15.0-88-generic
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lite-On driver: ath10k_pci v: kernel port: 4000 bus ID: 03:00.0
vendor: Acer Incorporated ALI driver: r8169 v: 2.3LK-NAPI port: 3000
bus ID: 04:00.1
IF: enp4s0f1 state: down mac: <filter>
Local Storage: total: 1.35 TiB used: 984.79 GiB (71.0%)
ID-1: /dev/sda vendor: Kingston model: SUV500480G size: 447.13 GiB
ID-2: /dev/sdb vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
ID-3: /dev/sdc type: USB vendor: Generic model: Flash Disk size: 7.62 GiB
ID-1: / size: 91.17 GiB used: 17.72 GiB (19.4%) fs: ext4 dev: /dev/sda7
ID-2: /boot size: 464.6 MiB used: 158.3 MiB (34.1%) fs: ext4
dev: /dev/sda5
ID-3: /home size: 145.56 GiB used: 84.86 GiB (58.3%) fs: ext4
dev: /dev/sda8
ID-4: swap-1 size: 9.31 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda6
System Temperatures: cpu: 65.0 C mobo: N/A gpu: nvidia temp: 58 C
Processes: 275 Uptime: 4m Memory: 11.48 GiB used: 2.11 GiB (18.4%)
inxi: 3.0.32
Kernel: 4.15.0-88-generic x86_64 Desktop: Cinnamon 4.4.8 Distro: Linux Mint 19.3
Cуть проблемы. Постоянная нагрузка только на одно ядро. Не зависимо от того, после перезагрузки это, или после какого-то времени использования
Например вот скриншоты после перезагрузки ноутбука. Сразу же видна нагрузка на одно ядро. Нагрузка может варьироваться от 50% до 100%. При этом не видно какого-то процесса, который явно нагружал бы систему. Пытался гуглить, но у людей какой-либо процесс выделялся явно из списка и им удавалось решить проблему.
Скорее всего проблема с железом, но я не могу найти причину куда копать. При чем такая проблема с разными DE - Mate и KDE. Картина один в один. Загружается система. Открываю системный монитор и вижу такую же точно картину. Нагружаемое ядро после каждой перезагрузки может быть разным. То первое, то третье и т.д.
Загружался в Live режиме. Картина не меняется. Пробовал разные дистрибутивы. Mint 19.3, 18.3 с различными DE. Пробовал даже различные Ubuntu в Live режиме.
Но что интересно, загружался в Live режиме Manjaro и там такой проблемы не видно. Все отлично. Нагрузка по ядрам распределяется равномерно.
Пробовал разные ядра. 4.15, 5.0, 5.3. Результат всегда одинаковый.
Также после некоторого времени использования начинаются лаги. Все подвисает, загружается дольше. Страницы в браузере могут скролиться рывками.
Сломал голову в чем может быть дело. Подскажите, пожалуйста, куда копать, какие логи какими командами смотреть.
Заранее спасибо.
Решение Frozenpath » 23 мар 2020, 12:43
Спустя какое-то время экспериментов решил отписаться.
HDD пробовал отключать - это никак не влияло.
Как-то раз ноутбук не вышел из режима ожидания с ошибкой irq 16 nobody cared (try booting with the irqpoll option)
Собственно добавил irqpoll в загрузку. И о чудо. Проблема исчезла напрочь. Система летает. Нагрузок на одно ядро нет. Все отлично работает.
В любом случае спасибо всем, кто пытался помочь.
Linux Mint 21.3 Cinnamon. Kernel 6.5.0
kutalgin
Благодарил (а): 12 раз
02 мар 2020, 21:45
Что-то с видеодрайвером, видно что с иксами грузит систему. Попробуй на другой версии или свободном.
Ишимбайский
02 мар 2020, 21:55
kutalgin писал(а):
02 мар 2020, 21:45
В лайве нет невидии.
Frozenpath писал(а):
02 мар 2020, 20:51
Пользуйся манжарой, хорошая ОС
Ара Магеддон
Решено: 18
Благодарил (а): 37 раз
02 мар 2020, 22:06
Судя по hw-probe, умирает винт. В процессе умирания запросто может давать подобные симптомы.
Если есть возможность, то попробуй проверить "методом научного тыка": заменить и посмотреть что будет. На глюки видео непохоже.
Почему манжаре всё пофиг - тоже непонятно... :)
В htop заметное расхождение в общей загрузке cpu и нагрузке по процессам.
Попробуй нажать F2 и настроить как на скриншоте - мож получится выловить жрущий процесс.
Frozenpath
03 мар 2020, 06:58
Ара Магеддон писал(а):
02 мар 2020, 22:06
Умирающий HDD подключен как файлопомойка. Система стоит на SSD. Но да, я об этом думал, отключить его и посмотреть как и что будет. В Linux нет какой-либо утилиты, которая постоянно анализирует диски в фоне и которая могла бы давать такие проблемы, сталкиваясь с поврежденным HDD?
Windows 10 (упаси господи), кстати, которая стоит второй системой тоже проблем не вызывает.
Интересный факт. Иногда бывает. Что произошло и сегодня. После ждущего режима (иногда) проблема исчезает. Нагрузка распределяется равномерно. Лаги отсутствуют. Какой-либо закономерности выявить не получается.
MrTowelie
Решено: 8
Благодарил (а): 18 раз
03 мар 2020, 07:16
Если система стоит на SSD, то просто отключите HDD и проверьте, проявляется ли проблема. Если - нет, то проблема связана с HDD.
Лично я встречал, что нагрузка на 1 ядро может быть при копировании чего-то на HDD или с него. (или условного создания кэша файлов из-за которых я отключаю службу поиска в kde)
Судя по вашему отчёту SMART у вас очень много ошибок чтения и уже есть перераспределенные сектора. Обычно, такие HDD рекомендуется заменять. Моё ИМХО, если я вижу хоть 1 перераспределенный сектор, то меняю HDD, но я перестраховываюсь, скорее всего.
Обычно, такая утилита для анализа состояний уже встроена в HDD диски и называется SMART. Через некоторые приложения можно смотреть её отчеты (к примеру Gnome Disk Utility), но, чтобы выскакивало прямо предупреждение, о таких не знаю.
Frozenpath
23 мар 2020, 12:43
Алексей-bass
Благодарил (а): 2 раза
12 дек 2020, 13:35
скажи, плз, как его включить, этот irqpoll. У меня такая же проблема :dash2:
Белый Кролик
Решено: 10
Благодарил (а): 354 раза
12 дек 2020, 13:43
Алексей-bass, открываешь терминал и пишешь:
sudo nano /etc/default/grub
Находишь строчку GRUB_CMDLINE_LINUX_DEFAULT="quiet splash", после splash ставишь пробел и дописываешь опцию. Должно быть так:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash irqpoll"
Сохраняешь: ctrl+x, выходишь: ctrl+o, обновляешь grub:
sudo update-grub
и перезагружаешь компьютер.
Белый Кролик
Решено: 10
12 дек 2020, 13:49
Вернее сохраняешь ctrl+o, выходишь ctrl+x :-D
Алексей-bass
12 дек 2020, 13:58
Белый Кролик писал(а):
12 дек 2020, 13:49
Спасибо! Он и так запросил сохранение при выходе) Вроде лучше стало, время покажет :smile:
