Беспроводная радио Мышка.
Aquilam
29 дек 2016, 12:56
Есть комплект беспроводной радио мыши и клавиатуры. Клавиатура работает, а мышка нет, что делать?
System: Host: 111 Kernel: 3.13.0-24-generic x86_64 (64 bit, gcc: 4.8.2) Desktop: Gnome Distro: Linux Mint 17 Qiana
Machine: Mobo: Intel model: DH55TC version: AAE70932-206
Bios: Intel version: TCIBX10H.86A.0048.2011.1206.1342 date: 12/06/2011
CPU: Quad core Intel Core i7 CPU 870 (-HT-MCP-) cache: 8192 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 23408
Clock Speeds: 1: 1197.00 MHz 2: 1197.00 MHz 3: 1197.00 MHz 4: 1197.00 MHz 5: 1197.00 MHz 6: 1197.00 MHz 7: 1197.00 MHz 8: 1197.00 MHz
Graphics: Card: Advanced Micro Devices [AMD/ATI] Cape Verde XT [Radeon HD 7770/8760 / R7 250X] bus-ID: 01:00.0
X.Org: 1.15.1 drivers: ati,fglrx (unloaded: fbdev,vesa,radeon) Resolution: 1600x900@60.0hz
GLX Renderer: AMD Radeon HD 7700 Series GLX Version: 4.5.13399 - CPC 15.201.1151 Direct Rendering: Yes
Audio: Card-1: Intel 5 Series/3400 Series Chipset High Definition Audio driver: snd_hda_intel bus-ID: 00:1b.0
Card-2: Advanced Micro Devices [AMD/ATI] Cape Verde/Pitcairn HDMI Audio [Radeon HD 7700/7800 Series] driver: snd_hda_intel bus-ID: 01:00.1
Sound: Advanced Linux Sound Architecture ver: k3.13.0-24-generic
Network: Card: Intel 82578DC Gigabit Network Connection driver: e1000e ver: 2.3.2-k port: f020 bus-ID: 00:19.0
IF: eth0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives: HDD Total Size: 540.1GB (4.2% used) 1: id: /dev/sda model: OCZ size: 40.0GB
2: id: /dev/sdb model: SAMSUNG_HD502HJ size: 500.1GB
Partition: ID: / size: 29G used: 22G (78%) fs: ext4 ID: swap-1 size: 8.52GB used: 0.00GB (0%) fs: swap
RAID: No RAID devices detected - /proc/mdstat and md_mod kernel raid module present
Sensors: System Temperatures: cpu: 30.0C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 224 Uptime: 58 min Memory: 1257.7/7917.7MB Runlevel: 2 Gcc sys: 4.8.4 Client: Shell inxi: 1.8.4
Re: Беспроводная радио Мышка.
29 дек 2016, 13:12
что покажет?
Aquilam
29 дек 2016, 13:16
Bus 002 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 003: ID 09da:000a A4Tech Co., Ltd. Optical Mouse Opto 510D / OP-620D
Bus 001 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
оптическая мышь A4tech , временная, пока пытаюсь эту настроить.
29 дек 2016, 13:18
надо как раз чтоб была подключена та во время команды )
Aquilam
29 дек 2016, 13:23
в том то и дело, что она включена! она на аккумуляторах, индикаторы мигаюот, реагируют на нажание кнопок и передвижение мыши. Но на компьютере никакой реакции.
29 дек 2016, 13:30
даже клавы не видать. Клава то тоже через свисток? в usb гнездо.
29 дек 2016, 13:30
вот к примеру мой вариант
$ lsusb
Bus 002 Device 002: ID 8087:8000 Intel Corp.
Bus 001 Device 002: ID 8087:8008 Intel Corp.
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 005: ID 13d3:5188 IMC Networks
Bus 003 Device 003: ID 13d3:3474 IMC Networks Atheros AR3012 Bluetooth
Bus 003 Device 006: ID 062a:4101 Creative Labs Wireless Keyboard/Mouse
Bus 003 Device 004: ID 09da:0260 A4Tech Co., Ltd. KV-300H Isolation Keyboard
Bus 003 Device 008: ID 04a9:2774 Canon, Inc.
Bus 003 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
У меня клава в usb, а беспроводная мышь уже в usb клавы )
Aquilam
29 дек 2016, 13:42
Клава включена и прекрасно работает, у них с мышкой один и тот же радиопередатчик. И, этот передатчик полдключается к матери раздвоенным кабелем, один выход ЮСБ (для мыши) второй ччерез специльаный порт для клавиатуры, не ЮСБ.
29 дек 2016, 13:46
Aquilam писал(а): один выход ЮСБ (для мыши)
Вот тут как раз ошибочка. по USB это не для мыши, а от USB получается берется питание. Основной порт второй, а уж какой - это загадка )
Aquilam
29 дек 2016, 13:50
Он там один, круглый такой )старинный ))
29 дек 2016, 13:52
Aquilam писал(а): Он там один, круглый такой )старинный ))
Видимо ps/2
29 дек 2016, 13:54
Тут варианта 2. 1 - возможно нужен USB 3.0 2 - нужны спец дрова. А вообще лучше купите синезубый комплект. Он стопудово будет работать. Но я непротив послушать и другие мнения. :crazy:
adargeos
Решено: 8
Благодарил (а): 21 раз
29 дек 2016, 13:56
Фиолетовый PS/2? Это не старинный. Старинным можно было орехи колоть.
29 дек 2016, 13:57
adargeos писал(а): Старинным можно было орехи колоть.
поподробней, пожалуйста! :crazy:
adargeos
Решено: 8
29 дек 2016, 14:01
Для сравнения переходник с ps/2 на AT
29 дек 2016, 14:06
Aquilam, это вполне может быть просто выбор ( или в юсб или в старый разъём ), думаю подсоединять нужно только 1.
adargeos
Решено: 8
29 дек 2016, 14:09
А если этот разъем зеленый, а не фиолетовый, его вообще нужно в порт мыши пихать
Aquilam
29 дек 2016, 14:17
Порт этот у меня, разделен двумя цветами, видимо он универсальный. Он наполовину фиолетовый наполовину зеленый. Пробовал подключать толкьо ЮСБ, тогда не работает ничего, ни клава ни мышка. Без ЮСБ только клава, как и с ЮСб.... Поэтому пришел к выводу что один выход для мышиЮ второй для клавы.
29 дек 2016, 14:21
Aquilam, а можешь выложить фотку с разъемами этого комбайна? (я про передатчик от клавы-мыши)
Aquilam
29 дек 2016, 14:27
Да, конечно.
