Имею следующую систему:
System: Host: arbeit Kernel: 4.19.49-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.15.5
Distro: Manjaro Linux
Machine: Type: Desktop Mobo: Gigabyte model: Z87M-D3H v: x.x serial: <root required>
BIOS: American Megatrends v: 11b date: 06/12/2014
CPU: Topology: Quad Core model: Intel Core i5-4690 bits: 64 type: MCP L2 cache: 6144 KiB
Speed: 1111 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 1083 2: 1040 3: 966 4: 1034
Graphics: Device-1: AMD Hawaii PRO [Radeon R9 290/390] driver: amdgpu v: kernel
Display: x11 server: X.Org 1.20.5 driver: amdgpu FAILED: ati unloaded: modesetting
resolution: 1920x1080~60Hz
OpenGL: renderer: AMD Radeon R9 200 Series (HAWAII DRM 3.27.0 4.19.49-1-MANJARO LLVM 8.0.0)
v: 4.5 Mesa 19.0.6
Audio: Device-1: Intel 8 Series/C220 Series High Definition Audio driver: snd_hda_intel
Device-2: AMD Hawaii HDMI Audio [Radeon R9 290/290X / 390/390X] driver: snd_hda_intel
Sound Server: ALSA v: k4.19.49-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8168
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: 94:de:80:6b:99:95
Drives: Local Storage: total: 817.89 GiB used: 31.33 GiB (3.8%)
ID-1: /dev/sda vendor: Samsung model: SSD 850 PRO 128GB size: 119.24 GiB
ID-2: /dev/sdb vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB
ID-3: /dev/sdc vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB
Partition: ID-1: / size: 35.77 GiB used: 10.04 GiB (28.1%) fs: ext4 dev: /dev/sdc2
ID-2: /boot size: 984.3 MiB used: 53.8 MiB (5.5%) fs: ext2 dev: /dev/sdc1
ID-3: /home size: 191.25 GiB used: 21.23 GiB (11.1%) fs: ext4 dev: /dev/sdc3
Sensors: System Temperatures: cpu: 46.0 C mobo: N/A gpu: amdgpu temp: 29 C
Info: Processes: 188 Uptime: 25m Memory: 15.60 GiB used: 2.46 GiB (15.8%) Shell: bash inxi: 3.0.34 Возникла следующая проблема. Купил SSD и установил систему на него. Но был сильно удивлен долгой загрузкой. Намного дольше чем винда. А самое главное система грузиться намного дольше даже чем с обычного диска. Порядка 40 секунд.
Долго пытался починить самостоятельно. Несколько раз переустанавливал. Даже умудрился сделать так настройки БИВАС, что даже в него зайти не мог. Слава богу догадался батарейку вынуть. Ничего не получается.
Нервно курил форумы и нашел подсказку в виде dmseg. Нашел там интересное. Самое интересное в самом конце. (Простите файлик большой.)
Подскажите пожалуйста на что он жалуется и что мне надо сделать и как? Опыт в линуксе - пользователь. Сложные вещи пока только прочитать могу, но не всегда понимаю.
Самое интересное. Большой временной разрыв. Что происходит то? (((
[ 132.774249] audit: type=1131 audit(1561914135.857:42): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-system comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 133.248455] audit: type=1130 audit(1561914136.330:43): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=org.cups.cupsd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 203.922893] audit: type=1130 audit(1561914207.004:44): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 233.972649] audit: type=1131 audit(1561914237.054:45): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 907.661829] audit: type=1130 audit(1561914910.739:46): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 907.661831] audit: type=1131 audit(1561914910.739:47): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1531.714163] amdgpu: [powerplay]
failed to send message 282 ret is 254
Полный текст файла
[ 0.000000] Linux version 4.19.49-1-MANJARO (builduser@development) (gcc version 8.3.0 (GCC)) #1 SMP PREEMPT Sun Jun 9 20:24:20 UTC 2019
[ 0.000000] Command line: BOOT_IMAGE=/vmlinuz-4.19-x86_64 root=UUID=7cdf2b30-e189-4c69-b7f6-bb018beae453 rw quiet
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Centaur CentaurHauls
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009d7ff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009d800-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000bf5f3fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000bf5f4000-0x00000000bf5fafff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000bf5fb000-0x00000000c00d4fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000c00d5000-0x00000000c062ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000c0630000-0x00000000dd62dfff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000dd62e000-0x00000000dd6c5fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000dd6c6000-0x00000000dd70dfff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000dd70e000-0x00000000dd7c5fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000dd7c6000-0x00000000df7fefff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000df7ff000-0x00000000df7fffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000041effffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.7 present.
[ 0.000000] DMI: Gigabyte Technology Co., Ltd. Z87M-D3H/Z87M-D3H, BIOS 11b 06/12/2014
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 3492.052 MHz processor
[ 0.001330] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.001331] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.001336] last_pfn = 0x41f000 max_arch_pfn = 0x400000000
[ 0.001339] MTRR default type: uncachable
[ 0.001340] MTRR fixed ranges enabled:
[ 0.001340] 00000-9FFFF write-back
[ 0.001341] A0000-BFFFF uncachable
[ 0.001341] C0000-CFFFF write-protect
[ 0.001342] D0000-E7FFF uncachable
[ 0.001342] E8000-FFFFF write-protect
[ 0.001343] MTRR variable ranges enabled:
[ 0.001344] 0 base 0000000000 mask 7C00000000 write-back
[ 0.001344] 1 base 0400000000 mask 7FF0000000 write-back
[ 0.001345] 2 base 0410000000 mask 7FF8000000 write-back
[ 0.001345] 3 base 0418000000 mask 7FFC000000 write-back
[ 0.001346] 4 base 041C000000 mask 7FFE000000 write-back
[ 0.001346] 5 base 041E000000 mask 7FFF000000 write-back
[ 0.001347] 6 base 00E0000000 mask 7FE0000000 uncachable
[ 0.001347] 7 disabled
[ 0.001347] 8 disabled
[ 0.001348] 9 disabled
[ 0.001954] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.002100] total RAM covered: 16368M
[ 0.002349] Found optimal setting for mtrr clean up
[ 0.002350] gran_size: 64K chunk_size: 32M num_reg: 7 lose cover RAM: 0G
[ 0.002938] e820: update [mem 0xe0000000-0xffffffff] usable ==> reserved
[ 0.002942] last_pfn = 0xdf800 max_arch_pfn = 0x400000000
[ 0.008279] found SMP MP-table at [mem 0x000fd740-0x000fd74f]
[ 0.014748] Scanning 1 areas for low memory corruption
[ 0.014751] Using GB pages for direct mapping
[ 0.014753] BRK [0x172c01000, 0x172c01fff] PGTABLE
[ 0.014754] BRK [0x172c02000, 0x172c02fff] PGTABLE
[ 0.014754] BRK [0x172c03000, 0x172c03fff] PGTABLE
[ 0.014783] BRK [0x172c04000, 0x172c04fff] PGTABLE
[ 0.014784] BRK [0x172c05000, 0x172c05fff] PGTABLE
[ 0.014939] BRK [0x172c06000, 0x172c06fff] PGTABLE
[ 0.014968] BRK [0x172c07000, 0x172c07fff] PGTABLE
[ 0.015030] BRK [0x172c08000, 0x172c08fff] PGTABLE
[ 0.015030] BRK [0x172c09000, 0x172c09fff] PGTABLE
[ 0.015077] BRK [0x172c0a000, 0x172c0afff] PGTABLE
[ 0.015146] BRK [0x172c0b000, 0x172c0bfff] PGTABLE
[ 0.015233] BRK [0x172c0c000, 0x172c0cfff] PGTABLE
[ 0.015284] RAMDISK: [mem 0x36a97000-0x37542fff]
[ 0.015289] ACPI: Early table checksum verification disabled
[ 0.016967] ACPI: RSDP 0x00000000000F0490 000024 (v02 ALASKA)
[ 0.016969] ACPI: XSDT 0x00000000DD792078 000074 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.016973] ACPI: FACP 0x00000000DD79EE18 00010C (v05 ALASKA A M I 01072009 AMI 00010013)
[ 0.016977] ACPI: DSDT 0x00000000DD792188 00CC8D (v02 ALASKA A M I 00000088 INTL 20091112)
