Не рабоает wifi модуль realtek rtl8111
Ruslan
30 май 2019, 16:40
System
Host: HP Kernel: 4.15.0-50-generic x86_64 bits: 64 compiler: gcc v: 7.3.0
Desktop: Cinnamon 4.0.10 Distro: Linux Mint 19.1 Tessa
base: Ubuntu 18.04 bionic
Type: Laptop System: HP product: HP Pavilion Laptop 15-ck0xx
v: Type1ProductConfigId serial: <filter>
Mobo: HP model: 841C v: 64.14 serial: <filter> UEFI: Insyde v: F.10
date: 11/09/2018
ID-1: BAT0 charge: 15.6 Wh condition: 40.1/40.1 Wh (100%)
model: HP Primary status: Discharging
Topology: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake rev: A L2 cache: 6144 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28800
Speed: 800 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0
Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Hewlett-Packard
driver: nouveau v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.19.6 driver: modesetting,nouveau
unloaded: fbdev,vesa resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel UHD Graphics 620 (Kabylake GT2)
v: 4.5 Mesa 18.2.8 direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
Sound Server: ALSA v: k4.15.0-50-generic
Device-1: Realtek vendor: Hewlett-Packard driver: N/A port: 4000
bus ID: 02:00.0
vendor: Hewlett-Packard driver: r8168 v: 8.045.08-NAPI port: 3000
bus ID: 03:00.0
Local Storage: total: 931.51 GiB used: 9.19 GiB (1.0%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
ID-1: / size: 915.40 GiB used: 9.18 GiB (1.0%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 43.0 C mobo: N/A
Processes: 226 Uptime: 10m Memory: 7.68 GiB used: 1.61 GiB (21.0%)
inxi: 3.0.27
уже что только не делал,все равно ничего не работает
Решение vir0id » 30 май 2019, 18:08
Ruslan,
Походу дело драйвер RTL8723de
git clone -b extended --single-branch https://github.com/lwfinger/rtlwifi_new.git
cd rtlwifi_new
sudo make install
Griga211
Благодарил (а): 9 раз
30 май 2019, 16:49
Может включить забыл? :sad:
sudo apt install rfkill
sudo rfkill list
Ruslan
30 май 2019, 16:52
Griga211 писал(а):
30 май 2019, 16:49
sudo rfkill list
0: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
Griga211
30 май 2019, 16:59
Ruslan писал(а):
30 май 2019, 16:52
0: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
У тебя драйвера похоже нету, потому что показывает только блютуз, и тот выключен.
sudo apt install linux-firmware
Ruslan
30 май 2019, 17:06
Griga211 писал(а):
30 май 2019, 16:59
Ruslan писал(а):
30 май 2019, 16:52
0: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
Уже установлен пакет linux-firmware самой новой версии (1.173.6).
Обновлено 0 пакетов, установлено 0 новых пакетов, для удаления отмечено 0 пакетов, и 1 пакетов не обновлено.
30 май 2019, 17:17
Ruslan писал(а):
30 май 2019, 16:40
Он то у тебя как раз работает, только это проводная сетевушка под eno1.
покажи вывод sudo lshw -C network
Ruslan
30 май 2019, 17:33
30 май 2019, 17:17
Ruslan писал(а):
30 май 2019, 16:40
*-network UNCLAIMED
       описание: Network controller
       продукт: Realtek Semiconductor Co., Ltd.
       производитель: Realtek Semiconductor Co., Ltd.
       физический ID: 0
       сведения о шине: pci@0000:02:00.0
       версия: 00
       разрядность: 64 bits
       частота: 33MHz
       возможности: pm msi pciexpress cap_list
       конфигурация: latency=0
       ресурсы: ioport:4000(размер=256) память:b4100000-b410ffff
  *-network
       описание: Ethernet interface
       продукт: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
       физический ID: 0
       сведения о шине: pci@0000:03:00.0
       логическое имя: eno1
       версия: 15
       серийный №: ac:e2:d3:64:55:9e
       capacity: 1Gbit/s
       частота: 33MHz
       возможности: pm msi pciexpress msix bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       конфигурация: autonegotiation=on broadcast=yes driver=r8168 driverversion=8.045.08-NAPI duplex=full ip=192.168.0.105 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
       ресурсы: IRQ:127 ioport:3000(размер=256) память:b4004000-b4004fff память:b4000000-b4003fff
Griga211
30 май 2019, 17:37
Ruslan писал(а):
30 май 2019, 17:33
*-network UNCLAIMED
А в спецификации с этим процем указан Intel.
30 май 2019, 17:54
Ruslan,
Давай еще
lspci -v -s 02:00.0
Больше инфы о шине, карте... Всё в студию. Быстрее поймём что за карта и какой нужен драйвер
Ruslan
30 май 2019, 18:02
vir0id писал(а):
30 май 2019, 17:54
Ruslan,
Давай еще
lspci -v -s 02:00.0
02:00.0 Network controller: Realtek Semiconductor Co., Ltd. Device d723
	Subsystem: Hewlett-Packard Company Device 8319
	Flags: fast devsel, IRQ 255
	I/O ports at 4000 (размер = 256)
	Memory at b4100000 (64-bit, non-prefetchable)(размер = 6К)
	Capabilities: <access denied>
30 май 2019, 18:08
Ruslan,
cd rtlwifi_new
sudo make install
Ruslan
30 май 2019, 18:18
vir0id писал(а):
30 май 2019, 18:08
Ruslan,
cd rtlwifi_new
sudo make install
Спасибо большое :hshake: :bravo: :yahoo: :yahoo: :thumbs: :thumbs: :thumbs: :thumbs: :thumbs: :thumbs: :thumbs: :thumbs: :thumbs: :thumbs:
30 май 2019, 18:25
Ruslan писал(а):
30 май 2019, 18:18
Спасибо большое
:thumbs:
