Проблема с установкой ПО.
elenass
27 окт 2019, 12:02
Здравствуйте! У меня операционная система Tina i386, Cinnamon.
Характеристики:
Host: SAMSUNG-R510-Elena
Kernel: 4.15.0-54-generic i686
bits: 32 compiler: gcc v: 7.4.0
Desktop: Cinnamon 4.2.4
Distro: Linux Mint 19.2 Tina
base: Ubuntu 18.04 bionic
Type: Laptop System: SAMSUNG
product: R510/P510 v: N/A
serial: <filter>
Mobo: SAMSUNG model: R510/P510
serial: <filter> BIOS: Phoenix
v: 06LI.MP00.20080919.SCY
date: 09/19/2008
ID-1: BAT1 charge: 10.2 Wh
condition: 16.6/44.4 Wh (37%)
model: SAMSUNG Electronics
status: Discharging
Topology: Dual Core
model: Intel Core2 Duo T5850 bits: 64
type: MCP arch: Core Merom rev: D
L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 ssse3
bogomips: 8644
Speed: 1315 MHz
min/max: 1000/2166 MHz
Core speeds (MHz): 1: 1207 2: 1195
Device-1: NVIDIA G98M [GeForce 9200M
GS]
vendor: Samsung Co driver: nvidia
v: 340.107 bus ID: 01:00.0
Display: x11 server: X.Org 1.19.6
driver: nvidia
unloaded: fbdev,modesetting,nouveau,vesa
resolution: 1280x800~60Hz
OpenGL:
renderer: GeForce 9200M GS/PCIe/SSE2
v: 3.3.0 NVIDIA 340.107
Device-1: Intel 82801I HD Audio
vendor: Samsung Co
driver: snd_hda_intel v: kernel
bus ID: 00:1b.0
Sound Server: ALSA
v: k4.15.0-54-generic
Device-1: Qualcomm Atheros AR242x /
AR542x Wireless Network Adapter
vendor: Askey driver: ath5k v: kernel
port: 2000 bus ID: 02:00.0
Device-2: Marvell 88E8055 PCI-E
Gigabit Ethernet
vendor: Samsung Co driver: sky2
v: 1.30 port: 5000 bus ID: 06:00.0
IF: enp6s0 state: down mac: <filter>
Local Storage: total: 186.31 GiB
used: 15.28 GiB (8.2%)
ID-1: /dev/sda vendor: Fujitsu
model: MHZ2200BH G2 size: 186.31 GiB
temp: 51 C
ID-1: / size: 182.38 GiB
used: 15.28 GiB (8.4%) fs: ext4
dev: /dev/sda1
System Temperatures: cpu: 70.0 C
mobo: 70.0 C gpu: nvidia temp: 75 C
Processes: 184 Uptime: 35m
Memory: 1.96 GiB
used: 1.21 GiB (61.7%) Init: systemd
runlevel: 5 Compilers: gcc: 7.4.0
Shell: bash v: 4.4.20 inxi: 3.0.32
При попытке установить Хром выводит:
root@SAMSUNG-R510-Elena:/home/elena# cd Загрузки
root@SAMSUNG-R510-Elena:/home/elena/Загрузки# dpkg -i google-chrome-stable_current_amd64.deb
dpkg: ошибка при обработке архива google-chrome-stable_current_amd64.deb (--install):
архитектура пакета (amd64) не соответствует архитектуре системы (i386)
Есть ли версия Chrome i386? И можно ли как-нибудь поменять разрядность системы?
Я качал образ амд64, а установился и386 можно это исправить?
elenass
27 окт 2019, 12:03
:tema:
27 окт 2019, 12:04
Для 32 есть Cromium из реп.
27 окт 2019, 12:14
elenass писал(а):
27 окт 2019, 12:02
Такое невозможно.
elenass писал(а):
27 окт 2019, 12:02
Нет, но есть chromium и его можно установить
sudo apt install chromium-browser
27 окт 2019, 12:19
27 окт 2019, 12:14
и добавить через пробел chromium-browser-l10n , чтобы сразу русским был. Кстати проц вроде поддерживает 64 бита.
https://www.notebook-center.ru/processor_38.html
elenass
27 окт 2019, 12:42
27 окт 2019, 12:14
elenass писал(а):
27 окт 2019, 12:02
Такое невозможно.
elenass писал(а):
27 окт 2019, 12:02
невозможное возможно.
Вы можете ответить на другое: почему вайн при установке нигде не оставляет ярлыков? установил а ярлыков нет :( :tux:
27 окт 2019, 13:04
elenass писал(а):
27 окт 2019, 12:42
Потому что это wine. Так он устроен. Это консольная утилита - ей не нужны ярлыки для запуска. Читай FAQ и документцию
27 окт 2019, 13:47
Ставьте систему 64 и будет вам счастье
Благодарил (а): 212 раз
29 окт 2019, 23:55
Dja писал(а):
27 окт 2019, 13:47
А надо ли?
elenass писал(а):
27 окт 2019, 12:02
date: 09/19/2008
Memory: 1.96 GiB