[ 0.016979] ACPI: FACS 0x00000000DD7C4080 000040
[ 0.016981] ACPI: APIC 0x00000000DD79EF28 000072 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.016983] ACPI: FPDT 0x00000000DD79EFA0 000044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.016985] ACPI: SSDT 0x00000000DD79EFE8 000539 (v01 PmRef Cpu0Ist 00003000 INTL 20120711)
[ 0.016987] ACPI: SSDT 0x00000000DD79F528 000AD8 (v01 PmRef CpuPm 00003000 INTL 20120711)
[ 0.016989] ACPI: MCFG 0x00000000DD7A0000 00003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.016991] ACPI: HPET 0x00000000DD7A0040 000038 (v01 ALASKA A M I 01072009 AMI. 00000005)
[ 0.016993] ACPI: SSDT 0x00000000DD7A0078 00036D (v01 SataRe SataTabl 00001000 INTL 20120711)
[ 0.016995] ACPI: SSDT 0x00000000DD7A03E8 0034E1 (v01 SaSsdt SaSsdt 00003000 INTL 20091112)
[ 0.016997] ACPI: DMAR 0x00000000DD7A38D0 000080 (v01 INTEL HSW 00000001 INTL 00000001)
[ 0.017003] ACPI: Local APIC address 0xfee00000
[ 0.017059] No NUMA configuration found
[ 0.017059] Faking a node at [mem 0x0000000000000000-0x000000041effffff]
[ 0.017062] NODE_DATA(0) allocated [mem 0x41effc000-0x41effffff]
[ 0.017078] Zone ranges:
[ 0.017080] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.017081] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.017081] Normal [mem 0x0000000100000000-0x000000041effffff]
[ 0.017082] Device empty
[ 0.017083] Movable zone start for each node
[ 0.017083] Early memory node ranges
[ 0.017084] node 0: [mem 0x0000000000001000-0x000000000009cfff]
[ 0.017084] node 0: [mem 0x0000000000100000-0x00000000bf5f3fff]
[ 0.017085] node 0: [mem 0x00000000bf5fb000-0x00000000c00d4fff]
[ 0.017085] node 0: [mem 0x00000000c0630000-0x00000000dd62dfff]
[ 0.017085] node 0: [mem 0x00000000dd6c6000-0x00000000dd70dfff]
[ 0.017086] node 0: [mem 0x00000000df7ff000-0x00000000df7fffff]
[ 0.017086] node 0: [mem 0x0000000100000000-0x000000041effffff]
[ 0.017088] Reserved but unavailable: 100 pages
[ 0.017089] Initmem setup node 0 [mem 0x0000000000001000-0x000000041effffff]
[ 0.017090] On node 0 totalpages: 4178097
[ 0.017091] DMA zone: 64 pages used for memmap
[ 0.017091] DMA zone: 21 pages reserved
[ 0.017092] DMA zone: 3996 pages, LIFO batch:0
[ 0.017149] DMA32 zone: 14085 pages used for memmap
[ 0.017149] DMA32 zone: 901397 pages, LIFO batch:63
[ 0.029846] Normal zone: 51136 pages used for memmap
[ 0.029847] Normal zone: 3272704 pages, LIFO batch:63
[ 0.074416] ACPI: PM-Timer IO Port: 0x1808
[ 0.074418] ACPI: Local APIC address 0xfee00000
[ 0.074423] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.074432] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[ 0.074433] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.074434] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.074435] ACPI: IRQ0 used by override.
[ 0.074435] ACPI: IRQ9 used by override.
[ 0.074437] Using ACPI (MADT) for SMP configuration information
[ 0.074438] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.074441] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.074452] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.074453] PM: Registered nosave memory: [mem 0x0009d000-0x0009dfff]
[ 0.074453] PM: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
[ 0.074454] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[ 0.074454] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[ 0.074455] PM: Registered nosave memory: [mem 0xbf5f4000-0xbf5fafff]
[ 0.074456] PM: Registered nosave memory: [mem 0xc00d5000-0xc062ffff]
[ 0.074457] PM: Registered nosave memory: [mem 0xdd62e000-0xdd6c5fff]
[ 0.074458] PM: Registered nosave memory: [mem 0xdd70e000-0xdd7c5fff]
[ 0.074458] PM: Registered nosave memory: [mem 0xdd7c6000-0xdf7fefff]
[ 0.074459] PM: Registered nosave memory: [mem 0xdf800000-0xf7ffffff]
[ 0.074459] PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[ 0.074460] PM: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
[ 0.074460] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.074460] PM: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[ 0.074461] PM: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
[ 0.074461] PM: Registered nosave memory: [mem 0xfed04000-0xfed1bfff]
[ 0.074462] PM: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[ 0.074462] PM: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
[ 0.074462] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.074463] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[ 0.074463] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.074465] [mem 0xdf800000-0xf7ffffff] available for PCI devices
[ 0.074465] Booting paravirtualized kernel on bare hardware
[ 0.074467] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.151298] random: get_random_bytes called from start_kernel+0x95/0x53f with crng_init=0
[ 0.151302] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
[ 0.151423] percpu: Embedded 46 pages/cpu s151552 r8192 d28672 u524288
[ 0.151427] pcpu-alloc: s151552 r8192 d28672 u524288 alloc=1*2097152
[ 0.151427] pcpu-alloc: [0] 0 1 2 3
[ 0.151439] Built 1 zonelists, mobility grouping on. Total pages: 4112791
[ 0.151440] Policy zone: Normal
[ 0.151441] Kernel command line: BOOT_IMAGE=/vmlinuz-4.19-x86_64 root=UUID=7cdf2b30-e189-4c69-b7f6-bb018beae453 rw quiet
[ 0.154200] Calgary: detecting Calgary via BIOS EBDA area
[ 0.154201] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.187938] Memory: 16343708K/16712388K available (12300K kernel code, 1385K rwdata, 3600K rodata, 1540K init, 3788K bss, 368680K reserved, 0K cma-reserved)
[ 0.188009] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.188012] Kernel/User page tables isolation: enabled
[ 0.193357] ftrace: allocating 36153 entries in 142 pages
[ 0.202990] rcu: Preemptible hierarchical RCU implementation.
[ 0.202991] rcu: CONFIG_RCU_FANOUT set to non-default value of 32.
[ 0.202991] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.202992] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[ 0.202992] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.202993] Tasks RCU enabled.
[ 0.202993] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.204155] NR_IRQS: 20736, nr_irqs: 456, preallocated irqs: 16
[ 0.204294] rcu: Offload RCU callbacks from CPUs: (none).
[ 0.204328] spurious 8259A interrupt: IRQ7.
[ 0.204338] Console: colour dummy device 80x25
[ 0.204342] console [tty0] enabled
[ 0.204351] ACPI: Core revision 20180810
[ 0.204484] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.204490] hpet clockevent registered
[ 0.204493] APIC: Switch to symmetric I/O mode setup
[ 0.204494] DMAR: Host address width 39
[ 0.204495] DMAR: DRHD base: 0x000000fed90000 flags: 0x1
[ 0.204498] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap d2008c20660462 ecap f010da
[ 0.204499] DMAR: RMRR base: 0x000000df682000 end: 0x000000df690fff
[ 0.204500] DMAR-IR: IOAPIC id 8 under DRHD base 0xfed90000 IOMMU 0
[ 0.204500] DMAR-IR: HPET id 0 under DRHD base 0xfed90000
[ 0.204501] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.204708] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.204709] x2apic enabled
[ 0.204713] Switched APIC routing to cluster x2apic.
[ 0.205087] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.221160] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x3255fcceed3, max_idle_ns: 440795202126 ns
[ 0.221169] Calibrating delay loop (skipped), value calculated using timer frequency.. 6986.10 BogoMIPS (lpj=11640173)
[ 0.221170] pid_max: default: 32768 minimum: 301
[ 0.221193] Security Framework initialized
[ 0.221194] Yama: becoming mindful.
