Перестал подключаться телефон
Restart1566
27 дек 2016, 14:51
Проблема вот в чем.
После перехода на 17.3 и затем выше перестал подключаться телефон как флэшка. Вроде и буквы присваиваются, но дисками он не видится.
Вывод dmesg
[527504.976019] usb 3-1: new full-speed USB device number 2 using uhci_hcd
[527505.403047] usb 3-1: New USB device found, idVendor=0e8d, idProduct=0002
[527505.403051] usb 3-1: New USB device strings: Mfr=2, Product=3, SerialNumber=4
[527505.403053] usb 3-1: Product: Product
[527505.403056] usb 3-1: Manufacturer: MediaTek Inc
[527505.403058] usb 3-1: SerialNumber: 68852320990703f
[527505.409106] usb-storage 3-1:1.0: USB Mass Storage device detected
[527505.409243] scsi host6: usb-storage 3-1:1.0
[527506.433074] scsi 6:0:0:0: Direct-Access MEDIATEK FLASH DISK PQ: 0 ANSI: 0 CCS
[527506.436176] scsi 6:0:0:1: Direct-Access MEDIATEK FLASH DISK PQ: 0 ANSI: 0 CCS
[527506.436684] sd 6:0:0:0: Attached scsi generic sg6 type 0
[527506.437306] sd 6:0:0:1: Attached scsi generic sg7 type 0
[527506.445075] sd 6:0:0:0: [sdf] 15366144 512-byte logical blocks: (7.87 GB/7.33 GiB)
[527506.448073] sd 6:0:0:1: [sdg] 26000 512-byte logical blocks: (13.3 MB/12.7 MiB)
[527506.451058] sd 6:0:0:0: [sdf] Write Protect is off
[527506.451061] sd 6:0:0:0: [sdf] Mode Sense: 03 00 00 00
[527506.454051] sd 6:0:0:1: [sdg] Write Protect is off
[527506.454054] sd 6:0:0:1: [sdg] Mode Sense: 03 00 00 00
[527506.457054] sd 6:0:0:0: [sdf] No Caching mode page found
[527506.457059] sd 6:0:0:0: [sdf] Assuming drive cache: write through
[527506.460106] sd 6:0:0:1: [sdg] No Caching mode page found
[527506.460111] sd 6:0:0:1: [sdg] Assuming drive cache: write through
[527506.778073] sdf: sdf1
[527506.785073] sdg:
[527506.816063] sd 6:0:0:0: [sdf] Attached SCSI removable disk
[527506.819050] sd 6:0:0:1: [sdg] Attached SCSI removable disk
[527506.924076] scsi 6:0:0:0: rejecting I/O to dead device
[527506.924101] Buffer I/O error on dev sdf, logical block 1920767, async page read
[527506.951092] Buffer I/O error on dev sdg, logical block 3200, async page read
[527509.419994] usbcore: registered new interface driver usbserial
[527509.420013] usbcore: registered new interface driver usbserial_generic
[527509.420290] usbserial: USB Serial support registered for generic
[527509.439270] usbcore: registered new interface driver option
[527509.439290] usbserial: USB Serial support registered for GSM modem (1-port)
вывод lsusb
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 002: ID 046d:c045 Logitech, Inc. Optical Mouse
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 002: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 002: ID 0e8d:0002 MediaTek Inc.
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Прошу прощения, не нашел, как отформатировать под код
Заранее спасибо!
 ! Сообщение из: Dja
Под код как правило оформляют либо длинную команду, либо текст скрипта, чтоб его скопировать сразу и вставить. Если же вы просто демонстрируете лог - то это в спойлере
Re: Перестал подключаться телефон
29 дек 2016, 09:32
Что за телефон? Не люмия случаем?
Restart1566
29 дек 2016, 10:52
Philips Xenium E560
29 дек 2016, 10:59
В параметрах стоит "Использовать USB для передачи данных (или отладка)"?
