По самбе можете помочь?
kotopes
Благодарил (а): 10 раз
11 дек 2016, 13:20
По самбе можете помочь? папку разщарил. одну в домашней директории, вторую на примонтированом ехт4 разделе.
Та что в домашней удалённо открывается, а та что на примонтированом не открывается.
в самба им одинаковые права выставлены.
на те папку откуда разшарен права доступа также одинаковые стоят
файл snb.conf
# Sample configuration file for the Samba suite for Debian GNU/Linux.
# This is the main Samba configuration file. You should read the
# smb.conf(5) manual page in order to understand the options listed
# here. Samba has a huge number of configurable options most of which
# are not shown in this example
# Some options that are often worth tuning have been included as
# commented-out examples in this file.
# - When such options are commented with ";", the proposed setting
# differs from the default Samba behaviour
# - When commented with "#", the proposed setting is the default
# behaviour of Samba but the option is considered important
# enough to be mentioned here
# NOTE: Whenever you modify this file you should run the command
# "testparm" to check that you have not made any basic syntactic
# errors.
#======================= Global Settings =======================
[global]
## Browsing/Identification ###
# Change this to the workgroup/NT-domain name your Samba server will part of
workgroup = WORKGROUP
# server string is the equivalent of the NT Description field
server string = %h server (Samba, Ubuntu)
