Сброс яркости экрана и вывод "No External Monitor" при 3D графике.
Xen
09 окт 2019, 23:36
Всем привет!
Linux Mint Mate 19.2 Tina x64
Lenovo g505s
Hw-probe - https://linux-hardware.org/?probe=4f005c8ffe
Host: elagin-Lenovo-G505s Kernel: 4.18.0-20-generic x86_64 bits: 64
compiler: gcc v: 7.3.0 Desktop: MATE 1.22.0 Distro: Linux Mint 19.2 Tina
base: Ubuntu 18.04 bionic
Type: Laptop System: LENOVO product: 20255 v: Lenovo G505s
serial: <filter>
Mobo: LENOVO model: Lenovo G505s v: 00000000Not Defined serial: <filter>
UEFI [Legacy]: LENOVO v: 83CN53WW(V3.00) date: 01/08/2014
ID-1: BAT1 charge: 37.5 Wh condition: 37.5/37.5 Wh (100%)
model: SIMPLO PABAS0241231 status: Full
Topology: Quad Core model: AMD A10-5750M APU with Radeon HD Graphics
bits: 64 type: MCP arch: Piledriver rev: 1 L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 19961
Speed: 2326 MHz min/max: 1400/2500 MHz Core speeds (MHz): 1: 2180 2: 2464
3: 2204 4: 1907
Device-1: AMD Richland [Radeon HD 8650G] vendor: Lenovo driver: radeon
v: kernel bus ID: 00:01.0
Device-2: AMD Sun PRO [Radeon HD 8570A/8570M] vendor: Lenovo
driver: radeon v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.19.6 driver: none unloaded: radeon
resolution: 1366x768~60Hz
OpenGL: renderer: AMD ARUBA (DRM 2.50.0 / 4.18.0-20-generic LLVM 9.0.0)
v: 4.3 Mesa 19.3.0-devel (git-b049ebc 2019-10-09 bionic-oibaf-ppa)
Device-1: AMD Trinity HDMI Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 00:01.1
Device-2: AMD FCH Azalia vendor: Lenovo driver: snd_hda_intel v: kernel
bus ID: 00:14.2
Device-3: C-Media type: USB driver: hid-generic,snd-usb-audio,usbhid
bus ID: 5-2:2
Sound Server: ALSA v: k4.18.0-20-generic
Device-1: Qualcomm Atheros QCA8172 Fast Ethernet vendor: Lenovo
driver: alx v: kernel port: 2000 bus ID: 02:00.0
Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: Lenovo
driver: ath9k v: kernel port: 2000 bus ID: 03:00.0
Device-3: Atheros AR3012 Bluetooth 4.0 type: USB driver: btusb
bus ID: 3-3:3
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Local Storage: total: 938.95 GiB used: 684.06 GiB (72.9%)
ID-1: /dev/mmcblk0 type: USB model: SD size: 7.44 GiB
ID-2: /dev/sda vendor: Seagate model: ST1000LM024 HN-M101MBB
ID-1: / size: 25.54 GiB used: 15.56 GiB (60.9%) fs: ext4 dev: /dev/sda7
ID-2: /home size: 25.54 GiB used: 21.49 GiB (84.1%) fs: ext4
dev: /dev/sda8
ID-3: swap-1 size: 9.91 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/dm-0
System Temperatures: cpu: 55.8 C mobo: N/A
GPU: device: radeon temp: 53 C device: radeon temp: 55 C
Processes: 247 Uptime: 49m Memory: 7.01 GiB used: 2.54 GiB (36.2%)
inxi: 3.0.32
Решил продвинуть драйвера ))) Обновился отсюда:
ppa:oibaf/graphics-driver
ppa:graphics-drivers/ppa
И всё бы вроде и ничего, но при запуске 3D графики через некоторое время гаснет яркость экрана до мизера и возникает надпись "No Extended Monitor".
Яркость приходится восстанавливать вручную. Я понимаю, что это не слишком критичная ошибка, но меня напрягают такие вещи.
Мне очень нужно либо допилить это дело, либо откатится.
Пробовал sudo add-apt-repository --remove ppa:oibaf/graphics-drivers , ppa-purge не решился. Но проблема не исчезла.
Прошу помощи либо в решении проблемы с данным глюком либо в откате на стабильные драйвера.
Спасибо!
Последний раз редактировалось пользователем 1 Dja; всего редактировалось раз: 9
Причина: подправил картинку
09 окт 2019, 23:41
Возможно срабатывает правило, прописанное в сбережении электропитания. Смотрите в настройках.
Xen
10 окт 2019, 09:31
Dja писал(а):
09 окт 2019, 23:41
К сожалению, "заклинание не сработало". (((
Спасибо за совет.
Думаю, всё же дело либо в Xorg драйверах либо в Mesa, конкретно в версиях, на которые обновилось.
10 окт 2019, 10:44
Бэкапа, разумеется, нет?
Xen
10 окт 2019, 11:36
Dja писал(а):
10 окт 2019, 10:44
Есть, но старый. Было бы крайне нежелательно. Хотелось бы перед этим с бубном поплясать маленько ))
В принципе, я убрал репы из источников, теперь ко мне должны идти не чьи-то девелопные версии, по крайней мере. Есть шанс, что когда-нибудь всё решится само собой))) Но если можно как-то ускорить процесс... Удалить эти драйвера и mesa, поставить заново со стабильных веток основных репозиториев.
Нашёл похожую проблему https://forums.linuxmint.com/viewtopic.php?t=260424 .
Вот эта фраза интригует "Mint software sources has a toold to downgrade foreign packages. USe that."
10 окт 2019, 12:04
может синаптик?
Xen
10 окт 2019, 18:37
Dja писал(а):
10 окт 2019, 12:04
может синаптик?
Синаптик сам по себе ничего не дал. В "Источник приложений" - "Обслуживание" есть "Откат сторонних пакетов". Да, видит как раз, что надо. Но видно что-то нужное затесалось там или зацепило как-то, но у меня с панели меню пропало, настройки системы потом при запуске ошибку выдавали.
В итоге поднял бэкап через Timeshift и... ничего. А бэкап вообще 19.1.
Вывод - что-то сдохло в ноуте, происходящее - реакция драйверов на этот трабл. Второй системой винда, там тоже такое наблюдается, на самом деле. Но это там наблюдалось давно, а здесь только недавно начало... Поэтому и хотел откатится на драйвера, которые это принимали. В общем так. Большое спасибо за помощь, будем наблюдать, может отклинит.
