LM 18.3 x64 Silviya PC, Ошибка при обновлении
vladimir146
Благодарил (а): 3 раза
10 сен 2019, 15:38
При обновлении стала выходить ошибка:
Извлечение шаблонов из пакетов: 100%
Настраивается пакет util-linux (2.27.1-6ubuntu3.8) …
insserv: warning: script 'S99panasoniclpd-init' missing LSB tags and overrides
insserv: warning: script 'panasoniclpd-init' missing LSB tags and overrides
insserv: There is a loop at service plymouth if started
insserv: There is a loop between service plymouth and networking if started
insserv:  loop involving service networking at depth 3
insserv:  loop involving service procps at depth 2
insserv:  loop involving service rpcbind at depth 6
insserv:  loop involving service urandom at depth 4
insserv: There is a loop between service panasoniclpd-init and mountdevsubfs if started
insserv:  loop involving service mountdevsubfs at depth 2
insserv:  loop involving service udev at depth 1
insserv: Starting panasoniclpd-init depends on plymouth and therefore on system facility `$all' which can not be true!
insserv: Max recursions depth 99 reached
insserv:  loop involving service lvm2-lvmetad at depth 1
insserv: There is a loop at service panasoniclpd-init if started
insserv: There is a loop between service panasoniclpd-init and udev if started
insserv:  loop involving service mountkernfs at depth 1
insserv: There is a loop between service panasoniclpd-init and dns-clean if started
insserv:  loop involving service dns-clean at depth 1
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
dpkg: ошибка при обработке пакета util-linux (--configure):
 подпроцесс установлен сценарий post-installation возвратил код ошибки 1
 util-linux
Ошибка при установке пакета. Попытка восстановления:
Настраивается пакет cups-daemon (2.1.3-4ubuntu0.10) …
dpkg: ошибка при обработке пакета cups-daemon (--configure):
dpkg: зависимости пакетов не позволяют настроить пакет cups-core-drivers:
 cups-core-drivers зависит от cups-daemon (>= 2.1.3-4ubuntu0.10), однако:
  Пакет cups-daemon пока не настроен.
dpkg: ошибка при обработке пакета cups-core-drivers (--configure):
 проблемы зависимостей — оставляем не настроенным
Настраивается пакет mysql-server-5.7 (5.7.27-0ubuntu0.16.04.1) …
dpkg: ошибка при обработке пакета mysql-server-5.7 (--configure):
dpkg: зависимости пакетов не позволяют настроить пакет mysql-server:
 mysql-server зависит от mysql-server-5.7, однако:
  Пакет mysql-server-5.7 пока не настроен.
dpkg: ошибка при обработке пакета mysql-server (--configure):
dpkg: зависимости пакетов не позволяют настроить пакет cups:
 cups зависит от cups-core-drivers (>= 2.1.3-4ubuntu0.10), однако:
  Пакет cups-core-drivers пока не настроен.
 cups зависит от cups-daemon (>= 2.1.3-4ubuntu0.10), однако:
dpkg: ошибка при обработке пакета cups (--configure):
dpkg: проблемы зависимостей не позволяют выполнить обработку триггеров systemd:
 systemd зависит от util-linux (>= 2.27.1), однако:
  Пакет util-linux пока не настроен.
dpkg: ошибка при обработке пакета systemd (--configure):
 проблемы зависимостей — оставляем триггеры не обработанными
 cups-daemon
 cups-core-drivers
 mysql-server-5.7
 util-linux
 mysql-server
 cups
 systemd
можно как-то пправить или надо сносить и ставить 19?
Решение Chocobo » 10 сен 2019, 17:15
В верхушку после /bin/sh попробуй добавить ему аналогичные строчки, как в том топике
### BEGIN INIT INFO
# Provides:
# Required-Start:
# Required-Stop:
# Default-Start:
# Default-Stop:
# Short-Description:
### END INIT INFO
Дорогу осилит идущий...
10 сен 2019, 16:40
vladimir146 писал(а):
10 сен 2019, 15:38
думается, принтер тут тебе наверное мешается, ели пишет про panasonic lpd
vladimir146
10 сен 2019, 16:57
может быть, а как бороться? принтер и сканер работают (МФУ)
10 сен 2019, 17:01
Встречали такую ошибку пару лет назад, вспомнил где я это видел ранее :)
Сломался пакет util-linux
vladimir146
10 сен 2019, 17:10
есть такой файл с кодом:
#! /bin/sh
start() {
	/usr/local/share/panasonic/scanner/bin/PanasonicMFSlpd &
stop() {
	killall PanasonicMFSlpd
	echo
restart() {
	stop
	start
case "$1" in
  start)
	start
  stop)
	stop
  restart|force-reload)
	restart
	echo $"Usage: $0 {start|stop|status|restart|reload|force-reload|condrestart}"
	exit 1
esac
exit 0
что может глючить? Дрова от МФУ Panasonic KX-MB1500
Последний раз редактировалось пользователем 1 vladimir146; всего редактировалось раз: 10
10 сен 2019, 17:15
### BEGIN INIT INFO
# Provides:
# Required-Start:
# Required-Stop:
# Default-Start:
# Default-Stop:
### END INIT INFO
vladimir146
10 сен 2019, 17:23
Chocobo, Спасибо, все заработало!!! Все обновилось без ошибок.
#! /bin/sh
### BEGIN INIT INFO
# Provides:
# Required-Start:
# Required-Stop:
# Default-Start:
# Default-Stop:
start() {
stop() {
	echo
restart() {
	stop
	start
case "$1" in
  start)
	start
  stop)
	stop
	restart
	exit 1
esac
exit 0
### END INIT INFO
10 сен 2019, 18:47
До 19 2?
vladimir146
10 сен 2019, 21:23
Dja, :-D да уж подловил :bravo:
Сейчас этот форум просматривают: ByteSpyder [Bot], Google [Bot] и 4 гостя
