LinuxMint 19x64 + WiFi Intel 4965agn rev61 + низкая скорость
Mashulechka
05 июл 2019, 10:39
1. Linux Mint 19 x64
2. Ноутбук Acer TravelMate 5720G
3. Встроенный WiFi адаптер Intel 4965agn rev61
TravelMate-5720 ~ $ inxi -Fxz
System:    Host: TravelMate-5720 Kernel: 4.15.0-54-generic x86_64
           bits: 64 gcc: 7.4.0
           Desktop: MATE 1.20.1 (Gtk 3.22.30-1ubuntu3)
           Distro: Linux Mint 19 Tara
Machine:   Device: laptop System: Acer product: TravelMate 5720 v: 0100 serial: N/A
           Mobo: Acer model: Columbia v: Rev serial: N/A
           BIOS: Phoenix v: V1.31 date: 01/17/2008
CPU:       Dual core Intel Core2 Duo T9300 (-MCP-)
           arch: Penryn rev.6 cache: 6144 KB
           flags: (lm nx sse sse2 sse3 sse4_1 ssse3 vmx) bmips: 9974
           clock speeds: max: 2501 MHz 1: 1326 MHz 2: 1250 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] RV630/M76 [Mobility Radeon HD 2600]
           bus-ID: 01:00.0
           drivers: ati,radeon (unloaded: modesetting,fbdev,vesa)
           Resolution: 1280x800@59.91hz
           OpenGL: renderer: AMD RV630 (DRM 2.50.0 / 4.15.0-54-generic, LLVM 8.0.0)
           version: 3.3 Mesa 19.0.2 Direct Render: Yes
Audio:     Card Intel 82801H (ICH8 Family) HD Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.15.0-54-generic
Network:   Card-1: Broadcom and subsidiaries NetLink BCM5787M Gigabit Ethernet PCIE
           driver: tg3 v: 3.137 bus-ID: 02:00.0
           Card-2: Intel PRO/Wireless 4965 AG or AGN [Kedron] Network Connection
           driver: iwl4965 v: in-tree: bus-ID: 04:00.0
           IF: wlp4s0 state: up mac: <filter>
Drives:    HDD Total Size: 120.0GB (16.0% used)
           ID-1: /dev/sda model: KINGSTON_SV300S3 size: 120.0GB
Partition: ID-1: / size: 106G used: 15G (15%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 4.29GB used: 0.00GB (0%)
           fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 56.0C mobo: 48.0C gpu: 38.0
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 203 Uptime: 1:28 Memory: 1504.7/3944.2MB
           Init: systemd runlevel: 5 Gcc sys: 7.4.0
Проблема: низкая скорость входящего интернет соединения по WiFi 5GHz IEEE 802.11n (16-18 мегабит), причём исходящая выше почти в 4 раза.
Видео смотреть невозможно, тормозится каждые 2-3 секунды. Через провод - всё хорошо (скорость ~90 мегабит, видео играет без запинки).
Перегружаюсь в Windows (например Win10 x64) скорость по WiFi ~90 мегабит (как и на всех других моих устройствах: телефонах, планшетах, смарт тв, тв боксах), видео играет без запинки. Беру старый свисток Dlink DWA140 rev3 ver2 2,4GHz, подключаю к ноутбуку с запущенным Linux Mint 19 x64, скорость становится веселее: Вопрос: можно ли на Linux Mint 19 x64 увеличить скорость входящего интернет соединения по WiFi на моей конфигурации ноутбука?
05 июл 2019, 11:24
Mashulechka, возможно нужно переключить антенну.
