не работает драйвер на nvidia geforce 1050ti
fatx
Благодарил (а): 4 раза
24 янв 2020, 14:59
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Acer Incorporated ALI
driver: N/A bus ID: 01:00.0
помогите плз. неделю мучаюсь
1System: Host: compucter Kernel: 5.3.0-26-generic x86_64 bits: 64 compiler: gcc v: 7.4.0
Desktop: Cinnamon 4.4.8 Distro: Linux Mint 19.3 Tricia base: Ubuntu 18.04 bionic
Machine: Type: Laptop System: Acer product: Predator G3-572 v: V1.10 serial: <filter>
Mobo: KBL model: Sienta_KLS v: V1.10 serial: <filter> UEFI: Insyde v: 1.10
date: 08/22/2017
Battery: ID-1: BAT1 charge: 39.6 Wh condition: 39.6/48.9 Wh (81%) model: COMPAL PABAS0241231
status: Full
CPU: Topology: Quad Core model: Intel Core i5-7300HQ bits: 64 type: MCP arch: Kaby Lake
rev: 9 L2 cache: 6144 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19999
Speed: 1100 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 1100 2: 1100 3: 1100
4: 1100
Graphics: Device-1: Intel vendor: Acer Incorporated ALI driver: i915 v: kernel bus ID: 00:02.0
Display: x11 server: X.Org 1.19.6 driver: modesetting unloaded: fbdev,vesa tty: N/A
OpenGL: renderer: Mesa DRI Intel HD Graphics 630 (Kaby Lake GT2) v: 4.5 Mesa 19.2.1
Audio: Device-1: Intel CM238 HD Audio vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus ID: 00:1f.3
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel v: kernel
bus ID: 01:00.1
Sound Server: ALSA v: k5.3.0-26-generic
Network: Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter vendor: Lite-On
driver: ath10k_pci v: kernel port: 4000 bus ID: 02:00.0
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000 bus ID: 03:00.1
IF: enp3s0f1 state: down mac: <filter>
Drives: Local Storage: total: 931.51 GiB used: 40.35 GiB (4.3%)
ID-1: /dev/sda vendor: Western Digital model: WD10SPZX-21Z10T0 size: 931.51 GiB
Partition: ID-1: / size: 58.71 GiB used: 34.91 GiB (59.5%) fs: ext4 dev: /dev/sda7
ID-2: /home size: 36.91 GiB used: 5.42 GiB (14.7%) fs: ext4 dev: /dev/sda8
Sensors: Missing: Required tool sensors not installed. Check --recommends
Info: Processes: 225 Uptime: 3h 30m Memory: 7.66 GiB used: 2.45 GiB (32.0%) Init: systemd
runlevel: 5 Compilers: gcc: 7.4.0 Shell: bash v: 4.4.20 inxi: 3.0.32
2.
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
libnvidia-cfg1-435/bionic,bionic-updates,now 435.21-0ubuntu0.18.04.2 amd64 [установлен, автоматически]
libnvidia-common-430/bionic,bionic,now 430.64-0ubuntu0~gpu18.04.1 all [установлен, может быть удалён автоматически]
libnvidia-common-435/bionic,bionic,bionic-updates,bionic-updates,now 435.21-0ubuntu0.18.04.2 all [установлен, автоматически]
libnvidia-common-440/bionic,bionic,now 440.48.02-0ubuntu0~~18.04.1 all [установлен, может быть удалён автоматически]
libnvidia-compute-435/bionic,bionic-updates,now 435.21-0ubuntu0.18.04.2 amd64 [установлен, автоматически]
libnvidia-decode-435/bionic,bionic-updates,now 435.21-0ubuntu0.18.04.2 amd64 [установлен, автоматически]
libnvidia-encode-435/bionic,bionic-updates,now 435.21-0ubuntu0.18.04.2 amd64 [установлен, автоматически]
libnvidia-fbc1-435/bionic,bionic-updates,now 435.21-0ubuntu0.18.04.2 amd64 [установлен, автоматически]
libnvidia-gl-435/bionic,bionic-updates,now 435.21-0ubuntu0.18.04.2 amd64 [установлен, автоматически]
libnvidia-ifr1-435/bionic,bionic-updates,now 435.21-0ubuntu0.18.04.2 amd64 [установлен, автоматически]
nvidia-compute-utils-435/bionic,bionic-updates,now 435.21-0ubuntu0.18.04.2 amd64 [установлен, автоматически]
nvidia-dkms-435/bionic,bionic-updates,now 435.21-0ubuntu0.18.04.2 amd64 [установлен, автоматически]
nvidia-driver-435/bionic,bionic-updates,now 435.21-0ubuntu0.18.04.2 amd64 [установлен]
nvidia-kernel-common-435/bionic,bionic-updates,now 435.21-0ubuntu0.18.04.2 amd64 [установлен, автоматически]
nvidia-kernel-source-435/bionic,bionic-updates,now 435.21-0ubuntu0.18.04.2 amd64 [установлен, автоматически]
nvidia-prime/bionic-updates,bionic-updates,now 0.8.8.2 all [установлен]
nvidia-settings/bionic,now 418.56-0ubuntu0~gpu18.04.1 amd64 [установлен]
nvidia-utils-435/bionic,bionic-updates,now 435.21-0ubuntu0.18.04.2 amd64 [установлен, автоматически]
xserver-xorg-video-nvidia-435/bionic,bionic-updates,now 435.21-0ubuntu0.18.04.2 amd64 [установлен, автоматически]
24 янв 2020, 15:44
fatx, загляни в менеджер драйверов.
