Не работает wifi на ноутбуке Dell Inspiron 15 3537 i7
deimosprg
22 янв 2020, 16:52
1. Версия ОС вместе с разрядностью.
ОС - Linux Mint 19.3 Cinnamon x64
Ядро - Linux pc 5.0.0-32-generic #34~18.04.2-Ubuntu SMP Thu Oct 10 10:36:02 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
2. Железо
System:    Host: pc Kernel: 5.0.0-32-generic x86_64 bits: 64 compiler: gcc v: 7.4.0 Desktop: Cinnamon 4.4.5
Machine:   Type: Portable System: Dell product: Inspiron 3537 v: A08 serial: <filter>
           Mobo: Dell model: 0PHTY0 v: A00 serial: <filter> UEFI: Dell v: A08 date: 04/30/2014
CPU:       Topology: Dual Core model: Intel Core i7-4500U bits: 64 type: MT MCP arch: Haswell rev: 1 L2 cache: 4096 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19156
           Speed: 2243 MHz min/max: 800/3000 MHz Core speeds (MHz): 1: 1467 2: 1484 3: 1470 4: 1471
Graphics:  Device-1: Intel Haswell-ULT Integrated Graphics vendor: Dell driver: i915 v: kernel bus ID: 00:02.0
           Device-2: Advanced Micro Devices [AMD/ATI] Venus PRO [Radeon HD 8850M / R9 M265X] vendor: Dell driver: radeon
           v: kernel bus ID: 03:00.0
           Display: server: X.Org 1.20.4 driver: ati,modesetting,radeon unloaded: fbdev,vesa resolution: 1366x768~60Hz
           OpenGL: renderer: Mesa DRI Intel Haswell Mobile v: 4.5 Mesa 19.0.8 direct render: Yes
Audio:     Device-1: Intel Haswell-ULT HD Audio vendor: Dell driver: snd_hda_intel v: kernel bus ID: 00:03.0
           Device-2: Intel 8 Series HD Audio vendor: Dell driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Network:   Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell driver: r8169 v: kernel port: 4000
           bus ID: 01:00.0
           Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter vendor: Dell driver: ath9k v: kernel
           port: 4000 bus ID: 02:00.0
           IF: wlp2s0 state: down mac: <filter>
           Device-3: Atheros type: USB driver: btusb bus ID: 1-1.5:8
           IF-ID-1: enp0s29u1u3 state: unknown speed: N/A duplex: N/A mac: <filter>
Drives:    Local Storage: total: 931.51 GiB used: 10.16 GiB (1.1%)
           ID-1: /dev/sda vendor: Seagate model: ST1000LM024 HN-M101MBB size: 931.51 GiB temp: 34 C
Partition: ID-1: / size: 91.17 GiB used: 4.86 GiB (5.3%) fs: ext4 dev: /dev/sda3
           ID-2: /home size: 820.19 GiB used: 5.30 GiB (0.6%) fs: ext4 dev: /dev/sda4
           ID-3: swap-1 size: 3.81 GiB used: 1.0 MiB (0.0%) fs: swap dev: /dev/sda2
Sensors:   System Temperatures: cpu: 48.0 C mobo: N/A gpu: radeon temp: 51 C
           Fan Speeds (RPM): cpu: 2500
Info:      Processes: 228 Uptime: 1h 18m Memory: 7.67 GiB used: 2.63 GiB (34.3%) Init: systemd runlevel: 5 Compilers:
           gcc: 7.4.0 Shell: bash v: 4.4.20 inxi: 3.0.32
lshw -class network
*-network
       описание: Ethernet interface
       продукт: RTL810xE PCI Express Fast Ethernet controller
       производитель: Realtek Semiconductor Co., Ltd.
       физический ID: 0
       сведения о шине: pci@0000:01:00.0
       логическое имя: enp1s0
       версия: 07
       серийный №: 74:86:7a:4d:31:e6
       capacity: 100Mbit/s
       разрядность: 64 bits
       частота: 33MHz
       возможности: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       конфигурация: autonegotiation=on broadcast=yes driver=r8169 duplex=half firmware=rtl8106e-1_0.0.1 06/29/12 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
       ресурсы: IRQ:18 ioport:4000(размер=256) память:c0700000-c0700fff память:c0400000-c0403fff
  *-network ВЫКЛЮЧЕНО
       описание: Беспроводной интерфейс
       продукт: QCA9565 / AR9565 Wireless Network Adapter
       производитель: Qualcomm Atheros
       физический ID: 0
       сведения о шине: pci@0000:02:00.0
       логическое имя: wlp2s0
       версия: 01
       серийный №: 80:56:f2:36:b9:b7
       частота: 33MHz
       возможности: pm msi pciexpress bus_master cap_list rom ethernet physical wireless
       конфигурация: broadcast=yes driver=ath9k driverversion=5.0.0-32-generic firmware=N/A latency=0 link=no multicast=yes wireless=IEEE 802.11
       ресурсы: IRQ:19 память:c0600000-c067ffff память:c0680000-c068ffff
  *-network
       физический ID: 2
       логическое имя: enp0s29u1u3
       серийный №: 36:dd:65:9c:ab:ff
       возможности: ethernet physical
       конфигурация: broadcast=yes driver=rndis_host driverversion=22-Aug-2005 firmware=RNDIS device ip=192.168.42.59 link=yes multicast=yes
3. Суть
Ну ни как не хочет работать Wi-Fi, помогите пожалуйста, я не очень шарю, если мягко сказать. Под Windows Wi-Fi очень даже работает (правда сама винда не работает). Wi-Fi адаптер распознается.
4. Скрин
22 янв 2020, 16:55
deimosprg, покажи вывод
rfkill list
и
lspci -knn | grep -A3 "Net"
deimosprg
22 янв 2020, 17:00
rogoznik,
rfkill list
0: dell-rbtn: Wireless LAN
	Soft blocked: yes
	Hard blocked: yes
1: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: no
2: hci0: Bluetooth
	Soft blocked: no
	Hard blocked: no
02:00.0 Network controller [0280]: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter [168c:0036] (rev 01)
	Subsystem: Dell QCA9565 / AR9565 Wireless Network Adapter [1028:020c]
	Kernel driver in use: ath9k
	Kernel modules: ath9k
03:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Venus PRO [Radeon HD 8850M / R9 M265X] [1002:6823]
22 янв 2020, 17:01
deimosprg писал(а):
22 янв 2020, 17:00
Soft blocked: yes
Hard blocked: yes
Ищи на ноуте выключатель wifi и включи его
22 янв 2020, 17:03
sudo rfkill unblok all
deimosprg
22 янв 2020, 17:08
rogoznik, мда, ну я и тупой, два дня инфу всякую искал, а оно вона чо, спасибо большое
Если не жалко времени, не могли бы вы по подробней объяснить как вы поняли что надо сделать?
22 янв 2020, 17:12
deimosprg писал(а):
22 янв 2020, 17:08
deimosprg писал(а):
22 янв 2020, 17:00
Hard blocked: yes
Все просто блокировка на уровне железа или BIOS/UEFI
deimosprg писал(а):
22 янв 2020, 17:00
Soft blocked: yes
Блокировка на программном уровне
