System: Host: maximus-Aspire-5750G Kernel: 5.3.0-19-generic x86_64 bits: 64 compiler: gcc v: 7.4.0 Desktop: Xfce 4.12.3 Distro: Linux Mint 19.2 Tina base: Ubuntu 18.04 bionic Machine: Type: Laptop System: Acer product: Aspire 5750G v: V1.21 serial: <filter> Mobo: Acer model: JE50_HR serial: <filter> BIOS: Acer v: 1.21 date: 08/09/2012 CPU: Topology: Quad Core model: Intel Core i7-2670QM bits: 64 type: MT MCP arch: Sandy Bridge rev: 7 L2 cache: 6144 KiB flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 35118 Speed: 1153 MHz min/max: 800/3100 MHz Core speeds (MHz): 1: 1994 2: 1342 3: 1956 4: 1362 5: 1484 6: 2163 7: 2064 8: 2067 Graphics: Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics vendor: Acer Incorporated ALI driver: i915 v: kernel bus ID: 00:02.0 Display: x11 server: X.Org 1.19.6 driver: modesetting unloaded: fbdev,vesa resolution: 1366x768~60Hz OpenGL: renderer: Mesa DRI Intel Sandybridge Mobile v: 3.3 Mesa 19.0.8 direct render: Yes Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel bus ID: 00:1b.0 Sound Server: ALSA v: k5.3.0-19-generic Network: Device-1: Broadcom and subsidiaries NetLink BCM57785 Gigabit Ethernet PCIe vendor: Acer Incorporated ALI driver: tg3 v: 3.137 port: 2040 bus ID: 02:00.0 IF: enp2s0f0 state: down mac: <filter> Device-2: Qualcomm Atheros AR9462 Wireless Network Adapter vendor: Foxconn driver: ath9k v: kernel port: 2040 bus ID: 03:00.0 IF: wlp3s0 state: up mac: <filter> Drives: Local Storage: total: 1.02 TiB used: 839.71 GiB (80.5%) ID-1: /dev/sda vendor: Kingston model: SA400S37120G size: 111.79 GiB ID-2: /dev/sdb vendor: Western Digital model: WD10SPZX-08Z10 size: 931.51 GiB Partition: ID-1: / size: 109.53 GiB used: 9.84 GiB (9.0%) fs: ext4 dev: /dev/sda1 ID-2: /home size: 915.89 GiB used: 829.87 GiB (90.6%) fs: ext4 dev: /dev/sdb5 Sensors: System Temperatures: cpu: 50.0 C mobo: N/A Fan Speeds (RPM): N/A Info: Processes: 278 Uptime: 4h 17m Memory: 7.63 GiB used: 2.12 GiB (27.8%) Init: systemd runlevel: 5 Compilers: gcc: 7.4.0 Shell: bash v: 4.4.20 inxi: 3.0.32
Не запускаются браузеры на движке chromium
Автор темы - Сообщения: 3
Прошу помощи. Linux Mint 19.2 64bit XFCE. Не запускаются браузеры Opera, Chromium, Google Chrome. Все три с одинаковой ошибкой - Ошибка сегментирования (стек памяти сброшен на диск). Ставил как пакеты через dpkg так и из репозиториев - результат один и тот же. Mozilla, Pale moon, Tor browser - функционируют как положено.
Последний раз редактировалось пользователем 2 rogoznik; всего редактировалось раз: 30
Причина: картинка, bbcode
- Решено: 21
> ...Ошибка сегментирования ...
однако , какая старая история ...
2009г - https://archlinux.org.ru/forum/topic/146/
2010г - https://forum.ubuntu.ru/index.php?topic=89108.0
2011г - https://forum.ubuntu.ru/index.php?topic=146458.0
2014г- https://debianforum.ru/index.php?topic=8222.0
2016г - Ошибка сегментирования Ubuntu
собсно иногда проблемка решалась обновлениями или установкой других версий программ , как например в этой теме
Вылетает YAGF (распознавание текста)
- Решено: 18
"Ошибка сегментирования" - это такое универсальное сообщение на все случаи жизни, и может говорить о чём угодно. Примерно как в своё время был "Access violation" в программах на Delphi
Первое, обновите пакеты командой
Если не поможет, то:
а) попробуйте создать нового пользователя, перелогиниться и запустить браузер из его сессии.
б) удалите пакеты chromium-codecs-ffmpeg-extra и adobe-flashplugin (как вероятные источники проблем).
sudo apt update && sudo apt upgrade
- Решено: 38
как раз то говорит оно конкретно что происходит... а причин конечно может быть много - занятый ресурс, неправильно взятый указатель и так далее...Ара Магеддон писал(а): ↑30 окт 2019, 13:43"Ошибка сегментирования" - это такое универсальное сообщение на все случаи жизни, и может говорить о чём угодно. Примерно как в своё время был "Access violation" в программах на Delphi
создал пользователя - перелогинился, браузеры работают. почему?Ара Магеддон писал(а): ↑30 окт 2019, 13:43"Ошибка сегментирования" - это такое универсальное сообщение на все случаи жизни, и может говорить о чём угодно. Примерно как в своё время был "Access violation" в программах на Delphi
Первое, обновите пакеты командойsudo apt update && sudo apt upgrade
- Решено: 18
Некорректный вопрос. Корректный: "Почему браузеры не работают от основного пользователя?"
Скорее всего, упираются в битый файл где-то в кэше или конфиге, или права доступа слетели.
На askubuntu народ советует удалить один файлик:
rm ~/.gtkrc-2.0
Думаю, стоит начать с этого.
Кэш можно смело чистить командой
sudo rm -rf ~/.cache/opera ~/.cache/google-chrome ~/.cache/chromium
Права можно восстановить командами
sudo chown -R $USER:$USER /home/$USER
и chmod -R 755 ~/.config/opera ~/.config/google-chrome ~/.config/chromium
(кроме папки .dbus, которая по-умолчанию принадлежит root'у. Вернём её командой
sudo chown -R root:root /home/$USER/.dbus
)Если не поможет, то попробуйте удалить в папке
.config
(скрытая) все что связано с этими браузерами. Или переименовать/переместить в другое место, если не хотите терять историю и сохраненные пароли. Также возможно, что "собака зарыта" где-то в fontconfig или темах (окна, иконки).Если меняли - то попробуйте вернуть стандартные.В крайнем случае, выдайте новому юзеру те же права, что и основному (внеся в те же группы), и работайте от него. А старого можно будет со временем удалить.
- Решено: 21
как понимаю о том что такое Ошибка сегментирования и " с чем её едят", и тд .... и что делать прочитать по ссылкам в сообщении #2 ТС не пожелал. наверное было лень мозги напрячь для чтения.
Дядь, ты че такой токсичный? Я и без тебя в поиске находил эти темы и читал. И ничего из того что в них изложено не помогает. Имеено поэтому я и прошу помощи а не гавна которое ты тут пытаешься мне на голову намазать. Не хочешь помочь - лучше молчи.
Попробуй, однако, "с чистого листа", т.е. снести (отлить в сторону) профиль (~/.config/chromium/Default) и попробовать и сюда отписаться.
Я бы начал с этого, с простого...
- Решено: 3
Vivaldi в их числе. Сегодня обновил до последней версии - "ни трЁш не ймЁшь". Сделал откат на старую версию через синаптик и все заработало.
- Решено: 21
перечитал первый пост темы, не нашёл ни слова о том что вами искалось ,читалось для решения вашей проблемы и что и как практически делалось для решения ...
очевидно надо было догадаться.
относительно ссылок в сообщении #2
в них разные возможные причины указывались , и возможные решения в т.ч. и не совсем подходящие плагины и дополнения или какие либо настройки ,
и было сказано :
" ...что нужно сделать - это обновить систему .... возможно, был баг и его уже исправили, а может у вас установлены старые версии библиотек и обновление решит проблему. ....
Если это не помогло, нужно обнулить настройки программы до значений по умолчанию, возможно, удалить кэш. Настройки программ в Linux обычно содержатся в домашней папке, скрытых подкаталогах с именем программы. Также, настройки и кэш могут содержаться в каталогах ~/.config и ~/.cache. Просто удалите папки программы и попробуйте снова ее запустить. " и т.д - это практически то что указано Ара Магеддоном в #3 и #6?
собсно предложенный им способ проверки с созданием нового аккаунта - быстрый способ "обнуления" кеша и конфигов настроек
так что своим мелкопакостным постиком #8 , вы только подтвердили отсутствие желания немного напрячь мозги.
думал что номерной 230-й поумнее, ...увы ошибался