Покажи вывод
lspci -knn | grep -A3 Network
Mashulechka
05 июл 2019, 11:34
05 июл 2019, 11:24
Покажи вывод
TravelMate-5720 ~ $ lspci -knn | grep -A3 Network
04:00.0 Network controller [0280]: Intel Corporation PRO/Wireless 4965 AG or AGN [Kedron] Network Connection [8086:4229] (rev 61)
	Subsystem: Intel Corporation PRO/Wireless 4965 AG or AGN [8086:1101]
	Kernel driver in use: iwl4965
	Kernel modules: iwl4965
05 июл 2019, 12:08
Mashulechka, попробуй сделать так и проверь как работает инет
sudo modprobe -r iwl4965
sudo modprobe iwl4965 ant_sel=2
Mashulechka
05 июл 2019, 12:22
05 июл 2019, 12:08
К сожалению, так же.
Смотрю - в Сведениях О Текущем Подключении скорость прыгает каждые 3-7 секунд: 121 / 243 / 270 Мегабит/с
На вынях такого нет.
Обновление на 19.1 результата тоже не дало.
Изменение параметра ant_sel= какие-то странные вещи выдаёт (не может же быть антенны 3 и 4?)
TravelMate-5720 ~ $ inxi -s
  System Temperatures: cpu: 56.0 C mobo: 47.0 C gpu: radeon temp: 40 C
TravelMate-5720 ~ $ inxi -S
  Host: TravelMate-5720 Kernel: 4.15.0-54-generic x86_64 bits: 64
  Desktop: MATE 1.20.1 Distro: Linux Mint 19.1 Tessa
TravelMate-5720 ~ $ sudo modprobe -r iwl4965
TravelMate-5720 ~ $ sudo modprobe iwl4965 ant_sel=1
TravelMate-5720 ~ $ iwlist scan | egrep -i 'ssid|quality'
                    Quality=66/70  Signal level=-44 dBm
                    ESSID:"Babylon5_5GHz"
TravelMate-5720 ~ $ sudo modprobe iwl4965 ant_sel=2
                    Quality=63/70  Signal level=-47 dBm
TravelMate-5720 ~ $ sudo modprobe iwl4965 ant_sel=3
                    Quality=64/70  Signal level=-46 dBm
TravelMate-5720 ~ $ sudo modprobe iwl4965 ant_sel=4
Последний раз редактировалось пользователем 1 Mashulechka; всего редактировалось раз: 5
Благодарил (а): 1737 раз
05 июл 2019, 13:10
видимо что-то с каналами связано, постоянно перебирает отчего-то...
никаких хактулз не ставил на сканирование эфира?
Mashulechka
05 июл 2019, 13:13
05 июл 2019, 13:10
Нет, я так - по минимуму Linux познаю - браузеры, видео, документики.
Только 18.3 вчера на 19 обновилось, а сегодня на 19.1.
Тут вот: Переключение антенн адаптера Wi-Fi на примере Realtek RTL8723BE
проблема решилась с переключением антенн (так же - в винде работает, под линуксом не очень).
А у меня не выходит каменный цветок :)
Mashulechka
05 июл 2019, 17:37
Временный выход.
В ящике завалялся китайский свисток (5GHz, небольшой), драйвера с диска не встали, в комментах товара на али посоветовали способ: Сработал способ: Build and install without DKMS
Был скачан архив, распакован, произведён вход в эту директорию и выполнены эти 3 команды.
Свисток системой увиделся, wifi заработал, скорость - тарифная максимальная: Но всё же хочется, чтоб без таких внешних костылей заработал бы встроенный адаптер.
06 июл 2019, 06:53
Mashulechka писал(а):
05 июл 2019, 17:37
Там нужна старая версия фирмвари. Вообще устанавливать на металлолом современные версии дистров это глупость, если до тебя это ещё не дошло.
С ядром 3.16 на каком-нибудь дистре вафля бы заработала. В 6 и 7 Дебиане ещё поддерживали, но точно уже не помню.
Ну или другой дистр попробуй.
yurikfm
Благодарил (а): 4 раза
06 июл 2019, 10:33
так а зачем тебе 5ГГц?
он же только ширину канала дает.наверняка ты не владелец интернет-кафе,тебе незачем использовать такую частоту.
пересаживайся на 2.5ГГц,если оборудование позволяет.
