Proxychains проблема при установки
Antonbaton
11 янв 2020, 15:24
Все привет , столкнулся с такой проблемой при установки proxychains,
1) Linux Mint 19.3 х64
2) xfce
3)
Host: Kernel: 5.0.0-37-generic x86_64 bits: 64 compiler: gcc
v: 7.4.0 Desktop: Xfce 4.14.1 Distro: Linux Mint 19.3 Tricia
base: Ubuntu 18.04 bionic
Type: Laptop System: PEGATRON product: A17W8 v: 1.0 serial: <filter>
Mobo: PEGATRON model: A17W8 v: 1.0 serial: <filter>
UEFI: American Megatrends v: 507 date: 03/12/2013
ID-1: BAT0 charge: 28.6 Wh condition: 30.0/47.3 Wh (63%) model: A15
status: Not charging
Topology: Dual Core model: Intel Core i3-3120M bits: 64 type: MT MCP
arch: Ivy Bridge rev: 9 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19955
Speed: 1326 MHz min/max: 1200/2500 MHz Core speeds (MHz): 1: 1326 2: 1325
3: 1347 4: 1326
Device-1: Intel 3rd Gen Core processor Graphics vendor: Pegatron
Device-2: NVIDIA GK107M [GeForce GT 640M] vendor: Pegatron driver: nvidia
v: 390.116 bus ID: 01:00.0
Display: x11 server: X.Org 1.20.4 driver: modesetting,nvidia
unloaded: fbdev,nouveau,vesa resolution: 1600x900~60Hz
OpenGL: renderer: GeForce GT 640M/PCIe/SSE2 v: 4.6.0 NVIDIA 390.116
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: Pegatron driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Device-2: NVIDIA GK107 HDMI Audio driver: snd_hda_intel v: kernel
bus ID: 01:00.1
Sound Server: ALSA v: k5.0.0-37-generic
Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter
vendor: AzureWave driver: ath9k v: kernel port: e000 bus ID: 03:00.0
vendor: Pegatron driver: r8169 v: kernel port: d000 bus ID: 04:00.0
Device-3: IMC Networks Atheros AR3012 Bluetooth 4.0 Adapter type: USB
driver: btusb bus ID: 1-1.4:5
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Local Storage: total: 960.35 GiB used: 110.86 GiB (11.5%)
ID-1: /dev/sda vendor: Western Digital model: WD10JPVT-22A1YT0
ID-2: /dev/sdb type: USB vendor: Verbatim model: STORE N GO
ID-1: / size: 913.75 GiB used: 110.69 GiB (12.1%) fs: ext4 dev: /dev/dm-1
ID-2: /boot size: 704.5 MiB used: 163.3 MiB (23.2%) fs: ext4
dev: /dev/sda2
ID-3: swap-1 size: 976.0 MiB used: 2.3 MiB (0.2%) fs: swap dev: /dev/dm-2
System Temperatures: cpu: 68.0 C mobo: N/A gpu: nvidia temp: 64 C
Processes: 243 Uptime: 16h 06m Memory: 7.67 GiB used: 4.45 GiB (58.1%)
inxi: 3.0.32
4 Log
:~$ sudo apt-get install git gcc
[sudo] пароль для $:
Уже установлен пакет gcc самой новой версии (4:7.4.0-1ubuntu2.3).
Уже установлен пакет git самой новой версии (1:2.17.1-1ubuntu0.5).
Следующий пакет устанавливался автоматически и больше не требуется:
libproxychains3
Для его удаления используйте «sudo apt autoremove».
Обновлено 0 пакетов, установлено 0 новых пакетов, для удаления отмечено 0 пакетов, и 16 пакетов не обновлено.
:~$ sudo apt-get remove proxychains
Пакет «proxychains» не установлен, поэтому не может быть удалён
libproxychains3
~$ git clone https://github.com/rofl0r/proxychains-ng.git
fatal: целевой путь «proxychains-ng» уже существует и не является пустым каталогом.
~$ cd proxychains-ng/
$ :~/proxychains-ng$ ./configure --prefix=/usr --sysconfdir=/etc
checking whether we have GNU-style getservbyname_r() ... no
checking whether we have pipe2() and O_CLOEXEC ... no
checking whether $CC defines __APPLE__ ... no
checking whether $CC defines __FreeBSD__ ... no
checking whether $CC defines __OpenBSD__ ... no
checking whether $CC defines __sun ... no
checking whether we can use -Wl,--no-as-needed ... no
checking what's the option to use in linker to set library name ...
cannot find an option to set library name
$ :~/proxychains-ng$ make
cc -DSUPER_SECURE -Wall -O0 -g -std=c99 -D_GNU_SOURCE -pipe -DLIB_DIR=\"/usr/lib\" -DSYSCONFDIR=\"/etc\" -DDLL_NAME=\"libproxychains4.so\" -fPIC -c -o src/nameinfo.o src/nameinfo.c
src/nameinfo.c:1:10: fatal error: sys/socket.h: Нет такого файла или каталога
#include <sys/socket.h>
compilation terminated.
Makefile:82: recipe for target 'src/nameinfo.o' failed
make: *** [src/nameinfo.o] Error 1
Помогите решить, на линуксе всего неделю , пробывал на VB с KALI там все работает и ставиться
11 янв 2020, 15:37
Для начала, удали ненужный пакет, который был установлен по зависимости.
sudo apt autoremove
Какой смысл делать make, если у тебя configure не выполнилось.
Перед сборкой поставить минимальный необходимый для этого набор
sudo apt install build-essential
Удалить в домашнем каталоге каталог proxychains-ng. Можешь проделать это в ФМ, можешь в терминале
rm -rf proxychains-ng
Поновой стянуть с гита
Ну и дальше по инструкции
Перейти в каталог proxychains-ng
Должен получить вот такое
checking whether we have GNU-style getservbyname_r() ... yes
checking whether we have pipe2() and O_CLOEXEC ... yes
checking whether we can use -Wl,--no-as-needed ... yes
checking what's the option to use in linker to set library name ... --soname
Done, now run make && make install
Только после этого можно делать make
Antonbaton
11 янв 2020, 15:50
спасибо большое))) :thumbs: все поставилось
Вернуться в «Xfce»
