Восстановить GRUB
vlalu
Восстановить GRUB
24 дек 2019, 23:39
LM 19.3 x64 Cinnamon
После попытки переинсталяции загрузчика GRUB c помощью программы Boot Repair, программа выдала ошибку. При перезагрузке компа загрузочного меню нет, только минимал grub>. При работе Boot Repair выдала лог:
Boot Info Script 8f991e4 + Boot-Repair extra info [Boot-Info 25oct2017]
============================= Boot Info Summary: ===============================
=> Grub2 (v2.00) is installed in the MBR of /dev/sda and looks at sector 1 of
the same hard drive for core.img. core.img is at this location and looks
for (,msdos4)/grub. It also embeds following components:
modules
fshelp ext2 part_msdos biosdisk
=> Grub2 (v2.00) is installed in the MBR of /dev/sdb and looks at sector 1 of
for /boot/grub. It also embeds following components:
modules
fshelp ext2 part_msdos biosdisk search_fs_uuid
config script
search.fs_uuid af47bade-8ad6-4f99-942f-e9e68d546475 root hd0,msdos5
set prefix=($root)'/boot/grub'
=> No known boot loader is installed in the MBR of /dev/sdd.
sda1: __________________________________________________________________________
File system: ntfs
Boot sector type: Windows 7/2008: NTFS
Boot sector info: No errors found in the Boot Parameter Block.
Operating System:
Boot files: /grldr /bootmgr /Boot/BCD /grldr
sda2: __________________________________________________________________________
File system: ntfs
Operating System:
/Windows/System32/winload.exe /grldr
sda3: __________________________________________________________________________
File system: Extended Partition
Boot sector type: Unknown
Boot sector info:
sda5: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System: Linux Mint 19.3
Boot files: /etc/fstab /boot/grub/i386-pc/core.img
sda6: __________________________________________________________________________
File system: swap
Boot sector type: -
Boot sector info:
sda7: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System:
Boot files:
sda8: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System: Mageia 7
Boot files: /boot/grub2/grub.cfg /etc/fstab
/boot/grub2/i386-pc/core.img
sda4: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System:
Boot files: /grub/i386-pc/core.img
sdb1: __________________________________________________________________________
File system: ntfs
Boot sector type: Windows Vista: NTFS
Operating System:
Boot files:
sdd1: __________________________________________________________________________
File system: iso9660
Boot sector info:
Mounting failed: mount: /mnt/BootInfo/sdd1: /dev/sdd1 already mounted or mount point busy.
sdd2: __________________________________________________________________________
File system: vfat
Boot sector type: FAT16
Boot sector info: According to the info in the boot sector, sdd2 starts
at sector 0. But according to the info from fdisk,
sdd2 starts at sector 680. According to the info in
the boot sector, sdd2 has 0 sectors.
mount: /mnt/BootInfo/sdd2: /dev/sdd2 already mounted or mount point busy.
============================ Drive/Partition Info: =============================
Drive: sda _____________________________________________________________________
Disk /dev/sda: 232.9 GiB, 250059350016 bytes, 488397168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
Disklabel type: dos
Partition Boot Start Sector End Sector # of Sectors Id System
/dev/sda1 2,048 206,847 204,800 7 NTFS / exFAT / HPFS
/dev/sda2 206,848 155,105,279 154,898,432 7 NTFS / exFAT / HPFS
/dev/sda3 157,945,854 416,718,847 258,772,994 f W95 Extended (LBA)
/dev/sda5 252,995,584 348,366,677 95,371,094 83 Linux
/dev/sda6 348,368,896 364,199,935 15,831,040 82 Linux swap / Solaris
/dev/sda7 364,201,984 416,718,847 52,516,864 83 Linux
/dev/sda8 157,945,856 252,993,535 95,047,680 83 Linux
/dev/sda4 * 155,105,280 157,943,807 2,838,528 83 Linux
Drive: sdb _____________________________________________________________________
Disk /dev/sdb: 596.2 GiB, 640135028736 bytes, 1250263728 sectors
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
/dev/sdb1 245,760 800,413,695 800,167,936 7 NTFS / exFAT / HPFS
Drive: sdd _____________________________________________________________________
Disk /dev/sdd: 3.7 GiB, 4004511744 bytes, 7821312 sectors
Disklabel type: dos
/dev/sdd1 * 0 3,978,175 3,978,176 0 Empty
/dev/sdd2 680 5,607 4,928 ef EFI (FAT-12/16/32)
/dev/sdd1 overlaps with /dev/sdd2
GUID Partition Table detected, but does not seem to be used.
Partition Attrs Start Sector End Sector # of Sectors System
/dev/sdd1 + R 0 3,978,119 3,978,120 Data partition (Windows/Linux)
/dev/sdd2 + R 680 5,607 4,928 Data partition (Windows/Linux)
Attributes: R=Required, N=No Block IO, B=Legacy BIOS Bootable, +=More bits set
"blkid" output: ________________________________________________________________
Device UUID TYPE LABEL
/dev/loop0 squashfs
/dev/sda1 A21CDE351CDE0467 ntfs System Reserved
/dev/sda2 A85EEDDC5EEDA374 ntfs Windows
/dev/sda4 2255c72d-43ef-40b0-8608-16a2e5b56ce9 ext4 /boot
/dev/sda5 af47bade-8ad6-4f99-942f-e9e68d546475 ext4
/dev/sda6 4ebacfb8-79c2-4cfb-ad6f-76ec85818855 swap
/dev/sda7 1815f9be-c20a-4280-8cfd-b5e66c47d03f ext4