fatx
24 янв 2020, 15:45
symon2014, там я все испробовал. все равно не работает
24 янв 2020, 15:47
fatx, покажи скрин менеджера
fatx
24 янв 2020, 15:51
symon2014,
24 янв 2020, 15:54
И нет ни одного рекомендованного . Думать надо. :hm:
Сотрудник
25 янв 2020, 03:51
fatx, в менеджере пакетов Synaptic поищите и установите дополнительно драйвера и компоненты для предыдущих моделей NVIDIA, лишние потом можно удалить. Этот метод помог мне решить проблему с принтером, может решить и для других устройств.
25 янв 2020, 04:25
fatx, А с чего ты взял что драйвер не работает?
MrTowelie
Решено: 8
Благодарил (а): 18 раз
25 янв 2020, 06:30
А попробуйте сделать так, как делается тут https://bugs.launchpad.net/ubuntu/+sour ... ug/1860306
Т.е.:
1. Очищаем от Nvidia всё установленное sudo apt purge nvidia* libnvidia* screen-resolution-extras
2. sudo apt autoremove
3. Проверяете есть ли что-то ещё dpkg -l | grep nvidia **, если есть ещё установленные файлы, то удаляете их sudo apt purge имя_файла
4. Добавляете репы Nvidia снова sudo apt-add-repository ppa:graphics-drivers/ppa и sudo apt update
5. Ставите драйвера sudo apt install nvidia-driver-440 nvidia-dkms-440
6. Скорее всего видите ошибку, тогда добавляете sudo apt install linux-headers-5.3.0-26 (если версия ядра ещё такая же у вас, если изменилась, то номер надо поменять)
7. Перезагрузка sudo reboot
Если не получилось, то попробуйте повторить всё, но пункт 5 и 6 поменять местами.
В противном случае ищите в интернете "Как в Linux mint / Ubuntu установить старую версию ядра" и пробуйте уже обычной установкой на версии ядра постарше, но не сильно.
ampersand
24 апр 2020, 15:52
А при установке драйвера не было никаких сообщений о включенном UEFI Secureboot?
Была точно такая же проблема с точно такой же видеокартой, сделал всё как написал MrTowelie, но никаких ошибок не произошло, 6 пункт выполнять не потребовалось.
Но в процессе установки вышло сообщение что включен Secureboot и нужно ввести пароль, который нужно будет повторить после перезагрузки.
djsantehnik
Благодарил (а): 24 раза
25 апр 2020, 09:48
25 апр 2020, 09:58
djsantehnik писал(а):
25 апр 2020, 09:48
а это пробовали
лучше не пробовать
25 апр 2020, 11:14
Greey
Благодарил (а): 16 раз
15 июл 2020, 17:23
Чем не угодили драйвера "из коробки"? Любые видеокарты прекрасно работают запускаются. Зачем на Linux ставить мощную видеокарту и потом шаманить с драйверами к ней (без учёта, конечно, видеомонтажа и подобных действий), когда под систему нет игр, где такие ресурсы можно задействовать?
15 июл 2020, 17:24
Greey писал(а):
15 июл 2020, 17:23
В "коробке" нет Nvidia
Greey
15 июл 2020, 17:30
Странно :crazy: , конечно, ещё многого не понимаю, всего лишь в 2006 году познакомился с Unix ситемами, а Mint открыл только в начале этого года, но как же тогда сразу после установки заработала моя GTX 760 :magic: , если в дистрибутиве к ней нет драйвера?
15 июл 2020, 17:31
Greey писал(а):
15 июл 2020, 17:30
поставили галочку в чекбоксе , установить дополнительное ПО
15 июл 2020, 17:32
Greey писал(а):
15 июл 2020, 17:23
А мужики то - не знали...
https://store.steampowered.com/linux#p=1&tab=TopSellers
И это без учета того, что можно через wine запустить.
Greey
15 июл 2020, 17:34
Устанавливал с USB. Подключения к интернету не было. Тут хоть ставь галочку, хоть не ставь - без разницы.
Greey
15 июл 2020, 17:35
Через Wine даже Fallout 4 не запустишь :-D, а ресурсоёмкость интернет-игр вообще минимальна.
Вернуться в «Видеокарты»