# Windows Internet Name Serving Support Section:
# WINS Support - Tells the NMBD component of Samba to enable its WINS Server
# wins support = no
# WINS Server - Tells the NMBD components of Samba to be a WINS Client
# Note: Samba can be either a WINS Server, or a WINS Client, but NOT both
; wins server = w.x.y.z
# This will prevent nmbd to search for NetBIOS names through DNS.
dns proxy = no
#### Networking ####
# The specific set of interfaces / networks to bind to
# This can be either the interface name or an IP address/netmask;
# interface names are normally preferred
; interfaces = 127.0.0.0/8 eth0
# Only bind to the named interfaces and/or networks; you must use the
# 'interfaces' option above to use this.
# It is recommended that you enable this feature if your Samba machine is
# not protected by a firewall or is a firewall itself. However, this
# option cannot handle dynamic or non-broadcast interfaces correctly.
; bind interfaces only = yes
#### Debugging/Accounting ####
# This tells Samba to use a separate log file for each machine
# that connects
log file = /var/log/samba/log.%m
# Cap the size of the individual log files (in KiB).
max log size = 1000
# If you want Samba to only log through syslog then set the following
# parameter to 'yes'.
# syslog only = no
# We want Samba to log a minimum amount of information to syslog. Everything
# should go to /var/log/samba/log.{smbd,nmbd} instead. If you want to log
# through syslog you should set the following parameter to something higher.
syslog = 0
# Do something sensible when Samba crashes: mail the admin a backtrace
panic action = /usr/share/samba/panic-action %d
####### Authentication #######
# Server role. Defines in which mode Samba will operate. Possible
# values are "standalone server", "member server", "classic primary
# domain controller", "classic backup domain controller", "active
# directory domain controller".
# Most people will want "standalone sever" or "member server".
# Running as "active directory domain controller" will require first
# running "samba-tool domain provision" to wipe databases and create a
# new domain.
server role = standalone server
# If you are using encrypted passwords, Samba will need to know what
# password database type you are using.
; passdb backend = tdbsam
obey pam restrictions = yes
# This boolean parameter controls whether Samba attempts to sync the Unix
# password with the SMB password when the encrypted SMB password in the
# passdb is changed.
unix password sync = yes
# For Unix password sync to work on a Debian GNU/Linux system, the following
# parameters must be set (thanks to Ian Kahan <<kahan@informatik.tu-muenchen.de> for
# sending the correct chat script for the passwd program in Debian Sarge).
passwd program = /usr/bin/passwd %u
passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
# This boolean controls whether PAM will be used for password changes
# when requested by an SMB client instead of the program listed in
# 'passwd program'. The default is 'no'.
pam password change = yes
# This option controls how unsuccessful authentication attempts are mapped
# to anonymous connections
map to guest = bad user
########## Domains ###########
# The following settings only takes effect if 'server role = primary
# classic domain controller', 'server role = backup domain controller'
# or 'domain logons' is set
# It specifies the location of the user's
# profile directory from the client point of view) The following
# required a [profiles] share to be setup on the samba server (see
# below)
; logon path = \\%N\profiles\%U
# Another common choice is storing the profile in the user's home directory
# (this is Samba's default)
# logon path = \\%N\%U\profile
# The following setting only takes effect if 'domain logons' is set
# It specifies the location of a user's home directory (from the client
# point of view)
; logon drive = H:
# logon home = \\%N\%U
# It specifies the script to run during logon. The script must be stored
# in the [netlogon] share
# NOTE: Must be store in 'DOS' file format convention
; logon script = logon.cmd
# This allows Unix users to be created on the domain controller via the SAMR
# RPC pipe. The example command creates a user account with a disabled Unix
# password; please adapt to your needs
; add user script = /usr/sbin/adduser --quiet --disabled-password --gecos "" %u
# This allows machine accounts to be created on the domain controller via the
# SAMR RPC pipe.
# The following assumes a "machines" group exists on the system
; add machine script = /usr/sbin/useradd -g machines -c "%u machine account" -d /var/lib/samba -s /bin/false %u
# This allows Unix groups to be created on the domain controller via the SAMR
# RPC pipe.
; add group script = /usr/sbin/addgroup --force-badname %g
############ Misc ############
# Using the following line enables you to customise your configuration
# on a per machine basis. The %m gets replaced with the netbios name
# of the machine that is connecting
; include = /home/samba/etc/smb.conf.%m
# Some defaults for winbind (make sure you're not using the ranges
# for something else.)
; idmap uid = 10000-20000
; idmap gid = 10000-20000
; template shell = /bin/bash
# Setup usershare options to enable non-root users to share folders
# with the net usershare command.
# Maximum number of usershare. 0 (default) means that usershare is disabled.
; usershare max shares = 100
# Allow users who've been granted usershare privileges to create
# public shares, not just authenticated ones
usershare allow guests = yes
#======================= Share Definitions =======================
# Un-comment the following (and tweak the other settings below to suit)
# to enable the default home directory shares. This will share each
# user's home directory as \\server\username
;[homes]
; comment = Home Directories
; browseable = no
# By default, the home directories are exported read-only. Change the
# next parameter to 'no' if you want to be able to write to them.
; read only = yes
# File creation mask is set to 0700 for security reasons. If you want to
# create files with group=rw permissions, set next parameter to 0775.
; create mask = 0700
# Directory creation mask is set to 0700 for security reasons. If you want to
# create dirs. with group=rw permissions, set next parameter to 0775.
; directory mask = 0700
# By default, \\server\username shares can be connected to by anyone
# with access to the samba server.
# Un-comment the following parameter to make sure that only "username"
# can connect to \\server\username
# This might need tweaking when using external authentication schemes
; valid users = %S
# Un-comment the following and create the netlogon directory for Domain Logons
# (you need to configure Samba to act as a domain controller too.)
;[netlogon]
; comment = Network Logon Service
; path = /home/samba/netlogon
; guest ok = yes
; read only = yes
# Un-comment the following and create the profiles directory to store
# users profiles (see the "logon path" option above)
# The path below should be writable by all users so that their
# profile directory may be created the first time they log on
;[profiles]
; comment = Users profiles
; path = /home/samba/profiles
; guest ok = no
; browseable = no
; create mask = 0600
[printers]
comment = All Printers
browseable = no
path = /var/spool/samba
printable = yes
; guest ok = no
; read only = yes
create mask = 0700
# Windows clients look for this share name as a source of downloadable
# printer drivers
[print$]
