Зависание системы в любой момент.
sched
07 фев 2020, 21:43
1. Linux mint 19.3 32bit
2.
Host: sched-pc Kernel: 5.3.0-28-generic i686 bits: 32 compiler: gcc
v: 7.4.0 Desktop: Cinnamon 4.4.8 Distro: Linux Mint 19.3 Tricia
base: Ubuntu 18.04 bionic
Type: Desktop System: O.E.M product: O.E.M v: N/A serial: <filter>
Mobo: FOXCONN model: G41MX 2.0/G41MX-K 2.0 v: 1.0 serial: <filter>
BIOS: American Megatrends v: 080015 date: 01/27/2010
Topology: Dual Core model: Pentium E6500 bits: 64 type: MCP arch: Penryn
rev: A L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 ssse3 vmx bogomips: 11733
Speed: 2822 MHz min/max: N/A Core speeds (MHz): 1: 2822 2: 2737
Device-1: Intel 4 Series Integrated Graphics vendor: Foxconn driver: i915
v: kernel bus ID: 00:02.0
Display: x11 server: X.Org 1.20.5 driver: modesetting unloaded: fbdev,vesa
resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel G41 x86/MMX/SSE2 v: 2.1 Mesa 19.2.8
Device-1: Intel NM10/ICH7 Family High Definition Audio vendor: Foxconn
Sound Server: ALSA v: k5.3.0-28-generic
vendor: Foxconn driver: r8169 v: kernel port: e800 bus ID: 02:00.0
Device-2: Realtek RTL8192CU 802.11n WLAN Adapter type: USB
driver: rtl8192cu bus ID: 1-1:2
IF: wlx60e3270d5f46 state: up mac: <filter>
Local Storage: total: 409.88 GiB used: 14.56 GiB (3.6%)
ID-1: /dev/sda vendor: Seagate model: ST3320418AS size: 298.09 GiB
ID-2: /dev/sdb vendor: Western Digital model: WD1200BEVS-22UST0
ID-1: / size: 27.37 GiB used: 12.79 GiB (46.7%) fs: ext4 dev: /dev/sda5
ID-2: /home size: 71.74 GiB used: 1.49 GiB (2.1%) fs: ext4 dev: /dev/sda7
ID-3: swap-1 size: 1.91 GiB used: 289.8 MiB (14.8%) fs: swap
dev: /dev/sda6
System Temperatures: cpu: 78.0 C mobo: N/A
Processes: 178 Uptime: 53m Memory: 1.77 GiB used: 1.42 GiB (80.1%)
inxi: 3.0.32
3.В любой момент ( не зависимо от действий) система может полностью зависнуть. При этом курсором двигать можно. Помогает только отключение удлинителя и перезагрузка.
07 фев 2020, 22:26
как минимум сменить DE
07 фев 2020, 22:29
Обратите внимание на индикатор жесткого диска во время такого подвисания. Если он в это время горит постоянно (или почти постоянно) - система уходит свопинг от недостатка памяти (вероятность 95%, остальные 5% - винчестер дохнет). Тут только немедленно убрать руки от клавиатуры с мышью и дать системе закончить этот процесс - закончит, отвиснет. Но это может занять несколько минут, и любое действие в этот момент лишь усугубит ситуацию. Радикально лечится только добавлением памяти в машину.
А вот если винчестер в этот момент не работает - тогда какие-то проблемы с железом скорее всего.
sched
07 фев 2020, 22:47
slant, Проблема в том, что на винде такого нет. Из этого следует, что это точно не железо.
sched
07 фев 2020, 22:50
slant, и при этом это не зависит от недостатка памяти, у меня может быть включен только монитор ресурсов и при этом повиснуть система, хотя свободной памяти еще много.
sched
07 фев 2020, 22:51
rogoznik, что это и как это сделать. Не столь сильно разбираюсь в линуксе.
Whowka
Благодарил (а): 777 раз
07 фев 2020, 23:18
sched писал(а):
07 фев 2020, 22:51
DE это окружение "рабочего стола". В "MINT"е бувает:"Cinnamon", "Mate" и "XFCE"(на сегодняшнее время). "Cinnamon" самоежрущеепамять (пишетца слитно) окружение. А "как сделать": гугль (или яндекс) расскажет :smile:
Благодарил (а): 406 раз
07 фев 2020, 23:23
sched, не плоди много постов, - добавляй в один. Там справа вверху есть карандашик , его жми и добавляй, будь ласка!
strannik
08 фев 2020, 00:41
Если зависает в Windows, то проблема решается подбором драйверов.
А в Линуксе придётся перебирать дистрибутивы. Попробуй МХ, Росу, POP-OS.
Я исхожу из личного опыта.
08 фев 2020, 01:19
sched писал(а):
07 фев 2020, 22:50
Вот не надо. Много у вас ее в принципе быть не может, никак. У вас всего 2 гигабайта памяти в машине. Для 19-го минта - это критично мало. 600-800 мегабайт занимает сама система сразу после старта. Любой современный броузер отжирает еще как минимум гигабайт, а чаще - 1.5-2 даже при открытии всего 2-3 страниц. Скайп, viber, и еще часть мессендеров которые ныне используют платформу electron - это как минимум от 200-от мегабайт просто по факту запуска. Собственно даже в вашем выводе inxi: 1.42 гигабайт занято (80% от доступного), и еще ~300 уже в свапе. Причем в качестве видеоадаптера у вас intel, а значит видеопамять вычитается из обычной. Это еще минус 200-300 мегабайт сразу, а возможно и больше - если 3D активно задействовано.
Так что смотрите следующий раз на винчестер. Если активен - это именно оно.
Если же все-таки настаиваете что память тут не причем - у меня для вас плохие новости. Такие симптомы еще могут быть при умирающем винчестере. Проверить так: ставите пакет smartmontools (если еще не стоит), и даете команды в консоли:
sudo smartctl -a /dev/sda
sudo smartctl -a /dev/sdb
Вывод команд - сюда. Посмотрим.