[ 0.221196] AppArmor: AppArmor disabled by boot time parameter
[ 0.222986] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.223900] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.223937] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.223966] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.224124] CPU0: Thermal monitoring enabled (TM1)
[ 0.224134] process: using mwait in idle threads
[ 0.224136] Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 1024
[ 0.224136] Last level dTLB entries: 4KB 1024, 2MB 1024, 4MB 1024, 1GB 4
[ 0.224137] Spectre V2 : Mitigation: Full generic retpoline
[ 0.224138] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.224138] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.224143] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.224144] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.224160] MDS: Mitigation: Clear CPU buffers
[ 0.226782] Freeing SMP alternatives memory: 28K
[ 0.227876] TSC deadline timer enabled
[ 0.227877] smpboot: CPU0: Intel(R) Core(TM) i5-4690 CPU @ 3.50GHz (family: 0x6, model: 0x3c, stepping: 0x3)
[ 0.247844] Performance Events: PEBS fmt2+, Haswell events, 16-deep LBR, full-width counters, Intel PMU driver.
[ 0.247874] ... version: 3
[ 0.247874] ... bit width: 48
[ 0.247875] ... generic registers: 8
[ 0.247875] ... value mask: 0000ffffffffffff
[ 0.247876] ... max period: 00007fffffffffff
[ 0.247876] ... fixed-purpose events: 3
[ 0.247876] ... event mask: 00000007000000ff
[ 0.254508] rcu: Hierarchical SRCU implementation.
[ 0.277889] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.284512] smp: Bringing up secondary CPUs ...
[ 0.324514] x86: Booting SMP configuration:
[ 0.324515] .... node #0, CPUs: #1 #2 #3
[ 0.405751] smp: Brought up 1 node, 4 CPUs
[ 0.405751] smpboot: Max logical packages: 1
[ 0.405751] smpboot: Total of 4 processors activated (27947.43 BogoMIPS)
[ 0.408109] devtmpfs: initialized
[ 0.408109] x86/mm: Memory block size: 128MB
[ 0.408584] PM: Registering ACPI NVS region [mem 0xbf5f4000-0xbf5fafff] (28672 bytes)
[ 0.408584] PM: Registering ACPI NVS region [mem 0xdd70e000-0xdd7c5fff] (753664 bytes)
[ 0.408584] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.408584] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.408584] pinctrl core: initialized pinctrl subsystem
[ 0.408584] RTC time: 20:00:02, date: 06/30/19
[ 0.408584] NET: Registered protocol family 16
[ 0.408584] audit: initializing netlink subsys (disabled)
[ 0.408584] audit: type=2000 audit(1561924802.203:1): state=initialized audit_enabled=0 res=1
[ 0.408584] cpuidle: using governor ladder
[ 0.411166] cpuidle: using governor menu
[ 0.411181] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.411181] ACPI: bus type PCI registered
[ 0.411182] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.411225] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.411226] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.411233] PCI: Using configuration type 1 for base access
[ 0.411249] core: PMU erratum BJ122, BV98, HSD29 workaround disabled, HT off
[ 0.411838] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.411838] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.411838] ACPI: Added _OSI(Module Device)
[ 0.411838] ACPI: Added _OSI(Processor Device)
[ 0.411838] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.411838] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.411838] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.411838] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.420682] ACPI: 5 ACPI AML tables successfully acquired and loaded
[ 0.423479] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.424219] ACPI: Dynamic OEM Table Load:
[ 0.424223] ACPI: SSDT 0xFFFFA1048E412400 0003D3 (v01 PmRef Cpu0Cst 00003001 INTL 20120711)
[ 0.424620] ACPI: Dynamic OEM Table Load:
[ 0.424624] ACPI: SSDT 0xFFFFA1048C754800 0005AA (v01 PmRef ApIst 00003000 INTL 20120711)
[ 0.425060] ACPI: Dynamic OEM Table Load:
[ 0.425062] ACPI: SSDT 0xFFFFA1048C76E000 000119 (v01 PmRef ApCst 00003000 INTL 20120711)
[ 0.425408] ACPI: Interpreter enabled
[ 0.425408] ACPI: (supports S0 S3 S4 S5)
[ 0.425408] ACPI: Using IOAPIC for interrupt routing
[ 0.425408] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.425664] ACPI: Enabled 7 GPEs in block 00 to 3F
[ 0.433048] ACPI: Power Resource [FN00] (off)
[ 0.433103] ACPI: Power Resource [FN01] (off)
[ 0.433158] ACPI: Power Resource [FN02] (off)
[ 0.433210] ACPI: Power Resource [FN03] (off)
[ 0.433263] ACPI: Power Resource [FN04] (off)
[ 0.433881] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[ 0.433884] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.434091] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME]
[ 0.434214] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability LTR]
[ 0.434215] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.434553] PCI host bridge to bus 0000:00
[ 0.434555] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.434555] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.434556] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.434557] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[ 0.434557] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[ 0.434558] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[ 0.434559] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[ 0.434559] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[ 0.434560] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
[ 0.434560] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xfeafffff window]
[ 0.434561] pci_bus 0000:00: root bus resource [bus 00-3e]
[ 0.434566] pci 0000:00:00.0: [8086:0c00] type 00 class 0x060000
[ 0.434633] pci 0000:00:01.0: [8086:0c01] type 01 class 0x060400
[ 0.434661] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.434770] pci 0000:00:14.0: [8086:8c31] type 00 class 0x0c0330
[ 0.434787] pci 0000:00:14.0: reg 0x10: [mem 0xf7f00000-0xf7f0ffff 64bit]
[ 0.434836] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.434891] pci 0000:00:16.0: [8086:8c3a] type 00 class 0x078000
[ 0.434908] pci 0000:00:16.0: reg 0x10: [mem 0xf7f1a000-0xf7f1a00f 64bit]
[ 0.434960] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.435019] pci 0000:00:1a.0: [8086:8c2d] type 00 class 0x0c0320
[ 0.435037] pci 0000:00:1a.0: reg 0x10: [mem 0xf7f18000-0xf7f183ff]
[ 0.435107] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.435165] pci 0000:00:1b.0: [8086:8c20] type 00 class 0x040300
[ 0.435181] pci 0000:00:1b.0: reg 0x10: [mem 0xf7f10000-0xf7f13fff 64bit]
[ 0.435237] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.435292] pci 0000:00:1c.0: [8086:8c10] type 01 class 0x060400
[ 0.435350] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.435443] pci 0000:00:1c.2: [8086:8c14] type 01 class 0x060400
[ 0.435503] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.435594] pci 0000:00:1c.3: [8086:8c16] type 01 class 0x060400
[ 0.435653] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.435748] pci 0000:00:1d.0: [8086:8c26] type 00 class 0x0c0320
[ 0.435766] pci 0000:00:1d.0: reg 0x10: [mem 0xf7f17000-0xf7f173ff]
[ 0.435837] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.435896] pci 0000:00:1f.0: [8086:8c44] type 00 class 0x060100
[ 0.436040] pci 0000:00:1f.2: [8086:8c02] type 00 class 0x010601
[ 0.436052] pci 0000:00:1f.2: reg 0x10: [io 0xf070-0xf077]
[ 0.436057] pci 0000:00:1f.2: reg 0x14: [io 0xf060-0xf063]
[ 0.436063] pci 0000:00:1f.2: reg 0x18: [io 0xf050-0xf057]
[ 0.436068] pci 0000:00:1f.2: reg 0x1c: [io 0xf040-0xf043]
[ 0.436073] pci 0000:00:1f.2: reg 0x20: [io 0xf020-0xf03f]
[ 0.436078] pci 0000:00:1f.2: reg 0x24: [mem 0xf7f16000-0xf7f167ff]
[ 0.436106] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.436157] pci 0000:00:1f.3: [8086:8c22] type 00 class 0x0c0500
[ 0.436171] pci 0000:00:1f.3: reg 0x10: [mem 0xf7f15000-0xf7f150ff 64bit]
[ 0.436187] pci 0000:00:1f.3: reg 0x20: [io 0xf000-0xf01f]
[ 0.436273] pci 0000:01:00.0: [1002:67b1] type 00 class 0x030000
[ 0.436287] pci 0000:01:00.0: reg 0x10: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.436293] pci 0000:01:00.0: reg 0x18: [mem 0xf0000000-0xf07fffff 64bit pref]
[ 0.436297] pci 0000:01:00.0: reg 0x20: [io 0xe000-0xe0ff]
[ 0.436302] pci 0000:01:00.0: reg 0x24: [mem 0xf7e00000-0xf7e3ffff]
[ 0.436306] pci 0000:01:00.0: reg 0x30: [mem 0xf7e40000-0xf7e5ffff pref]
[ 0.436340] pci 0000:01:00.0: supports D1 D2
[ 0.436340] pci 0000:01:00.0: PME# supported from D1 D2 D3hot
[ 0.436384] pci 0000:01:00.1: [1002:aac8] type 00 class 0x040300
[ 0.436396] pci 0000:01:00.1: reg 0x10: [mem 0xf7e60000-0xf7e63fff 64bit]
[ 0.436441] pci 0000:01:00.1: supports D1 D2
[ 0.436483] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.436485] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.436486] pci 0000:00:01.0: bridge window [mem 0xf7e00000-0xf7efffff]
