Бесконечная авторизация на странице логина.
c-3po
09 ноя 2019, 15:34
Host: c-3po-Lenovo-IP-330 Kernel: 4.15.0-54-generic x86_64 bits: 64
compiler: gcc v: 7.4.0 Desktop: Xfce 4.12.3 Distro: Linux Mint 19.2 Tina
base: Ubuntu 18.04 bionic
Type: Laptop System: LENOVO product: 81DE v: Lenovo ideapad 330-15IKB
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40688 WIN serial: <filter>
UEFI: LENOVO v: 8TCN50WW date: 10/30/2018
ID-1: BAT0 charge: 26.2 Wh condition: 27.5/30.6 Wh (90%)
model: CPT-COS L16C2PB2 status: Unknown
Topology: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake rev: A L2 cache: 6144 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28800
Speed: 803 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 806 2: 800
3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
bus ID: 00:02.0
Device-2: NVIDIA GP108M [GeForce MX150] vendor: Lenovo driver: nouveau
v: kernel bus ID: 01:00.0
Display: server: X.Org 1.19.6 driver: modesetting,nouveau
unloaded: fbdev,vesa resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel UHD Graphics 620 (Kabylake GT2)
v: 4.5 Mesa 19.0.2 direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
vendor: Lenovo driver: r8169 v: 2.3LK-NAPI port: 3000 bus ID: 02:00.0
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel port: 3000 bus ID: 03:00.0
Device-3: Atheros type: USB driver: btusb bus ID: 1-7:3
Local Storage: total: 237.98 GiB used: 38.93 GiB (16.4%)
ID-1: /dev/sda vendor: Kingston model: SA400S37240G size: 223.57 GiB
ID-2: /dev/sdb type: USB vendor: Kingston model: DataTraveler 3.0
ID-1: / size: 81.76 GiB used: 38.90 GiB (47.6%) fs: ext4 dev: /dev/sda5
System Temperatures: cpu: 40.5 C mobo: N/A gpu: nouveau temp: 35 C
Processes: 280 Uptime: 31m Memory: 7.70 GiB used: 1.18 GiB (15.3%)
inxi: 3.0.32
Проблема заключается в следующем. Пытаюсь залогиниться на странице логина. Пароль ввожу верный (раскладку проверил). Но после логина появляется черный экран и после нескольких секунд опять выкидывает на страницу логина.
Пытался залогинится в tty. Залогинился без проблем. Запустил startx. Загрузился рабочий стол. Правда какой страшный. Видимо оболочка не прогрузилась (незнаю).
Единственный странный момент, в терминале в tty не видело комманд mv, startx и тому подобное. Мол типо они есть но не могу запустить потому что их нет в PATH. Делаю export с добавлением директорий и все работает.
Есть нюанс что на машине есть еще система Windows 10. Грузится все через GRUB. Вчера все нормально работало. Из последних вчерашних действий: пытался настроить vpn.
Help люди!!!!
09 ноя 2019, 15:42
c-3po писал(а):
09 ноя 2019, 15:34
c-3po писал(а):
09 ноя 2019, 15:34
Пока увидел только это , нет видеодрайвера и не обновлена система после установки
c-3po
09 ноя 2019, 15:43
Если честно не понял. В чем проблема?
09 ноя 2019, 15:48
У тебя 2 видеокарты , на одну из них не установлен драйвер , это может быть одной из причин , загляни в менеджер драйверов. А по поводу ядра , этот номер обычно присутствует в дистре , а после установки система просит обновиться до актуального состояния , и номер ядра будет другой.
c-3po
09 ноя 2019, 15:55
Да только driver manager пустой. Два дня работало же нормально. Пытаюсь обновится вылетает следующее в менеджере обновлений
Can't exec "locale": No such file or directory at /usr/share/perl5/Debconf/Encoding.pm line 16.
Use of uninitialized value $Debconf::Encoding::charmap in scalar chomp at /usr/share/perl5/Debconf/Encoding.pm line 17.
debconf: delaying package configuration, since apt-utils is not installed
dpkg: warning: 'sh' not found in PATH or not executable
dpkg: warning: 'rm' not found in PATH or not executable
dpkg: warning: 'tar' not found in PATH or not executable
dpkg: warning: 'diff' not found in PATH or not executable
dpkg: warning: 'dpkg-deb' not found in PATH or not executable
dpkg: warning: 'ldconfig' not found in PATH or not executable
dpkg: warning: 'start-stop-daemon' not found in PATH or not executable
dpkg: error: 7 expected programs not found in PATH or not executable
Note: root's PATH should usually contain /usr/local/sbin, /usr/sbin and /sbin
E: Sub-process /usr/bin/dpkg returned an error code (2)
A package failed to install. Trying to recover:
sh: 1: dpkg: not found
09 ноя 2019, 16:00
Это огрызок сообщения без начала и конца. Давай запусти обновление в терминале и выводы сюда , начни с апдейта.
c-3po
09 ноя 2019, 16:01
Вот
c-3po@c-3po-Lenovo-IP-330:~$ sudo apt-get update
[sudo] password for c-3po:
Hit:1 http://archive.canonical.com/ubuntu bionic InRelease
Hit:2 http://archive.ubuntu.com/ubuntu bionic InRelease
Hit:3 http://ppa.launchpad.net/danielrichter2 ... zer/ubuntu bionic InRelease
Ign:4 http://dl.google.com/linux/chrome/deb stable InRelease
Get:5 http://security.ubuntu.com/ubuntu bionic-security InRelease [88,7 kB]
Ign:6 http://packages.linuxmint.com tina InRelease
Hit:7 http://dl.google.com/linux/chrome/deb stable Release
Get:8 http://archive.ubuntu.com/ubuntu bionic-updates InRelease [88,7 kB]
Hit:9 http://ppa.launchpad.net/linuxuprising/java/ubuntu bionic InRelease
Hit:11 http://packages.linuxmint.com tina Release
Hit:12 https://repo.skype.com/deb stable InRelease
Hit:14 http://ppa.launchpad.net/openjdk-r/ppa/ubuntu bionic InRelease
Get:15 http://archive.ubuntu.com/ubuntu bionic-backports InRelease [74,6 kB]
Hit:16 http://ppa.launchpad.net/remmina-ppa-te ... ext/ubuntu bionic InRelease
Hit:17 http://ppa.launchpad.net/webupd8team/java/ubuntu bionic InRelease
Get:18 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages [768 kB]
Get:19 http://archive.ubuntu.com/ubuntu bionic-updates/main i386 Packages [601 kB]
Get:20 http://archive.ubuntu.com/ubuntu bionic-updates/restricted i386 Packages [9 304 B]
Get:21 http://archive.ubuntu.com/ubuntu bionic-updates/restricted amd64 Packages [18,7 kB]
Fetched 1 649 kB in 8s (220 kB/s)
Reading package lists... Done
c-3po
09 ноя 2019, 16:03
Менеджер обновлений предлагает мне обновиться, но при обновлении вылетает тот месседж который я чуть выше отправил (огрызок)
09 ноя 2019, 16:03
Ну и, апдейт нормальный , давай обновление в терминале. И кстати , почему английский?
c-3po
09 ноя 2019, 16:05
Система на английском? Прихоть. Что за обновление в терминале?
09 ноя 2019, 16:06
apt upgrade
c-3po
09 ноя 2019, 16:08
похоже это на долго. Скинуть сюда весь результат потом?
09 ноя 2019, 18:25
c-3po писал(а):
09 ноя 2019, 16:08
Не надо. Смотри внимательно не будет ли ошибок. Если будут сюда покажешь.
А по поводу твоей проблемы очень похоже на проблемы с файлом .Xauthority. Лежит в домашней директории, он скрытый.
В tty залогинься и удали его
rm .Xauthority
После пробуй перезагрузиться и залогиниться в графике.
c-3po
10 ноя 2019, 12:23
Его удалял. Не помогло. Решил переустановить ОС. Закрываю тему. Всем спасибо.
