Не запускается STEAM на Linux Mint 19.3 32 бит.
KoST
16 янв 2020, 16:22
Добрый день коллеги!
Прошу помочь решить проблему с установкой Steam на Linux Mint 19.3 32 бит.
Параметры моей системы через inxi -FxZ
System:    Host: konstantin-desktop Kernel: 5.0.0-37-generic i686 bits: 32 compiler: gcc v: 7.4.0
           Desktop: Cinnamon 4.4.8 Distro: Linux Mint 19.3 Tricia base: Ubuntu 18.04 bionic
Machine:   Type: Desktop Mobo: ASUSTeK model: P4R800-VM v: 1.02 serial: <root required>
           BIOS: American Megatrends v: 1006.003 date: 09/02/2004
CPU:       Topology: Single Core model: Intel Pentium 4 bits: 32 type: MT arch: Netburst Northwood rev: 9
           L2 cache: 512 KiB
           flags: pae sse sse2 bogomips: 9577
           Speed: 2394 MHz min/max: N/A Core speeds (MHz): 1: 2394 2: 2394
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] RV350 [Radeon 9550] driver: radeon v: kernel
           bus ID: 01:05.0
           Display: x11 server: X.Org 1.20.4 driver: ati,radeon unloaded: fbdev,modesetting,vesa
           resolution: 1280x1024~60Hz
           OpenGL: renderer: ATI RV350 v: 2.1 Mesa 19.0.8 direct render: Yes
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] IXP150 AC97 Audio vendor: ASUSTeK driver: snd_atiixp
           v: kernel bus ID: 00:14.5
           Device-2: Creative Labs EMU10k1 [Sound Blaster Live! Series] driver: snd_emu10k1 v: kernel
           bus ID: 02:06.0
           Sound Server: ALSA v: k5.0.0-37-generic
Network:   Device-1: Realtek RTL-8100/8101L/8139 PCI Fast Ethernet Adapter driver: 8139too v: 0.9.28
           port: e800 bus ID: 02:07.0
           IF: enp2s7 state: down mac: 00:11:6b:93:6a:94
           Device-2: 3Com 3C920B-EMB-WNM Integrated Fast Ethernet vendor: ASUSTeK driver: 3c59x v: kernel
           port: ec00 bus ID: 02:08.0
           IF: enp2s8 state: down mac: 00:11:2f:d5:20:60
           IF-ID-1: enp0s19f2u2 state: unknown speed: N/A duplex: N/A mac: 0e:08:c0:76:4a:75
Drives:    Local Storage: total: 74.56 GiB used: 30.66 GiB (41.1%)
           ID-1: /dev/sda vendor: Samsung model: SP0812N size: 74.56 GiB temp: 37 C
Partition: ID-1: / size: 72.89 GiB used: 30.66 GiB (42.1%) fs: ext4 dev: /dev/sda1
Sensors:   Message: No sensors data was found. Is sensors configured?
Info:      Processes: 164 Uptime: 6h 56m Memory: 1.15 GiB used: 516.1 MiB (43.8%) Init: systemd runlevel: 5
           Compilers: gcc: 7.4.0 Shell: bash v: 4.4.20 inxi: 3.0.32
При запуске Steam через консоль отображается след.:
konstantin@konstantin-desktop:~$ steam
Running Steam on linuxmint 19.3 32-bit
STEAM_RUNTIME is enabled automatically
Pins up-to-date!
/home/konstantin/.local/share/Steam/ubuntu12_32/steam
Installing breakpad exception handler for appid(steam)/version(1576550254)
[2020-01-16 16:13:37] Startup - updater built Dec 16 2019 16:48:42
Looks like steam didn't shutdown cleanly, scheduling immediate update check
[2020-01-16 16:13:38] Checking for update on startup
[2020-01-16 16:13:38] Checking for available updates...
[2020-01-16 16:13:38] Downloading manifest: client-download.steampowered.com/client/steam_client_ubuntu12
[2020-01-16 16:13:39] Download skipped: /client/steam_client_ubuntu12 version 1576550254, installed version 1576550254
[2020-01-16 16:13:39] Nothing to do
[2020-01-16 16:13:39] Verifying installation...
[2020-01-16 16:13:39] Performing checksum verification of executable files
[2020-01-16 16:13:48] Verification complete
../common/friendsuihelpers.cpp (54) : Assertion Failed: Is64BitOS()
../common/friendsuihelpers.cpp (55) : Assertion Failed: GetCPUInformation().m_bSSE3
assert_20200116161351_5.dmp[22460]: Uploading dump (out-of-process)
/tmp/dumps/assert_20200116161351_5.dmp
Gtk-Message: 16:13:53.363: Failed to load module "gail"
Gtk-Message: 16:13:53.364: Failed to load module "atk-bridge"
(steam:22450): Gtk-WARNING **: 16:13:53.611: Загружаемый модуль тем не найден в module_path: «adwaita»,
/usr/share/themes/Mint-Y/gtk-2.0/main.rc:1085: error: unexpected identifier 'direction', expected character '}'
assert_20200116161337_1.dmp[22466]: Uploading dump (out-of-process)
/tmp/dumps/assert_20200116161337_1.dmp
assert_20200116161351_5.dmp[22460]: Finished uploading minidump (out-of-process): success = yes
assert_20200116161351_5.dmp[22460]: response: CrashID=bp-312384e7-8436-4ef4-a1fd-c94eb2200116
assert_20200116161351_5.dmp[22460]: file ''/tmp/dumps/assert_20200116161351_5.dmp'', upload yes: ''CrashID=bp-312384e7-8436-4ef4-a1fd-c94eb2200116''
assert_20200116161337_1.dmp[22466]: Finished uploading minidump (out-of-process): success = yes
assert_20200116161337_1.dmp[22466]: response: CrashID=bp-64f6a58e-36e2-4737-84f6-fbff82200116
assert_20200116161337_1.dmp[22466]: file ''/tmp/dumps/assert_20200116161337_1.dmp'', upload yes: ''CrashID=bp-64f6a58e-36e2-4737-84f6-fbff82200116''
/home/konstantin/.local/share/Steam/steam.sh: строка 722: 22450 Недопустимая инструкция                     (стек памяти сброшен на диск) $STEAM_DEBUGGER "$STEAMROOT/$STEAMEXEPATH" "$@"
Прошу помочь с решением данной проблемы. Заранее всем спасибо!
16 янв 2020, 16:28
KoST писал(а):
16 янв 2020, 16:22
KoST писал(а):
16 янв 2020, 16:22
:hm:
MrTowelie
Решено: 8
Благодарил (а): 18 раз
16 янв 2020, 16:31
Вы его с официального сайта скачивали или через встроенный в систему центр приложений?
Была это первая установка или перед этим он удалялся и заново устанавливался?
16 янв 2020, 16:39
KoST писал(а):
16 янв 2020, 16:22
KoST писал(а):
16 янв 2020, 16:22
Этот процессор не умеет набор инструкций SSE3. А стим хочет им пользоваться. Увы, запустить не получится.
KoST
16 янв 2020, 16:49
Скачивал с официального сайта и со встроенного в систему центр приложений, так же удалял и пытался переустановить.
KoST
16 янв 2020, 17:09
slant,
А что за набор инструкций SSE3
16 янв 2020, 18:55
KoST писал(а):
16 янв 2020, 17:09
А что в гугле забанили https://yandex.ru/search/?text=SSE3&cli ... 79190122.1
16 янв 2020, 18:57
KoST
16 янв 2020, 21:18
slant, Спасибо
Вернуться в «Игры»
