Почему Conky не могу найти в магазине
djsantehnik
Благодарил (а): 24 раза
29 дек 2019, 17:28
Имеем
  Host: kostusha-MS-7528 Kernel: 4.15.0-72-generic x86_64 bits: 64
  compiler: gcc v: 7.4.0 Desktop: Cinnamon 4.4.5
  Type: Desktop Mobo: MICRO-STAR model: MS-7528 v: 1.0 serial: <filter>
  BIOS: American Megatrends v: 1.2 date: 07/03/2008
  Topology: Quad Core model: Intel Core2 Quad Q8200 bits: 64 type: MCP
  arch: Penryn rev: 7 L2 cache: 2048 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 bogomips: 18729
  Speed: 2339 MHz min/max: N/A Core speeds (MHz): 1: 2339 2: 2338 3: 2338
  4: 2335
  Device-1: AMD Caicos [Radeon HD 6450/7450/8450 / R5 230 OEM]
  vendor: Pegatron driver: radeon v: kernel bus ID: 01:00.0
  Display: x11 server: X.Org 1.19.6 driver: ati,radeon
  unloaded: fbdev,modesetting,vesa resolution: 1440x900~60Hz
  OpenGL: renderer: AMD CAICOS (DRM 2.50.0 / 4.15.0-72-generic LLVM 8.0.0)
  v: 3.3 Mesa 19.0.8 direct render: Yes
  vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  Sound Server: ALSA v: k4.15.0-72-generic
  vendor: Micro-Star MSI driver: r8169 v: 2.3LK-NAPI port: e800
  bus ID: 03:00.0
  IF: ens33 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 1.66 TiB used: 56.18 GiB (3.3%)
  ID-1: /dev/sda vendor: Seagate model: ST3500630A size: 465.76 GiB
  ID-2: /dev/sdb vendor: Hitachi model: HDS721010DLE630 size: 931.51 GiB
  ID-3: /dev/sdc vendor: Hitachi model: HDP725032GLA360 size: 298.09 GiB
  ID-4: /dev/sdd type: USB vendor: Transcend model: JetFlash Transcend 4GB
  ID-1: / size: 27.37 GiB used: 13.56 GiB (49.5%) fs: ext4 dev: /dev/sdb1
  ID-2: /home size: 45.58 GiB used: 38.99 GiB (85.5%) fs: ext4
  dev: /dev/sdb2
  System Temperatures: cpu: 47.0 C mobo: 46.0 C gpu: radeon temp: 47 C
  Fan Speeds (RPM): cpu: 894 fan-2: 0 fan-3: 0 fan-4: 0
  Voltages: 12v: N/A 5v: N/A 3.3v: 3.10 vbat: 3.02
  Processes: 200 Uptime: 5m Memory: 2.93 GiB used: 1.39 GiB (47.4%)
  inxi: 3.0.32
и в нем
а вот после накатывания свежего образа все выглядит так
источники приложений по умолчанию и там и там- как так? (из-за ядра - в оригинале устаревшее 4,15?)
29 дек 2019, 17:54
djsantehnik, покажи на обоих системах
djsantehnik
29 дек 2019, 17:56
Есть репы, но я их гасил смотрел что получится ничего вродь не поменялось
Repos:
  No active apt repos in: /etc/apt/sources.list
  Active apt repos in: /etc/apt/sources.list.d/additional-repositories.list
  1: deb https://dl.winehq.org/wine-builds/ubuntu/ bionic main
  Active apt repos in: /etc/apt/sources.list.d/danielrichter2007-grub-customizer-bionic.list
  1: deb http://ppa.launchpad.net/danielrichter2007/grub-customizer/ubuntu bionic main
  2: deb-src http://ppa.launchpad.net/danielrichter2007/grub-customizer/ubuntu bionic main
  Active apt repos in: /etc/apt/sources.list.d/google-chrome.list
  1: deb [arch=amd64] http://dl.google.com/linux/chrome/deb/ stable main
  Active apt repos in: /etc/apt/sources.list.d/google-earth-pro.list
  1: deb http://dl.google.com/linux/earth/deb/ stable main
  Active apt repos in: /etc/apt/sources.list.d/js-reynaud-kicad-4-bionic.list
  1: deb http://ppa.launchpad.net/js-reynaud/kicad-4/ubuntu bionic main
  2: deb-src http://ppa.launchpad.net/js-reynaud/kicad-4/ubuntu bionic main
  1: deb http://packages.linuxmint.com tricia main upstream import backport
  2: deb http://archive.ubuntu.com/ubuntu bionic main restricted universe multiverse
  3: deb http://archive.ubuntu.com/ubuntu bionic-updates main restricted universe multiverse
  4: deb http://archive.ubuntu.com/ubuntu bionic-backports main restricted universe multiverse
  5: deb http://security.ubuntu.com/ubuntu/ bionic-security main restricted universe multiverse
  6: deb http://archive.canonical.com/ubuntu/ bionic partner