comment = Printer Drivers
path = /var/lib/samba/printers
; browseable = yes
; read only = yes
; guest ok = no
# Uncomment to allow remote administration of Windows print drivers.
# You may need to replace 'lpadmin' with the name of the group your
# admin users are members of.
# Please note that you also need to set appropriate Unix permissions
# to the drivers directory for these users to have write rights in it
; write list = root, @lpadmin
[Загрузки]
path = /home/konstantin/Загрузки
writeable = yes
; browseable = yes
guest ok = yes
[Папка]
path = /media/konstantin/d/Папка
writeable = yes
; browseable = yes
guest ok = yes
Монтирование дисков файл fstab:
# / was on /dev/sda2 during installation
UUID=f1dd9e44-7b8b-4223-86b0-07df73311627 / ext4 errors=remount-ro 0 1
# /boot was on /dev/sda5 during installation
UUID=d6973fb4-f844-4346-b72b-282c8610fb26 /boot ext2 defaults 0 2
# swap was on /dev/sda4 during installation
UUID=c4f3d5f4-3ed1-402f-a1e8-6c9397388672 none swap sw 0 0
#/dev/disk/by-uuid/8ebd75bf-60f4-4e2e-adff-7aeb0a5abe78 /home/konstantin/Загрузки/d auto nosuid,nodev,nofail,x-gvfs-show,owner 0 0
#/dev/disk/by-uuid/8ebd75bf-60f4-4e2e-adff-7aeb0a5abe78 /media/konstantin/d auto defaults 0 0
/dev/disk/by-uuid/8ebd75bf-60f4-4e2e-adff-7aeb0a5abe78 /media/konstantin/d auto nosuid,nodev,nofail,x-gvfs-show 0 0
Права на папки 777
Решение kotopes » 13 дек 2016, 20:33
Сделал так:
[Папка]
writeable = yes
; browseable = yes
guest ok = yes
force user = konstantin
Отсюда:
http://smb-conf.ru/force-user-s.html
Доступ появился.
Re: По самбе можете помочь?
11 дек 2016, 13:50
kotopes писал(а): Та что в домашней удалённо открывается, а та что на примонтированом не открывается.
С какой ошибкой отбивает? что скажет попытка подключения smclient -L смбсервер?
kotopes писал(а): на те папку откуда разшарен права доступа также одинаковые стоят
может перед той что в /media - права где обломные в вышестоящих папках
kotopes
11 дек 2016, 14:36
Chocobo писал(а): может перед той что в /media - права где обломные в вышестоящих папках
Может, но в нее я не захожу ведь. Это тогда от корня надо права выставлять всем папкам и владельца меня назначать. А это не правильно. Ведь домашняя папка от корня тоже, и не имеет прав меня /home/ ,а только root, и только когда уже идет konstantin она становится моей.
kotopes
11 дек 2016, 14:40
smclient -L смбсервер -так и писать?
11 дек 2016, 14:53
kotopes писал(а): Это тогда от корня надо права выставлять всем папкам и владельца меня назначать
А ничего что от корня стоят права на все основные директории (кроме /root) r-x для всех, да и владельцем для доступа туда быть вовсе не обязательно.
kotopes писал(а): так и писать?
ну тут думаю не возникает сомнений, что смбсервер в этой команде - будет хостнейм или ip хоста где поднят smb-сервис :blink:
kotopes
11 дек 2016, 15:02
кonstantin@asus-pc ~ $ smbclient -L ASUS-PC
WARNING: The "syslog" option is deprecated
Enter konstantin's password:
Domain=[WORKGROUP] OS=[Windows 6.1] Server=[Samba 4.3.11-Ubuntu]
Sharename Type Comment
print$ Disk Printer Drivers
Загрузки Disk
Папка Disk
IPC$ IPC IPC Service (asus-pc server (Samba, Ubuntu))
Общая Disk
Server Comment
ASUS-PC asus-pc server (Samba, Ubuntu)
KONSTANTIN-PC
Workgroup Master
WORKGROUP ASUS-PC
konstantin@asus-pc ~ $
11 дек 2016, 15:21
kotopes, здесь выглядит норм с виду. попробуй напрямую в "Папку"
smbclient //ASUS-PC/Папка
Если отдаст приветсиве самбы вида smb: \> - то проверь содержимое например с dir
И если отдаст корректо - конфиг самбы в норме и вопрос уже к фм (ошибку кстати ты так и не засветил)
kotopes
11 дек 2016, 15:57
проверю. ошибка не содержит текст ошибки. в винде просто выдает ошибку и просит проверить настройки сети виндовса, а с планшета просто не реагирует на нажатие.
kotopes
11 дек 2016, 16:38
smb: \> dir
NT_STATUS_ACCESS_DENIED listing \*
smb: \>
12 дек 2016, 20:45
kotopes писал(а): NT_STATUS_ACCESS_DENIED
Ну и проверяй права исходя из этой ошибки.
Если работает из домашней директории - зацепи шару через симлинк оттуда (или вовсе туда маунтить, раз в пермишнах заблудился)
kotopes
13 дек 2016, 14:19
я же уже проверил и написал какие стоят, читайте пожалуйста внимательнее . символьные ссылки не работают удалённо
kotopes
13 дек 2016, 20:33
Сделал так:
[Папка]
writeable = yes
; browseable = yes
guest ok = yes
Отсюда:
Доступ появился.
Вернуться в «Работа с сетью»