/dev/sda8 e15415a1-19e8-4574-a8c9-b684a5a4e408 ext4
/dev/sdb1 75EE86DE1209B8B0 ntfs Data
/dev/sdd1 2019-12-13-16-58-44-00 iso9660 Linux Mint 19.3 Cinnamon 64-bit
/dev/sdd2 833C-CDB0 vfat
========================= "ls -l /dev/disk/by-id" output: ======================
total 0
lrwxrwxrwx 1 root root 9 Dec 24 18:23 ata-Samsung_SSD_850_EVO_250GB_S21PNSBG933514P -> ../../sda
lrwxrwxrwx 1 root root 10 Dec 24 18:24 ata-Samsung_SSD_850_EVO_250GB_S21PNSBG933514P-part1 -> ../../sda1
lrwxrwxrwx 1 root root 10 Dec 24 18:24 ata-Samsung_SSD_850_EVO_250GB_S21PNSBG933514P-part2 -> ../../sda2
lrwxrwxrwx 1 root root 10 Dec 24 18:23 ata-Samsung_SSD_850_EVO_250GB_S21PNSBG933514P-part3 -> ../../sda3
lrwxrwxrwx 1 root root 10 Dec 24 18:23 ata-Samsung_SSD_850_EVO_250GB_S21PNSBG933514P-part4 -> ../../sda4
lrwxrwxrwx 1 root root 10 Dec 24 18:23 ata-Samsung_SSD_850_EVO_250GB_S21PNSBG933514P-part5 -> ../../sda5
lrwxrwxrwx 1 root root 10 Dec 24 18:23 ata-Samsung_SSD_850_EVO_250GB_S21PNSBG933514P-part6 -> ../../sda6
lrwxrwxrwx 1 root root 10 Dec 24 18:23 ata-Samsung_SSD_850_EVO_250GB_S21PNSBG933514P-part7 -> ../../sda7
lrwxrwxrwx 1 root root 10 Dec 24 18:23 ata-Samsung_SSD_850_EVO_250GB_S21PNSBG933514P-part8 -> ../../sda8
lrwxrwxrwx 1 root root 9 Dec 24 18:15 ata-WDC_WD6400BPVT-75HXZT1_WD-WX41A1178402 -> ../../sdb
lrwxrwxrwx 1 root root 10 Dec 24 18:24 ata-WDC_WD6400BPVT-75HXZT1_WD-WX41A1178402-part1 -> ../../sdb1
lrwxrwxrwx 1 root root 9 Dec 24 18:24 usb-Generic-_Multi-Card_20090516388200000-0:0 -> ../../sdc
lrwxrwxrwx 1 root root 9 Dec 24 18:15 usb-SanDisk_Cruzer_2005173781029D71C0A5-0:0 -> ../../sdd
lrwxrwxrwx 1 root root 10 Dec 24 18:15 usb-SanDisk_Cruzer_2005173781029D71C0A5-0:0-part1 -> ../../sdd1
lrwxrwxrwx 1 root root 10 Dec 24 18:15 usb-SanDisk_Cruzer_2005173781029D71C0A5-0:0-part2 -> ../../sdd2
lrwxrwxrwx 1 root root 9 Dec 24 18:15 wwn-0x50014ee6ab8fdf44 -> ../../sdb
lrwxrwxrwx 1 root root 10 Dec 24 18:24 wwn-0x50014ee6ab8fdf44-part1 -> ../../sdb1
lrwxrwxrwx 1 root root 9 Dec 24 18:23 wwn-0x5002538da037bb27 -> ../../sda
lrwxrwxrwx 1 root root 10 Dec 24 18:24 wwn-0x5002538da037bb27-part1 -> ../../sda1
lrwxrwxrwx 1 root root 10 Dec 24 18:24 wwn-0x5002538da037bb27-part2 -> ../../sda2
lrwxrwxrwx 1 root root 10 Dec 24 18:23 wwn-0x5002538da037bb27-part3 -> ../../sda3
lrwxrwxrwx 1 root root 10 Dec 24 18:23 wwn-0x5002538da037bb27-part4 -> ../../sda4
lrwxrwxrwx 1 root root 10 Dec 24 18:23 wwn-0x5002538da037bb27-part5 -> ../../sda5
lrwxrwxrwx 1 root root 10 Dec 24 18:23 wwn-0x5002538da037bb27-part6 -> ../../sda6
lrwxrwxrwx 1 root root 10 Dec 24 18:23 wwn-0x5002538da037bb27-part7 -> ../../sda7
lrwxrwxrwx 1 root root 10 Dec 24 18:23 wwn-0x5002538da037bb27-part8 -> ../../sda8
================================ Mount points: =================================
Device Mount_Point Type Options
/dev/loop0 /rofs squashfs (ro,noatime)
/dev/sdd /cdrom iso9660 (ro,noatime,nojoliet,check=s,map=n,blocksize=2048)
========================== sda1/grldr embedded menu: ===========================
========================== sda2/grldr embedded menu: ===========================
=============================== sda5/etc/fstab: ================================
# / was on /dev/sda5 during installation
UUID=af47bade-8ad6-4f99-942f-e9e68d546475 / ext4 errors=remount-ro 0 1
# swap was on /dev/sda6 during installation
UUID=4ebacfb8-79c2-4cfb-ad6f-76ec85818855 none swap sw 0 0
UUID=2255c72d-43ef-40b0-8608-16a2e5b56ce9 /boot ext4 defaults 0 2
=================== sda5: Location of files loaded by Grub: ====================
GiB - GB File Fragment(s)
146.838890076 = 157.667057664 boot/grub/i386-pc/core.img 1
127.559478760 = 136.965947392 boot/vmlinuz-4.15.0-50-generic 1
148.043922424 = 158.960951296 boot/vmlinuz-4.15.0-72-generic 1
132.255233765 = 142.007975936 boot/vmlinuz-5.0.0-32-generic 2
142.606811523 = 153.122897920 boot/vmlinuz-5.0.0-37-generic 2
142.606811523 = 153.122897920 vmlinuz 2
132.255233765 = 142.007975936 vmlinuz.old 2
149.156814575 = 160.155910144 boot/initrd.img-4.15.0-50-generic 3
142.746921539 = 153.273339904 boot/initrd.img-4.15.0-72-generic 3
144.489055634 = 155.143942144 boot/initrd.img-5.0.0-32-generic 6
144.614070892 = 155.278176256 boot/initrd.img-5.0.0-37-generic 4
144.614070892 = 155.278176256 initrd.img 4
144.489055634 = 155.143942144 initrd.img.old 6
========================== sda8/boot/grub2/grub.cfg: ===========================
# DO NOT EDIT THIS FILE
# It is automatically generated by grub2-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
set pager=1
if [ -s $prefix/grubenv ]; then
load_env
fi
if [ "${next_entry}" ] ; then
set default="${next_entry}"
set next_entry=
save_env next_entry
set boot_once=true
else
set default="${saved_entry}"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
menuentry_id_option="--id"
else
menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function load_video {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
if [ x$feature_default_font_path = xy ] ; then
font=unicode
else
insmod part_msdos
insmod ext2
set root='hd0,msdos8'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos8 --hint-efi=hd0,msdos8 --hint-baremetal=ahci0,msdos8 e15415a1-19e8-4574-a8c9-b684a5a4e408