29 дек 2016, 11:28
Restart1566, mtp установлен?
Restart1566
29 дек 2016, 14:08
Dja писал(а):В параметрах стоит "Использовать USB для передачи данных (или отладка)"?
В параметрах чего?
Unborn: mtp - это что?
29 дек 2016, 14:33
Restart1566 писал(а): В параметрах чего?
смартфона конечно
Restart1566
29 дек 2016, 15:02
Отвечаю:
Во-первых, у меня не смартфон. Но при подключении к порту он спрашивает, и я, естественно отвечаю USB
Во-вторых, повторю, в версиях 17.2и ранее и других сборках все работает и сейчас. Что-то изменилось в 17.3, и я пытаюсь понять - что
29 дек 2016, 15:20
так вы еще хотите чтоб это старье цеплялось как флешка? )) В первом вашем же посте вы сами же отвечаете на свой вопрос.
Restart1566 писал(а): После перехода на 17.3 и затем выше перестал подключаться телефон как флэшка.
т.е. не поддерживается сие велосипед изобретение в современных ОС. Ставьте 16-ую и будет вам счастье. Прогресс на месте не стоит. Уже смартфоны давно придумали.
29 дек 2016, 15:35
пробуйте по wi-fi наладить связь с пк )
machulan
Благодарил (а): 4 раза
29 дек 2016, 16:05
А раньше Вы подключались к USB 2.0 или USB 3.1 ? Между ними совместимость не полная.
Restart1566
29 дек 2016, 16:25
Dja писал(а):так вы еще хотите чтоб это старье цеплялось как флешка? ... Уже смартфоны давно придумали.
Почему старье, осенью купил, вайфая в нем нет.
Смартфон мне не нужен
Я спрашиваю, где ошибка происходит при подключении, логаут привел, а не то, какой мне покупать телефон.
Restart1566
29 дек 2016, 16:26
machulan писал(а):А раньше Вы подключались к USB 2.0 или USB 3.1 ? Между ними совместимость не полная.
Да к тому же компьютеру, УСБ 2.0
29 дек 2016, 16:53
Restart1566 писал(а): где ошибка происходит
ошибка в переходе с mint 16 на mint 17, который это древо уже не поддерживает. Nokia 3310 тоже продаются, но никто не будет отрицать, что это уже каменный век.
Благодарил (а): 845 раз
29 дек 2016, 19:22
Restart1566, как sdf и sdg похоже определяются разделы именно оттуда, покажи sudo lsblk при подключенном девайсе
29 дек 2016, 19:45
Restart1566 писал(а): mtp - это что?
В гугле поищи и почитай.
Открой Синаптик, в поиске mtp и установи.
Restart1566
30 дек 2016, 09:20
Chocobo писал(а):Restart1566, как sdf и sdg похоже определяются разделы именно оттуда, покажи sudo lsblk при подключенном девайсе
Я уже приводил, но повторю
mint-w360 lexa1 # lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sdd 8:48 0 232,9G 0 disk
├─sdd2 8:50 0 5,7G 0 part [SWAP]
├─sdd3 8:51 0 9,3G 0 part /var
├─sdd1 8:49 0 28G 0 part /
└─sdd4 8:52 0 189,9G 0 part /home
sdb 8:16 0 465,8G 0 disk
├─sdb2 8:18 0 326,4G 0 part /mnt/users
└─sdb1 8:17 0 139,4G 0 part /mnt/sdb1home
sr0 11:0 1 580,2M 0 rom
sde 8:64 0 931,5G 0 disk
└─sde1 8:65 0 931,5G 0 part /media/lexa1/1TB
sdc 8:32 0 931,5G 0 disk
├─sdc2 8:34 0 700G 0 part /mnt/backup
├─sdc3 8:35 0 229,5G 0 part /mnt/store
└─sdc1 8:33 0 2G 0 part