  Active apt repos in: /etc/apt/sources.list.d/playonlinux.list
  1: deb http://deb.playonlinux.com/ precise main
погасил в источниках приложений все репы
Repos:
  No active apt repos in: /etc/apt/sources.list.d/additional-repositories.list
  No active apt repos in: /etc/apt/sources.list.d/danielrichter2007-grub-customizer-bionic.list
  No active apt repos in: /etc/apt/sources.list.d/google-chrome.list
  No active apt repos in: /etc/apt/sources.list.d/google-earth-pro.list
  No active apt repos in: /etc/apt/sources.list.d/js-reynaud-kicad-4-bionic.list
  No active apt repos in: /etc/apt/sources.list.d/playonlinux.list
а выдача в магазине не изменилось - все есть
Последний раз редактировалось пользователем 1 djsantehnik; всего редактировалось раз: 29
29 дек 2019, 17:59
apt policy conky
conky:
  Установлен: (отсутствует)
  Кандидат:   1.10.8-1
  Таблица версий:
     1.10.8-1 500
djsantehnik
29 дек 2019, 18:10
на новой системе все так - Так в магазине то почему пусто по поиску, Пользователю как-то единообразия хочется - а тут бац и проги нет
kostusha@kostusha-Aspire-XC-105:~$ apt policy conky
conky:
  Кандидат:   1.10.8-1
  Таблица версий:
     1.10.8-1 500
        500 http://archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
        500 http://archive.ubuntu.com/ubuntu bionic/universe i386 Packages
djsantehnik
29 дек 2019, 18:15
на новой системе репы - даже больше на одну (если с выключенным вариантом сравнивать)
kostusha@kostusha-Aspire-XC-105:~$ inxi -r
Repos:
Благодарил (а): 406 раз
29 дек 2019, 19:27
а прям в консоли проинсталлить (sudo apt install conky) не айс?
29 дек 2019, 20:16
Блин... x230, опередил. Должно быть айс
djsantehnik
30 дек 2019, 04:48
x230 писал(а):
29 дек 2019, 19:27
запросто, но вопрос то останется - куда прога исчезла, сколько их исчезло вообще, они теперь всегда так исчезать будут и про магазин можно забыть?
Это что ж это такое?
И на что ж это похоже?
Ведь лежать не можно стоя
И стоять не можно лежа.
Можно ж нервный тик
Заработать так.
djsantehnik
30 дек 2019, 05:01
А программа, когда мы её с магазина качаем, она одним деб-файлом идет или там много всего перед началом инсталяции качается, и можно перехватить процесс - Установить прогу и заиметь этот деб (если он один)
30 дек 2019, 05:27
djsantehnik писал(а):
30 дек 2019, 05:01
apt download conky
┌─[✗]─[vir0id]─[~/conky]
└──╼ $sudo dpkg -I conky_1.10.8-1_all.deb
 new Debian package, version 2.0.
 size 36176 bytes: control archive=836 bytes.
     702 байт(а),    18 строк      control
     274 байт(а),     4 строк      md5sums
 Package: conky
 Version: 1.10.8-1
 Architecture: all
 Maintainer: Vincent Cheng <vcheng@debian.org>
 Installed-Size: 45
 Depends: conky-std | conky-cli | conky-all
 Section: oldlibs
 Priority: optional
 Homepage: http://conky.sourceforge.net/
 Description: highly configurable system monitor (transitional package)
  Conky is a system monitor that can display just about anything,
  either on your root desktop or in its own window.
  Conky has many built-in objects, as well as the ability to execute
  external programs or scripts (either external or through built-in
  Lua support).
  This is a dummy package to ease transition to the new packaging scheme.
  It may be safely removed after upgrade/installation.
Depends: conky-std | conky-cli | conky-all Ну и т.д
djsantehnik
30 дек 2019, 05:29
vir0id, а вообще - любая прога это один деб или бывает иначе (с магазина если, без зависимостей)
30 дек 2019, 05:31
30 дек 2019, 05:29
Ну как тут, по тому же принципу. В пакет указывают зависимости. А в пакет тех зависимостей указывают свои зависимости
AlexelA
Благодарил (а): 110 раз
06 окт 2020, 16:55
30 дек 2019, 05:01
По ссылке есть инструкция и необходимые деб-пакеты, сегодня установил на ЛМС20...
