Не могу записать ISO-образ на CD
Амдир
Благодарил (а): 8 раз
29 дек 2019, 21:06
Добрый день!
Загрузил с сайта GParted свежий ISO-образ GParted Live (версия 1.0.0-5), но никак не могу прожечь его на CD. Brasero сообщает о "неизвестной ошибке", K3b пишет, что "cdrecord не имеет прав на открытие устройства". При этом DVD-диски записываются нормально. Не подскажет ли кто-нибудь, что с этим можно сделать или что ещё нужно проверить?
Журнал Brasero:
Checking session consistency (brasero_burn_check_session_consistency brasero-burn.c:1739)
BraseroBurnURI called brasero_job_get_action
BraseroBurnURI called brasero_job_set_output_size_for_current_track
BraseroBurnURI stopping
BraseroBurnURI called brasero_job_get_session_output_size
BraseroBurnURI output set (IMAGE) image = /tmp/brasero_tmp_E9GLD0.bin toc = none
BraseroBurnURI called brasero_job_get_current_track
BraseroBurnURI no burn:// URI found
BraseroLocalTrack called brasero_job_get_action
BraseroLocalTrack called brasero_job_set_output_size_for_current_track
BraseroLocalTrack stopping
BraseroLocalTrack called brasero_job_get_session_output_size
BraseroLocalTrack output set (IMAGE) image = /tmp/brasero_tmp_UHJLD0.bin toc = none
BraseroLocalTrack called brasero_job_get_current_track
BraseroLocalTrack no remote URIs
BraseroChecksumImage called brasero_job_get_current_track
BraseroChecksumImage called brasero_job_get_action
BraseroChecksumImage called brasero_job_get_flags
BraseroChecksumImage Dummy operation, skipping
BraseroWodim called brasero_job_get_action
BraseroWodim getting varg
BraseroWodim got varg:
BraseroWodim deactivating
BraseroWodim called brasero_job_get_device
BraseroWodim called brasero_job_get_flags
BraseroWodim called brasero_job_get_speed
BraseroWodim called brasero_job_get_input_type
BraseroWodim called brasero_job_get_fd_in
BraseroWodim called brasero_job_get_current_track
BraseroWodim called brasero_job_set_current_action
        wodim
        -v
        dev=/dev/sr0
        -dummy
        speed=10
        driveropts=burnfree
        fs=16m
        -data
        -nopad
        /home/mmm/Документы/Сын/Текущие_дела/gparted-live-1.0.0-5-amd64.iso
BraseroWodim Launching command
BraseroWodim called brasero_job_get_fd_out
BraseroWodim stderr: wodim: No write mode specified.
BraseroWodim stdout: TOC Type: 1 = CD-ROM
BraseroWodim stderr: wodim: Assuming -tao mode.
BraseroWodim stderr: wodim: Future versions of wodim may have different drive dependent defaults.
BraseroWodim stderr: wodim: Operation not permitted. Warning: Cannot raise RLIMIT_MEMLOCK limits.
BraseroWodim stdout: HUP
BraseroWodim stderr: wodim: Resource temporarily unavailable. Cannot get mmap for 16781312 Bytes on /dev/zero.
BraseroWodim stderr: HUP
BraseroWodim process finished with status 11
BraseroWodim called brasero_job_error
BraseroWodim finished with an error
BraseroWodim asked to stop because of an error
        error           = 0
        message = "no message"
BraseroWodim stopping
Session error : unknown (brasero_burn_record brasero-burn.c:2859)
Вывод отладки K3b:
Devices
Optiarc DVD RW AD-7261S 1.01 (/dev/sr0, CD-R, CD-RW, CD-ROM, DVD-ROM, DVD-R, DVD-RW, DVD-R DL, DVD+R, DVD+RW, DVD+R DL) [DVD-ROM, Последовательный DVD-R, Двухслойный последовательный DVD-R, DVD-R Dual Layer Jump, DVD-RAM, DVD-RW с ограниченной перезаписью, Последовательный DVD-RW, DVD+RW, DVD+R, Двухслойный DVD+R, CD-ROM, CD-R, CD-RW] [SAO, TAO, RAW, SAO/R96R, RAW/R16, RAW/R96P, RAW/R96R, Ограниченная перезапись, Layer Jump] [%7]
System
K3b Version: 17.12.3
KDE Version: 5.44.0
Qt Version: 5.9.5
Kernel: 5.0.0-37-generic
Used versions
cdrecord: 1.1.11
cdrecord
/usr/bin/wodim: Operation not permitted. Warning: Cannot raise RLIMIT_MEMLOCK limits.
