Проблема с режимом сна
Eonwe
27 май 2019, 15:06
После выхода из режима сна ноутбук просто перезагружается, слетают обои раб. стола, т.е. сном пользоваться невозможно.
Вывод inxi -Fxz
 Host: VAIO Kernel: 5.0.0-15-generic x86_64 bits: 64 compiler: gcc v: 7.3.0
  Desktop: Cinnamon 4.0.10 Distro: Linux Mint 19.1 Tessa
  base: Ubuntu 18.04 bionic
  Type: Laptop System: Sony product: VPCEB1E1R v: C603S026 serial: <filter>
  Mobo: Sony model: VAIO serial: <filter> BIOS: American Megatrends
  v: R0220Y8 date: 01/12/2010
  Topology: Dual Core model: Intel Core i3 M 330 bits: 64 type: MT MCP
  arch: Nehalem rev: 2 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 17025
  Speed: 1058 MHz min/max: 933/2133 MHz Core speeds (MHz): 1: 1129 2: 1167
  3: 1182 4: 1146
  Device-1: AMD Park [Mobility Radeon HD 5430/5450/5470] vendor: Sony
  driver: radeon v: kernel bus ID: 01:00.0
  Display: x11 server: X.Org 1.19.6 driver: ati,radeon
  unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
  OpenGL: renderer: AMD CEDAR (DRM 2.50.0 / 5.0.0-15-generic LLVM 7.0.0)
  v: 3.3 Mesa 18.2.8 direct render: Yes
  Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Sony
  Device-2: AMD Cedar HDMI Audio [Radeon HD 5400/6300/7300 Series]
  vendor: Sony driver: snd_hda_intel v: kernel bus ID: 01:00.1
  Device-3: JMTek LLC. type: USB driver: hid-generic,snd-usb-audio,usbhid
  bus ID: 2-1.6:4
  Sound Server: ALSA v: k5.0.0-15-generic
  Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter
  vendor: Foxconn T77H126.00 802.11bgn driver: ath9k v: kernel port: d000
  bus ID: 02:00.0
  IF: wlp2s0 state: down mac: <filter>
  Device-2: Marvell Yukon Optima 88E8059 [PCIe Gigabit Ethernet with AVB]
  vendor: Sony driver: sky2 v: 1.30 port: a000 bus ID: 04:00.0
  Local Storage: total: 298.09 GiB used: 11.22 GiB (3.8%)
  ID-1: /dev/sda vendor: Toshiba model: MK3265GSX size: 298.09 GiB
  ID-1: / size: 29.76 GiB used: 10.71 GiB (36.0%) fs: ext4 dev: /dev/sda6
  ID-2: swap-1 size: 3.81 GiB used: 523.0 MiB (13.4%) fs: swap
  dev: /dev/sda5
  System Temperatures: cpu: 48.0 C mobo: N/A gpu: radeon temp: 51 C
  Processes: 211 Uptime: 3h 35m Memory: 3.71 GiB used: 2.37 GiB (64.0%)
  inxi: 3.0.27
Благодарил (а): 212 раз
27 май 2019, 21:59
Eonwe писал(а):
27 май 2019, 15:06
А он вообще работает полноценно у кого-нить на Linux Mint 19.1 Cinnamon?
Я понимаю, что в данном случае не мудрено на таком железе..
Eonwe писал(а):
27 май 2019, 15:06
Mobo: Sony model: VAIO date: 01/12/2010
Device-1: AMD Park [Mobility Radeon HD 5430/5450/5470] driver: ati,radeon
..но хотелось бы знать, как обстоят дела на более современном. А то пока только отписки типа он никому нах не нужен..
Ара Магеддон
Решено: 18
Благодарил (а): 37 раз
28 май 2019, 01:02
А на дефолтном ядре (4.15) как работает? И я бы memtest прогнал для начала.
AlexZ писал(а):
27 май 2019, 21:59
На десктопе полноценно работает. Но года 4 назад приходилось колхозить: ставить xfce4-power-manager.
28 май 2019, 06:28
AlexZ писал(а):
27 май 2019, 21:59
У меня работал, когда стоял.
Whowka
Благодарил (а): 777 раз
28 май 2019, 09:59
AlexZ писал(а):
27 май 2019, 21:59
Судя по фразе из : https://losst.ru/spyashhij-rezhim-v-ubuntu проблемы остаются :smile:
Если после отключения питания компьютера и последующего нажатия кнопки включения вам удастся продолжить работу с ранее запущенными приложениями, то спящий режим работает корректно. Если же после некоторого ожидания вы видите лишь чёрный экран или элементы графического интерфейса системы оказываются неработоспособными, лучше отключить спящий режим
28 май 2019, 10:21
Whowka писал(а):
28 май 2019, 09:59
Вобщем я у себя сделал свап-файл больше ОЗУ, запустил браузер с несколькими вкладками и отправил в сон (т.к. кнопки нет, командой systemctl hibernate) - система как-будто выключилась, индикатор не мигал, на клавиши и мышь не реагировала. С кнопки включения стандартно загрузил систему и запустился браузер с вкладками. Это что за спящий такой? :hoho:
П.С. Ждущий работает без проблем, и спящий на многих других осях.
28 май 2019, 10:44
AlexZ писал(а):
28 май 2019, 10:21
А что тебя не устроило? Вернулся же к тому состоянию из которого ушел спать. А кнопку легко сделать.
Whowka
28 май 2019, 21:11
AlexZ писал(а):
28 май 2019, 10:21
Сам в шоке! :blink2:
30 май 2019, 08:15
28 май 2019, 10:44
Да, но как-то коряво это работает, тебе не кажется?
По идее, после загрузки должен показаться рабочий стол с браузером и открытыми вкладками. А тут чистый раб. стол и вернее браузер даже не запускается (подождал пару минут), я зам его запускаю и вот тогда он мне покажет все открытые вкладки до ухода в спящий.
Вобщем я спящим не пользуюсь, уменьшил своп-файл обратно до 1,5 Гб. Так, проверил ради спорт. интереса (может у кого также будет, чтобы не удивлялись). Ковыряться с этим нет ни времени, ни желания
30 май 2019, 08:28
AlexZ, суспенд в файл немного отдельная тема и у нас ее рассматривали Cпящий режим (Suspend-To-Disk) в файл подкачи
31 май 2019, 21:50
30 май 2019, 08:28
Вона чё, теперь понятно. Но уже неактуально :smile:
