Проблема с 2 видеокартами (Nvidia+Intel)
Leetlive
22 янв 2020, 00:11
Понимаю что тема скорее всего заезженная для бывалых,но новичок в плане пользования линукса. В общем что имеем: 1. LM 19.3 Tricia x64. 2. XFCE.
3.
Kernel: 5.3.0-26-generic x86_64 bits: 64 compiler: gcc
  v: 7.4.0 Desktop: Xfce 4.14.1 Distro: Linux Mint 19.3 Tricia
  base: Ubuntu 18.04 bionic
  Type: Desktop System: MICRO-STAR product: MS-AC1111 v: N/A
  serial: <filter>
  Mobo: MICRO-STAR model: MS-AC111 v: 100 serial: <filter>
  BIOS: American Megatrends v: EAC11IMS V1.7 date: 04/21/2014
  Topology: Dual Core model: Intel Core i3-4170 bits: 64 type: MT MCP
  arch: Haswell rev: 3 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 29531
  Speed: 897 MHz min/max: 800/3700 MHz Core speeds (MHz): 1: 798 2: 798
  3: 799 4: 799
  Device-1: Intel 4th Generation Core Processor Family Integrated Graphics
  vendor: Micro-Star MSI driver: i915 v: kernel bus ID: 00:02.0
  Device-2: NVIDIA GK208M [GeForce GT 740M] vendor: Micro-Star MSI
  driver: N/A bus ID: 01:00.0
  Display: x11 server: X.Org 1.20.5 driver: modesetting unloaded: fbdev,vesa
  resolution: 1920x1080~60Hz
  OpenGL: renderer: Mesa DRI Intel Haswell v: 4.5 Mesa 19.2.1
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
  driver: snd_hda_intel v: kernel bus ID: 00:03.0
  Device-2: Intel 8 Series/C220 Series High Definition Audio
  vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  Sound Server: ALSA v: k5.3.0-26-generic
  vendor: Micro-Star MSI driver: r8169 v: kernel port: d000 bus ID: 03:00.0
  IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Realtek RTL8188EE Wireless Network Adapter vendor: AzureWave
  driver: rtl8188ee v: kernel port: c000 bus ID: 04:00.0
  IF: wlp4s0 state: down mac: <filter>
  IF-ID-1: ppp0 state: unknown speed: N/A duplex: N/A mac: N/A
  Local Storage: total: 931.51 GiB used: 72.48 GiB (7.8%)
  ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-22RKKA0
  ID-1: / size: 915.89 GiB used: 72.48 GiB (7.9%) fs: ext4 dev: /dev/sda1
  System Temperatures: cpu: 60.0 C mobo: N/A
  Processes: 191 Uptime: 6m Memory: 7.70 GiB used: 1.29 GiB (16.7%)
  inxi: 3.0.32
4. После первой же установки Lm как основную OC,все было довольно хорошо,поставились драйвера и приложения нужные из менеджера и терминал,все обновилось,работал как надо NVIDIA X SERVER (имел ряд настроек и возможность выкрутить все на макс.производительность) и в играх показывал 100-120 фпс,чего не делал на винде например,да и в целом в работе приложений был шустрый. Но после первого же ребута после этой установки и радости, фпс упал до 40-60,бывают фризы и иногда подвисают приложения, а так же пропали все настройки из панели Nvidia (скрин ниже)
Ара Магеддон
Решено: 18
Благодарил (а): 37 раз
22 янв 2020, 07:34
Пока работает драйвер интел вместо нвидии, от того и производительность упала.
А что происходит, если выбрать карту командой sudo prime-select nvidia?
Leetlive
22 янв 2020, 19:18
Ара Магеддон, Ара Магеддон,
nfo: the nvidia profile is already set
Вообще перепробовал довольно много чего,забыл написать это в вопросе,т.к. уже просто начали нервы сдавать) Устанавливал nvidia prime. Результат:сколько не нажимал в трее переключиться на нвидиа,писал что ребутнись и все будет Ок,но ОК не было,все так же работала карта итнел (проверял командойlspci -vnnn | perl -lne 'print if /^\d+\:.+(\[\S+\:\S+\])/' | grep VGA)+в этом же прайме была какая то надпись интел график,но она была не активна,мб она и отвечала за показ того что сейчас работает. Ставил бамбалби.В итоге улетел какой то не тот драйвер,причем по моему он сам его выбрал на удаление и в итоге поймал черный экран. Пробовал разобраться тогда с интелом,может его выкрутить на макс производ-ть,но там еще все хуже,т.к. на линь ничего толком не нашел из софта,а то что есть с моим уровнем знаний не установить. Сегодня вот задумался может поможет установить предыдущую версию? 17-18 какую нибудь или там будет такая же проблема? Причем что странно,только установишь дистр,обновишь все драйвера-пакеты и т.п.,все отлично,летает 100+ ФПС, ребутнешься-все падает до 40-60 в лучшем случае с фризами мелками,да и сама производительность компа немного падает
Ара Магеддон
Решено: 18
23 янв 2020, 03:51
Leetlive писал(а):
22 янв 2020, 19:18
Можно попробовать, если "вторая свежесть" софта не смущает. И да, какую версию драйвера ставили (и откуда)?
В биосе карта интел отключается?
Leetlive
23 янв 2020, 07:19
Ара Магеддон, драйвер ставил через менеджер драйверов,тот что он предложил, 390 версию,в биосе не пробовал отключить,да и чет страшно туда лезть за этим) тем более что в программах то интел работает хорошо,только в играх плохо,можно было бы настроить их на совместную работу
Вернуться в «Видеокарты»
