Проблема с всплывающими окнами DE cinnamon
Jarver
24 янв 2020, 02:07
Доброго времени суток, никак не могу побороть проблему с искаженными всплывающими окнами, проблема появилась после обновления пакетов и перезагрузки системы.
System:    Host: user-pc Kernel: 5.0.0-32-generic x86_64 bits: 64 compiler: gcc v: 7.4.0 Desktop: Cinnamon 4.4.8
Machine:   Type: Laptop System: LENOVO product: IdeaPad Z585 v: IdeaPad Z585 serial: <filter>
           Mobo: LENOVO model: Lenovo v: Lenovo LZ23BC serial: <filter> UEFI [Legacy]: LENOVO v: 60CN17WW date: 01/03/2013
Battery:   ID-1: BAT1 charge: 29.2 Wh condition: 33.1/38.9 Wh (85%) model: SANYO L11S6Y01 status: Unknown
           Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M315/M235 charge: 55% status: Discharging
CPU:       Topology: Quad Core model: AMD A8-4500M APU with Radeon HD Graphics bits: 64 type: MCP arch: Piledriver rev: 1
           L2 cache: 2048 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 15171
           Speed: 1572 MHz min/max: 1400/1900 MHz Core speeds (MHz): 1: 1444 2: 1456 3: 1537 4: 1464
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Trinity [Radeon HD 7640G] vendor: Lenovo driver: radeon v: kernel
           bus ID: 00:01.0
           Device-2: Advanced Micro Devices [AMD/ATI] Thames [Radeon HD 7500M/7600M Series] vendor: Lenovo driver: radeon
           v: kernel bus ID: 01:00.0
           Display: x11 server: X.Org 1.20.5 driver: ati,radeon unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
           OpenGL: renderer: AMD ARUBA (DRM 2.50.0 / 5.0.0-32-generic LLVM 9.0.0) v: 4.3 Mesa 19.2.1 direct render: Yes
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] Trinity HDMI Audio vendor: Lenovo driver: snd_hda_intel v: kernel
           bus ID: 00:01.1
           Device-2: Advanced Micro Devices [AMD] FCH Azalia vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 00:14.2
Network:   Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo driver: r8169 v: kernel port: 1000
           bus ID: 02:00.0
           Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: Lenovo driver: ath9k v: kernel port: 1000
           bus ID: 03:00.0
           Device-3: Atheros AR3012 Bluetooth 4.0 type: USB driver: btusb bus ID: 3-4:4
Drives:    Local Storage: total: 232.89 GiB used: 93.13 GiB (40.0%)
           ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB
Partition: ID-1: / size: 228.23 GiB used: 93.13 GiB (40.8%) fs: ext4 dev: /dev/sda1
Sensors:   System Temperatures: cpu: 62.1 C mobo: N/A
           GPU: device: radeon temp: 48 C device: radeon temp: 57 C
Info:      Processes: 234 Uptime: 14h 53m Memory: 7.23 GiB used: 4.13 GiB (57.1%) Init: systemd runlevel: 5 Compilers:
           gcc: 7.4.0 Shell: bash v: 4.4.20 inxi: 3.0.32
Screenshot from 2020-01-24 00-52-31.png (24.2 КБ) 366 просмотров
Решение Chocobo » 24 янв 2020, 02:22
Попробуй
apt install xserver-xorg xserver-xorg-video-all
24 янв 2020, 02:22
Попробуй
24 янв 2020, 02:25
Jarver писал(а):
24 янв 2020, 02:07
Не похоже на обновлени и перезагрузку , должно быть ядро 5.3.0-26.
з
24 янв 2020, 02:28
symon2014, На англ форуме ссылаются владельцы двух пред-gcn амд карточек на обновки от 17-го числа, когда оно проявилось
Jarver
24 янв 2020, 17:52
Решило проблему, спасибо)
