System: Host: mg-pc Kernel: 5.3.0-40-generic x86_64 bits: 64 compiler: gcc v: 7.4.0 Desktop: Cinnamon 4.4.8 Distro: Linux Mint 19.3 Tricia base: Ubuntu 18.04 bionic Machine: Type: Laptop System: ASUSTeK product: X540SC v: 1.0 serial: <filter> Mobo: ASUSTeK model: X540SC v: 1.0 serial: <filter> UEFI: American Megatrends v: X540SC.301 date: 09/20/2016 Battery: ID-1: BAT0 charge: 18.4 Wh condition: 18.5/33.2 Wh (56%) model: ASUSTeK X550A26 status: Unknown CPU: Topology: Quad Core model: Intel Pentium N3700 bits: 64 type: MCP arch: Airmont rev: 3 L2 cache: 1024 KiB flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 12800 Speed: 1673 MHz min/max: 480/2400 MHz Core speeds (MHz): 1: 1445 2: 1479 3: 2297 4: 2135 Graphics: Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Integrated Graphics vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0 Device-2: NVIDIA GK107M [GeForce 810M] driver: nouveau v: kernel bus ID: 01:00.0 Display: x11 server: X.Org 1.20.5 driver: modesetting unloaded: fbdev,vesa resolution: 1366x768~60Hz OpenGL: renderer: Mesa DRI Intel HD Graphics 405 (Braswell) v: 4.5 Mesa 19.2.8 direct render: Yes Audio: Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:1b.0 Device-2: NVIDIA GK107 HDMI Audio driver: snd_hda_intel v: kernel bus ID: 01:00.1 Sound Server: ALSA v: k5.3.0-40-generic Network: Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus ID: 02:00.0 IF: enp2s0 state: down mac: <filter> Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter vendor: AzureWave driver: ath9k v: kernel port: d000 bus ID: 03:00.0 IF: wlp3s0 state: up mac: <filter> Drives: Local Storage: total: 465.76 GiB used: 136.48 GiB (29.3%) ID-1: /dev/sda vendor: Seagate model: ST500LT012-1DG142 size: 465.76 GiB Partition: ID-1: / size: 333.92 GiB used: 136.45 GiB (40.9%) fs: ext4 dev: /dev/sda2 Sensors: System Temperatures: cpu: 6280.0 C mobo: N/A gpu: nouveau temp: 41 C Fan Speeds (RPM): cpu: 3400 Info: Processes: 225 Uptime: 2h 07m Memory: 3.75 GiB used: 2.09 GiB (55.7%) Init: systemd runlevel: 5 Compilers: gcc: 7.4.0 Shell: bash v: 4.4.20 inxi: 3.0.32
fdisk -l
Диск /dev/sda: 465,8 GiB, 500107862016 байт, 976773168 секторов Единицы: секторов по 1 * 512 = 512 байт Размер сектора (логический/физический): 512 байт / 4096 байт Размер I/O (минимальный/оптимальный): 4096 байт / 4096 байт Тип метки диска: gpt Идентификатор диска: 3F1BE253-8EBB-4FFA-9FD7-1F82811E9AE7 Устр-во начало Конец Секторы Размер Тип /dev/sda1 2048 1050623 1048576 512M EFI /dev/sda2 1052672 714631167 713578496 340,3G Файловая система Linux /dev/sda3 714631168 714663935 32768 16M Зарезервированный раздел Microso /dev/sda4 714663936 976773119 262109184 125G Microsoft basic data
dmesg
[ 6982.163655] usb 1-2: USB disconnect, device number 3
[ 7056.521939] usb 1-2: new high-speed USB device number 7 using xhci_hcd
[ 7061.765901] usb 1-2: device descriptor read/64, error -110
[ 7077.381756] usb 1-2: device descriptor read/64, error -110
[ 7077.626358] usb 1-2: new high-speed USB device number 8 using xhci_hcd
[ 7083.013700] usb 1-2: device descriptor read/64, error -110
[ 7098.625709] usb 1-2: device descriptor read/64, error -110
[ 7098.733795] usb usb1-port2: attempt power cycle
[ 7099.389508] usb 1-2: new high-speed USB device number 9 using xhci_hcd
[ 7104.769479] usb 1-2: device descriptor read/64, error -110
[ 7120.385414] usb 1-2: device descriptor read/64, error -110
[ 7120.621347] usb 1-2: new high-speed USB device number 10 using xhci_hcd
[ 7125.761280] usb 1-2: device descriptor read/64, error -110
[ 7141.377182] usb 1-2: device descriptor read/64, error -110
[ 7141.485303] usb usb1-port2: unable to enumerate USB device
