Ноутбук Acer Aspire 7720G, ОС LM 19.3 x32. Проблема подключения к WiFi-роутеру
Алексей85
25 янв 2020, 19:11
Добрый день!
Ноутбук Ноутбук Acer Aspire 7720G с ОС LM 19.3 x32 не подключается в wifi-роутеру. При этом прекрасно подключается в точке тоступа wifi телефона.
Железо
  Host: carevav-pc Kernel: 5.3.0-26-generic i686 bits: 32 compiler: gcc
  v: 7.4.0 Desktop: Cinnamon 4.4.8 Distro: Linux Mint 19.3 Tricia
  base: Ubuntu 18.04 bionic
  Type: Kvm System: Acer product: Aspire 7720 v: V1.40 serial: <filter>
  Mobo: Acer model: Poyang v: V1.40 serial: <filter> BIOS: Acer v: 1.40
  date: 05/20/2008
  ID-1: BAT0 charge: 22.6 Wh condition: 22.6/48.8 Wh (46%)
  model: SANYO GC86508SAT0 status: Full
  Topology: Dual Core model: Intel Core2 Duo T7500 bits: 64 type: MCP
  arch: Core Merom rev: B L2 cache: 4096 KiB
  flags: lm nx pae sse sse2 sse3 ssse3 vmx bogomips: 8778
  Speed: 1352 MHz min/max: 800/2201 MHz Core speeds (MHz): 1: 1352 2: 1319
  Device-1: NVIDIA G84M [GeForce 8600M GT] vendor: Acer Incorporated ALI
  driver: nvidia v: 340.107 bus ID: 01:00.0
  Display: x11 server: X.Org 1.20.5 driver: nvidia
  unloaded: fbdev,modesetting,nouveau,vesa resolution: 1920x1200~60Hz
  OpenGL: renderer: GeForce 8600M GT/PCIe/SSE2 v: 3.3.0 NVIDIA 340.107
  Device-1: Intel 82801H HD Audio vendor: Acer Incorporated ALI
  Sound Server: ALSA v: k5.3.0-26-generic
  Device-1: Broadcom and subsidiaries NetLink BCM5787M Gigabit Ethernet PCI
  Express
  vendor: Acer Incorporated ALI driver: tg3 v: 3.137 port: 5000
  bus ID: 05:00.0
  IF: enp5s0 state: down mac: <filter>
  Device-2: Intel PRO/Wireless 4965 AG or AGN [Kedron] Network
  driver: iwl4965 v: in-tree: port: 5000 bus ID: 06:00.0
  IF: wlp6s0 state: up mac: <filter>
  Local Storage: total: 698.65 GiB used: 11.34 GiB (1.6%)
  ID-1: /dev/sda vendor: Western Digital model: WD2500BEVS-22UST0
  ID-2: /dev/sdb vendor: Seagate model: ST9500325AS size: 465.76 GiB
  ID-1: / size: 228.23 GiB used: 11.34 GiB (5.0%) fs: ext4 dev: /dev/sda1
  System Temperatures: cpu: 41.0 C mobo: N/A gpu: nvidia temp: 62 C
  Processes: 181 Uptime: 36m Memory: 2.88 GiB used: 993.1 MiB (33.7%)
  inxi: 3.0.32
25 янв 2020, 19:55
Алексей85, а если попробовать подключиться к роутеру, находясь непосредственно рядом с ним?
26 янв 2020, 08:15
Алексей85 писал(а):
25 янв 2020, 19:11
Роутер настраивай. LM тут совершенно не причём. Ну разве если, ты не переключил шифрование в NM
Сейчас этот форум просматривают: alek_j и 1 гость
