НЕТУ WIFI. Сетевая карта Realtek RTL8111 / 8168/8411 PCI Express Gigabit Ethernet Controller
xtv
21 авг 2019, 14:05
У меня не видно wifi и он не работает. У меня Linux Mint Cinnamon 19.1 Tessa 64x.
вот
Результат inxi -Fxz
  Host: blup-HP-Laptop-17-ak0xx Kernel: 4.15.0-58-generic x86_64 bits: 64
  compiler: gcc v: 7.4.0 Desktop: Cinnamon 4.0.10
  Type: Laptop System: HP product: HP Laptop 17-ak0xx
  v: Type1ProductConfigId serial: <filter>
  Mobo: HP model: 8346 v: 41.33 serial: <filter> UEFI: Insyde v: F.06
  date: 11/02/2017
  ID-1: BAT0 charge: 40.9 Wh condition: 40.9/40.9 Wh (100%)
  model: 133-42-6E-A JC04041 status: Full
  Topology: Dual Core model: AMD A6-9220 RADEON R4 5 COMPUTE CORES 2C+3G
  bits: 64 type: MCP arch: Excavator L2 cache: 1024 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 9981
  Speed: 1297 MHz min/max: 1300/2500 MHz Core speeds (MHz): 1: 1297 2: 1297
  Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics] vendor: Hewlett-Packard
  driver: amdgpu v: kernel bus ID: 00:01.0
  Device-2: AMD Topaz XT [Radeon R7 M260/M265 / M340/M360 / M440/M445]
  driver: amdgpu v: kernel bus ID: 01:00.0
  Display: x11 server: X.Org 1.19.6 driver: amdgpu,ati
  unloaded: fbdev,modesetting,radeon,vesa resolution: 1600x900~60Hz
  OpenGL: renderer: AMD STONEY (DRM 3.23.0 4.15.0-58-generic LLVM 8.0.0)
  v: 4.5 Mesa 19.0.8 direct render: Yes
  Device-1: AMD vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
  bus ID: 00:01.1
  Device-2: AMD Family 15h Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus ID: 00:09.2
  Sound Server: ALSA v: k4.15.0-58-generic
  vendor: Hewlett-Packard driver: r8168 v: 8.045.08-NAPI port: 3000
  bus ID: 02:00.0
  IF: eno1 state: down mac: <filter>
  Device-2: Realtek vendor: Hewlett-Packard driver: N/A port: 2000
  bus ID: 03:00.0
  Device-3: T & A Mobile Phones type: USB driver: cdc_eem bus ID: 2-2:4
  IF: enp0s16u2 state: unknown speed: N/A duplex: N/A mac: <filter>
  Local Storage: total: 465.76 GiB used: 21.82 GiB (4.7%)
  ID-1: /dev/sda vendor: Toshiba model: MQ01ABF050 size: 465.76 GiB
  temp: 38 C
  ID-1: / size: 456.96 GiB used: 21.82 GiB (4.8%) fs: ext4 dev: /dev/sda2
  System Temperatures: cpu: 46.6 C mobo: 39.0 C gpu: amdgpu temp: 46 C
  Processes: 207 Uptime: 21m Memory: 3.80 GiB used: 1.31 GiB (34.5%)
  inxi: 3.0.27
Еще раз повторю, мой контроллер это Realtek RTL8111 / 8168/8411 PCI Express Gigabit Ethernet Controller.
На данный момент я подключен к usb модему и могу пользоваться интернетом, но я хочу прекратить это делать и начать пользоваться wifi.
Я установил linux впервые только вчера и поэтому старайтесь всё написать подробно чтобы я мог понять.
Решение vir0id » 22 авг 2019, 08:57
Белый Кролик писал(а):
22 авг 2019, 08:51
Напиши понятную инструкцию пожалуйста как установить драйвер из искодников.
