Звуковая карта, не хочет воспроизводить звук. Так же, не работает микрофон.
Aquilam
29 дек 2016, 12:55
System: Host: 111 Kernel: 3.13.0-24-generic x86_64 (64 bit, gcc: 4.8.2) Desktop: Gnome Distro: Linux Mint 17 Qiana
Machine: Mobo: Intel model: DH55TC version: AAE70932-206
Bios: Intel version: TCIBX10H.86A.0048.2011.1206.1342 date: 12/06/2011
CPU: Quad core Intel Core i7 CPU 870 (-HT-MCP-) cache: 8192 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 23408
Clock Speeds: 1: 1197.00 MHz 2: 1197.00 MHz 3: 1197.00 MHz 4: 1197.00 MHz 5: 1197.00 MHz 6: 1197.00 MHz 7: 1197.00 MHz 8: 1197.00 MHz
Graphics: Card: Advanced Micro Devices [AMD/ATI] Cape Verde XT [Radeon HD 7770/8760 / R7 250X] bus-ID: 01:00.0
X.Org: 1.15.1 drivers: ati,fglrx (unloaded: fbdev,vesa,radeon) Resolution: 1600x900@60.0hz
GLX Renderer: AMD Radeon HD 7700 Series GLX Version: 4.5.13399 - CPC 15.201.1151 Direct Rendering: Yes
Audio: Card-1: Intel 5 Series/3400 Series Chipset High Definition Audio driver: snd_hda_intel bus-ID: 00:1b.0
Card-2: Advanced Micro Devices [AMD/ATI] Cape Verde/Pitcairn HDMI Audio [Radeon HD 7700/7800 Series] driver: snd_hda_intel bus-ID: 01:00.1
Sound: Advanced Linux Sound Architecture ver: k3.13.0-24-generic
Network: Card: Intel 82578DC Gigabit Network Connection driver: e1000e ver: 2.3.2-k port: f020 bus-ID: 00:19.0
IF: eth0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives: HDD Total Size: 540.1GB (4.2% used) 1: id: /dev/sda model: OCZ size: 40.0GB
2: id: /dev/sdb model: SAMSUNG_HD502HJ size: 500.1GB
Partition: ID: / size: 29G used: 22G (78%) fs: ext4 ID: swap-1 size: 8.52GB used: 0.00GB (0%) fs: swap
RAID: No RAID devices detected - /proc/mdstat and md_mod kernel raid module present
Sensors: System Temperatures: cpu: 30.0C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 224 Uptime: 58 min Memory: 1257.7/7917.7MB Runlevel: 2 Gcc sys: 4.8.4 Client: Shell inxi: 1.8.4
svm
Благодарил (а): 115 раз
Re: Звуковая карта, не хочет воспроизводить звук. Так же, не работает микрофон.
29 дек 2016, 13:06
ну у тебя две карты,(видимо по умолчанию встаёт не то что надо)
переключи вывод на нужное устройство/карту/порт
у меня было так
viewtopic.php?f=27&t=445
29 дек 2016, 13:07
Aquilam писал(а): Audio: Card-1: Intel 5 Series/3400 Series Chipset High Definition Audio driver: snd_hda_intel bus-ID: 00:1b.0
1 - уточните DE. 2 - посмотрите в параметрах звука. Может у вас в качестве выходного устройства выбрана не та карта. (тем более если и микрофон не работает, то это очевидно).
3 - можете глянуть такой вариант.
Aquilam
29 дек 2016, 13:21
Что за DE?
Вот, я так и подумал что нужно переключиться на внешнюю звуковую карту, но как это сделать я не знаю.
29 дек 2016, 13:24
Aquilam писал(а): Что за DE?
DE - Desktop environment (Русский) Среда рабочего стола предоставляет полнофункциональное графическое окружение для системы, включающее набор графических приложений, утилит и компонентов рабочего стола. Как правило, среды рабочего стола базируются на одном из графических тулкитов, таких как GTK+ или Qt. (KDE, xfce, mate, cinnamon).
Aquilam писал(а): но как это сделать я не знаю
В теме, указанной svm есть скрины с параметрами звука, где меняется карта.
Aquilam
29 дек 2016, 13:56
Я видел скрины и первым делом попробовал зайти туда и переключить, но там нет такого )
29 дек 2016, 14:00
Aquilam, DE то какое?
29 дек 2016, 14:44
параметры
микрофон - на вкладке "Ввод"
Aquilam
29 дек 2016, 16:27
В общем, хрен с ней со звуковой картой... Буду на встроенной. Всем спасибо.
Видит карту, но при переключении на нее, звук все равно не воспроизводится. Даже вкладка настроек с ней, пустая. Скорее всего драйвера криво встали, или не встали вообще.
29 дек 2016, 16:55
Ну а скрин то с настройками где? :crazy:
Aquilam
29 дек 2016, 17:21
Да формат скриншотов - png ) сюда не заливаются)
29 дек 2016, 17:26
Aquilam, заливаются
Aquilam
29 дек 2016, 17:37
Вот, имя надо сменить)
svm
29 дек 2016, 18:03
Aquilam писал(а):В общем, хрен с ней со звуковой картой... Буду на встроенной. Всем спасибо.
не тот профиль встаёт
я дал ссылку,но у меня мате
я тоже всю жизнь на виде,вроде и не тормоз,
Последний раз редактировалось пользователем 1 Dja; всего редактировалось раз: 30
Причина: цензура
29 дек 2016, 19:21
Aquilam, судя по скринам - звук не идет по HDMI но работает с задней панели на материнке, верно?
Отдельной звуковой карты я не наблюдаю в этой конфигурации, есть звуковуха встроенная и есть hdmi вывод с видака
30 дек 2016, 11:10
такое ощущение, что не 18.1...
30 дек 2016, 13:10
Dja писал(а): такое ощущение, что не 18.1...
17. См. #1. Хотя особо роли не играет. Принцип тот-же.
04 янв 2017, 03:08
я hdmi за аудио то не считаю ) По сути вижу только одну звуковуху.
Вернуться в «Звуковые карты»
