Установщик не видит nvme диск в режиме sata контроллера RST
egor_babintsev
18 сен 2019, 15:22
1. LM 19.2 x64
2.Cinnamon
3.
  Host: mint Kernel: 4.15.0-54-generic x86_64 bits: 64 compiler: gcc
  v: 7.4.0 Desktop: Cinnamon 4.2.3 Distro: Linux Mint 19.2 Tina
  base: Ubuntu 18.04 bionic
  Type: Laptop System: LENOVO product: 81N8 v: Lenovo IdeaPad S340-15IWL
  serial: <filter>
  Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <filter> UEFI: LENOVO
  v: ALCN27WW(V2.04) date: 07/02/2019
  ID-1: BAT1 charge: 26.7 Wh condition: 56.5/52.5 Wh (107%)
  model: 3831303200504D53 374650334D38314C status: Discharging
  Topology: Quad Core model: Intel Core i5-8265U bits: 64 type: MT MCP
  arch: Kaby Lake rev: C L2 cache: 6144 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28800
  Speed: 700 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 700 2: 700
  3: 700 4: 700 5: 700 6: 700 7: 700 8: 700
  Device-1: Intel vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0
  Display: x11 server: X.Org 1.19.6 driver: modesetting unloaded: fbdev,vesa
  resolution: 1920x1080~60Hz
  OpenGL: renderer: Mesa DRI Intel HD Graphics (Whiskey Lake 3x8 GT2)
  v: 4.5 Mesa 19.0.2 direct render: Yes
  Device-1: Intel vendor: Lenovo driver: snd_hda_intel v: kernel
  bus ID: 00:1f.3
  Device-1: Intel driver: iwlwifi v: kernel port: 3000 bus ID: 00:14.3
  IF: wlp0s20f3 state: up mac: <filter>
  Local Storage: total: 253.01 GiB used: 81.2 MiB (0.0%)
  ID-1: /dev/nvme0n1 vendor: Lenovo O.E.M. model: RPFTJ256PDD2MWX
  ID-2: /dev/sda type: USB vendor: Kingston model: DataTraveler 2.0
  ID-1: / size: 3.76 GiB used: 81.2 MiB (2.1%) fs: overlay source: ERR-102
  System Temperatures: cpu: 42.0 C mobo: N/A
  Processes: 241 Uptime: 4m Memory: 7.52 GiB used: 978.3 MiB (12.7%)
  inxi: 3.0.32
Вывод в режиме работы AHCI
  serial: <filter>
  ID-1: BAT1 charge: 25.2 Wh condition: 56.5/52.5 Wh (107%)
  Speed: 800 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 800 2: 800
  3: 799 4: 800 5: 800 6: 800 7: 800 8: 800
  bus ID: 00:1f.3
  Local Storage: total: 14.54 GiB used: 96.8 MiB (0.7%)
  ID-1: /dev/sda type: USB vendor: Kingston model: DataTraveler 2.0
RAID:
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
  v: 3.0 bus ID: 00:17.0
  ID-1: / size: 3.76 GiB used: 96.8 MiB (2.5%) fs: overlay source: ERR-102
  System Temperatures: cpu: 47.0 C mobo: N/A
  Processes: 245 Uptime: 3m Memory: 7.52 GiB used: 973.3 MiB (12.6%)
  inxi: 3.0.32
Вывод в режиме RST
4. Образ системы, записан на флешку, при загрузке с флешки система не видит ssd. Можно ли это как-то вылечить? Благодарю за помощь
S.A.
Благодарил (а): 9 раз
18 сен 2019, 15:47
Включить в ядре поддержку NVMe не пробовали https://www.dell.com/support/article/ru ... m2?lang=ru
egor_babintsev
18 сен 2019, 16:11
S.A. писал(а):
18 сен 2019, 15:47
То есть при переключении контроллера на RST автоматически отлючается поддержка NVME? Да и в гайде по ссылке написано переключить режим контроллера на AHCI, а мне нужна работа на RST
