FTL: Faster Than Light стимовская - черный экран
Vestgar
28 фев 2020, 19:07
1. LM 19.3 x64
2.cinnamon
3.
Host: vestgar-HP-Pavilion-g6-Notebook-PC Kernel: 5.3.0-40-generic x86_64
bits: 64 compiler: gcc v: 7.4.0 Desktop: Cinnamon 4.4.8
Type: Laptop System: Hewlett-Packard product: HP Pavilion g6 Notebook PC
v: 0594110000204610000610100 serial: <filter>
Mobo: Hewlett-Packard model: 3567 v: 21.09 serial: <filter>
BIOS: Hewlett-Packard v: F.20 date: 05/06/2011
Topology: Quad Core model: AMD A6-3400M APU with Radeon HD Graphics
bits: 64 type: MCP arch: Fusion L2 cache: 4096 KiB
flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 11179
Speed: 802 MHz min/max: 800/1400 MHz Core speeds (MHz): 1: 801 2: 801
3: 802 4: 829
Device-1: AMD BeaverCreek [Radeon HD 6520G] vendor: Hewlett-Packard
driver: radeon v: kernel bus ID: 00:01.0
Device-2: AMD Seymour [Radeon HD 6400M/7400M Series]
vendor: Hewlett-Packard driver: radeon v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.20.5 driver: ati,radeon
unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
OpenGL: renderer: AMD SUMO (DRM 2.50.0 / 5.3.0-40-generic LLVM 9.0.0)
v: 3.3 Mesa 19.2.8 direct render: Yes
Device-1: AMD BeaverCreek HDMI Audio [Radeon HD 6500D and 6400G-6600G
series]
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:01.1
Device-2: AMD FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus ID: 00:14.2
Sound Server: ALSA v: k5.3.0-40-generic
Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter
vendor: Hewlett-Packard driver: ath9k v: kernel port: 3000 bus ID: 02:00.0
Device-2: Realtek RTL810xE PCI Express Fast Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel port: 2000 bus ID: 03:00.0
IF: eno1 state: down mac: <filter>
Device-3: Atheros AR3011 Bluetooth type: USB driver: btusb bus ID: 7-1:3
Local Storage: total: 465.76 GiB used: 88.09 GiB (18.9%)
ID-1: /dev/sda vendor: Seagate model: ST9500325AS size: 465.76 GiB
ID-1: / size: 457.45 GiB used: 88.09 GiB (19.3%) fs: ext4 dev: /dev/sda1
System Temperatures: cpu: 47.6 C mobo: N/A
GPU: device: radeon temp: 48 C device: radeon temp: 50 C
Processes: 203 Uptime: 1h 19m Memory: 7.26 GiB used: 1.79 GiB (24.7%)
inxi: 3.0.32
4. Запускается и черное окно, музыка играет, слышно звук курсора при попадании на пункты меню, при попытке поставить вулкан окно превращается в кучу непонятного .
5.
Решение rogoznik » 28 фев 2020, 19:32
symon2014, в 19.х минте не поставит он старую проприетарь. Это можно было провернуть в 18.х с танцами, в 17.х просто из менеджера драйверов.
28 фев 2020, 19:18
Vestgar писал(а):
28 фев 2020, 19:07
Что запускается , и где чёрное окно?
Linux Mint 19 и amdgpu
Благодарил (а): 794 раза
28 фев 2020, 19:23
symon2014, на этой железке amdgpu не взлетит - очень старое она для этого
Vestgar
28 фев 2020, 19:24
28 фев 2020, 19:18
Vestgar писал(а):
28 фев 2020, 19:07
запускается игра в окне, и там при первом запуске черный экран, при втором просто набор каких то цветов
28 фев 2020, 19:30
28 фев 2020, 19:32
28 фев 2020, 19:33
rogoznik, ссылка выше как раз об этом.
Vestgar
28 фев 2020, 19:40
28 фев 2020, 19:30
тогда так Как установить драйвер для HD7670m
печаль беда, спасибо, пойду искать старые минты
28 фев 2020, 19:49
Vestgar писал(а):
28 фев 2020, 19:40
а че их искать https://mirror.yandex.ru/linuxmint/stable/
Vestgar
28 фев 2020, 19:55
28 фев 2020, 19:49
Vestgar писал(а):
28 фев 2020, 19:40
благодарю :thumbs: :tux:
Вернуться в «Игры»
