Игры в линукс.
Нативные и в Wine - настройка, обсуждение, решение проблем
Bums
Благодарил (а): 81 раз
Игры в линукс.
Сообщение Bums » 09 июн 2019, 13:16
Парни, если есть время может кто поможет запустить игру.
https://rutracker.org/forum/viewtopic.php?t=5216339
  Host: bums-Aspire-E1-571G Kernel: 4.15.0-50-generic x86_64 bits: 64
  compiler: gcc v: 7.3.0 Desktop: Cinnamon 4.0.10
  Type: Laptop System: Acer product: Aspire E1-571G v: V2.21
  serial: <filter>
  Mobo: Acer model: EA50_HC_HR v: Type2 - Board Version serial: <filter>
  UEFI: Insyde v: 2.21 date: 12/16/2013
  ID-1: BAT1 charge: 13.4 Wh condition: 13.4/47.5 Wh (28%)
  model: SANYO Li_Ion_4000mA status: Full
  Topology: Dual Core model: Intel Core i3-2348M bits: 64 type: MT MCP
  arch: Sandy Bridge rev: 7 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 18359
  Speed: 798 MHz min/max: 800/2300 MHz Core speeds (MHz): 1: 798 2: 798
  3: 798 4: 798
  Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT
  620M/625M/630M/720M]
  vendor: Acer Incorporated ALI driver: nvidia v: 340.107 bus ID: 01:00.0
  Display: x11 server: X.Org 1.19.6 driver: modesetting,nvidia
  unloaded: fbdev,nouveau,vesa resolution: 1366x768~60Hz
  OpenGL: renderer: GeForce 710M/PCIe/SSE2 v: 4.4.0 NVIDIA 340.107
  Device-1: Intel 7 Series/C216 Family High Definition Audio
  bus ID: 00:1b.0
  Sound Server: ALSA v: k4.15.0-50-generic
  Device-1: Broadcom and subsidiaries NetLink BCM57785 Gigabit Ethernet PCIe
  vendor: Acer Incorporated ALI driver: tg3 v: 3.137 port: 2000
  bus ID: 02:00.0
  IF: enp2s0f0 state: down mac: <filter>
  Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: Foxconn
  driver: ath9k v: kernel port: 2000 bus ID: 03:00.0
  Local Storage: total: 223.57 GiB used: 112.53 GiB (50.3%)
  ID-1: /dev/sda vendor: GOODRAM model: GOODRAM size: 223.57 GiB
  ID-1: / size: 17.89 GiB used: 8.84 GiB (49.4%) fs: ext4 dev: /dev/sda2
  ID-2: /home size: 200.70 GiB used: 103.69 GiB (51.7%) fs: ext4
  dev: /dev/sda4
  System Temperatures: cpu: 53.0 C mobo: N/A gpu: nvidia temp: 42 C
  Processes: 190 Uptime: 1h 55m Memory: 9.65 GiB used: 2.23 GiB (23.1%)
  inxi: 3.0.27
Запускаю в терминале и вот что получается.
TombRaider: crash reporter initialised with path "/home/bums/.local/share/feral-interactive/Tomb Raider/crashes"
[0609/161512:ERROR:browser_main_loop.cc(170)] Running without the SUID sandbox! See https://code.google.com/p/chromium/wiki ... evelopment for more information on developing with the sandbox on.
GLib-GIO-Message: 16:15:12.077: Using the 'memory' GSettings backend.  Your settings will not be saved or shared with other applications.
[0609/161512:ERROR:renderer_main.cc(212)] Running without renderer sandbox
[0609/161512:INFO:CONSOLE(0)] "The specified value '!' does not conform to the required format.  The format is '#rrggbb' where rr, gg, bb are two-digit hexadecimal numbers.", source: file://localhost/home/bums/GOGGames/TombRaider/share/FeralUI/PGOW/Core/feralUI.html (0)
[0609/161516:ERROR:gl_context_glx.cc(107)] Couldn't make context current with X drawable.
[0609/161516:ERROR:gles2_cmd_decoder.cc(3200)]   GLES2DecoderImpl: Context lost during MakeCurrent.
[0609/161516:ERROR:gl_bindings_autogen_gl.cc(6831)] Trying to call glGetGraphicsResetStatusARB() without current GL context
[0609/161516:WARNING:x11_util.cc(1490)] X error received: serial 869, error_code 172 (GLXBadDrawable), request_code 154, minor_code 26 (X_GLXMakeContextCurrent)
[0609/161516:WARNING:x11_util.cc(1490)] X error received: serial 902, error_code 8 (BadMatch (invalid parameter attributes)), request_code 154, minor_code 26 (X_GLXMakeContextCurrent)
[0609/161516:WARNING:x11_util.cc(1490)] X error received: serial 934, error_code 8 (BadMatch (invalid parameter attributes)), request_code 154, minor_code 26 (X_GLXMakeContextCurrent)
[0609/161516:WARNING:x11_util.cc(1490)] X error received: serial 966, error_code 8 (BadMatch (invalid parameter attributes)), request_code 154, minor_code 26 (X_GLXMakeContextCurrent)
[0609/161516:ERROR:gl_bindings_autogen_gl.cc(6522)] Trying to call glDeleteVertexArraysOES() without current GL context
[0609/161516:ERROR:gl_bindings_autogen_gl.cc(6512)] Trying to call glDeleteTextures() without current GL context
[0609/161516:WARNING:x11_util.cc(1490)] X error received: serial 997, error_code 3 (BadWindow (invalid Window parameter)), request_code 4, minor_code 0 (X_DestroyWindow)
TombRaider: dumped to "/home/bums/.local/share/feral-interactive/Tomb Raider/crashes/0c545bd7-f4a7-6c48-78585f91-6e487ea0.dmp"
TombRaider: crash reporter "/home/bums/GOGGames/TombRaider/bin/feral_linux_crash_reporter" launching
Game crashed, if possible email [support@feralinteractive.com] with the crash file [/home/bums/.local/share/feral-interactive/Tomb Raider/crashes/0c545bd7-f4a7-6c48-78585f91-6e487ea0.dmp] and details
Что она хочет?
