Высокая температура процессора
kowalskiy
05 ноя 2019, 21:56
Здравствуйте, столкнулся с проблемой.
На винде температура не такая высокая(при обычной работе), тут же он греется как кипятильник(60+).
Вывод inxi -Fxz
Host: alex-K56CM Kernel: 5.3.0-19-generic x86_64 bits: 64 compiler: gcc
v: 7.4.0 Desktop: Cinnamon 4.2.4 Distro: Linux Mint 19.2 Tina
base: Ubuntu 18.04 bionic
Type: Laptop System: ASUSTeK product: K56CM v: 1.0 serial: <filter>
Mobo: ASUSTeK model: K56CM v: 1.0 serial: <filter>
UEFI: American Megatrends v: K56CM.206 date: 08/21/2012
ID-1: BAT0 charge: 20.5 Wh condition: 32.4/33.0 Wh (98%)
model: ASUSTeK K56--30 status: Discharging
Topology: Dual Core model: Intel Core i5-3317U bits: 64 type: MT MCP
arch: Ivy Bridge rev: 9 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 13568
Speed: 2134 MHz min/max: 800/2600 MHz Core speeds (MHz): 1: 1131 2: 1180
3: 1098 4: 1312
Device-1: Intel 3rd Gen Core processor Graphics vendor: ASUSTeK
Device-2: NVIDIA GF108M [GeForce GT 635M] vendor: ASUSTeK driver: N/A
bus ID: 01:00.0
Display: x11 server: X.Org 1.19.6 driver: modesetting unloaded: fbdev,vesa
resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel Ivybridge Mobile v: 4.2 Mesa 19.0.8
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK
Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel
v: kernel bus ID: 01:00.1
Sound Server: ALSA v: k5.3.0-19-generic
Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter
vendor: AzureWave driver: ath9k v: kernel port: e000 bus ID: 03:00.0
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus ID: 04:00.2
IF: enp4s0f2 state: down mac: <filter>
Device-3: IMC Networks Atheros AR3012 Bluetooth 4.0 Adapter type: USB
driver: btusb bus ID: 1-1.1:3
Local Storage: total: 465.76 GiB used: 38.39 GiB (8.2%)
ID-1: /dev/sda vendor: Western Digital model: WD5000LPLX-60ZNTT1
ID-1: / size: 73.45 GiB used: 19.18 GiB (26.1%) fs: ext3 dev: /dev/sda7
ID-2: swap-1 size: 2.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/dm-0
System Temperatures: cpu: 69.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3900
Processes: 234 Uptime: 11m Memory: 7.66 GiB used: 1.46 GiB (19.1%)
inxi: 3.0.32
05 ноя 2019, 22:13
Покажите вывод команды cat /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor
Есть подозрение что у вас по умолчанию процессор в режиме максимальной производительности, а винда по умолчанию загоняет его в режим экономии - там производительность поменьше, но и тепловыделение тоже.
И еще вот это, что бы два раза не бегать: cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors - посмотрим, какие варианты вообще доступны.
kowalskiy
05 ноя 2019, 22:30
05 ноя 2019, 22:13
alex@alex-K56CM:~$ cat /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor
powersave
powersave
powersave
powersave
alex@alex-K56CM:~$
05 ноя 2019, 22:13
alex@alex-K56CM:~$ cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors
performance powersave
alex@alex-K56CM:~$
05 ноя 2019, 22:58
Отбой тревоги, экономичный режим и так включен.
Уточните: с температурой под под виндой вы текущее состояние сравниваете имея эту самую винду второй системой прямо сейчас (т.е. можете переключится и сравнить), или она у вас раньше там стояла? Если второе - могла просто забиться система охлаждения.
И еще - а вентилятор в вытяжке у вас запускается при таком нагреве? А то некоторые нотбуки/материнки позволят ручное управление вентиляторами прямо из системы, и бывает, что по какой-то причине кулер не заводится вовремя...
06 ноя 2019, 13:23
05 ноя 2019, 22:13
Интересно получилось. Оказывается, у меня доступны режимы performance и powersave, а работают все ядра на powersave. А как можно переключаться (хотел попробовать performance)? Или не стоит трогать?
06 ноя 2019, 14:03
Пока не убедитесь что система охлаждения физически исправна - не стоит. Т.к. нагрев вырастет.
Эти режимы различаются не столько пиковой производительностью, сколько стратегией набора и сброса частоты. В режиме powersave процессор при старается держать минимально возможную частоту если нет нагрузки, и разгоняется до максимальной только если она стабильно есть. В perfomance - процессор выдает максимальную частоту скачком при малейшем чихе. В результате - не так хорошо остывает, т.к. подобная мелкая нагрузка - это 90% времени "офисной работы". Да, в powersave немного времени тратится на плавное "раскочегаривание" процессора с минималки до максимума, но выйдя на режим - производительность будет равной. Т.е. в игре, в нагруженной игре, скажем, разницы будет незаметно.
Мне только раз встретилась игра где переключение режима убирало подтормаживания графики - и была она наоборот, из малотребовательных. Происходило следующее - на полной частоте делать было нечего, процессор замедлялся, и на минималке ему чуть-чуть не хватало производительности - подтормаживание, разгон до максимума... и по новой делать нечего. :) Т.е. такое, теоретически может и еще где-то встретится, но шанс невелик. Однако, в любом случае, если он у вас в powersve до 70 греется - тут может и до 90 разогреться уйдя в тротлинг по температуре.