else
search --no-floppy --fs-uuid --set=root e15415a1-19e8-4574-a8c9-b684a5a4e408
fi
font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
set gfxmode=1024x768x32
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=ru_RU
insmod gettext
fi
terminal_output gfxterm
insmod part_msdos
insmod ext2
else
fi
insmod gfxmenu
loadfont ($root)/boot/grub2/themes/maggy/MageiaLogo-Bold-16.pf2
loadfont ($root)/boot/grub2/themes/maggy/MageiaLogo-Bold-20.pf2
loadfont ($root)/boot/grub2/themes/maggy/MageiaLogo-Bold-28.pf2
loadfont ($root)/boot/grub2/themes/maggy/MageiaLogo-Regular-20.pf2
insmod png
set theme=($root)/boot/grub2/themes/maggy/theme.txt
export theme
if [ x$feature_timeout_style = xy ] ; then
set timeout_style=menu
set timeout=30
# Fallback normal timeout code in case the timeout_style feature is
# unavailable.
else
set timeout=30
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/01_users ###
if [ -f ${prefix}/user.cfg ]; then
source ${prefix}/user.cfg
if [ -n "${GRUB2_PASSWORD}" ]; then
set superusers="root"
export superusers
password_pbkdf2 root ${GRUB2_PASSWORD}
fi
fi
### END /etc/grub.d/01_users ###
### BEGIN /etc/grub.d/10_linux ###
menuentry 'Mageia' --class mageia --class gnu-linux --class gnu --class os --unrestricted $menuentry_id_option 'gnulinux-simple-e15415a1-19e8-4574-a8c9-b684a5a4e408' {
savedefault
set gfxpayload=text
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux16 /boot/vmlinuz-5.4.2-desktop-1.mga7 root=UUID=e15415a1-19e8-4574-a8c9-b684a5a4e408 ro splash quiet noiswmd resume=UUID=4ebacfb8-79c2-4cfb-ad6f-76ec85818855 audit=0
initrd16 /boot/initrd-5.4.2-desktop-1.mga7.img
submenu 'а”аОаПаОаЛаНаИб‚аЕаЛбŒаНб‹аЕ аПаАб€аАаМаЕб‚б€б‹ аДаЛб Mageia' $menuentry_id_option 'gnulinux-advanced-e15415a1-19e8-4574-a8c9-b684a5a4e408' {
menuentry 'Mageia (5.4.2-desktop-1.mga7) 7' --class mageia --class gnu-linux --class gnu --class os --unrestricted $menuentry_id_option 'gnulinux-5.4.2-desktop-1.mga7-advanced-e15415a1-19e8-4574-a8c9-b684a5a4e408' {
savedefault
set gfxpayload=text
insmod gzio
insmod part_msdos
insmod ext2
else
fi
menuentry 'Mageia (5.4.2-desktop-1.mga7) 7 (recovery mode)' --class mageia --class gnu-linux --class gnu --class os --unrestricted $menuentry_id_option 'gnulinux-5.4.2-desktop-1.mga7-recovery-e15415a1-19e8-4574-a8c9-b684a5a4e408' {
set gfxpayload=text
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux16 /boot/vmlinuz-5.4.2-desktop-1.mga7 root=UUID=e15415a1-19e8-4574-a8c9-b684a5a4e408 ro failsafe
menuentry 'Mageia (4.18.20-desktop-1.mga6) 7' --class mageia --class gnu-linux --class gnu --class os --unrestricted $menuentry_id_option 'gnulinux-4.18.20-desktop-1.mga6-advanced-e15415a1-19e8-4574-a8c9-b684a5a4e408' {
savedefault
set gfxpayload=text
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux16 /boot/vmlinuz-4.18.20-desktop-1.mga6 root=UUID=e15415a1-19e8-4574-a8c9-b684a5a4e408 ro splash quiet noiswmd resume=UUID=4ebacfb8-79c2-4cfb-ad6f-76ec85818855 audit=0
initrd16 /boot/initrd-4.18.20-desktop-1.mga6.img
menuentry 'Mageia (4.18.20-desktop-1.mga6) 7 (recovery mode)' --class mageia --class gnu-linux --class gnu --class os --unrestricted $menuentry_id_option 'gnulinux-4.18.20-desktop-1.mga6-recovery-e15415a1-19e8-4574-a8c9-b684a5a4e408' {
set gfxpayload=text
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux16 /boot/vmlinuz-4.18.20-desktop-1.mga6 root=UUID=e15415a1-19e8-4574-a8c9-b684a5a4e408 ro failsafe
menuentry 'Mageia (4.14.70-desktop-2.mga6) 7' --class mageia --class gnu-linux --class gnu --class os --unrestricted $menuentry_id_option 'gnulinux-4.14.70-desktop-2.mga6-advanced-e15415a1-19e8-4574-a8c9-b684a5a4e408' {
savedefault
set gfxpayload=text
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux16 /boot/vmlinuz-4.14.70-desktop-2.mga6 root=UUID=e15415a1-19e8-4574-a8c9-b684a5a4e408 ro splash quiet noiswmd resume=UUID=4ebacfb8-79c2-4cfb-ad6f-76ec85818855 audit=0
initrd16 /boot/initrd-4.14.70-desktop-2.mga6.img
menuentry 'Mageia (4.14.70-desktop-2.mga6) 7 (recovery mode)' --class mageia --class gnu-linux --class gnu --class os --unrestricted $menuentry_id_option 'gnulinux-4.14.70-desktop-2.mga6-recovery-e15415a1-19e8-4574-a8c9-b684a5a4e408' {
set gfxpayload=text
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux16 /boot/vmlinuz-4.14.70-desktop-2.mga6 root=UUID=e15415a1-19e8-4574-a8c9-b684a5a4e408 ro failsafe
menuentry 'Mageia (desktop) 7' --class mageia --class gnu-linux --class gnu --class os --unrestricted $menuentry_id_option 'gnulinux-desktop-advanced-e15415a1-19e8-4574-a8c9-b684a5a4e408' {
savedefault
set gfxpayload=text
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux16 /boot/vmlinuz-desktop root=UUID=e15415a1-19e8-4574-a8c9-b684a5a4e408 ro splash quiet noiswmd resume=UUID=4ebacfb8-79c2-4cfb-ad6f-76ec85818855 audit=0
initrd16 /boot/initrd-desktop.img
menuentry 'Mageia (desktop) 7 (recovery mode)' --class mageia --class gnu-linux --class gnu --class os --unrestricted $menuentry_id_option 'gnulinux-desktop-recovery-e15415a1-19e8-4574-a8c9-b684a5a4e408' {
set gfxpayload=text
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux16 /boot/vmlinuz-desktop root=UUID=e15415a1-19e8-4574-a8c9-b684a5a4e408 ro failsafe
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/20_ppc_terminfo ###
### END /etc/grub.d/20_ppc_terminfo ###
### BEGIN /etc/grub.d/30_os-prober ###
menuentry 'Windows 7 (аНаА /dev/sda1)' --class windows --class os $menuentry_id_option 'osprober-chain-A21CDE351CDE0467' {
savedefault
insmod part_msdos
insmod ntfs
set root='hd0,msdos1'
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos1 --hint-efi=hd0,msdos1 --hint-baremetal=ahci0,msdos1 A21CDE351CDE0467
else
search --no-floppy --fs-uuid --set=root A21CDE351CDE0467
fi
parttool ${root} hidden-
chainloader +1
menuentry 'Linux Mint 19.3 Tricia (19.3) (аНаА /dev/sda5)' --class linuxmint --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-af47bade-8ad6-4f99-942f-e9e68d546475' {
savedefault
insmod part_msdos
insmod ext2
set root='hd0,msdos5'
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos5 --hint-efi=hd0,msdos5 --hint-baremetal=ahci0,msdos5 af47bade-8ad6-4f99-942f-e9e68d546475
else
search --no-floppy --fs-uuid --set=root af47bade-8ad6-4f99-942f-e9e68d546475
fi
linux /boot/vmlinuz-4.15.0-50-generic root=UUID=af47bade-8ad6-4f99-942f-e9e68d546475 ro quiet splash $vt_handoff
initrd /boot/initrd.img-4.15.0-50-generic
submenu 'а”аОаПаОаЛаНаИб‚аЕаЛбŒаНб‹аЕ аПаАб€аАаМаЕб‚б€б‹ аДаЛб Linux Mint 19.3 Tricia (19.3) (аНаА /dev/sda5)' $menuentry_id_option 'osprober-gnulinux-advanced-af47bade-8ad6-4f99-942f-e9e68d546475' {
menuentry 'Linux Mint 19.1 Tessa (аНаА /dev/sda5)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-4.15.0-50-generic--af47bade-8ad6-4f99-942f-e9e68d546475' {
savedefault
insmod part_msdos
insmod ext2
else
fi
menuentry 'Ubuntu, б Linux 5.0.0-37-generic (аНаА /dev/sda5)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-5.0.0-37-generic--af47bade-8ad6-4f99-942f-e9e68d546475' {
savedefault
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-5.0.0-37-generic root=UUID=af47bade-8ad6-4f99-942f-e9e68d546475 ro quiet splash $vt_handoff
initrd /boot/initrd.img-5.0.0-37-generic
menuentry 'Ubuntu, б Linux 5.0.0-37-generic (recovery mode) (аНаА /dev/sda5)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-5.0.0-37-generic--af47bade-8ad6-4f99-942f-e9e68d546475' {
savedefault
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-5.0.0-37-generic root=UUID=af47bade-8ad6-4f99-942f-e9e68d546475 ro recovery nomodeset
menuentry 'Ubuntu, б Linux 5.0.0-32-generic (аНаА /dev/sda5)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-5.0.0-32-generic--af47bade-8ad6-4f99-942f-e9e68d546475' {
savedefault