Тут же все поняино. Вводи себе команды и все
wget -d -c -O 'rtlwifi_new.zip' 'https://github.com/lwfinger/rtlwifi_new/archive/extended.zip'
unzip rtlwifi_new.zip
cd rtlwifi_new-extended
sudo make install
sudo modprobe -r rtl8723de
sudo modprobe rtl8723de
К тому же на форуме куча инструкций есть
Последний раз редактировалось пользователем 2 xtv; всего редактировалось раз: 21
Белый Кролик
Решено: 10
Благодарил (а): 354 раза
НЕТУ WIFI. Realtek RTL8111 / 8168/8411 PCI Express Gigabit Ethernet Controller
21 авг 2019, 14:22
Найди в меню программ терминал (вроде открывается при нажатии alt+ctrl+t) и скопируй туда эти команды (после каждой команды нажимай кнопку enter самой собой)
sudo apt-get install git build-essential dkms linux-headers-$(uname -r)
git clone -b extended https://github.com/lwfinger/rtlwifi_new.git
sudo dkms add ./rtlwifi_new
sudo dkms install rtlwifi-new/0.6
sudo cp /usr/src/rtlwifi-new-0.6/firmware/rtlwifi/* /lib/firmware/rtlwifi/
sudo reboot
Белый Кролик
Решено: 10
21 авг 2019, 14:27
xtv, я напутал. Realtek RTL8111/8168/8411 это не wi-fi, а сетевая карта.
xtv
21 авг 2019, 14:32
Я сделал всё, но ничего не изменилось. Я добавил в заголовок что это сетевая карта.
Белый Кролик
Решено: 10
21 авг 2019, 14:39
xtv писал(а):
21 авг 2019, 14:32
Поискал описание твоего ноутбука в интернете. Пишут что wi-fi называется RTL8723DE. Попробуй в терминале так:
sudo modprobe -r rtl8723de && sudo modprobe rtl8723de
21 авг 2019, 14:42
xtv писал(а):
21 авг 2019, 14:05
это вайфай без драйвера.
xtv писал(а):
21 авг 2019, 14:05
А это результат работы sudo lshw -C network
а сюда сам загляни. :-D
xtv
21 авг 2019, 14:43
Вот результат
modprobe: FATAL: Module rtl8723de not found.
xtv
21 авг 2019, 14:44
etamax, Я не понимаю что это значит. Мне надо как-то установить драйвер? И как это сделать?
21 авг 2019, 14:46
xtv, Да , нужен драйвер , и под второй спойлер ты сдублировал содержимое первого .
Белый Кролик
Решено: 10
21 авг 2019, 14:47
Давай еще разок вот так:
git clone https://github.com/lwfinger/rtlwifi_new.git
cd rtlwifi_new
git checkout extended
sudo make install
21 авг 2019, 14:50
21 авг 2019, 14:47
make install
без make ?
Белый Кролик
Решено: 10
21 авг 2019, 14:53
etamax писал(а):
21 авг 2019, 14:50
21 авг 2019, 14:47
make install
без make ?
Я хз, инструкция с убунтовского форума, но поправь если что не так.
21 авг 2019, 14:57
Белый Кролик, я не смотрел ту инструкцию , но обычно из исходников сначала собирают потом ставят.
Белый Кролик
Решено: 10
21 авг 2019, 15:00
etamax, инструкцию тут нашел https://ibcomputing.com/install-rtl8723 ... ntu-18-04/
В комментариях кто-то пишет что не работает, а кто-то что работает.
xtv
21 авг 2019, 15:03
Я сделал всё. Вот итог последнего кода
modprobe: ERROR: could not insert 'rtl8723de': Unknown symbol in module, or unknown parameter (see dmesg)
Белый Кролик
Решено: 10
21 авг 2019, 15:17
xtv, похоже пропустили make так что пробуй вот так:
cd rtlwifi_new
make
sudo make install
xtv
21 авг 2019, 15:23
Белый Кролик, :sad: увы, всё также
Белый Кролик
Решено: 10
21 авг 2019, 15:31
xtv, перезагружался после установки?
xtv
21 авг 2019, 15:35
Белый Кролик, да
21 авг 2019, 15:37
А поиском пользоваться не умеем?
PCIe Bus error severity=Corrected много-много строк (Пост Dja #62265)
Для этого необязательно быть несколько дней/недель/месяцев/лет в linux
У форума есть поиск. Будьте добры использовать данный функционал.
________________________________
И внимательно читайте выхлоп при make. Помнится он там что-то пишет. про ветки
