Проблема подключения сетевого сканера МФУ Epson L366 на Mint 19.2 Cinnamon
Kinder_Pingui
09 фев 2020, 13:58
Принтер подключился без проблем, а как сканер подключить, нет понимания. На сайте производителя вместо драйвера pdf-файл на английском или китайском на выбор. Все инструкции, найденные мной в интернете зашиты на то, что дровишки у меня есть :dash2:
09 фев 2020, 14:04
sane-find-scanner
и не жми инфу о железе и системе , телепаты на зимних каникулах.
Kinder_Pingui
09 фев 2020, 14:27
09 фев 2020, 14:04
sane-find-scanner
И что мне с этой шнягой делать?
09 фев 2020, 14:29
Kinder_Pingui писал(а):
09 фев 2020, 14:27
Всунуть в терминал и показать , что получится.
Kinder_Pingui
09 фев 2020, 14:32
09 фев 2020, 14:29
# sane-find-scanner will now attempt to detect your scanner. If the
# result is different from what you expected, first make sure your
# scanner is powered up and properly connected to your computer.
# No SCSI scanners found. If you expected something different, make sure that
# you have loaded a kernel SCSI driver for your SCSI adapter.
could not open USB device 0x1d6b/0x0003 at 002:001: Access denied (insufficient permissions)
could not open USB device 0x0bda/0x57b5 at 001:003: Access denied (insufficient permissions)
could not open USB device 0x046d/0xc077 at 001:002: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0002 at 001:001: Access denied (insufficient permissions)
# No USB scanners found. If you expected something different, make sure that
# you have loaded a kernel driver for your USB host controller and have setup
# the USB system correctly. See man sane-usb for details.
# Not checking for parallel port scanners.
# Most Scanners connected to the parallel port or other proprietary ports
# can't be detected by this program.
# You may want to run this program as root to find all devices. Once you
# found the scanner devices, be sure to adjust access permissions as
# necessary.
09 фев 2020, 14:34
тоже самое с sudo
Kinder_Pingui
09 фев 2020, 14:37
09 фев 2020, 14:34
тоже самое с sudo
09 фев 2020, 14:48
Ещё пару выводов , lsusb и введи отдельно simple-scan
Kinder_Pingui
09 фев 2020, 14:52
09 фев 2020, 14:48
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 0bda:57b5 Realtek Semiconductor Corp.
Bus 001 Device 002: ID 046d:c077 Logitech, Inc. M105 Optical Mouse
Сканеры не обнаружены
09 фев 2020, 14:54
Kinder_Pingui, так и принтеры тоже , оно вообще включено?
Kinder_Pingui
09 фев 2020, 14:56
09 фев 2020, 14:54
Включено, работает, принтер печатает.
09 фев 2020, 14:57
09 фев 2020, 14:56
В USB он не определился , как подключен?
Kinder_Pingui
09 фев 2020, 15:00
09 фев 2020, 14:57
как подключен?
По wi-fi. И сканер тоже нужен по сети.
09 фев 2020, 15:08
09 фев 2020, 15:00
Я тебе щас иголки под ногти воткну , партизан . Опиши ситуацию подробней , про телепатов я уже говорил. :evil:
Kinder_Pingui
09 фев 2020, 15:25
09 фев 2020, 15:08
Поставила вчера Линух, до этого всю жизнь в окне торчала. Вроде все гладко было до момента подключения МФУ. Принтер без проблем нашла и подключила через Меню- Параметры- Принтеры- Добавить- Сетевой принтер, а со сканером толку дать не могу.
Kinder_Pingui
09 фев 2020, 15:30
Проблема в том, что я в принципе не знаю, как это сделать. :blush:
09 фев 2020, 15:30
09 фев 2020, 15:25
Да уж , не Джоан Роулинг. Возможно потребуется отдельный драйвер для сканера. Для установки и настройки будет нужно непосредственное подключение к компу.
Kinder_Pingui
09 фев 2020, 15:37
09 фев 2020, 15:30
Т.е. Без провода никак? Его собака сожрала (
09 фев 2020, 15:47
09 фев 2020, 15:37
Съесть её. :-D
Kinder_Pingui
09 фев 2020, 15:48
09 фев 2020, 15:30
драйвер для сканера
На сайте Epson нет драйвера для Линукс. Перенаправляют на другой сайт, там два PDF на китайском и на английском.
http://download.ebz.epson.net/dsc/searc ... FromResult
