Работа по сети с Libreelec
YuriS74
Благодарил (а): 2 раза
28 ноя 2019, 11:56
Доброго всем!
LM 19.2 x64 Cinnamon
System:    Host: yuri-pc Kernel: 4.15.0-70-generic x86_64 bits: 64 compiler: gcc v: 7.4.0 Desktop: Cinnamon 4.2.4
           Distro: Linux Mint 19.2 Tina base: Ubuntu 18.04 bionic
Machine:   Type: Desktop System: Acer product: Aspire C22-760 v: N/A serial: <filter>
           Mobo: Acer model: Aspire C22-760(KBL) serial: <filter> UEFI: American Megatrends v: R02-A1 date: 06/30/2017
CPU:       Topology: Dual Core model: Intel Core i3-7100U bits: 64 type: MT MCP arch: Kaby Lake rev: 9 L2 cache: 3072 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19200
           Speed: 800 MHz min/max: 400/2400 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
Graphics:  Device-1: Intel HD Graphics 620 vendor: Acer Incorporated ALI driver: i915 v: kernel bus ID: 00:02.0
           Display: x11 server: X.Org 1.19.6 driver: modesetting unloaded: fbdev,vesa resolution: 1920x1080~60Hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 620 (Kaby Lake GT2) v: 4.5 Mesa 19.0.8 direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
           bus ID: 00:1f.3
           Sound Server: ALSA v: k4.15.0-70-generic
Network:   Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi v: kernel port: f040 bus ID: 01:00.0
           IF: wlp1s0 state: down mac: <filter>
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169 v: 2.3LK-NAPI port: e000
           bus ID: 02:00.0
Drives:    Local Storage: total: 454.40 GiB used: 60.34 GiB (13.3%)
           ID-1: /dev/sda vendor: Western Digital model: WDS480G2G0A-00JH30 size: 447.14 GiB
           ID-2: /dev/sdb type: USB vendor: Kingston model: DataTraveler 3.0 size: 7.26 GiB
Partition: ID-1: / size: 29.17 GiB used: 7.57 GiB (25.9%) fs: ext4 dev: /dev/sda7
           ID-2: /home size: 9.09 GiB used: 37.6 MiB (0.4%) fs: ext4 dev: /dev/sda6
Sensors:   System Temperatures: cpu: 62.0 C mobo: N/A
Info:      Processes: 232 Uptime: 2h 20m Memory: 7.71 GiB used: 1.61 GiB (20.9%) Init: systemd runlevel: 5 Compilers:
           gcc: 7.4.0 Shell: bash v: 4.4.20 inxi: 3.0.32
Имеем в локальной сети файловый серверок, он же по совместительству медиа-центр (малинка с установленной Libreelec), прицепленный к телеку по hdmi и к компу сетевым шнуром через роутер. Либра нормально определяется в сетевых подключениях в Nemo, выводится в закладки, с нее можно проигрывать и просматривать файлы на компе. Но с компа я не могу закачать на нее файлы через transmission (равно как и через qbittorrent). Начинается закачка и через 3-5 секунд прерывается с ошибкой "Неподдерживаемая операция (/run/user/1000/gvfs/smb-share:server=libreelec.local,share=usb-data/Видео/...)", если сохранять страничку из браузера или файлы с компа, то проблем нет. При этом в установленной в дуалбуте Win 10 все прекрасно работает в обе стороны. Пробовал такое же проделать с других live-дистров с разными DE с флешки: результат одинаковый. Хотелось бы разобраться в ситуации, что-то может где-либо подправить?
Последний раз редактировалось пользователем 1 rogoznik; всего редактировалось раз: 28
Причина: bbcode
28 ноя 2019, 17:43
Как указано в wiki, Kodi использует SMBv2, вследствие чего необходимо указывать эту версию в параметрах подключения клиента к серверу Samba. Может быть в этом дело?
Цит. As from LibreELEC 8.2.3, Kodi uses SMBv2 as the default Samba client specification. This will mean, that when you want to connect to a Samba server in your network, you will have to use the “Add a network location…” method, and specify the server credentials manually (источник)
YuriS74
28 ноя 2019, 18:20
madesta, Вы имеете ввиду прописать smb=2.0 в fstab? Но я пока не хочу заморачиваться с этой настройкой, хотя может быть и придётся. Ведь кроме как закачка торрентов с инета непосредственно на диск либры все остальное работает. Вот сейчас туда нормально копируется фильм весом 7,5 Гб. Можно, конечно, скачивать на комп, а потом отправлять на либру, но это уже изврат, в моем понимании. Самое обидное, что в винде все это проделывается как само собой разумеющееся :sad:
28 ноя 2019, 18:34
YuriS74 писал(а):
28 ноя 2019, 11:56
А это уже не вариант что ли?
YuriS74
28 ноя 2019, 18:48
vir0id, может быть и вариант, но чем это может помочь? Можно подробнее? Установил я файлзиллу, соединился с либрой, вижу нужную папку, файлы в ней. Но это все есть и в Nemo.
28 ноя 2019, 18:54
28 ноя 2019, 18:55
YuriS74 писал(а):
28 ноя 2019, 18:48
YuriS74 писал(а):
28 ноя 2019, 18:20
Ну... я, когда-то, таким образом скидывал туда торренты и стримил Quasar-ом помоему
Вернуться в «Работа с сетью»
