Проблема с Менеджер драйверов
KoST
16 янв 2020, 17:04
Добрый день коллеги!
Прошу помочь решить проблему с запуском "Менеджер драйверов" на Linux Mint 19.3 32 бит.
Параметры моей системы через inxi -FxZ
S
ystem: Host: konstantin-desktop Kernel: 5.0.0-37-generic i686 bits: 32 compiler: gcc v: 7.4.0
           Desktop: Cinnamon 4.4.8 Distro: Linux Mint 19.3 Tricia base: Ubuntu 18.04 bionic
Machine: Type: Desktop Mobo: ASUSTeK model: P4R800-VM v: 1.02 serial: <root required>
           BIOS: American Megatrends v: 1006.003 date: 09/02/2004
CPU: Topology: Single Core model: Intel Pentium 4 bits: 32 type: MT arch: Netburst Northwood rev: 9
           L2 cache: 512 KiB
           flags: pae sse sse2 bogomips: 9577
           Speed: 2394 MHz min/max: N/A Core speeds (MHz): 1: 2394 2: 2394
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] RV350 [Radeon 9550] driver: radeon v: kernel
           bus ID: 01:05.0
           Display: x11 server: X.Org 1.20.4 driver: ati,radeon unloaded: fbdev,modesetting,vesa
           resolution: 1280x1024~60Hz
           OpenGL: renderer: ATI RV350 v: 2.1 Mesa 19.0.8 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] IXP150 AC97 Audio vendor: ASUSTeK driver: snd_atiixp
           v: kernel bus ID: 00:14.5
           Device-2: Creative Labs EMU10k1 [Sound Blaster Live! Series] driver: snd_emu10k1 v: kernel
           bus ID: 02:06.0
           Sound Server: ALSA v: k5.0.0-37-generic
Network: Device-1: Realtek RTL-8100/8101L/8139 PCI Fast Ethernet Adapter driver: 8139too v: 0.9.28
           port: e800 bus ID: 02:07.0
           IF: enp2s7 state: down mac: 00:11:6b:93:6a:94
           Device-2: 3Com 3C920B-EMB-WNM Integrated Fast Ethernet vendor: ASUSTeK driver: 3c59x v: kernel
           port: ec00 bus ID: 02:08.0
           IF: enp2s8 state: down mac: 00:11:2f:d5:20:60
           IF-ID-1: enp0s19f2u2 state: unknown speed: N/A duplex: N/A mac: 0e:08:c0:76:4a:75
Drives: Local Storage: total: 74.56 GiB used: 30.66 GiB (41.1%)
           ID-1: /dev/sda vendor: Samsung model: SP0812N size: 74.56 GiB temp: 37 C
Partition: ID-1: / size: 72.89 GiB used: 30.66 GiB (42.1%) fs: ext4 dev: /dev/sda1
Sensors: Message: No sensors data was found. Is sensors configured?
Info: Processes: 164 Uptime: 6h 56m Memory: 1.15 GiB used: 516.1 MiB (43.8%) Init: systemd runlevel: 5
           Compilers: gcc: 7.4.0 Shell: bash v: 4.4.20 inxi: 3.0.32
 ! Сообщение из: symon2014
Учись оформлять тему , я не нянька.
Ошибка при запуске "Менеджер драйверов ":
E:Failed to fetch http://packages.linuxmint.com/dists/tricia/InRelease Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?), E:The repository 'http://packages.linuxmint.com tricia InRelease' is not signed.
Скрин во вложении.
Прошу помочь решить данную проблему. Заранее спасибо!
16 янв 2020, 21:06
Так в сообщении же указано, что репозиторий не подписан. При вставке пути http://packages.linuxmint.com/dists/tricia/InRelease у меня вообще ошибка 404 Может быть что-то не то с указанием пути для загрузки?
KoST
16 янв 2020, 21:17
а как его подписать? я просто в linux новичок и не особо знаю.
16 янв 2020, 21:26
Вы, наверное, используете источник обновлений по умолчанию? Попробуйте переключиться на ближайшее географическое зеркало. Возможно, что с вашей скоростью интернет система не успевает достучаться до всех пакетов источника обновлений по умолчанию и после некоторого времени "размышлений" говорит, что имеет место ошибка.
KoST
17 янв 2020, 07:51
madesta, к сожалению это не помогает(((