/usr/bin/wodim: Resource temporarily unavailable. Cannot get mmap for 12587008 Bytes on /dev/zero.
cdrecord command:
/usr/bin/wodim -v gracetime=2 dev=/dev/sr0 speed=10 -sao driveropts=burnfree -data -tsize=175616s -
Сведения о системе:
System:    Host: sholem Kernel: 5.0.0-37-generic x86_64 bits: 64 compiler: gcc v: 7.4.0
           Desktop: Cinnamon 4.4.5 wm: muffin dm: LightDM Distro: Linux Mint 19.3 Tricia
           base: Ubuntu 18.04 bionic
Machine:   Type: Desktop System: Gigabyte product: N/A v: N/A serial: <filter> Chassis: type: 3
           serial: <filter>
           Mobo: Gigabyte model: Z77-D3H v: x.x serial: <filter> BIOS: American Megatrends v: F18
           date: 08/21/2012
CPU:       Topology: Quad Core model: Intel Core i5-3570K bits: 64 type: MCP arch: Ivy Bridge
           rev: 9 L2 cache: 6144 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 27229
           Speed: 1602 MHz min/max: 1600/3800 MHz Core speeds (MHz): 1: 1602 2: 1602 3: 1602
           4: 1602
Graphics:  Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics vendor: Gigabyte
           driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0162
           Display: x11 server: X.Org 1.19.6 driver: modesetting unloaded: fbdev,vesa
           resolution: 1280x1024~60Hz
           OpenGL: renderer: Mesa DRI Intel Ivybridge Desktop v: 4.2 Mesa 19.0.8 compat-v: 3.0
Audio:     Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Gigabyte
           driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
           Device-2: Syntek ARCTIC Sound P261 Headphones type: USB
           driver: hid-generic,snd-usb-audio,usbhid bus ID: 2-1.6:3 chip ID: 05e1:2010
           Sound Server: ALSA v: k5.0.0-37-generic
Network:   Device-1: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: Gigabyte driver: alx
           v: kernel port: e000 bus ID: 04:00.0 chip ID: 1969:1091
           IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Drives:    Local Storage: total: 1.43 TiB used: 918.82 GiB (62.8%)
           ID-1: /dev/sda vendor: Western Digital model: WD10EFRX-68JCSN0 size: 931.51 GiB
           speed: 6.0 Gb/s serial: <filter>
           ID-2: /dev/sdb vendor: Hitachi model: HTS545032B9A300 size: 298.09 GiB speed: 3.0 Gb/s
           serial: <filter>
           ID-3: /dev/sdc vendor: Samsung model: SSD 860 EVO mSATA 250GB size: 232.89 GiB
           speed: 3.0 Gb/s serial: <filter>
Partition: ID-1: / size: 43.97 GiB used: 16.11 GiB (36.6%) fs: ext4 dev: /dev/sdc2
           ID-2: /home size: 803.13 GiB used: 589.64 GiB (73.4%) fs: xfs dev: /dev/sda4
           ID-3: swap-1 size: 16.11 GiB used: 1024 KiB (0.0%) fs: swap dev: /dev/sdc1
Sensors:   System Temperatures: cpu: 50.0 C mobo: N/A
Repos:     No active apt repos in: /etc/apt/sources.list
           Active apt repos in: /etc/apt/sources.list.d/drweb-apt.list
           1: deb http: //repo.drweb.com/drweb/debian 11.1 non-free
           Active apt repos in: /etc/apt/sources.list.d/nordvpn.list
           1: deb https: //repo.nordvpn.com/deb/nordvpn/debian stable main
           1: deb http: //mirrors.evowise.com/linuxmint/packages tricia main upstream import backport
           2: deb http: //mirror.corbina.net/ubuntu bionic main restricted universe multiverse
           3: deb http: //mirror.corbina.net/ubuntu bionic-updates main restricted universe multiverse
           4: deb http: //mirror.corbina.net/ubuntu bionic-backports main restricted universe multiverse
           5: deb http: //security.ubuntu.com/ubuntu/ bionic-security main restricted universe multiverse
           6: deb http: //archive.canonical.com/ubuntu/ bionic partner
           Active apt repos in: /etc/apt/sources.list.d/skype-stable.list
           1: deb [arch=amd64] https: //repo.skype.com/deb stable main
Info:      Processes: 266 Uptime: 5h 58m Memory: 7.68 GiB used: 3.76 GiB (49.0%) Init: systemd
           v: 237 runlevel: 5 Compilers: gcc: 7.4.0 alt: 7 Client: Unknown python3.6 client
           inxi: 3.0.32
Спасибо.
