Низкая скорость WIFI на ноутбуке HP
Leonid Malakhov
08 сен 2019, 02:27
1. Linux Mint 19.2 x64 XFCE
2.
Host: Malakhovs-HP-Laptop Kernel: 4.15.0-60-generic x86_64 bits: 64
compiler: gcc v: 7.4.0 Desktop: Xfce 4.12.3 Distro: Linux Mint 19.2 Tina
base: Ubuntu 18.04 bionic
Type: Laptop System: HP product: HP Laptop 17-ak0xx
v: Type1ProductConfigId serial: <filter>
Mobo: HP model: 8345 v: 41.33 serial: <filter> UEFI: Insyde v: F.06
date: 11/02/2017
ID-1: BAT0 charge: 33.2 Wh condition: 40.3/40.3 Wh (100%)
model: 133-42-6E-A JC04041 status: Discharging
Topology: Dual Core model: AMD A6-9220 RADEON R4 5 COMPUTE CORES 2C+3G
bits: 64 type: MCP arch: Excavator L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 9981
Speed: 1596 MHz min/max: 1300/2500 MHz Core speeds (MHz): 1: 1894 2: 1946
Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics] vendor: Hewlett-Packard
driver: amdgpu v: kernel bus ID: 00:01.0
Display: x11 server: X.Org 1.19.6 driver: amdgpu,ati
unloaded: fbdev,modesetting,radeon,vesa resolution: 1600x900~60Hz
OpenGL: renderer: AMD STONEY (DRM 3.23.0 4.15.0-60-generic LLVM 8.0.0)
v: 4.5 Mesa 19.0.8 direct render: Yes
Device-1: AMD vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus ID: 00:01.1
Device-2: AMD Family 15h Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 00:09.2
Sound Server: ALSA v: k4.15.0-60-generic
vendor: Hewlett-Packard driver: r8169 v: 2.3LK-NAPI port: 3000
bus ID: 02:00.0
IF: eno1 state: down mac: <filter>
Device-2: Realtek vendor: Hewlett-Packard driver: rtl8723de v: kernel
port: 2000 bus ID: 03:00.0
Local Storage: total: 465.76 GiB used: 7.69 GiB (1.7%)
ID-1: /dev/sda vendor: Seagate model: ST500LT012-1DG142 size: 465.76 GiB
ID-1: / size: 18.21 GiB used: 7.13 GiB (39.2%) fs: ext4 dev: /dev/sda3
ID-2: /home size: 426.10 GiB used: 565.9 MiB (0.1%) fs: ext4
dev: /dev/sda5
ID-3: swap-1 size: 3.82 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda2
System Temperatures: cpu: 47.4 C mobo: 34.0 C gpu: amdgpu temp: 47 C
Processes: 188 Uptime: 21m Memory: 3.80 GiB used: 1.09 GiB (28.6%)
inxi: 3.0.32
Проблема: Скороcть WIFI в Linux гораздо меньше, чем в Windows на той же конфигурации. Ноут как будто ловит очень слабый сигнал от роутера, хотя в Windows все отлично. Роутер Asus RT-N11P B1
Заранее спасибо!
08 сен 2019, 06:54
Примечание: если вы получаете очень слабый сигнал, попробуйте изменить выбор антенны
sudo tee /etc/modprobe.d/rtl8723de.conf <<< "options rtl8723de ant_sel=2"
(или ant_sel=1, если 2 не помогает).
https://askubuntu.ru/questions/144233/r ... stvom-d723