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-5.0.0-32-generic root=UUID=af47bade-8ad6-4f99-942f-e9e68d546475 ro quiet splash $vt_handoff
initrd /boot/initrd.img-5.0.0-32-generic
menuentry 'Ubuntu, б Linux 5.0.0-32-generic (recovery mode) (аНаА /dev/sda5)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-5.0.0-32-generic--af47bade-8ad6-4f99-942f-e9e68d546475' {
savedefault
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-5.0.0-32-generic root=UUID=af47bade-8ad6-4f99-942f-e9e68d546475 ro recovery nomodeset
menuentry 'Ubuntu, б Linux 4.15.0-72-generic (аНаА /dev/sda5)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-4.15.0-72-generic--af47bade-8ad6-4f99-942f-e9e68d546475' {
savedefault
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-4.15.0-72-generic root=UUID=af47bade-8ad6-4f99-942f-e9e68d546475 ro quiet splash $vt_handoff
initrd /boot/initrd.img-4.15.0-72-generic
menuentry 'Ubuntu, б Linux 4.15.0-72-generic (recovery mode) (аНаА /dev/sda5)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-4.15.0-72-generic--af47bade-8ad6-4f99-942f-e9e68d546475' {
savedefault
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-4.15.0-72-generic root=UUID=af47bade-8ad6-4f99-942f-e9e68d546475 ro recovery nomodeset
savedefault
insmod part_msdos
insmod ext2
else
fi
menuentry 'Linux Mint 19.1 Tessa, б Linux 4.15.0-50-generic (аНаА /dev/sda5)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-4.15.0-50-generic--af47bade-8ad6-4f99-942f-e9e68d546475' {
savedefault
insmod part_msdos
insmod ext2
else
fi
menuentry 'Linux Mint 19.1 Tessa, б Linux 4.15.0-50-generic (recovery mode) (аНаА /dev/sda5)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-4.15.0-50-generic--af47bade-8ad6-4f99-942f-e9e68d546475' {
savedefault
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-4.15.0-50-generic root=UUID=af47bade-8ad6-4f99-942f-e9e68d546475 ro recovery nomodeset
menuentry 'Memory test (memtest86+, serial console 115200) (аНаА /dev/sda5)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/memtest86+.bin--af47bade-8ad6-4f99-942f-e9e68d546475' {
savedefault
insmod part_msdos
insmod ext2
else
fi
linux /boot/memtest86+.bin console=ttyS0,115200n8
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
=============================== sda8/etc/fstab: ================================
# Entry for /dev/sda8 :
UUID=e15415a1-19e8-4574-a8c9-b684a5a4e408 / ext4 noatime,acl 1 1
# Entry for /dev/sda7 :
UUID=1815f9be-c20a-4280-8cfd-b5e66c47d03f /home ext4 noatime,acl 1 2
# Entry for /dev/sdb1 :
UUID=75EE86DE1209B8B0 /media/win_c ntfs-3g defaults,nofail,umask=000 0 0
# Entry for /dev/sda2 :
UUID=A85EEDDC5EEDA374 /media/win_d ntfs-3g defaults,nofail,umask=000 0 0
none /proc proc defaults 0 0
# Entry for /dev/sda6 :
UUID=4ebacfb8-79c2-4cfb-ad6f-76ec85818855 swap swap defaults 0 0
=================== sda8: Location of files loaded by Grub: ====================
101.448116302 = 108.929085440 boot/grub2/grub.cfg 1
101.443714142 = 108.924358656 boot/grub2/i386-pc/core.img 1
83.139038086 = 89.269862400 boot/vmlinuz 2
101.522682190 = 109.009149952 boot/vmlinuz-4.14.70-desktop-2.mga6 1
101.507293701 = 108.992626688 boot/vmlinuz-4.18.20-desktop-1.mga6 1
83.139038086 = 89.269862400 boot/vmlinuz-5.4.2-desktop-1.mga7 2
83.139038086 = 89.269862400 boot/vmlinuz-desktop 2
80.251949310 = 86.169874432 boot/initrd-4.14.13-desktop-1.mga6.img.old 2
80.238357544 = 86.155280384 boot/initrd-4.14.16-desktop-1.mga6.img.old 1
78.170127869 = 83.934535680 boot/initrd-4.14.18-desktop-1.mga6.img.old 2
78.168067932 = 83.932323840 boot/initrd-4.14.20-desktop-1.mga6.img.old 2
78.161212921 = 83.924963328 boot/initrd-4.14.25-desktop-1.mga6.img.old 2
78.050884247 = 83.806498816 boot/initrd-4.14.30-desktop-3.mga6.img.old 2
78.025386810 = 83.779121152 boot/initrd-4.14.40-desktop-1.mga6.img.old 2
78.048824310 = 83.804286976 boot/initrd-4.14.44-desktop-2.mga6.img.old 2
78.180900574 = 83.946102784 boot/initrd-4.14.56-desktop-1.mga6.img.old 2
78.918056488 = 84.737617920 boot/initrd-4.14.70-desktop-2.mga6.img 2
77.970699310 = 83.720400896 boot/initrd-4.14.70-desktop-2.mga6.img.old 2
80.385803223 = 86.313598976 boot/initrd-4.18.20-desktop-1.mga6.img 2
83.821186066 = 90.002313216 boot/initrd-5.4.2-desktop-1.mga7.img 2
83.821186066 = 90.002313216 boot/initrd-desktop.img 2
83.821186066 = 90.002313216 boot/initrd.img 2
=================== sda4: Location of files loaded by Grub: ====================
74.091117859 = 79.554732032 grub/i386-pc/core.img 1
======================== Unknown MBRs/Boot Sectors/etc: ========================
Unknown MBR on /dev/sdd
00000000 45 52 08 00 00 00 90 90 00 00 00 00 00 00 00 00 |ER..............|
00000010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00000020 33 ed fa 8e d5 bc 00 7c fb fc 66 31 db 66 31 c9 |3......|..f1.f1.|
00000030 66 53 66 51 06 57 8e dd 8e c5 52 be 00 7c bf 00 |fSfQ.W....R..|..|
00000040 06 b9 00 01 f3 a5 ea 4b 06 00 00 52 b4 41 bb aa |.......K...R.A..|
00000050 55 31 c9 30 f6 f9 cd 13 72 16 81 fb 55 aa 75 10 |U1.0....r...U.u.|
00000060 83 e1 01 74 0b 66 c7 06 f1 06 b4 42 eb 15 eb 00 |...t.f.....B....|
00000070 5a 51 b4 08 cd 13 83 e1 3f 5b 51 0f b6 c6 40 50 |ZQ......?[Q...@P|
00000080 f7 e1 53 52 50 bb 00 7c b9 04 00 66 a1 b0 07 e8 |..SRP..|...f....|
00000090 44 00 0f 82 80 00 66 40 80 c7 02 e2 f2 66 81 3e |D.....f@.....f.>|
000000a0 40 7c fb c0 78 70 75 09 fa bc ec 7b ea 44 7c 00 |@|..xpu....{.D|.|
000000b0 00 e8 83 00 69 73 6f 6c 69 6e 75 78 2e 62 69 6e |....isolinux.bin|
000000c0 20 6d 69 73 73 69 6e 67 20 6f 72 20 63 6f 72 72 | missing or corr|
000000d0 75 70 74 2e 0d 0a 66 60 66 31 d2 66 03 06 f8 7b |upt...f`f1.f...{|
000000e0 66 13 16 fc 7b 66 52 66 50 06 53 6a 01 6a 10 89 |f...{fRfP.Sj.j..|
000000f0 e6 66 f7 36 e8 7b c0 e4 06 88 e1 88 c5 92 f6 36 |.f.6.{.........6|
00000100 ee 7b 88 c6 08 e1 41 b8 01 02 8a 16 f2 7b cd 13 |.{....A......{..|
00000110 8d 64 10 66 61 c3 e8 1e 00 4f 70 65 72 61 74 69 |.d.fa....Operati|
00000120 6e 67 20 73 79 73 74 65 6d 20 6c 6f 61 64 20 65 |ng system load e|
00000130 72 72 6f 72 2e 0d 0a 5e ac b4 0e 8a 3e 62 04 b3 |rror...^....>b..|
00000140 07 cd 10 3c 0a 75 f1 cd 18 f4 eb fd 00 00 00 00 |...<.u..........|
00000150 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00000160 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00000170 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00000180 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00000190 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
000001a0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
000001b0 e8 15 00 00 00 00 00 00 c4 4a da 1d 00 00 80 00 |.........J......|
000001c0 01 00 00 79 e0 fa 00 00 00 00 c0 b3 3c 00 00 fe |...y........<...|
000001d0 ff ff ef fe ff ff a8 02 00 00 40 13 00 00 00 00 |..........@.....|
000001e0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
000001f0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 aa |..............U.|
00000200
/dev/sdd1: unknown GPT attributes
1000000000000001
/dev/sdd2: unknown GPT attributes
1000000000000001
Unknown BootLoader on sda3
Unknown BootLoader on sdd1
00000200
========= Devices which don't seem to have a corresponding hard drive: =========
sdc
=============================== StdErr Messages: ===============================
hexdump: /dev/sda3: No such device or address
File descriptor 9 (/proc/18201/mountinfo) leaked on lvs invocation. Parent PID 1467: bash
File descriptor 63 (pipe:[89810]) leaked on lvs invocation. Parent PID 1467: bash
ADDITIONAL INFORMATION :
=================== log of boot-repair 20191224_1815 ===================
boot-repair version : 4ppa65
boot-sav version : 4ppa65
boot-sav-extra version : 4ppa65
glade2script version : 3.2.3~ppa4
grub-probe: error: cannot find a GRUB drive for /dev/sdd1. Check your device.map.