Решение Ара Магеддон » 29 дек 2019, 23:41
Народ в инете пишет, что нужно выполнить команду sudo chmod u+s /usr/bin/wodim
Или, если не поможет, то установить параметр CDR_FIFOSIZE=6m в файле /etc/wodim.conf
https://bugs.launchpad.net/ubuntu/+sour ... ug/1769848
Благодарил (а): 406 раз
29 дек 2019, 21:15
В меню gparted найди пункт "Создать таблицу разделов" и создай на флэшке раздел ms-dos - т.е. сделай флэшку "загрузочной".
А потом записывай iso.
29 дек 2019, 21:18
Амдир писал(а):
29 дек 2019, 21:06
Ну так дай права. Прожги от рута
29 дек 2019, 21:20
x230 писал(а):
29 дек 2019, 21:15
Где флешка и K3b c Brasero? Говорит же
Амдир писал(а):
29 дек 2019, 21:06
прожечь его на CD
29 дек 2019, 22:30
vir0id писал(а):
29 дек 2019, 21:20
флешка и K3b
упс! :hoho:
29 дек 2019, 23:37
Амдир, Покажите содержимое файла /etc/group
(Текстовый файл, можно через xed открыть на чтение).
Или это может быть баг из ubuntu. Тогда лечится костылем:
Последний раз редактировалось пользователем 1 slant; всего редактировалось раз: 29
Ара Магеддон
Решено: 18
Благодарил (а): 37 раз
29 дек 2019, 23:41
Амдир
30 дек 2019, 15:09
slant, вот файл /etc/group:
root:x:0:
daemon:x:1:
bin:x:2:
sys:x:3:
adm:x:4:syslog,mmm
tty:x:5:
disk:x:6:
lp:x:7:mmm
mail:x:8:
news:x:9:
uucp:x:10:
man:x:12:
proxy:x:13:
kmem:x:15:
dialout:x:20:
fax:x:21:
voice:x:22:
cdrom:x:24:mmm
floppy:x:25:
tape:x:26:
sudo:x:27:mmm
audio:x:29:pulse
dip:x:30:mmm
www-data:x:33:
backup:x:34:
operator:x:37:
list:x:38:
irc:x:39:
src:x:40:
gnats:x:41:
shadow:x:42:
utmp:x:43:
video:x:44:
sasl:x:45:
plugdev:x:46:mmm
staff:x:50:
games:x:60:
users:x:100:
nogroup:x:65534:
systemd-journal:x:101:
systemd-network:x:102:
systemd-resolve:x:103:
input:x:104:
crontab:x:105:
syslog:x:106:
messagebus:x:107:
netdev:x:108:
mlocate:x:109:
ssl-cert:x:110:
uuidd:x:111:
lpadmin:x:112:mmm
rtkit:x:113:
avahi-autoipd:x:114:
ssh:x:115:
bluetooth:x:116:
lightdm:x:117:
nopasswdlogin:x:118:
scanner:x:119:saned,mmm
saned:x:120:mmm
nm-openvpn:x:121:
avahi:x:122:
colord:x:123:
pulse:x:124:
pulse-access:x:125:
geoclue:x:126:
mmm:x:1000:
sambashare:x:127:mmm
drweb:x:1001:
vboxusers:x:128:
Амдир
02 янв 2020, 01:30
Готово! Помогла установка SUID для wodim. Спасибо!