[ 0.436488] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xf07fffff 64bit pref]
[ 0.436531] acpiphp: Slot [1] registered
[ 0.436534] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.436592] pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
[ 0.436618] pci 0000:03:00.0: reg 0x10: [io 0xd000-0xd0ff]
[ 0.436643] pci 0000:03:00.0: reg 0x18: [mem 0xf7d00000-0xf7d00fff 64bit]
[ 0.436658] pci 0000:03:00.0: reg 0x20: [mem 0xf0900000-0xf0903fff 64bit pref]
[ 0.436744] pci 0000:03:00.0: supports D1 D2
[ 0.436745] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.436837] pci 0000:00:1c.2: PCI bridge to [bus 03]
[ 0.436839] pci 0000:00:1c.2: bridge window [io 0xd000-0xdfff]
[ 0.436841] pci 0000:00:1c.2: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.436845] pci 0000:00:1c.2: bridge window [mem 0xf0900000-0xf09fffff 64bit pref]
[ 0.436897] pci 0000:04:00.0: [8086:244e] type 01 class 0x060401
[ 0.437018] pci 0000:04:00.0: supports D1 D2
[ 0.437018] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.437059] pci 0000:00:1c.3: PCI bridge to [bus 04-05]
[ 0.437102] pci_bus 0000:05: extended config space not accessible
[ 0.437175] pci 0000:04:00.0: PCI bridge to [bus 05] (subtractive decode)
[ 0.437904] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.437946] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.437989] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.438029] ACPI: PCI Interrupt Link [LNKD] (IRQs *3 4 5 6 10 11 12 14 15)
[ 0.438070] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.438111] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.438152] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.438193] ACPI: PCI Interrupt Link [LNKH] (IRQs *3 4 5 6 10 11 12 14 15)
[ 0.438481] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[ 0.438481] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.438481] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.438481] vgaarb: loaded
[ 0.438481] ACPI: bus type USB registered
[ 0.438481] usbcore: registered new interface driver usbfs
[ 0.438481] usbcore: registered new interface driver hub
[ 0.438481] usbcore: registered new device driver usb
[ 0.438481] pps_core: LinuxPPS API ver. 1 registered
[ 0.438481] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.438481] PTP clock support registered
[ 0.438481] EDAC MC: Ver: 3.0.0
[ 0.438481] PCI: Using ACPI for IRQ routing
[ 0.439000] PCI: pci_cache_line_size set to 64 bytes
[ 0.439041] e820: reserve RAM buffer [mem 0x0009d800-0x0009ffff]
[ 0.439041] e820: reserve RAM buffer [mem 0xbf5f4000-0xbfffffff]
[ 0.439042] e820: reserve RAM buffer [mem 0xc00d5000-0xc3ffffff]
[ 0.439042] e820: reserve RAM buffer [mem 0xdd62e000-0xdfffffff]
[ 0.439043] e820: reserve RAM buffer [mem 0xdd70e000-0xdfffffff]
[ 0.439044] e820: reserve RAM buffer [mem 0xdf800000-0xdfffffff]
[ 0.439044] e820: reserve RAM buffer [mem 0x41f000000-0x41fffffff]
[ 0.439106] NetLabel: Initializing
[ 0.439106] NetLabel: domain hash size = 128
[ 0.439106] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.439115] NetLabel: unlabeled traffic allowed by default
[ 0.439117] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.439117] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.442176] clocksource: Switched to clocksource tsc-early
[ 0.448066] VFS: Disk quotas dquot_6.6.0
[ 0.448077] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.448120] pnp: PnP ACPI init
[ 0.448193] system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
[ 0.448196] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.448345] system 00:01: [io 0x0680-0x069f] has been reserved
[ 0.448346] system 00:01: [io 0xffff] has been reserved
[ 0.448347] system 00:01: [io 0xffff] has been reserved
[ 0.448348] system 00:01: [io 0xffff] has been reserved
[ 0.448348] system 00:01: [io 0x1c00-0x1cfe] has been reserved
[ 0.448349] system 00:01: [io 0x1d00-0x1dfe] has been reserved
[ 0.448350] system 00:01: [io 0x1e00-0x1efe] has been reserved
[ 0.448351] system 00:01: [io 0x1f00-0x1ffe] has been reserved
[ 0.448351] system 00:01: [io 0x1800-0x18fe] has been reserved
[ 0.448352] system 00:01: [io 0x164e-0x164f] has been reserved
[ 0.448354] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.448369] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.448402] system 00:03: [io 0x1854-0x1857] has been reserved
[ 0.448404] system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.448506] system 00:04: [io 0x0a00-0x0a0f] has been reserved
[ 0.448507] system 00:04: [io 0x0a30-0x0a3f] has been reserved
[ 0.448508] system 00:04: [io 0x0a20-0x0a2f] has been reserved
[ 0.448510] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.448720] pnp 00:05: [dma 0 disabled]
[ 0.448746] pnp 00:05: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.448987] pnp 00:06: [dma 0 disabled]
[ 0.449071] pnp 00:06: Plug and Play ACPI device, IDs PNP0400 (active)
[ 0.449105] system 00:07: [io 0x04d0-0x04d1] has been reserved
[ 0.449107] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.449438] system 00:08: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.449439] system 00:08: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.449441] system 00:08: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.449442] system 00:08: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.449442] system 00:08: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.449443] system 00:08: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.449444] system 00:08: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 0.449445] system 00:08: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.449445] system 00:08: [mem 0xff000000-0xffffffff] has been reserved
[ 0.449446] system 00:08: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.449447] system 00:08: [mem 0xf7fdf000-0xf7fdffff] has been reserved
[ 0.449448] system 00:08: [mem 0xf7fe0000-0xf7feffff] has been reserved
[ 0.449450] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.449635] pnp: PnP ACPI: found 9 devices
[ 0.454928] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.454962] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.454963] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.454965] pci 0000:00:01.0: bridge window [mem 0xf7e00000-0xf7efffff]
[ 0.454966] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xf07fffff 64bit pref]
[ 0.454968] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.454976] pci 0000:00:1c.2: PCI bridge to [bus 03]
[ 0.454977] pci 0000:00:1c.2: bridge window [io 0xd000-0xdfff]
[ 0.454980] pci 0000:00:1c.2: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.454982] pci 0000:00:1c.2: bridge window [mem 0xf0900000-0xf09fffff 64bit pref]
[ 0.454986] pci 0000:04:00.0: PCI bridge to [bus 05]
[ 0.455004] pci 0000:00:1c.3: PCI bridge to [bus 04-05]
[ 0.455012] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.455013] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.455013] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.455014] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff window]
[ 0.455015] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff window]
[ 0.455015] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff window]
[ 0.455016] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff window]
[ 0.455017] pci_bus 0000:00: resource 11 [mem 0x000e0000-0x000e3fff window]
[ 0.455017] pci_bus 0000:00: resource 12 [mem 0x000e4000-0x000e7fff window]
[ 0.455018] pci_bus 0000:00: resource 13 [mem 0xe0000000-0xfeafffff window]
[ 0.455019] pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
[ 0.455019] pci_bus 0000:01: resource 1 [mem 0xf7e00000-0xf7efffff]
[ 0.455020] pci_bus 0000:01: resource 2 [mem 0xe0000000-0xf07fffff 64bit pref]
[ 0.455021] pci_bus 0000:03: resource 0 [io 0xd000-0xdfff]
[ 0.455021] pci_bus 0000:03: resource 1 [mem 0xf7d00000-0xf7dfffff]
[ 0.455022] pci_bus 0000:03: resource 2 [mem 0xf0900000-0xf09fffff 64bit pref]
[ 0.455107] NET: Registered protocol family 2
[ 0.461208] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes)
[ 0.461244] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.461360] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.461454] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.461478] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[ 0.461507] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[ 0.461557] NET: Registered protocol family 1
[ 0.461560] NET: Registered protocol family 44
[ 0.461896] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.461901] pci 0000:01:00.1: Linked as a consumer to 0000:01:00.0
[ 0.461908] PCI: CLS 64 bytes, default 64
[ 0.461928] Unpacking initramfs...
[ 0.541256] Freeing initrd memory: 10928K
[ 0.541281] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.541282] software IO TLB: mapped [mem 0xd962e000-0xdd62e000] (64MB)
[ 0.541359] Scanning for low memory corruption every 60 seconds
[ 0.541699] Initialise system trusted keyrings
[ 0.541705] Key type blacklist registered
[ 0.541737] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[ 0.542459] zbud: loaded
[ 0.543302] Key type asymmetric registered
[ 0.543303] Asymmetric key parser 'x509' registered
[ 0.543307] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.543324] io scheduler noop registered
[ 0.543325] io scheduler deadline registered
[ 0.543340] io scheduler cfq registered
[ 0.543340] io scheduler mq-deadline registered
[ 0.543341] io scheduler kyber registered
[ 0.543354] io scheduler bfq registered
[ 0.543366] io scheduler bfq-sq registered (default)
[ 0.543367] BFQ I/O-scheduler: v10 (with cgroups support)
[ 0.543380] io scheduler bfq-mq registered
[ 0.543380] BFQ I/O-scheduler: v10 (with cgroups support)
[ 0.543800] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.543839] vesafb: mode is 1920x1080x32, linelength=7680, pages=0
[ 0.543839] vesafb: scrolling: redraw
[ 0.543840] vesafb: Truecolor: size=0:8:8:8, shift=0:16:8:0
[ 0.543850] vesafb: framebuffer at 0xe0000000, mapped to 0x0000000000242c7c, using 8128k, total 8128k
[ 0.543873] fbcon: Deferring console take-over
[ 0.543874] fb0: VESA VGA frame buffer device
[ 0.543882] intel_idle: MWAIT substates: 0x42120
[ 0.543883] intel_idle: v0.4.1 model 0x3C
[ 0.543976] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 0.544023] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.544030] ACPI: Power Button [PWRB]
[ 0.544055] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.544058] ACPI: Power Button [PWRF]
[ 0.544679] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.544679] ACPI: Thermal Zone [TZ00] (28 C)
[ 0.544853] thermal LNXTHERM:01: registered as thermal_zone1
[ 0.544854] ACPI: Thermal Zone [TZ01] (30 C)
[ 0.544973] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.565544] 00:05: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 0.566404] usbcore: registered new interface driver usbserial_generic
[ 0.566407] usbserial: USB Serial support registered for generic
[ 0.566420] rtc_cmos 00:02: RTC can wake from S4
[ 0.566555] rtc_cmos 00:02: registered as rtc0
[ 0.566572] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 0.566601] intel_pstate: Intel P-state driver initializing
[ 0.566834] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.567380] NET: Registered protocol family 10
[ 0.580228] Segment Routing with IPv6
[ 0.580264] NET: Registered protocol family 17
[ 0.580679] mce: Using 9 MCE banks
[ 0.580698] RAS: Correctable Errors collector initialized.
[ 0.580751] microcode: sig=0x306c3, pf=0x2, revision=0x27
[ 0.580833] microcode: Microcode Update Driver: v2.2.
[ 0.580853] sched_clock: Marking stable (580646792, 179938)->(593069551, -12242821)
[ 0.581142] registered taskstats version 1
[ 0.581151] Loading compiled-in X.509 certificates
[ 0.584893] Loaded X.509 cert 'Build time autogenerated kernel key: 265db79036b7d2ee20508ed408e69a69e9146eca'
[ 0.584915] zswap: loaded using pool lzo/zbud
[ 0.589767] Key type big_key registered
[ 0.590304] Magic number: 7:339:44
[ 0.590386] rtc_cmos 00:02: setting system clock to 2019-06-30 20:00:02 UTC (1561924802)
[ 0.769540] Freeing unused decrypted memory: 2040K
[ 0.900438] Freeing unused kernel image memory: 1540K
[ 0.900469] Write protecting the kernel read-only data: 18432k
[ 0.901189] Freeing unused kernel image memory: 2008K
[ 0.901313] Freeing unused kernel image memory: 496K
[ 0.906769] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.906770] x86/mm: Checking user space page tables
[ 0.911988] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.911989] Run /init as init process
[ 0.968960] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.969665] ehci-pci: EHCI PCI platform driver
[ 0.969783] ehci-pci 0000:00:1a.0: EHCI Host Controller
[ 0.969787] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 0.969796] ehci-pci 0000:00:1a.0: debug port 2
[ 0.972499] SCSI subsystem initialized
[ 0.973704] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[ 0.973717] ehci-pci 0000:00:1a.0: irq 16, io mem 0xf7f18000
[ 0.977196] libata version 3.00 loaded.
[ 0.979378] ahci 0000:00:1f.2: version 3.0
[ 0.979506] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x1d impl SATA mode
[ 0.979508] ahci 0000:00:1f.2: flags: 64bit ncq led clo pio slum part ems apst
[ 0.984516] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 0.984559] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.984560] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.984561] usb usb1: Product: EHCI Host Controller
[ 0.984562] usb usb1: Manufacturer: Linux 4.19.49-1-MANJARO ehci_hcd
[ 0.984562] usb usb1: SerialNumber: 0000:00:1a.0
[ 0.984645] hub 1-0:1.0: USB hub found
[ 0.984648] hub 1-0:1.0: 2 ports detected
[ 0.984762] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.984766] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 0.985817] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000000009810
[ 0.985820] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 0.985927] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.985928] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.985928] usb usb2: Product: xHCI Host Controller
[ 0.985929] usb usb2: Manufacturer: Linux 4.19.49-1-MANJARO xhci-hcd
[ 0.985930] usb usb2: SerialNumber: 0000:00:14.0
[ 0.986058] hub 2-0:1.0: USB hub found
[ 0.986073] hub 2-0:1.0: 14 ports detected
[ 0.988053] ehci-pci 0000:00:1d.0: EHCI Host Controller
[ 0.988056] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 3
[ 0.988067] ehci-pci 0000:00:1d.0: debug port 2
[ 0.988068] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.988069] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[ 0.988071] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[ 0.988098] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 0.988098] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.988099] usb usb4: Product: xHCI Host Controller
[ 0.988100] usb usb4: Manufacturer: Linux 4.19.49-1-MANJARO xhci-hcd
[ 0.988100] usb usb4: SerialNumber: 0000:00:14.0
[ 0.988225] hub 4-0:1.0: USB hub found
[ 0.988237] hub 4-0:1.0: 6 ports detected
[ 0.991953] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[ 0.991961] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7f17000
[ 1.004555] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 1.004597] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.004598] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.004599] usb usb3: Product: EHCI Host Controller
[ 1.004600] usb usb3: Manufacturer: Linux 4.19.49-1-MANJARO ehci_hcd
[ 1.004601] usb usb3: SerialNumber: 0000:00:1d.0
[ 1.004770] hub 3-0:1.0: USB hub found
[ 1.004775] hub 3-0:1.0: 2 ports detected
[ 1.008525] scsi host0: ahci
[ 1.008707] scsi host1: ahci
[ 1.008853] scsi host2: ahci
[ 1.008961] scsi host3: ahci
[ 1.009087] scsi host4: ahci
[ 1.009203] scsi host5: ahci
[ 1.009274] ata1: SATA max UDMA/133 abar m2048@0xf7f16000 port 0xf7f16100 irq 25
[ 1.009275] ata2: DUMMY
[ 1.009277] ata3: SATA max UDMA/133 abar m2048@0xf7f16000 port 0xf7f16200 irq 25
[ 1.009278] ata4: SATA max UDMA/133 abar m2048@0xf7f16000 port 0xf7f16280 irq 25
[ 1.009280] ata5: SATA max UDMA/133 abar m2048@0xf7f16000 port 0xf7f16300 irq 25
[ 1.009280] ata6: DUMMY
[ 1.314561] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 1.317895] usb 2-7: new full-speed USB device number 2 using xhci_hcd
[ 1.326163] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.326191] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.326219] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.326261] ata5: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.329409] ata4.00: supports DRM functions and may not be fully accessible
[ 1.329684] ata1.00: supports DRM functions and may not be fully accessible
[ 1.329704] ata5.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.329710] ata5.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.329714] ata5.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.329746] ata3.00: supports DRM functions and may not be fully accessible
[ 1.330390] ata3.00: ATA-11: Samsung SSD 860 EVO 500GB, RVT02B6Q, max UDMA/133
[ 1.330396] ata3.00: 976773168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 1.330595] ata4.00: ATA-11: Samsung SSD 860 EVO 250GB, RVT01B6Q, max UDMA/133
[ 1.330600] ata4.00: 488397168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 1.331421] ata5.00: ATAPI: Optiarc DVD RW AD-7280S, 1.01, max UDMA/100
[ 1.332835] ata3.00: supports DRM functions and may not be fully accessible
[ 1.333376] ata4.00: supports DRM functions and may not be fully accessible
[ 1.334529] usb 3-1: new high-speed USB device number 2 using ehci-pci
[ 1.334598] ata1.00: disabling queued TRIM support
[ 1.334602] ata1.00: ATA-9: Samsung SSD 850 PRO 128GB, EXM03B6Q, max UDMA/133
[ 1.334605] ata1.00: 250069680 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 1.334634] ata5.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.334640] ata5.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.334644] ata5.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.335990] ata3.00: configured for UDMA/133
[ 1.336245] ata5.00: configured for UDMA/100
[ 1.336771] ata4.00: configured for UDMA/133
[ 1.340153] ata1.00: supports DRM functions and may not be fully accessible
[ 1.345069] ata1.00: disabling queued TRIM support
[ 1.350154] ata1.00: configured for UDMA/133
[ 1.350336] scsi 0:0:0:0: Direct-Access ATA Samsung SSD 850 3B6Q PQ: 0 ANSI: 5
[ 1.350796] scsi 2:0:0:0: Direct-Access ATA Samsung SSD 860 2B6Q PQ: 0 ANSI: 5
[ 1.351245] scsi 3:0:0:0: Direct-Access ATA Samsung SSD 860 1B6Q PQ: 0 ANSI: 5
[ 1.352129] scsi 4:0:0:0: CD-ROM Optiarc DVD RW AD-7280S 1.01 PQ: 0 ANSI: 5
[ 1.428666] sd 0:0:0:0: [sda] 250069680 512-byte logical blocks: (128 GB/119 GiB)
[ 1.428678] sd 0:0:0:0: [sda] Write Protect is off
[ 1.428682] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.428698] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.428944] ata3.00: Enabling discard_zeroes_data
[ 1.428947] ata4.00: Enabling discard_zeroes_data
[ 1.428961] sd 2:0:0:0: [sdb] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[ 1.428962] sd 3:0:0:0: [sdc] 488397168 512-byte logical blocks: (250 GB/233 GiB)
[ 1.428964] sd 3:0:0:0: [sdc] Write Protect is off
[ 1.428965] sd 3:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[ 1.428966] sd 2:0:0:0: [sdb] Write Protect is off
[ 1.428966] sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 1.428970] sd 3:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.428971] sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.429026] ata4.00: Enabling discard_zeroes_data
[ 1.429033] ata3.00: Enabling discard_zeroes_data
[ 1.429236] sdc: sdc1 sdc2 sdc3
[ 1.429345] sdb: sdb1 sdb2 sdb3
[ 1.429440] ata4.00: Enabling discard_zeroes_data
[ 1.429585] ata3.00: Enabling discard_zeroes_data
[ 1.430454] sd 2:0:0:0: [sdb] supports TCG Opal
[ 1.430455] sd 2:0:0:0: [sdb] Attached SCSI disk
[ 1.430474] sd 3:0:0:0: [sdc] supports TCG Opal
[ 1.430475] sd 3:0:0:0: [sdc] Attached SCSI disk
[ 1.430712] sda: sda1 sda2 sda3
[ 1.431050] sd 0:0:0:0: [sda] supports TCG Opal
[ 1.431051] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.439298] random: fast init done
[ 1.459768] usb 2-7: New USB device found, idVendor=09da, idProduct=33c1, bcdDevice=99.00
[ 1.459769] usb 2-7: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.459779] usb 2-7: Product: USB Device
[ 1.459780] usb 2-7: Manufacturer: COMPANY
[ 1.461970] sr 4:0:0:0: [sr0] scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.461973] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.462133] sr 4:0:0:0: Attached scsi CD-ROM sr0
[ 1.464741] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.464865] usb 1-1: New USB device found, idVendor=8087, idProduct=8008, bcdDevice= 0.04
[ 1.464866] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.465011] hub 1-1:1.0: USB hub found
[ 1.465109] hub 1-1:1.0: 6 ports detected
[ 1.469933] usbcore: registered new interface driver usbhid
[ 1.469934] usbhid: USB HID core driver
[ 1.471576] input: COMPANY USB Device as /devices/pci0000:00/0000:00:14.0/usb2/2-7/2-7:1.0/0003:09DA:33C1.0001/input/input2
[ 1.481653] usb 3-1: New USB device found, idVendor=8087, idProduct=8000, bcdDevice= 0.04
[ 1.481655] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.481911] hub 3-1:1.0: USB hub found
[ 1.481984] hub 3-1:1.0: 8 ports detected
[ 1.527995] hid-generic 0003:09DA:33C1.0001: input,hidraw0: USB HID v1.11 Keyboard [COMPANY USB Device] on usb-0000:00:14.0-7/input0
[ 1.528154] input: COMPANY USB Device as /devices/pci0000:00/0000:00:14.0/usb2/2-7/2-7:1.1/0003:09DA:33C1.0002/input/input3
[ 1.528259] hid-generic 0003:09DA:33C1.0002: input,hidraw1: USB HID v1.11 Mouse [COMPANY USB Device] on usb-0000:00:14.0-7/input1
[ 1.528568] input: COMPANY USB Device Keyboard as /devices/pci0000:00/0000:00:14.0/usb2/2-7/2-7:1.2/0003:09DA:33C1.0003/input/input4
[ 1.564570] tsc: Refined TSC clocksource calibration: 3491.912 MHz
[ 1.564575] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x3255787006b, max_idle_ns: 440795244845 ns
[ 1.564594] clocksource: Switched to clocksource tsc
[ 1.584543] usb 2-8: new full-speed USB device number 3 using xhci_hcd
[ 1.584630] input: COMPANY USB Device System Control as /devices/pci0000:00/0000:00:14.0/usb2/2-7/2-7:1.2/0003:09DA:33C1.0003/input/input5
[ 1.584681] input: COMPANY USB Device Consumer Control as /devices/pci0000:00/0000:00:14.0/usb2/2-7/2-7:1.2/0003:09DA:33C1.0003/input/input6
[ 1.584710] input: COMPANY USB Device as /devices/pci0000:00/0000:00:14.0/usb2/2-7/2-7:1.2/0003:09DA:33C1.0003/input/input7
[ 1.584946] hid-generic 0003:09DA:33C1.0003: input,hiddev0,hidraw2: USB HID v1.11 Keyboard [COMPANY USB Device] on usb-0000:00:14.0-7/input2
[ 1.726749] usb 2-8: New USB device found, idVendor=09da, idProduct=f6bc, bcdDevice=bc.29
[ 1.726751] usb 2-8: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.726753] usb 2-8: Product: USB Device
[ 1.726755] usb 2-8: Manufacturer: COMPANY
[ 1.729390] input: COMPANY USB Device as /devices/pci0000:00/0000:00:14.0/usb2/2-8/2-8:1.0/0003:09DA:F6BC.0004/input/input8
[ 1.784800] hid-generic 0003:09DA:F6BC.0004: input,hidraw3: USB HID v1.11 Keyboard [COMPANY USB Device] on usb-0000:00:14.0-8/input0
[ 1.786055] input: COMPANY USB Device as /devices/pci0000:00/0000:00:14.0/usb2/2-8/2-8:1.1/0003:09DA:F6BC.0005/input/input9
[ 1.786195] hid-generic 0003:09DA:F6BC.0005: input,hidraw4: USB HID v1.11 Mouse [COMPANY USB Device] on usb-0000:00:14.0-8/input1
[ 1.788541] input: COMPANY USB Device Keyboard as /devices/pci0000:00/0000:00:14.0/usb2/2-8/2-8:1.2/0003:09DA:F6BC.0006/input/input10
[ 1.844594] input: COMPANY USB Device System Control as /devices/pci0000:00/0000:00:14.0/usb2/2-8/2-8:1.2/0003:09DA:F6BC.0006/input/input11
[ 1.844639] input: COMPANY USB Device Consumer Control as /devices/pci0000:00/0000:00:14.0/usb2/2-8/2-8:1.2/0003:09DA:F6BC.0006/input/input12
[ 1.844665] input: COMPANY USB Device as /devices/pci0000:00/0000:00:14.0/usb2/2-8/2-8:1.2/0003:09DA:F6BC.0006/input/input13
[ 1.844839] hid-generic 0003:09DA:F6BC.0006: input,hiddev1,hidraw5: USB HID v1.11 Keyboard [COMPANY USB Device] on usb-0000:00:14.0-8/input2
[ 1.889660] EXT4-fs (sdc2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.956654] systemd[1]: RTC configured in localtime, applying delta of 180 minutes to system time.
[ 1.967868] usb 2-12: new full-speed USB device number 4 using xhci_hcd
[ 1.976682] systemd[1]: systemd 242.29-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 1.991281] systemd[1]: Detected architecture x86-64.
[ 1.994123] systemd[1]: Set hostname to <arbeit>.
[ 2.113693] systemd[1]: Listening on Journal Audit Socket.
[ 2.113746] systemd[1]: Reached target Remote File Systems.
[ 2.113817] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.114915] systemd[1]: Created slice system-getty.slice.
[ 2.114985] systemd[1]: Listening on LVM2 poll daemon socket.
[ 2.115032] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 2.115086] systemd[1]: Listening on udev Kernel Socket.
[ 2.123444] usb 2-12: New USB device found, idVendor=0a12, idProduct=0001, bcdDevice=88.91
[ 2.123446] usb 2-12: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.123447] usb 2-12: Product: CSR8510 A10
[ 2.126271] EXT4-fs (sdc2): re-mounted. Opts: discard
[ 2.137734] random: systemd-random-: uninitialized urandom read (512 bytes read)
[ 2.140639] random: lvm: uninitialized urandom read (4 bytes read)
[ 2.305510] audit: type=1130 audit(1561914004.212:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.310988] systemd-journald[251]: Received request to flush runtime journal from PID 1
[ 2.359550] audit: type=1130 audit(1561914004.266:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.370538] audit: type=1130 audit(1561914004.276:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.437470] parport_pc 00:06: reported by Plug and Play ACPI
[ 2.437547] parport0: PC-style at 0x378, irq 5 [PCSPP,TRISTATE]
[ 2.441991] ACPI Warning: SystemIO range 0x0000000000001828-0x000000000000182F conflicts with OpRegion 0x0000000000001800-0x000000000000187F (\PMIO) (20180810/utaddress-213)
[ 2.441995] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 2.441997] ACPI Warning: SystemIO range 0x0000000000001C40-0x0000000000001C4F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20180810/utaddress-213)
[ 2.441999] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 2.441999] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20180810/utaddress-213)
[ 2.442001] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20180810/utaddress-213)
[ 2.442002] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 2.442003] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20180810/utaddress-213)
[ 2.442004] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20180810/utaddress-213)
[ 2.442006] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 2.442006] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 2.447423] r8168: loading out-of-tree module taints kernel.
[ 2.462490] r8168: module verification failed: signature and/or required key missing - tainting kernel
[ 2.463566] r8168 Gigabit Ethernet driver 8.047.01-NAPI loaded
[ 2.463574] r8168 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 2.470787] Linux agpgart interface v0.103
[ 2.471035] i801_smbus 0000:00:1f.3: enabling device (0001 -> 0003)
[ 2.471124] i801_smbus 0000:00:1f.3: SPD Write Disable is set
[ 2.471142] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[ 2.474446] Bluetooth: Core ver 2.22
[ 2.474455] NET: Registered protocol family 31
[ 2.474456] Bluetooth: HCI device and connection manager initialized
[ 2.474458] Bluetooth: HCI socket layer initialized
[ 2.474459] Bluetooth: L2CAP socket layer initialized
[ 2.474462] Bluetooth: SCO socket layer initialized
[ 2.474601] input: PC Speaker as /devices/platform/pcspkr/input/input14
[ 2.494558] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[ 2.494559] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 2.494560] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 2.494560] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 2.494560] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 2.500006] usbcore: registered new interface driver btusb
[ 2.501666] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 2.501671] r8168 Copyright (C) 2019 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 2.518087] cryptd: max_cpu_qlen set to 1000
[ 2.535668] AVX2 version of gcm_enc/dec engaged.
[ 2.535669] AES CTR mode by8 optimization enabled
[ 2.572246] iTCO_vendor_support: vendor-support=0
[ 2.572287] ppdev: user-space parallel port driver
[ 2.573742] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 2.573854] iTCO_wdt: unable to reset NO_REBOOT flag, device disabled by hardware/BIOS
[ 2.574277] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 2.574279] snd_hda_intel 0000:01:00.1: Force to non-snoop mode
[ 2.585443] intel-spi intel-spi: mx25l6405d (8192 Kbytes)
[ 2.594936] r8168 0000:03:00.0 enp3s0: renamed from eth0
[ 2.595118] audit: type=1130 audit(1561914004.502:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.599933] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input15
[ 2.599962] input: HDA ATI HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input16
[ 2.599987] input: HDA ATI HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input17
[ 2.600012] input: HDA ATI HDMI HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input18
[ 2.600036] input: HDA ATI HDMI HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input19
[ 2.600062] input: HDA ATI HDMI HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input20
[ 2.606608] snd_hda_codec_realtek hdaudioC0D2: autoconfig for ALC892: line_outs=4 (0x14/0x15/0x16/0x17/0x0) type:line
[ 2.606609] snd_hda_codec_realtek hdaudioC0D2: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 2.606610] snd_hda_codec_realtek hdaudioC0D2: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 2.606611] snd_hda_codec_realtek hdaudioC0D2: mono: mono_out=0x0
[ 2.606611] snd_hda_codec_realtek hdaudioC0D2: dig-out=0x11/0x0
[ 2.606612] snd_hda_codec_realtek hdaudioC0D2: inputs:
[ 2.606613] snd_hda_codec_realtek hdaudioC0D2: Front Mic=0x19
[ 2.606614] snd_hda_codec_realtek hdaudioC0D2: Rear Mic=0x18
[ 2.606614] snd_hda_codec_realtek hdaudioC0D2: Line=0x1a
[ 2.612109] Creating 1 MTD partitions on "intel-spi":
[ 2.612111] 0x000000000000-0x000000800000 : "BIOS"
[ 2.627930] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card0/input21
[ 2.628109] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input22
[ 2.628146] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input23
[ 2.628192] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input24
[ 2.628237] input: HDA Intel PCH Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input25
[ 2.628288] input: HDA Intel PCH Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input26
[ 2.628333] input: HDA Intel PCH Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input27
[ 2.628378] input: HDA Intel PCH Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input28
[ 2.628422] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input29
[ 2.651989] mousedev: PS/2 mouse device common for all mice
[ 2.694855] audit: type=1130 audit(1561914004.602:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.719964] audit: type=1130 audit(1561914004.626:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-8fabc7b5\x2d48ba\x2d4e3a\x2dbe79\x2d541815be1fce comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.720287] audit: type=1130 audit(1561914004.626:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-bd45167d\x2d3e3b\x2d4a02\x2d8d74\x2dba6e0fa66e39 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.722191] EXT4-fs (sdc1): mounting ext2 file system using the ext4 subsystem
[ 2.729789] EXT4-fs (sdc1): mounted filesystem without journal. Opts: (null)
[ 2.733035] EXT4-fs (sdc3): mounted filesystem with ordered data mode. Opts: discard
[ 2.748205] audit: type=1130 audit(1561914004.656:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.754279] audit: type=1127 audit(1561914004.659:10): pid=424 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[ 2.801513] intel_rapl: Found RAPL domain package
[ 2.801514] intel_rapl: Found RAPL domain core
[ 2.801515] intel_rapl: Found RAPL domain dram
[ 2.853076] [drm] radeon kernel modesetting enabled.
[ 2.853110] checking generic (e0000000 7f0000) vs hw (e0000000 10000000)
[ 2.853110] fb: switching to radeondrmfb from VESA VGA
[ 2.853346] radeon 0000:01:00.0: CIK support disabled by module param
[ 2.984548] [drm] amdgpu kernel modesetting enabled.
[ 2.988017] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 2.988018] AMD IOMMUv2 functionality not available on this system
[ 2.998381] CRAT table not found
[ 2.998383] Virtual CRAT table created for CPU
[ 2.998384] Parsing CRAT table with 1 nodes
[ 2.998384] Creating topology SYSFS entries
[ 2.998394] Topology: Add CPU node
[ 2.998395] Finished initializing topology
[ 2.998432] kfd kfd: Initialized module
[ 2.998790] [drm] initializing kernel modesetting (HAWAII 0x1002:0x67B1 0x1458:0x2290 0x00).
[ 2.998798] [drm] register mmio base: 0xF7E00000
[ 2.998799] [drm] register mmio size: 262144
[ 2.998808] [drm] add ip block number 0 <cik_common>
[ 2.998808] [drm] add ip block number 1 <gmc_v7_0>
[ 2.998809] [drm] add ip block number 2 <cik_ih>
[ 2.998810] [drm] add ip block number 3 <powerplay>
[ 2.998810] [drm] add ip block number 4 <dm>
[ 2.998811] [drm] add ip block number 5 <gfx_v7_0>
[ 2.998811] [drm] add ip block number 6 <cik_sdma>
[ 2.998812] [drm] add ip block number 7 <uvd_v4_2>
[ 2.998812] [drm] add ip block number 8 <vce_v2_0>
[ 2.998893] resource sanity check: requesting [mem 0x000c0000-0x000dffff], which spans more than PCI Bus 0000:00 [mem 0x000d0000-0x000d3fff window]
[ 2.998897] caller pci_map_rom+0x6a/0x1b0 mapping multiple BARs
[ 2.998908] amdgpu 0000:01:00.0: No more image in the PCI ROM
[ 2.998938] ATOM BIOS: xxx-xxx-xxx
[ 2.998959] [drm] vm size is 64 GB, 2 levels, block size is 10-bit, fragment size is 9-bit
[ 2.999399] amdgpu 0000:01:00.0: VRAM: 4096M 0x000000F400000000 - 0x000000F4FFFFFFFF (4096M used)
[ 2.999400] amdgpu 0000:01:00.0: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
[ 2.999405] [drm] Detected VRAM RAM=4096M, BAR=256M
[ 2.999405] [drm] RAM width 512bits GDDR5
[ 2.999494] [TTM] Zone kernel: Available graphics memory: 8180374 kiB
[ 2.999495] [TTM] Zone dma32: Available graphics memory: 2097152 kiB
[ 2.999496] [TTM] Initializing pool allocator
[ 2.999498] [TTM] Initializing DMA pool allocator
[ 2.999519] [drm] amdgpu: 4096M of VRAM memory ready
[ 2.999519] [drm] amdgpu: 4096M of GTT memory ready.
[ 2.999527] [drm] GART: num cpu pages 262144, num gpu pages 262144
[ 2.999993] [drm] PCIE GART of 1024M enabled (table at 0x000000F4007E9000).
[ 3.003797] [drm] Found UVD firmware Version: 1.64 Family ID: 9
[ 3.004526] [drm] Found VCE firmware Version: 50.10 Binary ID: 2
[ 3.005044] [drm] PCIE gen 3 link speeds already enabled
[ 3.013010] random: avahi-daemon: uninitialized urandom read (4 bytes read)
[ 3.021180] amdgpu: [powerplay] Failed to retrieve minimum clocks.
[ 3.021181] amdgpu: [powerplay] Error in phm_get_clock_info
[ 3.021224] [drm] dce110_link_encoder_construct: Failed to get encoder_cap_info from VBIOS with error code 4!
[ 3.021232] [drm] dce110_link_encoder_construct: Failed to get encoder_cap_info from VBIOS with error code 4!
[ 3.021239] [drm] dce110_link_encoder_construct: Failed to get encoder_cap_info from VBIOS with error code 4!
[ 3.034537] [drm] Display Core initialized with v3.1.59!
[ 3.066497] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.066498] Bluetooth: BNEP filters: protocol multicast
[ 3.066500] Bluetooth: BNEP socket layer initialized
[ 3.067576] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.067577] [drm] Driver supports precise vblank timestamp query.
[ 3.108842] [drm] UVD initialized successfully.
[ 3.229892] [drm] VCE initialized successfully.
[ 3.232164] kfd kfd: Allocated 3969056 bytes on gart
[ 3.232176] Virtual CRAT table created for GPU
[ 3.232176] Parsing CRAT table with 1 nodes
[ 3.232183] Creating topology SYSFS entries
[ 3.232254] Topology: Add dGPU node [0x67b1:0x1002]
[ 3.232285] kfd kfd: added device 1002:67b1
[ 3.233717] [drm] fb mappable at 0xE0BD0000
[ 3.233717] [drm] vram apper at 0xE0000000
[ 3.233717] [drm] size 8294400
[ 3.233718] [drm] fb depth is 24
[ 3.233718] [drm] pitch is 7680
[ 3.233816] fbcon: amdgpudrmfb (fb0) is primary device
[ 3.233816] fbcon: Deferring console take-over
[ 3.233818] amdgpu 0000:01:00.0: fb0: amdgpudrmfb frame buffer device
[ 3.255927] [drm] Initialized amdgpu 3.27.0 20150101 for 0000:01:00.0 on minor 0
[ 3.393617] IPv6: ADDRCONF(NETDEV_UP): enp3s0: link is not ready
[ 3.393843] enp3s0: 0xffffb26a81a85000, 94
[ 3.465889] IPv6: ADDRCONF(NETDEV_UP): enp3s0: link is not ready
[ 5.499522] r8168: enp3s0: link up
[ 5.499548] IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
[ 7.597246] kauditd_printk_skb: 20 callbacks suppressed
[ 7.597250] audit: type=1131 audit(1561914009.502:31): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.012485] audit: type=1131 audit(1561914015.919:32): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 33.403076] audit: type=1131 audit(1561914036.483:33): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 128.684527] random: crng init done
[ 128.684532] random: 7 urandom warning(s) missed due to ratelimiting
[ 129.970979] audit: type=1006 audit(1561914133.054:34): pid=625 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
[ 129.986396] audit: type=1130 audit(1561914133.067:35): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 129.990999] audit: type=1006 audit(1561914133.074:36): pid=630 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ 130.053583] audit: type=1130 audit(1561914133.134:37): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 131.649087] audit: type=1130 audit(1561914134.731:38): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 131.690205] audit: type=1130 audit(1561914134.771:39): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 131.805165] audit: type=1130 audit(1561914134.887:40): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 132.292833] Bluetooth: RFCOMM TTY layer initialized
[ 132.292837] Bluetooth: RFCOMM socket layer initialized
[ 132.292842] Bluetooth: RFCOMM ver 1.11
[ 132.338821] fuse init (API version 7.27)
[ 132.768873] audit: type=1130 audit(1561914135.850:41): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-system comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 132.774249] audit: type=1131 audit(1561914135.857:42): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-system comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 133.248455] audit: type=1130 audit(1561914136.330:43): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=org.cups.cupsd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 203.922893] audit: type=1130 audit(1561914207.004:44): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 233.972649] audit: type=1131 audit(1561914237.054:45): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 907.661829] audit: type=1130 audit(1561914910.739:46): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 907.661831] audit: type=1131 audit(1561914910.739:47): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success
https://yadi.sk/i/K0XP4KcJN2uKjg