Warning: The driver descriptor says the physical block size is 2048 bytes, but Linux says it is 512 bytes.
boot-repair is executed in live-session (Linux Mint 19.3 Tricia, tricia, LinuxMint, x86_64)
CPU op-mode(s): 32-bit, 64-bit
BOOT_IMAGE=/casper/vmlinuz file=/cdrom/preseed/linuxmint.seed boot=casper initrd=/casper/initrd.lz quiet splash --
ls: cannot access '/home/usr/.config': No such file or directory
=================== os-prober:
/dev/sda1:Windows 7:Windows:chain
/dev/sda2:Windows 7:Windows1:chain
/dev/sda5:Linux Mint 19.3 Tricia (19.3):LinuxMint:linux
/dev/sda8:Mageia 7 (7):Mageia:linux
=================== blkid:
/dev/sda1: LABEL="System Reserved" UUID="A21CDE351CDE0467" TYPE="ntfs" PARTUUID="0c7a859b-01"
/dev/sda2: LABEL="Windows" UUID="A85EEDDC5EEDA374" TYPE="ntfs" PARTUUID="0c7a859b-02"
/dev/sda5: UUID="af47bade-8ad6-4f99-942f-e9e68d546475" TYPE="ext4" PARTUUID="0c7a859b-05"
/dev/sda7: UUID="1815f9be-c20a-4280-8cfd-b5e66c47d03f" TYPE="ext4" PARTUUID="0c7a859b-07"
/dev/sda8: UUID="e15415a1-19e8-4574-a8c9-b684a5a4e408" TYPE="ext4" PARTUUID="0c7a859b-08"
/dev/sdb1: LABEL="Data" UUID="75EE86DE1209B8B0" TYPE="ntfs" PARTUUID="1efcbac3-01"
/dev/loop0: TYPE="squashfs"
/dev/sda6: UUID="4ebacfb8-79c2-4cfb-ad6f-76ec85818855" TYPE="swap" PARTUUID="0c7a859b-06"
/dev/sdd2: SEC_TYPE="msdos" UUID="833C-CDB0" TYPE="vfat" PARTUUID="1dda4ac4-02"
/dev/sda4: LABEL="/boot" UUID="2255c72d-43ef-40b0-8608-16a2e5b56ce9" TYPE="ext4" PARTUUID="0c7a859b-04"
/dev/sdd1: UUID="2019-12-13-16-58-44-00" LABEL="Linux Mint 19.3 Cinnamon 64-bit" TYPE="iso9660" PTUUID="1dda4ac4" PTTYPE="dos" PARTUUID="1dda4ac4-01"
1 disks with OS, 4 OS : 2 Linux, 0 MacOS, 2 Windows, 0 unknown type OS.
=================== sda5/etc/grub.d/ :
drwxr-xr-x 2 root root 4096 Dec 23 19:09 grub.d
drwxr-xr-x 5 root root 4096 Dec 23 19:08 grub.d.bak
total 76
-rwxr-xr-x 1 root root 10046 Nov 11 05:52 00_header
-rwxr-xr-x 1 root root 6258 Mar 18 2019 05_debian_theme
-rwxr-xr-x 1 root root 12693 Nov 11 05:52 10_linux
-rwxr-xr-x 1 root root 11298 Nov 11 05:52 20_linux_xen
-rwxr-xr-x 1 root root 12059 Nov 11 05:52 30_os-prober
-rwxr-xr-x 1 root root 1418 Nov 11 05:52 30_uefi-firmware
-rwxr-xr-x 1 root root 214 Nov 11 05:52 40_custom
-rwxr-xr-x 1 root root 216 Nov 11 05:52 41_custom
-rw-r--r-- 1 root root 483 Nov 11 05:52 README
=================== sda5/etc/default/grub :
# /boot/grub/grub.cfg.
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=10
GRUB_CMDLINE_LINUX=""
#GRUB_TERMINAL=console
#GRUB_GFXMODE=640x480
#GRUB_DISABLE_LINUX_UUID=true
#GRUB_DISABLE_RECOVERY="true"
#GRUB_INIT_TUNE="480 440 1"
=================== sda8/etc/grub.d/ :
drwxr-xr-x 3 root root 4096 Dec 23 15:17 grub.d
total 72
-rwxr-xr-x 1 root root 8703 May 11 2019 00_header
-rwxr-xr-x 1 root root 236 May 11 2019 01_users
-rwxr-xr-x 1 root root 10594 May 11 2019 10_linux
-rwxr-xr-x 1 root root 10487 May 11 2019 20_linux_xen
-rwxr-xr-x 1 root root 2562 May 11 2019 20_ppc_terminfo
-rwxr-xr-x 1 root root 11817 May 11 2019 30_os-prober
-rwxr-xr-x 1 root root 218 May 11 2019 40_custom
-rwxr-xr-x 1 root root 220 May 11 2019 41_custom
-rw-r--r-- 1 root root 483 May 21 2015 README
drwxr-xr-x 4 root root 4096 Jul 13 2018 backup
=================== sda8/etc/default/grub :
GRUB_CMDLINE_LINUX_DEFAULT="splash quiet noiswmd resume=UUID=4ebacfb8-79c2-4cfb-ad6f-76ec85818855 audit=0"
GRUB_DEFAULT=saved
GRUB_DISABLE_OS_PROBER=false
GRUB_DISABLE_RECOVERY=false
GRUB_DISABLE_SUBMENU=n
GRUB_DISTRIBUTOR=Mageia
GRUB_ENABLE_CRYPTODISK=y
GRUB_GFXMODE=1024x768x32
GRUB_GFXPAYLOAD_LINUX=text
GRUB_SAVEDEFAULT=true
GRUB_TERMINAL_OUTPUT=gfxterm
GRUB_THEME=/boot/grub2/themes/maggy/theme.txt
GRUB_TIMEOUT=30
=================== UEFI/Legacy mode:
This live-session is not in EFI-mode.
SecureBoot maybe enabled.
=================== PARTITIONS & DISKS:
sda1 : sda, not-sepboot, no-grubenv nogrub, no-docgrub, no-update-grub, 32, no-boot, is-os, not--efi--part, part-has-no-fstab, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, bootmgr, is-winboot, nopakmgr, nogrubinstall, no---usr, part-has-no-fstab, not-sep-usr, standard, not-far, notbiosboot, /mnt/boot-sav/sda1.
sda2 : sda, not-sepboot, no-grubenv nogrub, no-docgrub, no-update-grub, 32, no-boot, is-os, not--efi--part, part-has-no-fstab, part-has-no-fstab, no-nt, haswinload, no-recov-nor-hid, bootmgr, is-winboot, nopakmgr, nogrubinstall, no---usr, part-has-no-fstab, not-sep-usr, standard, not-far, notbiosboot, /mnt/boot-sav/sda2.
sda5 : sda, not-sepboot, grubenv-ok grub2, grub-pc , update-grub, 64, with-boot, is-os, not--efi--part, fstab-without-boot, fstab-without-efi, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, apt-get, grub-install, with--usr, fstab-without-usr, not-sep-usr, standard, farbios, notbiosboot, /mnt/boot-sav/sda5.
sda7 : sda, maybesepboot, no-grubenv nogrub, no-docgrub, no-update-grub, 32, no-boot, no-os, not--efi--part, part-has-no-fstab, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, nopakmgr, nogrubinstall, no---usr, part-has-no-fstab, not-sep-usr, standard, farbios, notbiosboot, /mnt/boot-sav/sda7.
sda8 : sda, not-sepboot, no-grubenv grub2, grub-pc , update-grub, 64, with-boot, is-os, not--efi--part, fstab-without-boot, fstab-without-efi, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, nopakmgr, grub2-install, with--usr, fstab-without-usr, not-sep-usr, standard, farbios, notbiosboot, /mnt/boot-sav/sda8.
sdb1 : sdb, not-sepboot, no-grubenv nogrub, no-docgrub, no-update-grub, 32, no-boot, no-os, not--efi--part, part-has-no-fstab, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, nopakmgr, nogrubinstall, no---usr, part-has-no-fstab, not-sep-usr, standard, farbios, notbiosboot, /mnt/boot-sav/sdb1.
sda4 : sda, maybesepboot, no-grubenv nogrub, no-docgrub, no-update-grub, 32, no-boot, no-os, not--efi--part, part-has-no-fstab, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, nopakmgr, nogrubinstall, no---usr, part-has-no-fstab, not-sep-usr, standard, not-far, notbiosboot, /mnt/boot-sav/sda4.
sda : not-GPT, BIOSboot-not-needed, has-no-EFIpart, not-usb, not-mmc, has-os, 2048 sectors * 512 bytes
sdb : not-GPT, BIOSboot-not-needed, has-no-EFIpart, not-usb, not-mmc, no-os, 2048 sectors * 512 bytes
=================== parted -lm:
BYT;
/dev/sda:250GB:scsi:512:512:msdos:ATA Samsung SSD 850:;
1:1049kB:106MB:105MB:ntfs::boot;
2:106MB:79.4GB:79.3GB:ntfs::;
4:79.4GB:80.9GB:1453MB:ext4::;
3:80.9GB:213GB:132GB:::lba;
8:80.9GB:130GB:48.7GB:ext4::;
5:130GB:178GB:48.8GB:ext4::;
6:178GB:186GB:8105MB:linux-swap(v1)::;
7:186GB:213GB:26.9GB:ext4::;
BYT;
/dev/sdb:640GB:scsi:512:4096:msdos:ATA WDC WD6400BPVT-7:;
1:126MB:410GB:410GB:ntfs::;
BYT;
/dev/sdd:4005MB:scsi:512:512:unknown:SanDisk Cruzer:;
=================== lsblk:
KNAME TYPE FSTYPE SIZE LABEL
loop0 loop squashfs 1.8G
sda disk 232.9G
sda1 part ntfs 100M System Reserved
sda2 part ntfs 73.9G Windows
sda4 part ext4 1.4G /boot
sda5 part ext4 45.5G
sda6 part swap 7.6G
sda7 part ext4 25G
sda8 part ext4 45.3G
sdb disk 596.2G
sdb1 part ntfs 381.6G Data
sdd disk iso9660 3.7G Linux Mint 19.3 Cinnamon 64-bit
sdd1 part iso9660 1.9G Linux Mint 19.3 Cinnamon 64-bit
sdd2 part vfat 2.4M Linux Mint 19.3 Cinnamon 64-bit
KNAME ROTA RO RM STATE MOUNTPOINT
loop0 1 1 0 /rofs
sda 0 0 0 running
sda1 0 0 0 /mnt/boot-sav/sda1
sda2 0 0 0 /mnt/boot-sav/sda2
sda4 0 0 0 /mnt/boot-sav/sda4
sda5 0 0 0 /mnt/boot-sav/sda5
sda6 0 0 0 [SWAP]
sda7 0 0 0 /mnt/boot-sav/sda7
sda8 0 0 0 /mnt/boot-sav/sda8
sdb 1 0 0 running
sdb1 1 0 0 /mnt/boot-sav/sdb1
sdd 1 0 1 running /cdrom
sdd1 1 0 1
sdd2 1 0 1
=================== mount:
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
udev on /dev type devtmpfs (rw,nosuid,relatime,size=4011276k,nr_inodes=1002819,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=806960k,mode=755)
/dev/sdd on /cdrom type iso9660 (ro,noatime,nojoliet,check=s,map=n,blocksize=2048)
/dev/loop0 on /rofs type squashfs (ro,noatime)
/cow on / type overlay (rw,relatime,lowerdir=//filesystem.squashfs,upperdir=/cow/upper,workdir=/cow/work)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,name=systemd)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
cgroup on /sys/fs/cgroup/hugetlb type cgroup (rw,nosuid,nodev,noexec,relatime,hugetlb)
cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
cgroup on /sys/fs/cgroup/rdma type cgroup (rw,nosuid,nodev,noexec,relatime,rdma)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=25,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=18289)
mqueue on /dev/mqueue type mqueue (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)
tracefs on /sys/kernel/debug/tracing type tracefs (rw,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
configfs on /sys/kernel/config type configfs (rw,relatime)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,relatime)
tmpfs on /run/user/999 type tmpfs (rw,nosuid,nodev,relatime,size=806956k,mode=700,uid=999,gid=999)
gvfsd-fuse on /run/user/999/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=999,group_id=999)
/dev/sda1 on /mnt/boot-sav/sda1 type fuseblk (rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096)
/dev/sda2 on /mnt/boot-sav/sda2 type fuseblk (rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096)
/dev/sda5 on /mnt/boot-sav/sda5 type ext4 (rw,relatime)
/dev/sda7 on /mnt/boot-sav/sda7 type ext4 (rw,relatime,stripe=32726)
/dev/sda8 on /mnt/boot-sav/sda8 type ext4 (rw,relatime)
/dev/sdb1 on /mnt/boot-sav/sdb1 type fuseblk (rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096)
/dev/sda4 on /mnt/boot-sav/sda4 type ext4 (rw,relatime)
=================== ls:
/sys/block/sda (filtered): alignment_offset bdi capability dev device discard_alignment events events_async events_poll_msecs ext_range hidden holders inflight integrity mq power queue range removable ro sda1 sda2 sda3 sda4 sda5 sda6 sda7 sda8 size slaves stat subsystem trace uevent
/sys/block/sdb (filtered): alignment_offset bdi capability dev device discard_alignment events events_async events_poll_msecs ext_range hidden holders inflight integrity mq power queue range removable ro sdb1 size slaves stat subsystem trace uevent
/sys/block/sdc (filtered): alignment_offset bdi capability dev device discard_alignment events events_async events_poll_msecs ext_range hidden holders inflight integrity mq power queue range removable ro size slaves stat subsystem trace uevent
/sys/block/sdd (filtered): alignment_offset bdi capability dev device discard_alignment events events_async events_poll_msecs ext_range hidden holders inflight integrity mq power queue range removable ro sdd1 sdd2 size slaves stat subsystem trace uevent
/dev (filtered): autofs block bsg btrfs-control bus char console core cpu cpu_dma_latency cuse disk dri ecryptfs fb0 fb1 fd full fuse hidraw0 hidraw1 hidraw2 hidraw3 hpet hugepages hwrng i2c-0 i2c-1 i2c-10 i2c-11 i2c-12 i2c-13 i2c-14 i2c-15 i2c-16 i2c-17 i2c-2 i2c-3 i2c-4 i2c-5 i2c-6 i2c-7 i2c-8 i2c-9 initctl input kmsg kvm lightnvm log mapper mcelog media0 media1 mei0 mem memory_bandwidth mqueue net network_latency network_throughput null port ppp psaux ptmx pts random rfkill rtc rtc0 sda sda1 sda2 sda3 sda4 sda5 sda6 sda7 sda8 sdb sdb1 sdc sdd sdd1 sdd2 sg0 sg1 sg2 sg3 shm snapshot snd stderr stdin stdout udmabuf uhid uinput urandom usb userio v4l vfio vga_arbiter vhci vhost-net vhost-vsock video0 video1 video2 video3 zero
ls /dev/mapper: control
=================== hexdump -n512 -C /dev/sda1
00000000 eb 52 90 4e 54 46 53 20 20 20 20 00 02 08 00 00 |.R.NTFS .....|
00000010 00 00 00 00 00 f8 00 00 3f 00 ff 00 00 08 00 00 |........?.......|
00000020 00 00 00 00 80 00 80 00 ff 1f 03 00 00 00 00 00 |................|
00000030 55 21 00 00 00 00 00 00 02 00 00 00 00 00 00 00 |U!..............|
00000040 f6 00 00 00 01 00 00 00 67 04 de 1c 35 de 1c a2 |........g...5...|
00000050 00 00 00 00 fa 33 c0 8e d0 bc 00 7c fb 68 c0 07 |.....3.....|.h..|
00000060 1f 1e 68 66 00 cb 88 16 0e 00 66 81 3e 03 00 4e |..hf......f.>..N|
00000070 54 46 53 75 15 b4 41 bb aa 55 cd 13 72 0c 81 fb |TFSu..A..U..r...|
00000080 55 aa 75 06 f7 c1 01 00 75 03 e9 dd 00 1e 83 ec |U.u.....u.......|
00000090 18 68 1a 00 b4 48 8a 16 0e 00 8b f4 16 1f cd 13 |.h...H..........|
000000a0 9f 83 c4 18 9e 58 1f 72 e1 3b 06 0b 00 75 db a3 |.....X.r.;...u..|
000000b0 0f 00 c1 2e 0f 00 04 1e 5a 33 db b9 00 20 2b c8 |........Z3... +.|
000000c0 66 ff 06 11 00 03 16 0f 00 8e c2 ff 06 16 00 e8 |f...............|
000000d0 4b 00 2b c8 77 ef b8 00 bb cd 1a 66 23 c0 75 2d |K.+.w......f#.u-|
000000e0 66 81 fb 54 43 50 41 75 24 81 f9 02 01 72 1e 16 |f..TCPAu$....r..|
000000f0 68 07 bb 16 68 70 0e 16 68 09 00 66 53 66 53 66 |h...hp..h..fSfSf|
00000100 55 16 16 16 68 b8 01 66 61 0e 07 cd 1a 33 c0 bf |U...h..fa....3..|
00000110 28 10 b9 d8 0f fc f3 aa e9 5f 01 90 90 66 60 1e |(........_...f`.|
00000120 06 66 a1 11 00 66 03 06 1c 00 1e 66 68 00 00 00 |.f...f.....fh...|
00000130 00 66 50 06 53 68 01 00 68 10 00 b4 42 8a 16 0e |.fP.Sh..h...B...|
00000140 00 16 1f 8b f4 cd 13 66 59 5b 5a 66 59 66 59 1f |.......fY[ZfYfY.|
00000150 0f 82 16 00 66 ff 06 11 00 03 16 0f 00 8e c2 ff |....f...........|
00000160 0e 16 00 75 bc 07 1f 66 61 c3 a0 f8 01 e8 09 00 |...u...fa.......|
00000170 a0 fb 01 e8 03 00 f4 eb fd b4 01 8b f0 ac 3c 00 |..............<.|
00000180 74 09 b4 0e bb 07 00 cd 10 eb f2 c3 0d 0a 41 20 |t.............A |
00000190 64 69 73 6b 20 72 65 61 64 20 65 72 72 6f 72 20 |disk read error |
000001a0 6f 63 63 75 72 72 65 64 00 0d 0a 42 4f 4f 54 4d |occurred...BOOTM|
000001b0 47 52 20 69 73 20 6d 69 73 73 69 6e 67 00 0d 0a |GR is missing...|
000001c0 42 4f 4f 54 4d 47 52 20 69 73 20 63 6f 6d 70 72 |BOOTMGR is compr|
000001d0 65 73 73 65 64 00 0d 0a 50 72 65 73 73 20 43 74 |essed...Press Ct|
000001e0 72 6c 2b 41 6c 74 2b 44 65 6c 20 74 6f 20 72 65 |rl+Alt+Del to re|
000001f0 73 74 61 72 74 0d 0a 00 8c a9 be d6 00 00 55 aa |start.........U.|
00000200
=================== hexdump -n512 -C /dev/sda2
00000010 00 00 00 00 00 f8 00 00 3f 00 ff 00 00 28 03 00 |........?....(..|
00000020 00 00 00 00 80 00 80 00 f8 8f 3b 09 00 00 00 00 |..........;.....|
00000030 00 00 0c 00 00 00 00 00 02 00 00 00 00 00 00 00 |................|
00000040 f6 00 00 00 01 00 00 00 74 a3 ed 5e dc ed 5e a8 |........t..^..^.|
00000200
=================== hexdump -n512 -C /dev/sdb1
00000010 00 00 00 00 00 f8 00 00 3f 00 ff 00 00 c0 03 00 |........?.......|
00000020 00 00 00 00 80 00 80 00 ff 97 b1 2f 00 00 00 00 |.........../....|
00000030 04 00 00 00 00 00 00 00 7f 19 fb 02 00 00 00 00 |................|
00000040 f6 00 00 00 01 00 00 00 b0 b8 09 12 de 86 ee 75 |...............u|
00000080 55 aa 75 06 f7 c1 01 00 75 03 e9 d2 00 1e 83 ec |U.u.....u.......|
000000d0 40 00 2b c8 77 ef b8 00 bb cd 1a 66 23 c0 75 2d |@.+.w......f#.u-|
00000100 55 16 16 16 68 b8 01 66 61 0e 07 cd 1a e9 6a 01 |U...h..fa.....j.|
00000110 90 90 66 60 1e 06 66 a1 11 00 66 03 06 1c 00 1e |..f`..f...f.....|
00000120 66 68 00 00 00 00 66 50 06 53 68 01 00 68 10 00 |fh....fP.Sh..h..|
00000130 b4 42 8a 16 0e 00 16 1f 8b f4 cd 13 66 59 5b 5a |.B..........fY[Z|
00000140 66 59 66 59 1f 0f 82 16 00 66 ff 06 11 00 03 16 |fYfY.....f......|
00000150 0f 00 8e c2 ff 0e 16 00 75 bc 07 1f 66 61 c3 a0 |........u...fa..|
00000160 f8 01 e8 08 00 a0 fb 01 e8 02 00 eb fe b4 01 8b |................|
00000170 f0 ac 3c 00 74 09 b4 0e bb 07 00 cd 10 eb f2 c3 |..<.t...........|
00000180 0d 0a 41 20 64 69 73 6b 20 72 65 61 64 20 65 72 |..A disk read er|
00000190 72 6f 72 20 6f 63 63 75 72 72 65 64 00 0d 0a 42 |ror occurred...B|
000001a0 4f 4f 54 4d 47 52 20 69 73 20 6d 69 73 73 69 6e |OOTMGR is missin|
000001b0 67 00 0d 0a 42 4f 4f 54 4d 47 52 20 69 73 20 63 |g...BOOTMGR is c|
000001c0 6f 6d 70 72 65 73 73 65 64 00 0d 0a 50 72 65 73 |ompressed...Pres|
000001d0 73 20 43 74 72 6c 2b 41 6c 74 2b 44 65 6c 20 74 |s Ctrl+Alt+Del t|
000001e0 6f 20 72 65 73 74 61 72 74 0d 0a 00 00 00 00 00 |o restart.......|
000001f0 00 00 00 00 00 00 00 00 80 9d b2 ca 00 00 55 aa |..............U.|
00000200
=================== df -Th:
Filesystem Type Size Used Avail Use% Mounted on
udev devtmpfs 3.9G 0 3.9G 0% /dev
tmpfs tmpfs 789M 1.6M 787M 1% /run
/dev/sdd iso9660 1.9G 1.9G 0 100% /cdrom
/dev/loop0 squashfs 1.9G 1.9G 0 100% /rofs
/cow overlay 3.9G 60M 3.8G 2% /
tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm
tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs tmpfs 3.9G 0 3.9G 0% /sys/fs/cgroup
tmpfs tmpfs 3.9G 112K 3.9G 1% /tmp
tmpfs tmpfs 789M 28K 789M 1% /run/user/999
/dev/sda1 fuseblk 100M 25M 76M 25% /mnt/boot-sav/sda1
/dev/sda2 fuseblk 74G 54G 21G 73% /mnt/boot-sav/sda2
/dev/sda5 ext4 45G 19G 24G 45% /mnt/boot-sav/sda5
/dev/sda7 ext4 25G 4.3G 21G 18% /mnt/boot-sav/sda7
/dev/sda8 ext4 45G 9.5G 33G 23% /mnt/boot-sav/sda8
/dev/sdb1 fuseblk 382G 130G 253G 34% /mnt/boot-sav/sdb1
/dev/sda4 ext4 1.4G 2.1M 1.3G 1% /mnt/boot-sav/sda4
=================== fdisk -l:
Disk /dev/loop0: 1.8 GiB, 1948299264 bytes, 3805272 sectors
Disklabel type: dos
Disk identifier: 0x0c7a859b
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 2048 206847 204800 100M 7 HPFS/NTFS/exFAT
/dev/sda2 206848 155105279 154898432 73.9G 7 HPFS/NTFS/exFAT
/dev/sda3 157945854 416718847 258772994 123.4G f W95 Ext'd (LBA)
/dev/sda4 155105280 157943807 2838528 1.4G 83 Linux
/dev/sda5 252995584 348366677 95371094 45.5G 83 Linux
/dev/sda6 348368896 364199935 15831040 7.6G 82 Linux swap / Solaris
/dev/sda7 364201984 416718847 52516864 25G 83 Linux
/dev/sda8 157945856 252993535 95047680 45.3G 83 Linux
Partition table entries are not in disk order.
