Прокрутка на тачпаде elan
MrNekitoshka
04 фев 2020, 13:52
Здравствуйте. Установлена mint cinnanomon 19.3 64bit на ноут lenovo g505s. Тачпад elan, вывод xinput и dmesg:
$ xinput
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ Logitech K230 id=9 [slave pointer (2)]
⎜ ↳ Logitech M510 id=10 [slave pointer (2)]
⎜ ↳ ETPS/2 Elantech Touchpad id=14 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Power Button id=8 [slave keyboard (3)]
↳ Lenovo EasyCamera: Lenovo EasyC id=11 [slave keyboard (3)]
↳ Ideapad extra buttons id=12 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=13 [slave keyboard (3)]
↳ Logitech K230 id=15 [slave keyboard (3)]
$ dmesg | grep elan
[ 3.834607] psmouse serio1: elantech: assuming hardware version 3 (with firmware version 0x450f03)
[ 3.877432] psmouse serio1: elantech: Synaptics capabilities query result 0x78, 0x17, 0x0b.
[ 3.920368] psmouse serio1: elantech: Elan sample query result 04, 5c, 85
System: Host: Lenovo-G505s-Mint Kernel: 5.3.0-28-generic x86_64 bits: 64 compiler: gcc v: 7.4.0 Desktop: Cinnamon 4.4.8
Machine: Type: Laptop System: LENOVO product: 20255 v: Lenovo G505s serial: <filter>
Mobo: LENOVO model: Lenovo G505s v: 31900004Std serial: <filter> UEFI: LENOVO v: 83CN53WW(V3.00) date: 01/08/2014
Battery: ID-1: BAT1 charge: 38.8 Wh condition: 57.5/63.4 Wh (91%) model: SANYO PABAS0241231 status: Discharging
CPU: Topology: Quad Core model: AMD A10-5750M APU with Radeon HD Graphics bits: 64 type: MCP arch: Piledriver rev: 1
L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 19962
Speed: 1260 MHz min/max: 1400/2500 MHz Core speeds (MHz): 1: 1304 2: 1333 3: 1279 4: 1270
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Richland [Radeon HD 8650G] vendor: Lenovo driver: radeon v: kernel
bus ID: 00:01.0
Display: x11 server: X.Org 1.20.5 driver: ati,radeon unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
OpenGL: renderer: AMD ARUBA (DRM 2.50.0 / 5.3.0-28-generic LLVM 9.0.0) v: 4.3 Mesa 19.2.8 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Trinity HDMI Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus ID: 00:01.1
Device-2: Advanced Micro Devices [AMD] FCH Azalia vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 00:14.2
Sound Server: ALSA v: k5.3.0-28-generic
Network: Device-1: Qualcomm Atheros QCA8172 Fast Ethernet vendor: Lenovo driver: alx v: kernel port: 2000 bus ID: 01:00.0
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter vendor: Lenovo driver: ath9k v: kernel
port: 2000 bus ID: 02:00.0
Drives: Local Storage: total: 1.13 TiB used: 24.94 GiB (2.2%)
ID-1: /dev/sda vendor: SanDisk model: SSD PLUS 240GB size: 223.58 GiB
ID-2: /dev/sdb vendor: Seagate model: ST1000LM024 HN-M101MBB size: 931.51 GiB
Partition: ID-1: / size: 25.99 GiB used: 13.42 GiB (51.6%) fs: ext4 dev: /dev/sda6
ID-2: /home size: 19.56 GiB used: 1.41 GiB (7.2%) fs: ext4 dev: /dev/sda1
ID-3: /var size: 4.74 GiB used: 803.7 MiB (16.5%) fs: ext4 dev: /dev/sda5
Sensors: Missing: Required tool sensors not installed. Check --recommends
Info: Processes: 217 Uptime: 19m Memory: 5.02 GiB used: 2.13 GiB (42.5%) Init: systemd runlevel: 5 Compilers: gcc: 7.4.0
Shell: bash v: 4.4.20 inxi: 3.0.32
Всё работает, тачпад конфигурируется через gui в настройках, но вот прокрутка двумя пальцами ведёт себя очень странно, а именно скроллит рывками (прокрутка с мышки плавная, но тут возможно заслуга логитеча и встроенного в свисток ПО).
Что можно с этим сделать, может где-то есть конфигурация, которой нет в gui? В винде стояло что-то пропиентарное с настройкой мультикасаний, работало сносно. На сайте производителя ноута, естественно, дров под линукс нет :).
04 фев 2020, 17:17
Есть подозрение, что вам может помочь настройка через synclient параметров FingerLow и FingerHigh. Подобрать, и запихнуть вызов в автостарт при входе в систему.
Подробные материалы тут: https://wiki.archlinux.org/index.php/To ... _(Русский)
(Не смотрите на упоминание synaptic в ссылке - этот же драйвер и другие тачпады обслуживает.)
MrNekitoshka
15 фев 2020, 19:44
04 фев 2020, 17:17
Не совсем понял как мне конфигурировать synclient, его у меня вроде бы нет.
15 фев 2020, 19:50
MrNekitoshka, ссылку то читали?
