LM 19.1 x64 (XFCE) Переключение между колонками и наушниками.
dmkthereal
16 июн 2019, 02:45
Доброго времени суток.
Нужна помощь по настройке аудио, быстрое переключение между колонками и наушниками и регулирование громкости с помощью клавиатуры.
  Host: HOPEUAREFINE Kernel: 4.15.0-51-generic x86_64 bits: 64 compiler: gcc
  v: 7.3.0 Desktop: Xfce 4.12.3 Distro: Linux Mint 19.1 Tessa
  base: Ubuntu 18.04 bionic
  Type: Desktop System: MSI product: MS-7817 v: 1.0 serial: <filter>
  Mobo: MSI model: H81M-E33 (MS-7817) v: 1.0 serial: <filter>
  BIOS: American Megatrends v: 6.7 date: 04/21/2015
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M315/235/317
  charge: 100% status: Discharging
  Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K270
  Topology: Dual Core model: Intel Pentium G3250 bits: 64 type: MCP
  arch: Haswell rev: 3 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 12799
  Speed: 1322 MHz min/max: 800/3200 MHz Core speeds (MHz): 1: 1017 2: 1009
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
  vendor: Micro-Star MSI driver: i915 v: kernel bus ID: 00:02.0
  Display: x11 server: X.Org 1.19.6 driver: modesetting unloaded: fbdev,vesa
  resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa DRI Intel Haswell Desktop v: 4.5 Mesa 18.2.8
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
  vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 00:03.0
  Device-2: Intel 8 Series/C220 Series High Definition Audio
  vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  Device-3: Logitech G430 Surround Sound Gaming Headset type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus ID: 3-10:6
  Sound Server: ALSA v: k4.15.0-51-generic
  vendor: Micro-Star MSI driver: r8169 v: 2.3LK-NAPI port: e000
  bus ID: 02:00.0
  IF-ID-1: wlxd46e0e09635b state: up mac: <filter>
  Local Storage: total: 465.76 GiB used: 179.14 GiB (38.5%)
  ID-1: /dev/sda vendor: Western Digital model: WD5000AAKX-001CA0
  ID-1: / size: 36.41 GiB used: 7.57 GiB (20.8%) fs: ext4 dev: /dev/sda6
  ID-2: /boot size: 453.0 MiB used: 219.9 MiB (48.5%) fs: ext4
  dev: /dev/sda5
  ID-3: /home size: 416.65 GiB used: 171.36 GiB (41.1%) fs: ext4
  dev: /dev/sda8
  ID-4: swap-1 size: 3.72 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda7
  System Temperatures: cpu: 29.8 C mobo: 27.8 C
  Processes: 190 Uptime: 1d 42m Memory: 7.67 GiB used: 4.21 GiB (54.8%)
  inxi: 3.0.27
При подключенных наушниках колонки вообще будь-то выключаются, то есть я не могу на них переключится. Нужно выключать наушники и только тогда начинают работать колонки.
Колонки подключены на передней панеле.
Наушники подключены через USB порт.
- Момент когда работают колонки.
- Момент когда работают наушники.
- Окно конфигурации.
Заранее благодарю.
dmkthereal
16 июн 2019, 23:43
И ещё один вопрос, можно ли сделать так, чтобы номер синка не менялся после его отключения/подключения?
C помощью pactl -- set-sink-volume 0 +3% получилось добиться изменения громкости, но при отключении номер меняется и уже не работает... Заранее огромное спасибо.
20 июн 2019, 13:21
Менять громкость несложно.
#!/bin/bash
#Уменьшение на 10%
amixer -q sset Master 10%-
#!/bin/bash
#Увеличиваем на 10%
amixer -q sset Master 10%+
Сохраняем, ставим исполняемость и биндим.
А вот с переключением посмотрите в эту сторону и вот
Вернуться в «Xfce»