sda 8:0 0 465,8G 0 disk
├─sda2 8:2 0 9,8G 0 part
├─sda3 8:3 0 426,7G 0 part /mnt/large
└─sda1 8:1 0 29,3G 0 part /mnt/system1
[767140.240072] usb 3-1: new full-speed USB device number 3 using uhci_hcd
[767140.458071] usb 3-1: New USB device found, idVendor=0e8d, idProduct=0002
[767140.458074] usb 3-1: New USB device strings: Mfr=2, Product=3, SerialNumber=4
[767140.458077] usb 3-1: Product: Product
[767140.458080] usb 3-1: Manufacturer: MediaTek Inc
[767140.458082] usb 3-1: SerialNumber: 68852320990703f
[767140.464114] usb-storage 3-1:1.0: USB Mass Storage device detected
[767140.464275] scsi host6: usb-storage 3-1:1.0
[767141.472097] scsi 6:0:0:0: Direct-Access MEDIATEK FLASH DISK PQ: 0 ANSI: 0 CCS
[767141.475080] scsi 6:0:0:1: Direct-Access MEDIATEK FLASH DISK PQ: 0 ANSI: 0 CCS
[767141.475582] sd 6:0:0:0: Attached scsi generic sg6 type 0
[767141.475893] sd 6:0:0:1: Attached scsi generic sg7 type 0
[767141.482078] sd 6:0:0:0: [sdf] 15366144 512-byte logical blocks: (7.87 GB/7.33 GiB)
[767141.485095] sd 6:0:0:1: [sdg] 26000 512-byte logical blocks: (13.3 MB/12.7 MiB)
[767141.488086] sd 6:0:0:0: [sdf] Write Protect is off
[767141.488090] sd 6:0:0:0: [sdf] Mode Sense: 03 00 00 00
[767141.491072] sd 6:0:0:1: [sdg] Write Protect is off
[767141.491075] sd 6:0:0:1: [sdg] Mode Sense: 03 00 00 00
[767141.494077] sd 6:0:0:0: [sdf] No Caching mode page found
[767141.494084] sd 6:0:0:0: [sdf] Assuming drive cache: write through
[767141.497080] sd 6:0:0:1: [sdg] No Caching mode page found
[767141.497085] sd 6:0:0:1: [sdg] Assuming drive cache: write through
[767141.814133] sdf: sdf1
[767141.821117] sdg:
[767141.844084] sd 6:0:0:0: [sdf] Attached SCSI removable disk
[767141.847146] sd 6:0:0:1: [sdg] Attached SCSI removable disk
[767144.732069] scsi 6:0:0:0: rejecting I/O to offline device
[767144.732079] scsi 6:0:0:0: [sdf] killing request
[767144.732098] scsi 6:0:0:0: [sdf] FAILED Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
[767144.732102] scsi 6:0:0:0: [sdf] CDB: Read(10) 28 00 00 00 08 80 00 00 90 00
[767144.732105] blk_update_request: I/O error, dev sdf, sector 2176
[767144.736163] Buffer I/O error on dev sdf1, logical block 15, async page read
[767144.736205] Buffer I/O error on dev sdf1, logical block 2, async page read
Restart1566
30 дек 2016, 09:21
Ничего не изменилось
Restart1566
30 дек 2016, 09:22
17 поддерживал.
И потом, из какого именно сообщения видно, что не поддерживает?
30 дек 2016, 10:23
Restart1566, возьмите новейший системник и попробуйте установить туда win 98. Или к примеру к семерке подключить принтер, который лет 30 уже как не производится и в продаже нет. В обоих случаях ждет крах. Железо развивается. Софт развивается. Более новые ОС требуют более шустрого железа и т. и прочее. Тоже самое и здесь. Хотите пользоваться этим деревом - ставьте обратно 16 или 17,0 и они у вас всё будут видеть. Не вижу проблемы.
