Проблема с размером интерфейса при высоком разрешении экрана
Andrzej
11 авг 2019, 20:51
Добрый день!
У меня Linux Mint 19.2 Cinnamon x64, видеокарта GeForce GTX 960M, версия драйвера 430.26.
Host: saband-pc Kernel: 4.15.0-55-generic x86_64 bits: 64 compiler: gcc
v: 7.4.0 Desktop: Cinnamon 4.2.3 Distro: Linux Mint 19.2 Tina
base: Ubuntu 18.04 bionic
Type: Portable System: Dell product: Inspiron 7559 v: 1.1.8
serial: <filter>
Mobo: Dell model: 0H0CC0 v: A00 serial: <filter> UEFI: Dell v: 1.1.8
date: 04/17/2016
ID-1: BAT0 charge: 6.3 Wh condition: 6.3/74.0 Wh (9%) model: SDI Dell
status: Full
Topology: Quad Core model: Intel Core i7-6700HQ bits: 64 type: MT MCP
arch: Skylake-S rev: 3 L2 cache: 6144 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 41472
Speed: 800 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
Device-1: Intel HD Graphics 530 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0
Device-2: NVIDIA GM107M [GeForce GTX 960M] vendor: Dell driver: nvidia
v: 430.26 bus ID: 02:00.0
Display: x11 server: X.Org 1.19.6 driver: modesetting,nvidia
unloaded: fbdev,nouveau,vesa resolution: 3200x1800~60Hz
OpenGL: renderer: GeForce GTX 960M/PCIe/SSE2 v: 4.6.0 NVIDIA 430.26
Device-1: Intel 100 Series/C230 Series Family HD Audio
vendor: Dell Sunrise Point-H driver: snd_hda_intel v: kernel
bus ID: 00:1f.3
Sound Server: ALSA v: k4.15.0-55-generic
vendor: Dell driver: r8169 v: 2.3LK-NAPI port: d000 bus ID: 04:00.0
Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel port: d000
bus ID: 05:00.0
IF: wlp5s0 state: up mac: <filter>
Local Storage: total: 1.03 TiB used: 377.58 GiB (35.9%)
ID-1: /dev/sda vendor: SanDisk model: Z400s M.2 2280 128GB
ID-2: /dev/sdb vendor: Western Digital model: WD10JPVX-75JC3T0
ID-1: / size: 54.01 GiB used: 19.99 GiB (37.0%) fs: ext4 dev: /dev/sda4
ID-2: /home size: 688.89 GiB used: 357.55 GiB (51.9%) fs: ext4
dev: /dev/sdb3
System Temperatures: cpu: 59.0 C mobo: 29.8 C sodimm: 57.0 C gpu: nvidia
temp: 59 C
Fan Speeds (RPM): cpu: 1937
Processes: 267 Uptime: 4h 45m Memory: 15.54 GiB used: 3.20 GiB (20.6%)
inxi: 3.0.32
Я использую разрешение экрана 3200x1800. В настройках у меня включено масштабирование double Hi-DPI и scaling factor 1.2 в настройках шрифтов. Некоторые приложения при этом выглядят хорошо, но в других все элементы интерфейса (шрифты и иконки) просто микроскопические. Пример можно увидеть на скрине: в Filezilla все иконки и шрифты нормального размере, а в Kdenlive всё маленькое. Настройки шрифта в Qt5 Settings менять пробовал, не помогло (помимо Kdenlive это ещё, например, такие программы, как GuitarPro 6, Enpass, Pinta... да много их).
Есть какие-то варианты решения, кроме как ставить низкое разрешение экрана?
Решение vir0id » 12 авг 2019, 05:24
Andrzej писал(а):
12 авг 2019, 00:28
То есть, с этим ничего нельзя сделать?
Можно. Ставь себе вторую DE. И там меняй размеры шрифтов по умолчанию. Может глядишь, и в этой шкуре чего-то подправится.
11 авг 2019, 20:58
Пан поляк? Почему в циннамоне проги для кде , может в этом причина?
Andrzej
11 авг 2019, 21:09
Нет, просто живу в Польше :)
Проги для KDE потому, что нет альтернатив. Получается, нужно менять Cinnamon на KDE?
11 авг 2019, 21:19
Andrzej писал(а):
11 авг 2019, 20:51
Linux Mint 19.2
Здесь уже нет KDE , только до 18.3
Благодарил (а): 794 раза
11 авг 2019, 21:45
Andrzej, проблема в том что не все приложения поддерживают Hi-DPI. А общесистемные настройки не могут повлиять на эти приложения
Andrzej
12 авг 2019, 00:28
etamax писал(а):
11 авг 2019, 21:19
Ну, теоретически, можно и даунгрейд сделать, если это решит проблему. На 19.2 я только пару неделю назад обновился.
11 авг 2019, 21:45
12 авг 2019, 05:24
Andrzej писал(а):
12 авг 2019, 00:28
12 авг 2019, 06:06
Andrzej, попробуй Kubuntu, возможно, в кедах лучше с Hi-DPI
Andrzej
13 авг 2019, 18:22
vir0id писал(а):
12 авг 2019, 05:24
А что, так можно было?! :)
Офигеть. Поставил рядом MATE, там все размеры шрифтов и иконок правильные. Круто :) Спасибо.