Благодарил (а): 803 раза
Игры в линукс.
Сообщение rogoznik » 09 июн 2019, 13:39
Bums писал(а):
09 июн 2019, 13:16
Судя по тому что удалось нагуглить это нормально. Это steam так использует движок chromium.
Остальные ошибки связаны с библиотеками.
Попробуй установить
sudo apt install libfontconfig1:i386 libuuid1:i386 libfontconfig1:i386 libpangocairo-1.0-0:i386 libcairo2:i386 libpango-1.0-0:i386 libnss3:i386 libnspr4:i386 libxcomposite1:i386 libxtst6:i386 libcups2:i386 libcap2:i386 libsdl2-2.0-0:i386
Bums
Игры в линукс.
Сообщение Bums » 09 июн 2019, 13:45
darkfenix, спасибо, библиотеки эти есть, может он в 64 битной системе не может их запустить, или найти?
Игры в линукс.
Сообщение rogoznik » 09 июн 2019, 13:49
Bums, давай еще проясним как запускаешь
Bums
Игры в линукс.
Сообщение Bums » 09 июн 2019, 13:51
darkfenix, открываю start.sh в терминале, может как по другому нужно.
Игры в линукс.
Сообщение rogoznik » 09 июн 2019, 13:53
Bums писал(а):
09 июн 2019, 13:51
Возможно. Это цитата из темы что ты в шапке указал
See this line in start.sh file:
LD_PRELOAD="/usr/lib/x86_64-linux-gnu/libasound.so.2:${LD_PRELOAD}"
It redirect you to use 64bit libasound.
Just start game from:
cd TombRaider/bin/
./TombRaider
Bums
Игры в линукс.
Сообщение Bums » 09 июн 2019, 13:58
darkfenix, прости меня, честно, я просто шахтёр который хочет поиграть и не знает англ, и что с этими командами делать.
Игры в линукс.
Сообщение rogoznik » 09 июн 2019, 14:00
Bums, зайди в католог с игрой, найди там каталог bin, зайди в него, открой в терминале и выполни
./TombRaider
Bums
Игры в линукс.
Сообщение Bums » 09 июн 2019, 14:04
Вот что получилось
bums@bums-Aspire-E1-571G:~$ '/home/bums/GOGGames/TombRaider/bin/TombRaider'
Warning: Missing charsets in String to FontSet conversion
Ini file not found at /home/bums/activated.inibums@bums-Aspire-E1-571G:~$
И почему activated.ini должен быть там.
AlexGer
Игры в линукс.
Сообщение AlexGer » 09 июн 2019, 14:17
А почему не взять игру в Steam, на нее кстати часто акция бывает всего за 59 деревянных? Или используй Windows версию, она с Wine очень даже отлично дружит.
MrTowelie
Решено: 8
Благодарил (а): 18 раз
Игры в линукс.
Сообщение MrTowelie » 09 июн 2019, 18:37
Я, конечно, не эксперт, особенно в пиратстве игр. (слишком уж удобно в линьке юзать лицензии, да и steam скидками заваливает)
Но, в требованиях игры стоит драйвер более поздней ветки "Driver version 364.12 tested" (у вас 340-ая ветка). Может быть вам стоит попробовать установить драйвер более современной ветки, разумеется, если это не навредит системе? И уже с драйверов ветки старше 364-ой попробовать запустить игру?
KOT040188
Благодарил (а): 13 раз
Игры в линукс.
Сообщение KOT040188 » 10 июн 2019, 04:25
Когда я просил помочь с игрой, тему сразу закрыли, типа иди покупай в Стиме…
Хто ты гэткі?
Благодарил (а): 212 раз
Игры в линукс.
Сообщение AlexZ » 18 июн 2019, 05:16
Bums писал(а):
09 июн 2019, 13:16
Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M] vendor: Acer Incorporated ALI driver: nvidia v: 340.107
Обнови прежде версию видеодрайвера до 390.
Если у тебя GeForce GT 720M, GeForce 710M можешь обновлять вплоть до 418 (это на будущее)
https://www.nvidia.ru/Download/driverRe ... /146955/ru
Вернуться в «Игры»