Disklabel type: dos
Disk identifier: 0x1efcbac3
/dev/sdb1 245760 800413695 800167936 381.6G 7 HPFS/NTFS/exFAT
Disklabel type: dos
Disk identifier: 0x1dda4ac4
/dev/sdd1 * 0 3978175 3978176 1.9G 0 Empty
/dev/sdd2 680 5607 4928 2.4M ef EFI (FAT-12/16/32)
=================== Default settings of Boot Repair
The default repair of the Boot-Repair utility would reinstall the grub2 of sda5 into the MBRs of all disks (except live-disks and removable disks without OS).
Additional repair would be performed: unhide-bootmenu-10s
=================== Final advice in case of suggested repair
Please do not forget to make your BIOS boot on sda (ATA Samsung SSD 850) disk!
The boot files of [Linux Mint 19.3 Tricia] are far from the start of the disk. Your BIOS may not detect them. You may want to retry after creating a /boot partition (EXT4, >200MB, start of the disk). This can be performed via tools such as gParted. Then select this partition via the [Separate /boot partition:] option of [Boot Repair]. (https://help.ubuntu.com/community/BootPartition)
=================== User settings
The settings chosen by the user will reinstall the grub2 of sda5 into the MBR of sda, using the following options: sda4/boot,
The boot flag will be placed on sda4.
Additional repair will be performed: unhide-bootmenu-30s
parted /dev/sda set 4 boot on
Information: You may need to update /etc/fstab.
parted /dev/sda set 1 boot off
SET@_progressbar1.pulse()
/boot added in sda5/fstab
Mount sda4 on /mnt/boot-sav/sda5/boot
Unhide GRUB boot menu in sda5/etc/default/grub
*******lspci -nnk | grep -iA3 vga
00:02.0 VGA compatible controller [0300]: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller [8086:0116] (rev 09)
Subsystem: Dell 2nd Generation Core Processor Family Integrated Graphics Controller [1028:04ca]
Kernel driver in use: i915
Kernel modules: i915
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GF108M [GeForce GT 525M] [10de:0df5] (rev a1)
Subsystem: Dell GF108M [GeForce GT 525M] [1028:04ca]
Kernel driver in use: nouveau
Kernel modules: nvidiafb, nouveau
grub-install --version
grub-install (GRUB) 2.02-2ubuntu8.14,grub-install (GRUB) 2.
Reinstall the GRUB of sda5 into the MBR of sda
Installing for i386-pc platform.
Installation finished. No error reported.
grub-install /dev/sda: exit code of grub-install /dev/sda:0
chroot /mnt/boot-sav/sda5 update-grub
Sourcing file `/etc/default/grub'
Sourcing file `/etc/default/grub.d/50_linuxmint.cfg'
Sourcing file `/etc/default/grub.d/63_mint-theme-2k.cfg'
Generating grub configuration file ...
/usr/sbin/grub-probe: error: failed to get canonical path of `/boot/grub/fonts/UbuntuMono32.pf2'.
No path or device is specified.
Usage: grub-probe [OPTION...] [OPTION]... [PATH|DEVICE]
Try 'grub-probe --help' or 'grub-probe --usage' for more information.
Unhide GRUB boot menu in sda8/boot/grub2/grub.cfg
An error occurred during the repair.
You can now reboot your computer.
pastebinit packages needed
Gtk-Message: 18:23:46.351: GtkDialog mapped without a transient parent. This is discouraged.
E: The repository 'cdrom://Linux Mint 19.3 _Tricia_ - Release amd64 20191213 bionic Release' does not have a Release file.
debconf: unable to initialize frontend: Dialog
debconf: (TERM is not set, so the dialog frontend is not usable.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
paste2.org ko (http://paste2.org/)
Прошу помочь разобраться, что не так и каковы возможности исправления. На диске три системы Win7, Mageia и LinuxMint. Минт как основной и загрузчик был его, но имел много мусора и правка с grub customizer сводилась в ноль после каждой команды update-grub (и обновления ядра).
S.A.
Благодарил (а): 9 раз
Восстановить GRUB
25 дек 2019, 15:43
Можно попробовать восстановить GRUB руками с установочного диска или флешки Linux.
Смонтировать раздел c Linux
sudo mount /dev/sdaX /mnt  - где Х это раздел с Linux
Установить GRUB.
sudo grub-install --root-directory=/mnt /dev/sda
После загрузки в систему, обновить GRUB.
vlalu
Восстановить GRUB
25 дек 2019, 16:47
S.A.
попробовал - результат тот же - минимал grub> при загрузке. Это я уже пытался делать загрузив LM19.3 с помощью груба внешнего диска, где были прописаны эти системы.
colonel
Решено: 21
Восстановить GRUB
25 дек 2019, 22:40
vlalu писал(а):
24 дек 2019, 23:39
.... При перезагрузке компа загрузочного меню нет, только минимал grub>
если с Boot Repair не получается
попробуйте командами набранными вручную загрузить линукс
https://yandex.ru/turbo?text=https%3A%2 ... %2F2275%2F
https://itproffi.ru/vosstanovlenie-zagr ... b-v-linux/
ну а из загруженной системы можно попробовать переустановить груб ( например , хоть через синаптик удалив и заново установив груб
ну или может ещё какой способ найдётся поиском -> ТЫЦ>>>
Whowka
Благодарил (а): 777 раз
Восстановить GRUB
25 дек 2019, 22:49
Может быть Так получитца?
и заодно это посмотреть
(там отличия в командах)
(Ссылки внутри файла и форума не проверял :smile: может и не рабочие)
S.A.
Восстановить GRUB
26 дек 2019, 09:43
vlalu,
У Вас система установлена с отдельным разделом /boot? Если да, го его тоже нужно монтировать при восстановлении GRUB.
